Hi All
I have an InDesign document (latest CC2018 running on Windows 10) which is showing two missing links.
When opening the document I receive the 'document contains 2 links to sources that are missing' alert, and there are two links showing as missing in the Links palette.
However, the two links are not showing as being on any page number.
If I right-click on the missing link in the palette and choose 'Go To Link...' nothing happens.
Any suggestions?
Many thanks
Forgot to mention ... if I work through each page in the document, select all elements and delete ... all the other links in the palette eventually disappear, leaving just the two annoying phantoms!!
take a look here
Hi Vladan
Yes indeed, I read through the entire thread several hours ago!
Unfortunately, we are all PC based so I am unable to run any Apple Scripts on our InDesign.
Chris
Well, maybe here could give a script for that
Hi
Have you tried Laubender's javascript snippet found in the Vladan's suggested link?
Hi All
Many thanks for your replies and suggestions.
I actually solved this by creating a brand new document and copying all the elements from the original to new document.
Thanks again
Chris
