I need help, I'm a novice in javascript, but I like to automate
my query is that the tables would like to give the effect of rounded edges. Searching the web I found 2 scripts that I would like to merge.
The first works like this:
The table is selected and when applying the script, I see options of corner, after selecting one, a floating frame appears on top of the table with the effect I chose.
var myCornerRadius;
var myCornerOptionsIndex;
main();
function main()
if (app.documents.length == 0)
alert ("The document is not open. Open the document first");
return;
if(app.selection.length > 0)
if(app.selection[0].constructor.name == "Table" )
if( myDialog() ) {
myTest(app.selection[0]);
roundedTable(app.selection[0]);
else
alert("It is necessary to select the table in text mode");
return;
else
alert("Select the table in text mode and run the script again");
return;
} // main()
function myDialog()
var myDialog = app.dialogs.add({name:"Corner Options"});
with(myDialog){
with(dialogColumns.add()){
with(borderPanels.add()){
with(dialogRows.add()){
staticTexts.add({staticLabel:"Effect:"});
var myEffectsMenu = dropdowns.add({stringList:["None", "Fancy", "Bevel", "Inset", "Inverce Rounded","Rounded"], selectedIndex:5});
} // with(dialogRows.add()){
staticTexts.add({staticLabel:"Point Size:"});
var myPointSizeField = realEditboxes.add({editValue:10});
} //with(dialogRows.add()){
} // borderpanel
} // with(dialogColumns
} // with(myDialog)
// end of dialogue
if ( !myDialog.show() )
myDialog.destroy();
return false;
myCornerRadius = myPointSizeField.editValue;
myCornerOptionsIndex = myEffectsMenu.selectedIndex;
myDialog.destroy();
return true;
} // fnc
function roundedTable(myTable)
var myDocument = app.activeDocument
with (myDocument.viewPreferences){
// Save the old units in variables OldXUnits, myOldYUnits
var myOldXUnits = horizontalMeasurementUnits;
var myOldYUnits = verticalMeasurementUnits;
// We set new units of measurement
horizontalMeasurementUnits = MeasurementUnits.points;
verticalMeasurementUnits = MeasurementUnits.points;
// The main script code
var myH = myTable.height;
var myW = myTable.width;
var myStrokeWeight = myTable.topBorderStrokeWeight;
var myTextFrame = myTable.parent;
var myParagraphs =myTextFrame.paragraphs;
if((myTextFrame.geometricBounds[3] - myTextFrame.geometricBounds[1] ) >= myW || (myTextFrame.geometricBounds[2] - myTextFrame.geometricBounds[0] ) >= myH)
DelTableEdge(myTable);
for (var i=0; i< myParagraphs.length; i++)
if(myParagraphs.tables[0] == myTable)
var myTablePara =myParagraphs;
break;
} // for
var myPrevPara = myParagraphs[i-1];
myTablePara.leading = 0;
// Insert a frame ****************
var myBorder = myPrevPara.insertionPoints[-1].rectangles.add();
// Define the properties of the inserted frame
var myNoneSwatch = app.activeDocument.swatches.item("None");
myBorder.fillColor = myNoneSwatch;
//myBorder.strokeColor= myStrokeColor;
myBorder.strokeWeight = myStrokeWeight;
// Set binding parameters
with(myBorder.anchoredObjectSettings)
anchoredPosition = AnchorPosition.anchored;
anchorPoint = AnchorPoint.TOP_LEFT_ANCHOR
horizontalReferencePoint = AnchoredRelativeTo.anchorLocation;
horizontalAlignment = HorizontalAlignment.leftAlign;
anchorXoffset = myTablePara.firstLineIndent;
verticalReferencePoint = VerticallyRelativeTo.lineBaseline;
anchorYoffset = myTable.spaceBefore;
anchorSpaceAbove = 0;
// Rounding type of corners
switch (myCornerOptionsIndex)
case 0:
myBorder.cornerOption = CornerOptions.NONE;
break;
case 1:
myBorder.cornerOption = CornerOptions.FANCY_CORNER;
break;
case 2:
myBorder.cornerOption = CornerOptions.BEVEL_CORNER;
break;
case 3:
myBorder.cornerOption = CornerOptions.INSET_CORNER;
break;
case 4:
