6 Replies Latest reply on Jun 6, 2018 9:54 AM by Laubender
    Export All Conditional Text to a Text file
    VWu Level 1
      I am trying to write a script that using find Grep to export all the conditional text, but I have a problem.
      I can only find the text with one condition applied, but not the text with two or more conditions applied
      Could someone please point me in the right direction?
          myDoc = app.activeDocument;
          var Report = new File ( myFiles[i].parent+"/"+myFiles[i].name.replace ( /\.indd$/i, ".txt" ) )
          Report.open( "w" );
          var myConditions = myDoc.conditions;
          myConditions.everyItem().visible = false;
          l = myConditions.length;
          //cycle thru conditions
          while(l--){
              myCondition =     myConditions[l];
              //set actual condition visible to true
              myCondition.visible = true;
              myConditionName = myCondition.name;
          app.findGrepPreferences = NothingEnum.nothing;
          app.findChangeGrepOptions.includeMasterPages = true;
              app.findGrepPreferences.appliedConditions=[myCondition];
              var myFind = myDoc.findGrep();
              Report.writeln(myConditionName)
              for(var a=myFind.length-1; a>=0; a--){
                  Report.writeln(myFind[a].contents+"\r");
              Report.writeln("\r\r");
          myCondition.visible = false;
        • 1. Re: Export All Conditional Text to a Text file
          Ananth@desgin Level 3
          Hi VWu,
          Please replace the second line.
          var Report = new File("~/Desktop/Conditinal_Report.txt" );
          Prabu G
          • 2. Re: Export All Conditional Text to a Text file
            VWu Level 1
            Sorry I didn’t include the full code in the beginning, I have a script point to a folder so that I can collect all files in folder and subfolders as myFiles.
            Thank you for your reply and Sorry for the confusion!
            My problem is not that I cannot generate the report,
            my problem is I cannot find the text with two or more conditions applied.
            I can only find the text with one condition applied.
            Revised full code as below. Any help would be appreciated.
            var myFolder = Folder.selectDialog( "Select a folder to process" );
            if ( myFolder != null ) {
                 var myFiles = [];
                  GetSubFolders(myFolder); }
              function GetSubFolders(theFolder) {
                 var myFileList = theFolder.getFiles();
                 for (var i = 0; i < myFileList.length; i++) {
                      var myFile = myFileList[i];
                      if (myFile instanceof Folder){
                           GetSubFolders(myFile);
                      else if (myFile instanceof File && myFile.name.match(/\.indd$/i)) {
                           myFiles.push(myFile);
            for(var i = 0; i < myFiles.length; i++){
                var newDoc =  app.open(myFiles[i]);
                Report.open( "w" );
                while(l--){
                    Report.writeln("\r\r\r");
            • 3. Re: Export All Conditional Text to a Text file
              Laubender Adobe Community Professional & MVP
              appliedConditions is a property of object Text and therefore a property of textStyleRange.
              Further: The value of appliedConditions is an Array.
              A textStyleRange is a range of text with mutual formatting.
              So you could go through all textStyleRanges of a Story and look for appliedConditions.
              The result will tell you what conditions are applied if any. You could even add the textStyleRanges to the result.
              Let's test that with a story at hand. A simple text frame where several conditions are applied. To parts of the text even more than one condition is applied:
              If you run the script snippet below on the selected text frame you can see the result in the JavaScript Console of your ESTK. It will contain the names of the applied conditions plus all the text ranges in an "associative" array. The result array could be used to duplicate the text ranges to a different document in a sorted way.
              // Text frame of story selected:
              var textStyleRanges = app.selection[0].parentStory.textStyleRanges.everyItem().getElements();
              var textStyleRangesLength = textStyleRanges.length;
              var resultArray = [];
              for(var n=0;n<textStyleRangesLength;n++)
                  // No condition applied, loop on:
                  if( textStyleRanges[n].appliedConditions.length == 0 ){ continue };
                  var conditions =  textStyleRanges[n].appliedConditions;
                  var conditionsLength = conditions.length;
                  var conditionNames = [];
                  for( var c = 0; c<conditionsLength; c++)
                      conditionNames[c] = conditions[c].name;
                  var conditionsNamesString = conditionNames.join(" & ");
                  if( conditionsNamesString in resultArray )
                      resultArray[ conditionsNamesString ] = resultArray[ conditionsNamesString ].concat( [textStyleRanges[n]] );
                  else
                      resultArray[ conditionsNamesString ] = [textStyleRanges[n]];
              // Write the results to the JavaScript-Console of the ESTK
              for( x in resultArray )
                  $.writeln( x +"\t"+ resultArray[x] );
              Here the result from the JavaScript-Console:
              Cond1 & Cond3    [object TextStyleRange]
              Cond2    [object TextStyleRange],[object TextStyleRange]
              Cond3    [object TextStyleRange],[object TextStyleRange]
              Cond2 & Cond3    [object TextStyleRange]
              Cond1    [object TextStyleRange],[object TextStyleRange]
              Cond1 & Cond2 & Cond3    [object TextStyleRange]
              Best,
              Uwe
              • 4. Re: Export All Conditional Text to a Text file
                Also see into DOM documentation for TextStyleRange :
                Adobe InDesign CS6 (8.0) Object Model JS: TextStyleRange
                and its property contents:
                Note: To visit all text style ranges of a document keep in mind that Story is not the only object you have to look at.
                See also into table text Cells and Footnotes.
                Uwe
                • 5. Re: Export All Conditional Text to a Text file
                  VWu Level 1
                  Thank you for your help Uwe!
                  I still have problem understanding the logic starting from line 21 to line 37,
                  and not yet familiar with how to get the contents of textStyleRange
                  but I will definitely do more readings.
                  Really appreciated it!
                  • 6. Re: Export All Conditional Text to a Text file
                    Hi VWu ,
                    to get the contents of a textStyleRange is easy.
                    contents is a property of textStyleRange.
                    Do a text frame, type some text, format some words or characters differently and run the following snippet after selecting the frame:
                    var story = app.selection[0].parentStory;
                    var textStyleRanges = story.textStyleRanges.everyItem().getElements();
                    var lengthOfStyleRanges = textStyleRanges.length;
                    for( var n=0; n<lengthOfStyleRanges; n++ )
                        $.writeln( textStyleRanges[n].contents );
                    To understand what I did in lines 21 to line 37 examine and run this little snippet from the ESTK:
                    // There is nothing special to the name of this variable:
                    var associativeArray = [];
                    var x;
                    // Next we store key and value pairs.
                    // Key must be a string, value can be anything. In this case an array with a string:
                    associativeArray["animals"] = [ "dog" ];
                    associativeArray["plants"] = [ "tree" ];
                    $.writeln( associativeArray.length ); // Returns 0
                    $.writeln( "animals" in associativeArray ); // Returns true
                    $.writeln( "mushrooms" in associativeArray ); // Returns false
                    // for in-loop to get all key/value-pairs:
                    for( x in associativeArray )
                        $.writeln( x +" : "+ associativeArray[x] );
                        $.writeln( x +" : "+ associativeArray[x].constructor.name );
                    // Adding something to the value of "animals" and not replacing the value:
                    if( "animals" in associativeArray )
                        associativeArray["animals"] = associativeArray["animals"].concat( ["cat"] );
                    else{ associativeArray["animals"] = ["cat"] };
                    So basically in lines 21 to 37 I am building key strings and assign an array of formatted chunks of text as value, the textStyleRanges.
                    Uwe
                    1 person found this helpful
