Hola, llego a ustedes para revisar con ustedes si les ha pasado. Desde que mi laptop hizo update actualmente windows 10, al usar LR Classic CC para exportar mi trabajo a la nube. Observo que las tonalidades desde cualquier mobil, son saturadas.
Sabran ustedes a que se debe este cambia, ya que antes no me pasaba?
Hola Stewart, me parece que me está sucediendo casi lo mismo, en mi caso cuando importo las fotos en formato RAW, estos se importan en una tonalidad rosada, como si el matiz se hubiera subido sin yo tocar nada.
En verdad que lo tuyo tambien se pueda solucionar.
Saludos tosso1997,
Entiendo que deberias revisar el profile picture en la camara, ver si tienes uno seleccionado con baja tonalidad.
stewartmPR wrote
Hi, I come to you to check with you if you passed them. Since my laptop made update currently 10 windows, when using LR Classic CC to export my work to the cloud. I note that keys from any mobil, are saturated.
So the appearance of images in Lightroom has not changed, only exported images?
Which color profile did you use when exporting?
Generally speaking, phones are not color managed, and can not be expected to display correct colors.
If the images don't look right in Lightroom, see below.
tosso1997 wrote
Hello Stewart, it seems to me that almost the same is happening to me in my case when I import the photos in RAW format, these are imported in a pink hue, as if nuance would have uploaded without me touching anything.
This sounds like a defective monitor profile.
Try setting the monitor profile to sRGB (Adobe RGB if you have a wide gamut monitor).
If this fixes the problem, you should ideally calibrate your monitor with a hardware calibrator.
