6 Replies Latest reply on Jun 5, 2018 11:20 AM by manuelb27477138
    Exclude the Roman Numerals Number Page Section
    manuelb27477138 Level 1
      Hello!
      In my Indesign document, normally my first pages are in Roman Numerals like you can see:
      After I use the normal numbers like you can see:
      Is there a script to know which number page start my normal number 1?
      For example, if my document has the next pages:
      I, II, III, IV, V, VI, VII, 1, 2, 3, 4, ...
      this means my page 1 is in the number 8.
      Here is the code but didn't works, because they find nothing in the number pages:
      var doc = app.activeDocument;
      // clear find change text preferences before search
      app.findTextPreferences = app.changeTextPreferences = NothingEnum.NOTHING;
      // this is scripting equivalent of the 'Find What:' edit text field
      app.findTextPreferences.findWhat = "1";
      // search it in the active document
      // you can also search it in almost everywhere: story, text frame, paragraph, line, word, etc
      var finds = doc.findText();
      if (finds.length > 0) { // something has been found
      // for the 1st found item display the name of the page where the 1st text frame (there can be several threaded frames) containing it is located
      alert("Found " + finds.length + " items, the first of them is on page " + finds[0].parentTextFrames[0].parentPage.name);
      else { // found nothing
      alert("Nothing has been found");
      // clear find change text preferences after search
      Maybe is helpful to know my number pages always have the style called Book Page Number  and is inside of my folder VARIOUS
      I try also do this, but the script didn't find the number 1:
      var myDoc = app.activeDocument,
      arrayRomanNumerals = ["1"],
      I = arrayRomanNumerals.length,  i;
      app.findTextPreferences = null;
      for ( i = 0; i < I; i++) {
          app.findTextPreferences.findWhat = arrayRomanNumerals[i];
          myFound = myDoc.findText();
          var J = myFound.length,  j;
          var styleBookPageNumber = myDoc.paragraphStyleGroups.itemByName("VARIOUS").paragraphStyles.itemByName("Book Page Number");
          for ( j = 0; j < J; j++) {
              myFound[j].appliedCharacterStyle = myDoc.characterStyles[0];
              if (myFound[j].appliedParagraphStyle == styleBookPageNumber) {
                  alert("Found!"); }
              else{break;}}}
      Thanks so much.
        • 1. Re: Exclude the Roman Numerals Number Page Section
          TᴀW Adobe Community Professional & MVP
          A page object has a name property and a documentOffset property. myPage.documentOffset will always give you the number of the page in the document. Does that help?
          Ariel
          • 2. Re: Exclude the Roman Numerals Number Page Section
            Hi Ariel!
            sorry I am beginner, I added this line but didn't work.:
                        var RealNumberPage = myDoc.pages.item(styleBookPageNumber).documentOffset
                        alert("The real first page, excluding the Roman Numerals is: " + RealNumberPage);
            My full script:
                    else{}}}
            • 3. Re: Exclude the Roman Numerals Number Page Section
              Trevorׅ Adobe Community Professional
              Replace
              with
              parentPage = myFound[j].parentPage;
              RealNumberPage = parentPage && parentPage.documentOffset
              The parentPage could be null if the textFrame is of the page so we need to check there's a parent page and if so then we can get it's offset
              • 4. Re: Exclude the Roman Numerals Number Page Section
                Hi Trevor,
                I replace the line but still not working:
                Please, here is my indesign file if you can check:
                Download
                Script:
                            RealNumberPage = parentPage && parentPage.documentOffset;
                        else{}}}
                Thanks so much!
                • 5. Re: Exclude the Roman Numerals Number Page Section
                  Laubender Adobe Community Professional & MVP
                  Hi Manuel,
                  a document can be parted in sections.
                  So I think, you are interested in object Section and several of its properties.
                  var sections = app.documents[0].sections.everyItem().getElements();
                  for( var n=0;n<sections.length;n++ )
                  var firstPageInSection = sections[n].pageStart;
                  var firstPageName = firstPageInSection.name;
                  var firstPageOfSectionPositionInDocument = firstPageInSection.documentOffset;
                  var pageNumberStyle = sections[n].pageNumberStyle;
                  $.writeln( n +"\t"+firstPageName );
                  $.writeln( n +"\t"+firstPageOfSectionPositionInDocument );
                  $.writeln( n +"\t"+pageNumberStyle.toString() );
                  See into documentation e.g.:
                  Adobe InDesign CS6 (8.0) Object Model JS: Section
                  Adobe InDesign CS6 (8.0) Object Model JS: PageNumberStyle
                  Uwe
                  • 6. Re: Exclude the Roman Numerals Number Page Section
                    Hi Laubender!
                    amazing you help a lot!
                    //var firstPageName = firstPageInSection.name;
                    //var pageNumberStyle = sections[n].pageNumberStyle;
                    //$.writeln( n +"\t"+firstPageName );
                    //$.writeln( n +"\t"+pageNumberStyle.toString() );
                    if (firstPageOfSectionPositionInDocument != 0){
                        alert (firstPageOfSectionPositionInDocument);
                    } else{};
                    Download the files
