1 Reply Latest reply on Jun 8, 2018 4:41 AM by manuelb27477138
    Apply Master Pages to specific Group Styles and Paragraph Styles with ONE or TWO dimension names
    manuelb27477138 Level 1
      Hello!
      I have paragraph styles with names in ONE and TWO dimensions, and I would apply automatically Master Pages based on their paragraph styles.
      The number of the paragraph styles and master pages can increase and decrease, according to your needs.
      My styles ONE dimension paragraph Styles are:
      Chapter 1
      Chapter 2
      Chapter 3
      My styles TWO dimension paragraph Styles are:
      Chapter 1.1
      Chapter 1.2
      Chapter 1.3
      Chapter 2.1
      Chapter 2.2
      Chapter 2.3
      Chapter 3.1
      Chapter 3.2
      Chapter 3.3
      My Master pages are:
      C1-Chapter
      C2-Chapter
      C3-Chapter
        • 1. Re: Apply Master Pages to specific Group Styles and Paragraph Styles with ONE or TWO dimension names
          Here is the solutions:
          Here you can get the files, fotos, and code:
          SOLUTION FOR ONE DIMENSION PARAGRAPH
          //_____________________________________________________________________________________
          // COUNT ALL PARAGRAPH STYLES IN A PARAGRAPH STYLES GROUP WITH THE SAME NAME
          var myDoc = app.documents[0];
          var paragraphStyle1 = [];
          var counter = 0;
          var paragraphStyleGroup1 = myDoc.paragraphStyleGroups.itemByName("CHAPTERS");
          while(counter < paragraphStyleGroup1.paragraphStyles.length){
              if(paragraphStyleGroup1.paragraphStyles[counter].name.toString().indexOf("Chapter ") != -1){
          paragraphStyle1.push(paragraphStyleGroup1.paragraphStyles[counter]);}
            counter++;}
          totalParagraphStyle1=paragraphStyle1.length;
          alert("Total Paragraph Styles: " + totalParagraphStyle1);
          //      END COUNT ALL PARAGRAPH STYLES IN A PARAGRAPH STYLES GROUP WITH THE SAME NAME
          //                   START Apply Master Page based on Paragraph Style
          var myDocument = app.activeDocument;
          var myParas = myDocument.stories.everyItem().paragraphs.everyItem().getElements();
          var myPage = myDocument.pages;
          totalParagraphStyle1++;
          for(i=0; i<myParas.length; i++){
          for(j=0;j<totalParagraphStyle1;j++){
          if(myParas[i].appliedParagraphStyle.name == "Chapter "+[j]){
          myParas[i].parentTextFrames[0].parentPage.appliedMaster = myDocument.masterSpreads.item("C"+[j]+"-Chapter");}}
          alert("Done!");
          //                     END Apply Master Page based on Paragraph Style
          SOLUTION FOR TWO DIMENSION PARAGRAPH
          var myName = "CHAPTERS"
          var myArr =[];
          var myParaStyleList = myGetParagraphStyleNames();
          for (var i=0; i< myParaStyleList.length; i++)
              if(myParaStyleList[i].indexOf(myName) !=-1)
                  myArr.push(myParaStyleList[i]);
          alert("Total Paragraph Styles FIRST and SECOND dimension: " + myArr.length); // TOTAL OF PARAGRAPH STYLES
          var myArr1=[], myArr2 = [];
          for(var i =0; i< myArr.length; i++)
              myArr1[i]=myArr[i].split(".")[0];
              myArr2[i]=myArr[i].split(".")[1];
          myArr3= Unique(myArr1);
          alert("Total Paragraph Styles FIRST dimension: " + myArr3.length);   // TOTAL OF FIRST DIMENSION
          myArr4 = Unique(myArr2);
          alert("Total Paragraph Styles SECOND dimension: " + myArr4.length);   // TOTAL OF SECOND DIMENSION
          function myGetParagraphStyleNames()
          var result = [];
          var myParagraphStyles = app.activeDocument.allParagraphStyles;
          var myParagraphStyleName, obj;
          for(var i=0; i < myParagraphStyles.length ; i++)
              myParagraphStyleName = myParagraphStyles[i].name;
              obj = myParagraphStyles[i];
              while(obj.parent instanceof ParagraphStyleGroup)
                  myParagraphStyleName = obj.parent.name + ":" + myParagraphStyleName;
                  obj = obj.parent;
              result.push(myParagraphStyleName);
           } // for
          result.shift(); // удаление стиля No Paragraph Style
          return result;
          } // fnc
          function Unique(A)
              var n = A.length, k = 0, B = [];
              for (var i = 0; i < n; i++)
               { var j = 0;
                 while (j < k && B[j] !== A[i]) j++;
                 if (j == k) B[k++] = A[i];
              return B;
          myArr3.length++;
          myArr4.length++;
          for(AppendixA=0;AppendixA<myArr3.length;AppendixA++){
          for(AppendixB=0;AppendixB<myArr4.length;AppendixB++){
          if(myParas[i].appliedParagraphStyle.name == "Chapter "+[AppendixA]+"."+[AppendixB]){
          myParas[i].parentTextFrames[0].parentPage.appliedMaster = myDocument.masterSpreads.item("C"+[AppendixA]+"-Chapter");}}}
          alert("Done!");
          QUICK VIEW
          Thanks so much to Boris.
