SOLVED
Building library during development
Avatar
Level 9
The tutorial videos cover some basic principles of the publish workflow, but now that I work with it I have a question. Do I have to create a revision for a Rule, Data Element or Extension when I have a small change in it? Even though the library never got to the approval stage yet?
I just rebuild it for development and I was hoping it can be configured to just always take the latest version of all the added pieces each time I rebuild it. But as of now I had to create a few revisions of some Rules for each little change. Is this how this is supposed to work or am I missing something?
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
Once you publish to an environment, it creates a revision. You can modify and change things around as often as you'd like, which will be included in the same revision once published to an environment.
Avatar
Correct answer by
Employee Advisor
Avatar
Level 9
Hm, every time I build a library then make a change to a rule, I have to create a new revision of this rule. Or am I doing somehting wrong.
