Tips for Colour Correcting Apple ProRes Footage
Jun 11, 2018 Jun 11, 2018
I've been given RAW Apple ProRes footage to edit. The colour looks awful. Any tips on how best to edit it?
The background is really bright - it looks over-exposed. And there is a fluorescent purple outline around the subject, the interviewee. (see purple line around his hair and arm)
Here's a screesnhot:
Rachel
4.2K
Community Expert , Jun 13, 2018 Jun 13, 2018
Hi Rachel - Glad you got the correct video info from your client. Here are two things that might help remove the purple and brightness of the image.
(1) Try applying the "Change to Color" effect from Premiere pro to the clip and changing it to a neutral white or gray to blend with the background. Make sure to enable "Hue & Saturation". Here is a screenshot of the effect.
(2) You can follow this advanced premiere pro color correction tutorial to use the luma curves and lumetri scopes to help redu
I'm not familiar with that media but if it's a RAW format, click on a clip in a project panel bin, go to the Effects panel, and see if there's a Master clip tab on it ... and that would be where you'd make the beginning adjustments. It is with say Red media, which I work with occasionally.
Neil
Jun 12, 2018 Jun 12, 2018
Thank you for the tip! Do you generally make the adjustments on the master clip and then copy and paste the attributes? I just have three .mov files (one for each of the three interviews).
The purple outline is a Chromatic Aberration, here is something useful from The Beat (After Effects) :
https://www.premiumbeat.com/blog/how-to-remove-chromatic-aberration-in-after-effects/
I haven't tried it before, but maybe working with the Channels or Color Correction inside Premiere
might work for some cases, concerning Chromatic Aberrations.
From my experience with over exposed background, lowering the Highlights worked in some cases,
starting with the basic properties and going on. I guess this footage will require some dedicated time
to fix it, especially if nothing works you will have to go for rotoscoping in After Effects to remove the
chromatic aberrations ...
Thank you for the link and tips!
As soon as I saw the footage I thought it looked iffy and emailed the videographers saying:
"All sounds good but the image looks off. Here’s stills from the three .mov files I received. Does the colour/lighting in these look right to you? There’s a purple outline around each interviewee. Just making sure I have all of the necessary files. Thank you!"
And they replied:
"the footage looks good to us — it’s raw, of course, and we tend to employ color balancing and correcting frequently on raw footage. Please let us know if we can provide anything else."
From your responses, it sounds like they could have avoided this extra editing during the shoot by avoiding such a bright background and using a different lens. I wasn't sure if this was the way the footage should look before colour correcting (as I'm not an expert with RAW footage) but it seems like the videographers were in error. What do you think? Should we be avoiding them for future video shoots?
To the best of my knowledge, only FCP X can handle ProRes RAW at this point in time, so it's likely you've got vanilla ProRes, in which case those highlights are probably gone for good.
The purple fringing is also likely not something you'll be able to correct for in post.  That's a lens issue that normally get's handled when shooting by using a better lens.
Do you think Final Cut would be easier for colour editing this footage than Premiere Pro and After Effects. The files I was given are .movs. I don't know what camera they're from. I was just told that it's RAW Apple ProRes footage.
I think the tools may vary, but the results probably won't.
If you've got them in PP, I'm skeptical they're ProRes RAW.  It's likely you were given false data.
Mentor ,
I don't see (from screenshot) a fluorescent purple outline. I just see a blown out background. Don't see no purple stuff around head or arm.
Maybe it's hard to see in the screenshots but there's definitely purple there.
Here's some close-ups:
Ok thanks. I'll stick with Premiere Pro.
The latest info I've been given is: "The footage was shot on a Canon C300, and the video files are Apple Pro Res."
So I don't think they are 'ProRes RAW'
No, this is not ProRes RAW. This is vanilla ProRes so it was a confusion between the both.
Personally i would have asked for the original footage from the camera instead of transcoded footage. (Maybe they have used a recorder that records to ProRes such as an Atomos, so it may not be possible...)
You can remove the purple fringe. I have not tested it but start here: https://www.google.com/search?q=removing+fringe+in+premiere+pro
/Roger
Great, thank you!
At first they gave me the original footage but they were no video files. I don’t know if it was them or my employee but somewhere along the way the video files disappeared from the folders and they were just giving me .xml and .jpgs. I think the files weren’t fully copied over.
After a bit of back and forth they gave me the Apple Pro Res (.mov) files because they were having trouble uploading the original files online to send to me.
(2) You can follow this advanced premiere pro color correction tutorial to use the luma curves and lumetri scopes to help reduce brightness and improve contrast.
Thanks a million! This is great Thanks everyone for all the helpful tips!
The change to colour worked really well. Thank you!
Here are the results:
(I'll need to darken the edge of his head but the white looks better than purple!)
That's awesome to see!
This works well but I'll need to use masks too. The purple around the head and shoulder was a quick fix but removing purple from the hands and side of face is a bigger job because there are some pinky purple highlights in the background.
You can try to use the Change to Color effect for the chromatic aberration.
The green is visible in the background.
Old but might still do the trick.
Its AE but also applicable for Pr.
CreativeCOW
Seems to me that there is some confusing going on. Some people tend to call footage from the camera as raw even if the footage itself is not RAW. I have seen this before. There is a difference between RAW footage and footage called raw taken directly out of a camera that is not even capable of shooting true RAW.
They use the word raw frequently in the answer you got. My interpretation is that they call any footage from a any camera raw. It´s the same we saw 15 years ago, when people frequently called DV for uncompressed. DV and uncompressed are two complete different animals, the same goes for RAW and raw.
Point is, ask them for full specifications, whatspecific camera did they use to determine what the footage is, iow RAW or "raw".
Let us know the outcome.
Thanks for the tip. I’ll ask them to specify. I was afraid of accusing them of giving me ‘overexposed’ footage with an ‘unnecessary amount of colour correcting because of the Chromatic Aberrations’ in case my lack of editing knowledge is the problem and not their filming skills.
I agree with Averdahl ... get precise camera/media data from the videographers.
This is something that many 'shooters' seem to skip, and can be so helpful in post with folks that of course have no clue what the media is that plops onto their desk. As someone who's been a stills photographer for a living and added video work a number of years back, including some jobs for others, knowing the media for either stills or video can save you a ton of time.
It's something that I know a few colorists have listed in their send-out to anyone giving them jobs ... a listing of all media used in the project, cameras/formats/codec specifically used. Not a bad idea.
Neil
I asked:
"What camera was this footage shot on and in what format was the footage captured? Was any of it compressed before I received the files?"
They replied:
So now they're not referring to it as raw?
Engaged ,
Make a Color Grading in a Gradinding Tool like DaVinci Resolve or Baselight.
This tools have a very good Debayering
and a good workflow for a nice Grading
Thanks Waldorf! I don’t think I’ll have time to learn a new program but if I’m not getting good enough results in Premiere Pro or After Effects I’ll definitely try out one of them!
Do you agree that background is overexposed and the interviewee is fading into the background? Or is it just me? I don’t want to complain about the videographers if this footage is just not aesthetically pleasing to me but looks ok to others! The Chromatic Aberration definitely seems to be something the videographers should have avoided during the shoot though.
