when i give a path a stroke weight and then scale and then scale it down, the stroke weight remains in the same. how can i get the stroke weight to scale proportionally too.
example: when I make a logo, I assign a stroke of 2 pts to the graphic. then I scale it down to a business card size and the stroke weight remains 2 pts which is too much for a tiny graphic. also when I scale it up, the stroke weight proportionally appears to be too thin... please help
General prefs. Check Scale Strokes & Effects.
thanks. it works fine!
Hi!
How can I do that in Photoshop CC version? I have the same problem!
Thank you!
It's from AI. You can select options when transforming objects. I'm not sure if it's the same in PS.
correct answer.
You can also make that change in the flyout menu in the Transform Panel.
Peter
awesome! this helped me, ive been goin to path>create outlines
Super helpful. Thanks!
You're welcome.
