Hello! I've been searching a way to access adjustment layers properties after created in the layers section, however I've failed with the ScriptListener pluging, which seems not to record that action. But I know there would be a way to access there via Action Manager, I have faith on that haha! This Action Manager language makes me happier everytime I learn something new about it. I think I found a cure for my anxiety!
you have to convert the level to an advanced object
and then change the level properties.
here is a link to code from Mike Hale which could help solve your problem.
I haven't used it yet, but I think with some modifications you should be able to use this stuff.
http://ps-scripts.com/bb/viewtopic.php?p=10945
btw there are several posts in ps-scripts.com referring to acv-files. They may be helpful too.
After I click that link I'm ending on ps-scripts site but recieving The requested topic does not exist. information.
I have the same problem trying to click on links of ps-scripts.com. I suppose that the content to these links is hidden deep in the archives and no longer available.
But here follows the code Mike Hale published some years ago:
#target photoshop
// Here is a sample script that will save an acv file from an existing curves adjustment layer.
// The script expects the adjustment layer to be the active layer and I only tested
// with RGB 8bit images on Windows
File.prototype.writeByte = function(b) { this.write(String.fromCharCode(b)) };
File.prototype.writeShort = function(ET,s) {
var self = this;
if(ET == "BE"){
self.writeByte(s & 0xFF);
self.writeByte((s >> 8) & 0xFF);
}else{
return self;
convertBCD = function( num ){
if(num == 13) { return [1,1,0,1] };// special case
var res = new Array;
if(num > 8 ){
res.unshift(1);
num = num - 8;
}else{
res.unshift(0);
if(num > 4 ){
res.unshift(1);
num = num - 4;
}else{
res.unshift(0);
if(num > 2 ){
res.unshift(1);
num = num - 2;
}else{
res.unshift(0);
if(num == 1 ){
res.unshift(1);
}else{
res.unshift(0);
return res;
getCurve = function( numberOfPoints ){
this.getPoints = function(){
this.tempArray = new Array;
this.tempArray.push( rawDesc.charCodeAt( pointer ) );
pointer = pointer + 2;// set pointer to next point
return this.tempArray;
this.pointsArray = new Array;
for( var i = 0; i < numberOfPoints; i++ ){
pointer = pointer + 2;// next point
this.pointsArray.push( this.getPoints() );
pointer = pointer + 2;// next curve
return this.pointsArray;
var ref = new ActionReference();
ref.putEnumerated( charIDToTypeID( 'Lyr ' ), charIDToTypeID( 'Ordn' ), charIDToTypeID( 'Trgt' ) );
var rawDesc = executeActionGet( ref ).getList( stringIDToTypeID( 'adjustment' ) ).getObjectValue( 0 ).getData( stringIDToTypeID( 'legacyContentData' ) );
var pointer = 2; // used to read rawData similar to reading a file
var flag = rawDesc.charCodeAt( pointer ); // char at offset 2 always == 1 so use to validate data
if( flag != 1 ) forceError; // unknown problem with rawData
pointer = 6;// update pointer to BCD byte
var bcd = rawDesc.charCodeAt( pointer );
if( bcd < 0 || bcd > 15 ) forceError;// check for valid value
if( bcd == 0 ) forceError;// an empty adjustment - no curves to process
var bcdArray = convertBCD( bcd );
var numberOfCurves = bcdArray.toString().match(/(1)/g).length;
var curvesArray = new Array;
pointer = 8;// set pointer to start of curve data
for(var i = 0; i < numberOfCurves; i++ ){
var numberOfPoints = rawDesc.charCodeAt( pointer );
curvesArray.push( getCurve( numberOfPoints ) );
// now need to map rawData curves in curvesArray to known channel curves
// for example if bcd == 7 then there is a RGB, RED, and GREEN curve
// if bcd == 8 then there is only a BLUE curve. etc
var acvArray = new Array;
if( bcdArray[0] == 1 ) {
acvArray.push( curvesArray.shift() );
} else {
acvArray.push( [ [0,0],[255,255] ] );
if( bcdArray[1] == 1 ) {
} else {
if( bcdArray[2] == 1 ) {
} else {
if( bcdArray[3] == 1 ) {
} else {
// Write to acv-File
var myACV = new File('~/Desktop/myCurve.acv');
myACV.open('w');
myACV.writeShort( 'LE','4' );// acv header
myACV.writeShort( 'LE','5' );// acv header
for( var i = 0; i< 5; i++ ) {
var numberOfPoints = acvArray.length;
myACV.writeShort( 'LE', numberOfPoints.toString() );
//myACV.writeByte( 0 );
for( var p = 0; p < numberOfPoints; p++ ){
myACV.writeShort( 'LE', acvArray
[0].toString() );
[1].toString() );
content = myACV.read()
myACV.close();
'Mike Hale '
True - all Ps-Scripts links I clicked last month that normally have been taking me to appropriate topics do not work. What is wired, even those correct ones I would post now do not display right pages 😕 There is also other change on that forums. All codes I posted with indentations are seen without them (so all scripts lines start in the same first column).
