3 Replies Latest reply on Jun 11, 2018 6:09 AM by Loic.Aigon
    detect xml structure changes in Indesign
    emiliep89320758
      I have to detect a change in the xml structure of my Indesign document (like node deleted, moved and so on).
      How can I do that in a cep extension ?
      I haven't seen any event for that in Indesign
      Thanks in advance
        • 1. Re: detect xml structure changes in Indesign
          Loic.Aigon Adobe Community Professional
          Well, I am guessing that you should either listen at AFTER_SELECTION_CHANGED EVENT or IDLE_EVENT and constantly monitor structural changes.
          AFTER_SELECTION_CHANGED may be preferable but could suffer from latencies dues to User UI manipulation (the event will be fired only when user will select anything else or deselect everything).
          IDLE_EVENT will be more "realtime" but could suffer from performance issues as xml files would be generated a lot of times per second.
          Of course one can argue that exporting XML could be unnecessary but I think this methods is better than looping through the DOM (but that's personal opinion and also a bit of measure)
          //inDesign.jsx
          #targetengine "xmlChanges"
          var main = function(){
          var evName = "onAfterSelectionChangedEvent",
          ev = app.eventListeners.itemByName (evName),
          db = {},
              externalObjectName = "PlugPlugExternalObject",
              mylib = new ExternalObject( "lib:" + externalObjectName ),
              eventObj = new CSXSEvent(),
          evHandler = function(evt) {
          var doc = app.properties.activeDocument, docId, docStr, xmlFile;
          if ( !doc ) {
          db = {};
          return;
          docId = doc.id;
          xmlFile = File ( Folder.temp+"/"+docId+".xml" );
          doc.exportFile ( ExportFormat.XML, xmlFile );
          if ( !xmlFile.exists ) return;
          if ( !xmlFile.open('r') ) return;
          docStr = XML ( xmlFile.read() );
          xmlFile.close();
          xmlFile.remove();
          if  ( !db[docId] ) {
          db[docId] = docStr;
                      eventObj.type="xmlChanged";
                      eventObj.data = "";
                      eventObj.dispatch();
          else {
          if ( docStr!= db[docId] ) {
                          eventObj.data = "Something changed !";
          db[docId] = docStr;
                      else {
                          eventObj.data = "Nothing new under the sun !";
              //="blahblah";
          if  ( !ev.isValid ) app.eventListeners.add("afterSelectionChanged",evHandler).name = evName;
          main();
          In main.js
          $(function() {
              var csInterface = new CSInterface();
              csInterface.addEventListener ( "xmlChanged", function(evt) {
                   $("#result").text ( evt.data );
          in html
           <body>
                <p>Listening at xml changes…</p>
                <p id="result"></p>
                <button onclick="window.location.reload()">RL</button>
            </body>
          And voilà :
          2 people found this helpful
          • 2. Re: detect xml structure changes in Indesign
            emiliep89320758 Level 1
            Thanks for you answer, it works well !
