apocalipsis19 wrote:
> Because I want to select images from anywhere in
> my network.
hmm... how do you expect <cfimage> to *guess* where
exactly it should
get the image from? :)
there's no way cf can 'guess' where myimage.gif is located -
that's what
the SOURCE attribute is for: to tell it where to fetch the
image from.
by default it will look in the same location the page with
<cfimage> tag
is located in. that's why SOURCE is a REQUIRED attribute.
or do you mean that your same codebase on different servers
should be
accessing a different, server-specific, images location?
you could set an application-scope var...
or maybe better just create a cf mapping to the location of
your images...
and use that as SOURCE value
sorry if i still have guessed your question wrong - maybe you
should try
to explain your network setup and how and where your
application runs a
bit more...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
