brush not working properly [OSX 10.12.6]
Feb 17, 2018 Feb 17, 2018
PS CC 2018 on macOS 10.12.6
the brush tool often times will not lay down any color at all on a normal layer. I have to quit and restart PS for it to work. I have done a reinstall of CC already.
so once it works, it's fine. open up a new file and use it again, it won't work. I am aware of mask painting user error, that is not it. sometimes I can get it to work if I CMD+Tab to a different program and back again. otherwise I am having to restart the program.
anyone else having this problem?
566
Community Expert , Feb 19, 2018 Feb 19, 2018
I'm sorry, but I am out of my depth with Mac issues of this nature.  I have changed the thread subject line to indicate that you are using a Mac, and this post will bump you to the top of th page again, so apart from that I can only wish you good luck.
I do remember seeing references to OSX versions and compatibility with different Photoshop versions, but 10.12.6 shouldn't be a problem
There's a long thread here that might have relevant content towards the end
https://forums.adobe.com/message/10185289?tstart=0#10185289
Adobe
Feb 18, 2018 Feb 18, 2018
Is there anything you can tell us that might tie it down?  Are you using a tablet, and if so, which one?
Have you tried opening Photoshop with the Shift key held down to force plugins and extensions not to load?  I don't know if the issue happen often enough for that test to be useful.
Are these particular image types? Mode, bit depth?
Any particular brush presets?  Do you always look at the Options bar to see if anything is going on up there (blend modes etc.)?
You mention a reinstall, but that does not necessarily give you a clean start with new settings, so resetting Preferences might be worth a try (sorry — we hate suggesting that unless all else fails as it is a PITA)
When you reinstalled, did you run the cleaner tool?
using a Wacom intuos 4, latest driver
I haven't reinstalled any 3rd party plugins since I reinstalled PS.
literally happens with any file type; and now I've had to restart PS because when I open a file, 6/10 times a healing brush, patch tool, clone stamp, or brush will result in absolutely nothing, even though the history palette is logging each stroke. nothing is selected, no blend modes, nothing.
this is on a fresh install of macOS as well. so there are no previous versions of anything on the machine. this is annoying and frustrating as it is increasing my work time unnecessarily.
I think Jeff Tranberry has a page as well.  Hmm I'm not finding anything current
Update on OS support for next major release of Photoshop
I'm guessing that your hardware would not support later versions of OSX seeing as this is a new clean install?  Like I said... I am a Windows user.
Jun 06, 2018 Jun 06, 2018
Same here.
I think it's something related to wacom.
Try use other side of pen (eraser) then brush.
Sometimes works
