Dear All,
After finish remix the Backsound Audio (to shorten the duration) in Audition CC 2018 then would Export To Premiere Pro (export back) it didn't worked No Pop Up Dialog Box "Copy Audition Track" as a new "Audio Track", then nothing happen in Premiere Pro CC 2018.
I have also rename Adobedynamiclink under apps\roaming\adobe to Adobedynamiclinkold, it seem didn't worked, and also try to use under File>Export>Export to Adobe Premiere Pro, however when use Export to Media Encoder it work.
Please advise to solve it.
Thanks & B/regards,
Hi there handjojot,
Sorry for the error. Does the same thing occur if you do not use the Remix function?
Kevin
Dear Kevin,
Yes I use Remix due to I would shorten the length of the backsound for fit my sequence, I think it shoul be no problem as I have saw in Adobe online tutorial can use the Dynamic Link to re-export to Premiere Pro.
I hope this issue can solve it.
I just make a trial not use Remix only Graphic Equalizer, same problem, nothing happen, the Dialog Box of Copy Audition Track didn't appeared only blue turning wheel cursor when export back to Premiere Pro.
Please see attached video.
B/REGARDS,
Dear Kevin,
I'm looking forward to solve The Dynamic Link export & import from Premiere Pro to Audition, please reply my above information.
Thanks & B/regards,
Hi handjojot,
I hope I can get a response for you soon. Sorry for the delay.
Kevin
Between this problem and the color panel crashing, I am becoming a frustrated editor! I hope Adobe can get a fix in place soon!
Thanks for your sharing too, please be patient as the developer/engineer working on it, and soon available CC will release the patch.
Cheers
