Hello,
Up until recently, I would open Bridge from InDesign CS6 in order to use the mini bridge panel. Now I open Bridge, and when I try to get mini bridge from the Window menu, nothing happens, no error message, no mini bridge, nothing - it is as if I clicked on nothing. Is there an option somewhere that got disabled? How do I get mini bridge back? Thank you for any feedback on this.
Have you upgraded your operating system or any of the components? Mini-Bridge relies upon Flash-air and in newer OSs, Flash cannot work. Also, if you have upgraded your Bridge, Mini-Bridge was dropped in more recent versions.
If this is it, sorry to bring bad news, I miss Mini-Bridge as well.
A fix in this thread:
Hello,
This is a fix for an empty mini-bridge panel. I get no panel at all. Also, the code in the "Terminal" window did not stay. I copied the code line defaults write com.adobe.CSXS.3 PlayerDebugMode in the window and closed it. When I go back to Terminal, the code is gone, and mini-bridge still does not appear in any way, shape, or form. It could be because I am not the administrator of this laptop, or because I am doing something incorrectly. But it was worth a try.
Thank you for the feedback.
Hello,
Mini-bridge could have disappeared after I did some updates, I did not take note of that, but the timing is possible. It seems to be the trend that mini-bridge is on its way out. I'll accept that. Thank you.
