Laggy playback and handling of AVC video
Guest
Jun 04, 2018 Jun 04, 2018
Got a video file recorded using OBS and Blackmagic Decklink 4K card. It was encoded using GPU and ended up in format like this:
Video
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : Main@L4.2
Format settings             : CABAC / 2 Ref Frames
Format settings, CABAC      : Yes
Format settings, ReFrames   : 2 frames
Codec ID                    : avc1
Codec ID/Info               : Advanced Video Coding
Duration                    : 46 min 50 s
Bit rate mode               : Constant
Bit rate                    : 35.0 Mb/s
Width                       : 1 920 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 60.000 FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.281
Stream size                 : 11.2 GiB (100%)
Color range                 : Limited
Matrix coefficients         : BT.470 System B/G
I have an 8 core xeon and 1080ti gpu, but program lagged hardly when I tried to edit something. Playback lagged too, cpu load was near 80%. What's wrong? Should I update some codecs or settings? CUDA rendering works fine, I checked.
944
Deleted User
It transcodes everyting ok, but with high cpu usage.
Adobe Employee ,
Hi AnnaV,
What happens if you transcode or create proxies for the footage?
Kevin
Guest
Jun 05, 2018 Jun 05, 2018
It may be more convenient, but...if it's not working...
Adobe Employee ,
Jun 18, 2018 Jun 18, 2018
Higher CPU usage for higher bandwidth clips is normal. Continue to transcode then.
Kevin
If you have a DeckLink, why would you choose OBS instead?
Guest
I stream, it's more convenient for me to record video in OBS.
