Hi All,
Any tips for removing glare on a client's eyeglasses on film?
Shelley
use an extra light on the model to keep the glare down when you take the photo
How about correcting it in post-edits? Any suggestions?
it would help to know what software you are using to make these edits;
Adobe Photoshop, Lightroom, Prem pro and After effects all bring to mind depending on the job needs
Sure no problem...using premier, photoshop and after effects
ok for Photoshop I would use the the trick WobertC posted... another model image can be used if you don't have a photo of that same person without their specs but at the end of the day,
best results = fix it at the camera first
shelleyp82438848 wrote
Best advice I have seen Pre&Post is-
Take two images of the person- 1) with specs, 2) without specs. by quickly asking person to remove glasses without shifting position.
In Photoshop- layer the 2) 'good' eyes over 1) the 'glare' eyes.
Even reduce opacity of 'good' eyes if you want to show a faint touch of glare.
Try putting a layer into the Camera Raw filter and use dehaze. It can reduce the reflection, but not completely eliminate it. You may not want to eliminate all the reflection.