myBorder.cornerOption = CornerOptions.INVERSE_ROUNDED_CORNER;
break;
case 5:
myBorder.cornerOption = CornerOptions.ROUNDED_CORNER;
break;
} //switch
// radio
myBorder.cornerRadius = myCornerRadius;
myBorder.strokeColor = app.activeDocument.swatches.item("Black");
var myTextFrameGB = myTextFrame.geometricBounds;
var anchorGB = myBorder.geometricBounds;
anchorGB[2] = anchorGB[0] + myH;
anchorGB[3] = anchorGB[1] + myW;
switch(myTablePara.justification)
case Justification.LEFT_ALIGN:
case Justification.LEFT_JUSTIFIED:
case Justification.FULLY_JUSTIFIED:
break;
case Justification.CENTER_ALIGN:
case Justification.CENTER_JUSTIFIED:
myBorder.anchoredObjectSettings.anchorPoint = AnchorPoint.TOP_CENTER_ANCHOR;
myBorder.anchoredObjectSettings.horizontalAlignment = HorizontalAlignment.centerAlign;
break;
case Justification.RIGHT_ALIGN:
myBorder.anchoredObjectSettings.anchorPoint = AnchorPoint.TOP_RIGHT_ANCHOR;
myBorder.anchoredObjectSettings.horizontalAlignment = HorizontalAlignment.rightAlign;
break;
default:
break;
} // switch
myBorder.geometricBounds = anchorGB;
else
alert("The size of the table is larger than the size of the frame.");
exit();
// Return the Indies to the old units of measure
try{
horizontalMeasurementUnits = myOldXUnits;
verticalMeasurementUnits = myOldYUnits;
catch(myError){
alert("Could not reset custom measurement units.");
} /// with
}// fnc
function DelTableEdge(myTable)
myTable.bottomBorderStrokeWeight = myTable.topBorderStrokeWeight = 0;
myTable.leftBorderStrokeWeight = myTable.rightBorderStrokeWeight = 0;
var myRows = myTable.rows;
var myNRows = myRows.length
var myFirstRow = myRows[0];
var myLastRow = myRows[myNRows-1];
var myColumns = myTable.columns;
var myNColumns = myColumns.length;
var myFirstColumn = myColumns[0];
var myLastColumn = myColumns[myNColumns-1];
// Up and down
for (var r = 0; r < myNColumns; r++)
try {
myFirstRow.cells
.topEdgeStrokeWeight = 0; myLastRow.cells
.bottomEdgeStrokeWeight = 0; }
catch(_) {}
// Left and right side
for (var c = 0; c < myNRows; c++)
try {
myFirstColumn.cells
.leftEdgeStrokeWeight = 0; myLastColumn.cells
.rightEdgeStrokeWeight = 0; }
catch(_) {}
} // fnc
function myTest(myTable)
// Check if the table is in the first paragraph of the text frame
break;
} // for
if(!i)
myParagraphs[0].insertionPoints[0].contents ="\r";
myTextFrame.recompose;
var a = app.activeDocument.allPageItems, t;
while( t = a.pop() )
t.isValid &&
t.hasOwnProperty('anchoredObjectSettings') &&
(t.parent instanceof Character) &&
(t=t.anchoredObjectSettings).isValid &&
t.releaseAnchoredObject();
The second works like this
I select any text and when applying the script the text happens to be in an independent text frame.
app.doScript(function() {
if (app.selection.length == 1 && app.selection[0].hasOwnProperty("baseline") && app.selection[0].length > 0)
frame = app.selection[0].parentTextFrames[0].duplicate();
frame.texts[0].remove();
frame.move (undefined, [0, app.selection[0].characters[0].baseline- app.selection[0].parentTextFrames[0].characters[0].baseline]);
app.selection[0].move(LocationOptions.AT_BEGINNING, frame.texts[0]);
while (frame.texts[0].characters[-1].contents == 'r')
frame.texts[0].characters[-1].remove();
frame.fit (FitOptions.FRAME_TO_CONTENT);
frame.select();
}, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "Frame from Selection");
You could merge these two scripts so that you can first choose the type of vertex and that when accepting the result is the table outside the main text frame (in an independent frame) but within the frame with the effect of the corner.
Thanks for your help
I agree: Play with tables is truly funny! [april 2017]
Best,
Michel, from FRIdNGE
[personal paid script]
