How to make selection auto
Participant ,
May 29, 2018 May 29, 2018
Hello all,
I have a image bellow, I want make selection window auto. I tried in many ways but not effective.8a.jpg
Please help me!
Thank in advance!
Actions and scripting
914
Advocate , Jun 06, 2018 Jun 06, 2018
I'm sorry but what you're looking for is not possible.
Adobe
Participant ,
May 30, 2018 May 30, 2018
It seems nobody helped my problem ~~
I think the only auto selection function Photoshop has that I know of is select subject and that feature is not perfect and would not select your window. None of Photoshop selection tools would auto select windows in an image.  I think you have seen this for none of the things you tried came close.
JJMack
Participant ,
i know there is no exact script, but I hope there is a way to do most of the work. About 70~80%. How to remove the black part around window?
Indeed how would you autoselect the black around the window and not select the black between and in the windows? Ask Watson its AI may be better than my intelligence.  AI the way to go.
JJMack
Advocate ,
May 31, 2018 May 31, 2018
You could use color range
try this and see if it's OK for your case
// Input 0
cTID = function(c) {
  return app.charIDToTypeID(c);
sTID = function(c) {
  return app.stringIDToTypeID(c);
function zm10() {
  (function(c, d) {
    if (void 0 == c || c) {
      var e = d ? DialogModes.ALL : DialogModes.NO, b = new ActionDescriptor, a = new ActionReference;
      a.putClass(PSClass.AdjustmentLayer);
      b.putReference(PSString.Null, a);
      a = new ActionDescriptor;
      var f = new ActionDescriptor;
      f.putEnumerated(PSString.presetKind, PSString.presetKindType, PSString.presetKindDefault);
      f.putInteger(PSKey.Red, 40);
      f.putInteger(PSEnum.Yellow, 60);
      f.putInteger(PSKey.Green, 40);
      f.putInteger(PSKey.Cyan, 60);
      f.putInteger(PSKey.Blue, 20);
      f.putInteger(PSKey.Magenta, 80);
      f.putBoolean(PSString.useTint, !1);
      var h = new ActionDescriptor;
      h.putDouble(PSKey.Red, 225.000457763672);
      h.putDouble(PSKey.Green, 211.000671386719);
      h.putDouble(PSKey.Blue, 179.001159667969);
      f.putObject(PSString.tintColor, PSClass.RGBColor, h);
      a.putObject(PSKey.Type, PSEnum.BlackAndWhite, f);
      b.putObject(PSKey.Using, PSClass.AdjustmentLayer, a);
      executeAction(sTID("make"), b, e);
  (function(c, d) {
      a.putObject(PSKey.Type, PSClass.Curves, f);
  (function(c, d) {
      a.putEnumerated(PSClass.Layer, PSType.Ordinal, PSEnum.Target);
      a.putString(PSKey.Name, "TMP");
      b.putObject(PSKey.To, PSClass.Layer, a);
      executeAction(sTID("set"), b, e);
  (function(c, d) {
      a.putEnumerated(PSClass.AdjustmentLayer, PSType.Ordinal, PSEnum.Target);
      a.putEnumerated(PSString.presetKind, PSString.presetKindType, PSString.presetKindCustom);
      var f = new ActionList, h = new ActionDescriptor, k = new ActionReference;
      k.putEnumerated(PSClass.Channel, PSClass.Channel, PSEnum.Composite);
      h.putReference(PSClass.Channel, k);
      k = new ActionList;
      var g = new ActionDescriptor;
      g.putDouble(PSKey.Horizontal, 200);
      g.putDouble(PSKey.Vertical, 0);
      k.putObject(PSClass.Point, g);
      g.putDouble(PSKey.Horizontal, 250);
      g.putDouble(PSKey.Vertical, 255);
      g.putDouble(PSKey.Horizontal, 255);
      g.putDouble(PSKey.Vertical, 251);
      h.putList(PSKey.Curve, k);
      f.putObject(PSClass.CurvesAdjustment, h);
      a.putList(PSKey.Adjustment, f);
      b.putObject(PSKey.To, PSClass.Curves, a);
  (function(c, d) {
      a.putProperty(PSClass.Channel, PSString.selection);
      a.putEnumerated(PSClass.Channel, PSClass.Channel, PSEnum.RGB);
      b.putReference(PSKey.To, a);
  (function(c, d) {
  (function(c, d) {
      b.putBoolean(PSKey.MakeVisible, !1);
      executeAction(sTID("select"), b, e);
  (function(c, d) {
      a.putString(PSKey.Name, "Zone 10");
  (function(c, d) {
      a.putEnumerated(PSClass.Layer, PSType.Ordinal, PSEnum.Backward);
      a = new ActionList;
      a.putInteger(246);
      b.putList(PSKey.LayerID, a);
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
      a = new ActionList;
      a.putInteger(246);
      executeAction(sTID("delete"), b, e);
  (function(c, d) {
      a = new ActionList;
      a.putInteger(245);
  (function(c, d) {
      a.putName(PSClass.Layer, "Zone 10");
