Exclude the Roman Numerals Number Page Section
Engaged ,
Jun 04, 2018 Jun 04, 2018
Hello!
In my Indesign document, normally my first pages are in Roman Numerals like you can see:
After I use the normal numbers like you can see:
Is there a script to know which number page start my normal number 1?
For example, if my document has the next pages:
I, II, III, IV, V, VI, VII, 1, 2, 3, 4, ...
this means my page 1 is in the number 8.
Here is the code but didn't works, because they find nothing in the number pages:
var doc = app.activeDocument;
// clear find change text preferences before search
app.findTextPreferences = app.changeTextPreferences = NothingEnum.NOTHING;
// this is scripting equivalent of the 'Find What:' edit text field
app.findTextPreferences.findWhat = "1";
// search it in the active document
// you can also search it in almost everywhere: story, text frame, paragraph, line, word, etc
var finds = doc.findText();
if (finds.length > 0) { // something has been found
// for the 1st found item display the name of the page where the 1st text frame (there can be several threaded frames) containing it is located
alert("Found " + finds.length + " items, the first of them is on page " + finds[0].parentTextFrames[0].parentPage.name);
else { // found nothing
alert("Nothing has been found");
// clear find change text preferences after search
Maybe is helpful to know my number pages always have the style called Book Page Number  and is inside of my folder VARIOUS
I try also do this, but the script didn't find the number 1:
var myDoc = app.activeDocument,
arrayRomanNumerals = ["1"],
I = arrayRomanNumerals.length,  i;
app.findTextPreferences = null;
for ( i = 0; i < I; i++) {
    app.findTextPreferences.findWhat = arrayRomanNumerals;
    myFound = myDoc.findText();
    var J = myFound.length,  j;
    var styleBookPageNumber = myDoc.paragraphStyleGroups.itemByName("VARIOUS").paragraphStyles.itemByName("Book Page Number");
    for ( j = 0; j < J; j++) {
        myFound.appliedCharacterStyle = myDoc.characterStyles[0];
        if (myFound.appliedParagraphStyle == styleBookPageNumber) {
            alert("Found!"); }
        else{break;}}}
Thanks so much.
Scripting
737
Community Expert , Jun 05, 2018 Jun 05, 2018
Hi Manuel,
a document can be parted in sections.
So I think, you are interested in object Section and several of its properties.
var sections = app.documents[0].sections.everyItem().getElements();
for( var n=0;n<sections.length;n++ )
var firstPageInSection = sections.pageStart;
var firstPageName = firstPageInSection.name;
var firstPageOfSectionPositionInDocument = firstPageInSection.documentOffset;
var pageNumberStyle = sections.pageNumberStyle;
$.writeln( n +"\t"+firstPageName );
People's Champ ,
A page object has a name property and a documentOffset property. myPage.documentOffset will always give you the number of the page in the document. Does that help?
Ariel
Engaged ,
Hi Ariel!
sorry I am beginner, I added this line but didn't work.:
            var RealNumberPage = myDoc.pages.item(styleBookPageNumber).documentOffset
            alert("The real first page, excluding the Roman Numerals is: " + RealNumberPage);
My full script:
        else{}}}
Guru ,
Replace
with
parentPage = myFound.parentPage;
RealNumberPage = parentPage && parentPage.documentOffset
The parentPage could be null if the textFrame is of the page so we need to check there's a parent page and if so then we can get it's offset
Engaged ,
Hi Trevor,
I replace the line but still not working:
Please, here is my indesign file if you can check:
Download
Script:
            RealNumberPage = parentPage && parentPage.documentOffset;
        else{}}}
Thanks so much!
Hi Manuel,
$.writeln( n +"\t"+firstPageOfSectionPositionInDocument );
$.writeln( n +"\t"+pageNumberStyle.toString() );
See into documentation e.g.:
Adobe InDesign CS6 (8.0) Object Model JS: Section
Adobe InDesign CS6 (8.0) Object Model JS: PageNumberStyle
Uwe
Engaged ,
Hi Laubender!
amazing you help a lot!
//var firstPageName = firstPageInSection.name;
//var pageNumberStyle = sections.pageNumberStyle;
//$.writeln( n +"\t"+firstPageName );
//$.writeln( n +"\t"+pageNumberStyle.toString() );
if (firstPageOfSectionPositionInDocument != 0){
    alert (firstPageOfSectionPositionInDocument);
} else{};
Download the files