What kind of adjustment layer data do you want to read or change? Different types of layers contain different data.
For the "Levels" type, you can examine this code.
Also about the scriptlistener or recording things done in Photoshop. Some things that are recorded are recorded in a delayed fashion. That is while you making some adjustments nothing is recorder. So you can make many trial adjustments till you find the one that suites you. When you move on to your next Photoshop step. Photoshop will record the last adjustment you made for your previous step. That way only the adjustment you want is recorded. So if you had a problem with Scriptlistener not recording your Adjustment it is very likely it was in delayed recording mode waiting for you to move on to your next Photoshop function. Some times you need to move on for a step to be recorded.
Guys, I appreciate a lot your help! I found a very easy way to do it, this study helped me to understand better Action Managers behavior ! It is so exciting learning this stuff tho!
First Irecorded with script listener a brightness and contrast adjustment directly into a layer. Studied the settings and how they were applied with which action descriptor, seems Actions Manager actions works hierarchically, so I just simplified variables and stuff.
Then I recorded again with script listener how an adjustment layer is created with Action Manager but added another action descriptor in the hierarchy to with the settings of the adjustment layers, seems to work the same for everyone of them.
Also found that putInteger() and putDouble() works the same haha!
Here is the code I built to create and adjustment layer with the desired settings, i tried some stuff also with random values to have differente results
What this code does is it creates a ColorBalance adjustment layer with randome balues on the different levels, and it checks if there´s any layer name "NewColorBalance", if so, it removes that layer and creates another ColorBalance adjustment layer with random settings.
If you rename the layer, it creates another adjustment layer and name it NewColorBalance.
function colorBalanceAdjLayer) {
var layLen = app.activeDocument.layers;
var actLayer = app.activeDocument.activeLayer;
var i;
for (i = 0; i < layLen.length; i++) {
if (layLen.name == "NewColorBalance") {
app.activeDocument.layers.getByName("NewColorBalance").remove();
function s2t(s) { return app.stringIDToTypeID(s) }
//Declaring variables////////////////////////////////////////////////////////////////////////////////////////////////
var ranD1 = Math.floor(Math.random() * (10 - 0 + 1) ) + 0
var ranD2 = Math.floor(Math.random() * (10 - (-10) + 1) ) + -10
var ranD3 = Math.floor(Math.random() * (0 - (-10) + 1) ) + -10
var ranD4 = Math.floor(Math.random() * (10 - (-10) + 1) ) + -10
var ranD5 = Math.floor(Math.random() * (10 - (-10) + 1) ) + -10
var ranD6 = Math.floor(Math.random() * (10 - (-10) + 1) ) + -10
var ranD7 = Math.floor(Math.random() * (0 - (-20) + 1) ) + -20
var ranD8 = Math.floor(Math.random() * (10 - (-10) + 1) ) + -10
var ranD9 = Math.floor(Math.random() * (10 - 0 + 1) ) + 0
var d1 = new ActionDescriptor();
var d2 = new ActionDescriptor();
var aRef = new ActionReference();
var d3 = new ActionDescriptor();
var d4 = new ActionDescriptor();
var d5 = new ActionDescriptor();
var l1 = new ActionList();
var l2 = new ActionList();
var l3 = new ActionList();
// Class of what is MADE////////////////////////////////////////////////////////////////////////////////////////
aRef.putClass( s2t( "adjustmentLayer" ) );
d1.putReference( s2t( "null" ), aRef );
//Adjustment layer properties////////////////////////////////////////////////////////////////////////////////
l3.putInteger( ranD1 );
l3.putInteger( ranD2 );
l3.putInteger( ranD3 );
d3.putList( s2t("shadowLevels"), l3 );
l2.putInteger( ranD4 );
l2.putInteger( ranD5 );
l2.putInteger( ranD6 );
d3.putList( s2t("midtoneLevels"), l2 );
l1.putInteger( ranD7 );
l1.putInteger( ranD8 );
l1.putInteger( ranD9 );
d3.putList( s2t("highlightLevels"), l1 );
d3.putBoolean( s2t("preserveLuminosity"), true);
//Type of adjustment layer//////////////////////////////////////////////////////////////////////////////////////
d2.putObject( s2t( "type" ), s2t( "colorBalance" ), d3 );
d1.putObject( s2t( "using" ), s2t( "adjustmentLayer" ), d2 );
//CREATE ADJUSTMENT LAYER ACTION///////////////////////////////////////////////////////////////
executeAction( s2t( "make" ), d1, DialogModes.NO );
// First step is to MAKE the object
app.activeDocument.activeLayer.name = "NewColorBalance"
You are wrong.
If you replace the
desc.putDouble( charIDToTypeID( "Gmm " ), gm );
with
desc.putInteger( charIDToTypeID( "Gmm " ), gm );
in the function edit_levels() of this post, Re: Modifying Levels Adjustment Layer?
then nothing good you will get
