Im having issues with you're software. Adobe premiere pro CC. The issue is while im editing the preview looks amazing. Nice and crisp footage but on export it gets degraded and filled with banding. expecially in the shadows. I shoot on a Sony a7sii. The 4k sony codec XAVC-S. Please help. Im losing money because this is taking way to much time to figure out.
heres some screenshots
Export quality is determined by export settings.
Having said that, it also must be said that the only correct way to evaluate an export is on a calibrated TV. You can't use your computer for this.
Hi bretts25770967,
Sorry for the trouble. Import the exported file back into Premiere Pro & check if the issue persists.
Post a screenshot of the export settings.
Have you tried changing the renderer in project settings & export? Steps: FAQ: How to change the Video Renderer in Premiere Pro?
Vidya
Ive tried all of that
. Last year this issue was like a huge bug with CC. Did you guys fix it? I believe the bug happened withh 8 bit footage
What is the bitrate of your source video?
What are your bitrate settings for your export?
Still having problems, BrettS? Please let us know.
Kevin
I've been having this same problem, but didn't really see a solution here
Please post a screenshot of your export settings summary on your exports settings pane, like this example below:
MtD
I am havind the same problem!
In order to get help, it would be useful if you could post a screen shot of your export settings summary, like this example below:
MtD
