Calling webhelp using URLs
Feb 23, 2009 Feb 23, 2009
Hi Peter,
I've been reading your topic 'Calling Webhelp using URLs' on your website.
I've created my webhelp application on my desktop. When I've tested it, I could able to access the topics with synchronised TOC using the URLs. Its working perfectly fine on my local machine.
Whereas, when I've tried accessing the same topic on a server, the target topic opens along with TOC. However, is not synchronised to the target topic.
I've gone through your snippet 1 and added the step 8 to whthost.js. After this, when I've tried accessing the same page, there is no change in the TOC and also getting an js error 'object doesn't support this property or method'.
Can you tell me what I am missing. BTW, I am using RH x5 and Tomcat 4.1
Ravi
753
Welcome to the forum.
Have you tried changing the setting in the wizard from WebHelp to LocalHelp?
yes, I've changed it to Local Help
It's not clear if you had tried that or have just tried it.
Assuming that you have tried it and it has failed, I am a bit stumped. Is the problem just when topics are called from the application?
I've already tried it still its not working.
Its working fine on my local desktop with sync TOC by using...("/Generate/index.htm#path/topic.htm")
where as, on the server not able to get the sync TOC by using...( http://my ip:8080/Generate/index.htm#path/topic.htm)
Sorry but the known solutions are those on my site.
Are you able to try it on a different server?
RoboHelp Documentation
Download Adobe RoboHelp
