I usually do not have problems opening AI files in Photoshop, but image number 151501383 is not displaying correctly. It opens as normal, but it just shows a bunch of text instead of the image.
Is it possible to get credited back for this image and have the image checked so others don't have the same problem? I downloaded it three times with the same issue.
This is what I see when I open in Photoshop:
Hello Amanda, I suspect the file has an issue on these situations - could be some compatibility issue in the mix. I will follow up with content team for investigation on the file. Meantime, I've added one standard license on your account.
Thanks for reporting the issue.
Thank you for your help!
