For a project from work, I was required to make a sequence using some video. I sent that in, and now my boss wants me to also send in a breakdown of the total run time of the scene, as well as a clip by clip breakdown of how I structured the video, something like this:
Ex:
TRT: 1:37.23
0:00.00 - 0:12.23 - Clip C004 Used, from 2:48.12 to 3:00.35
I have the total run time and clip name used, as well as the frames in which they all start and end. The bolded part above is what I can't find. I can't figure out how to find exactly what section of the source clip I used. The markers are no longer there to indicate what part of the source clip I extracted. Using my video, I can make my best estimate as to where I cut from the source clip, but I would much prefer having the section on the dot so it can be completely duplicated. Is there any way that I can find the frames in which I started and stopped using a source clip?
In the preferences/media set timecode to Use media source.
Put your mouse over a clip and double click
it will open in the sourch monitor.
set mouse of inpoint and you can read the timecode, same for outpoint.
Thank you so much! Works like a charm!
Look at creating an EDL - it should give you exactly what you want