zm10.loadSymbols = function() {
  var c = $.level;
  $.level = 0;
  try {
    PSConstants;
    return;
  } catch (e) {
  } finally {
    $.level = c;
  var d = !0;
  $.level = 0;
  try {
    PSClass, d = !1;
  } catch (e) {
  } finally {
    $.level = c;
  d && (PSClass = function() {
  }, PSEnum = function() {
  }, PSEvent = function() {
  }, PSForm = function() {
  }, PSKey = function() {
  }, PSType = function() {
  }, PSUnit = function() {
  }, PSString = function() {
  PSClass.AdjustmentLayer = cTID("AdjL");
  PSClass.Channel = cTID("Chnl");
  PSClass.Curves = cTID("Crvs");
  PSClass.CurvesAdjustment = cTID("CrvA");
  PSClass.Layer = cTID("Lyr ");
  PSClass.Point = cTID("Pnt ");
  PSClass.RGBColor = cTID("RGBC");
  PSEnum.Backward = cTID("Bckw");
  PSEnum.BlackAndWhite = cTID("BanW");
  PSEnum.Composite = cTID("Cmps");
  PSEnum.RGB = cTID("RGB ");
  PSEnum.Target = cTID("Trgt");
  PSEnum.Yellow = cTID("Yllw");
  PSKey.Adjustment = cTID("Adjs");
  PSKey.Blue = cTID("Bl  ");
  PSKey.Curve = cTID("Crv ");
  PSKey.Cyan = cTID("Cyn ");
  PSKey.Green = cTID("Grn ");
  PSKey.Horizontal = cTID("Hrzn");
  PSKey.LayerID = cTID("LyrI");
  PSKey.Magenta = cTID("Mgnt");
  PSKey.MakeVisible = cTID("MkVs");
  PSKey.Name = cTID("Nm  ");
  PSKey.Red = cTID("Rd  ");
  PSKey.To = cTID("T   ");
  PSKey.Type = cTID("Type");
  PSKey.Using = cTID("Usng");
  PSKey.Vertical = cTID("Vrtc");
  PSString.Null = sTID("null");
  PSString.presetKind = sTID("presetKind");
  PSString.presetKindCustom = sTID("presetKindCustom");
  PSString.presetKindDefault = sTID("presetKindDefault");
  PSString.presetKindType = sTID("presetKindType");
  PSString.selection = sTID("selection");
  PSString.tintColor = sTID("tintColor");
  PSString.useTint = sTID("useTint");
  PSType.Ordinal = cTID("Ordn");
zm10.loadSymbols();
zm10.main = function() {
  zm10();
zm10.main();
var idmove = charIDToTypeID("move"), desc208 = new ActionDescriptor, idnull = charIDToTypeID("null"),
ref198 = new ActionReference, idLyr = charIDToTypeID("Lyr "),
idOrdn = charIDToTypeID("Ordn"), idTrgt = charIDToTypeID("Trgt");
ref198.putEnumerated(idLyr, idOrdn, idTrgt);
desc208.putReference(idnull, ref198);
var idT = charIDToTypeID("T   "), ref199 = new ActionReference;
idLyr = charIDToTypeID("Lyr ");
idOrdn = charIDToTypeID("Ordn");
var idFrnt = charIDToTypeID("Frnt");
ref199.putEnumerated(idLyr, idOrdn, idFrnt);
desc208.putReference(idT, ref199);
executeAction(idmove, desc208, DialogModes.NO);
Participant ,
Thank you!,
I tried it but it was not as expected.
Advocate ,
Jun 01, 2018 Jun 01, 2018
in what sense do you create a window mask?
Participant ,
Jun 04, 2018 Jun 04, 2018
i want auto make selection area window.
Advocate ,
Jun 05, 2018 Jun 05, 2018
this is
// Input 0
function zm10() {
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
      k = new ActionList;
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
      a = new ActionList;
      a.putInteger(246);
  (function(c, d) {
  (function(c, d) {
  (function(c, d) {
      a = new ActionList;
      a.putInteger(246);
  (function(c, d) {
      a = new ActionList;
      a.putInteger(245);
  (function(c, d) {
  var c = $.level;
  $.level = 0;
  try {
    PSConstants;
    return;
  } catch (e) {
  } finally {
    $.level = c;
  var d = !0;
  $.level = 0;
  try {
    PSClass, d = !1;
  } catch (e) {
  } finally {
    $.level = c;
zm10.loadSymbols();
  zm10();
zm10.main();
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putProperty( charIDToTypeID( "Chnl" ), charIDToTypeID( "fsel" ) );
desc1.putReference( charIDToTypeID( "null" ), ref1 );
var ref2 = new ActionReference();
ref2.putEnumerated( charIDToTypeID( "Chnl" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
desc1.putReference( charIDToTypeID( "T   " ), ref2 );
executeAction( charIDToTypeID( "setd" ), desc1, DialogModes.NO );
var desc2 = new ActionDescriptor();
var ref3 = new ActionReference();
ref3.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
desc2.putReference( charIDToTypeID( "null" ), ref3 );
var list1 = new ActionList();
list1.putInteger( 7 );
desc2.putList( charIDToTypeID( "LyrI" ), list1 );
executeAction( charIDToTypeID( "Dlt " ), desc2, DialogModes.NO );
Participant ,
I tried, but trees, the house is also fill black. I want to choose all the trees, house,.. of outside.
Advocate ,
Participant ,
Yep, thank you so much!
