4 Replies Latest reply on Jun 12, 2018 5:19 AM by manuelb27477138
    Multiples Find Replaces with TRY CATCH errors in alert and console
    manuelb27477138 Level 1
      Hello!
      In my script I find and replaces many words:
          replaceTextUsingFIND ("Article 1.", "Article ONE");
          replaceTextUsingFIND ("Article 2.", "Article TWO");
          replaceTextUsingFIND ("Article 3.", "Article THREE");
          replaceTextUsingFIND ("Article 4.", "Article FOUR");
          function replaceTextUsingFIND (input, output)
              app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
              app.findTextPreferences.findWhat = input;
              app.changeTextPreferences.changeTo = output;
              app.activeDocument.changeText();
      This is my document:
      In this case, the words Article 2. and Article 4. do not exist, then I need to get one alert per each word.
      Is possible get the errors by alert and in the Javascript console? I try with try/catch but didn't work
      Thanks for help me!
        • 1. Re: Multiples Find Replaces with TRY CATCH errors in alert and console
          BarlaeDC Adobe Community Professional
          HI,
          It is not possible to get errors as such, as no error is thrown if the find doesn't find anything, but you can catch that the find didn't find anything.
          if you change the following line
          to
          var changedResults = app.activeDocument.changeText();
          Then you can check the length of changedResults to see if anything was changed something like
          if ( changedResults === 0)
               // I have put it into a alert, but you could put it to the console.
               alert ( "No results for " + input);
          Hpoe this helps
          Malcolm
          1 person found this helpful
          • 2. Re: Multiples Find Replaces with TRY CATCH errors in alert and console
            Hi Malcolm!
            I needed a change in the if conditional this === to ==
            And now is working!
            Here is the final Script:
            Download files
                    if ( changedResults == 0)  {
            Thanks so much!
            • 3. Re: Multiples Find Replaces with TRY CATCH errors in alert and console
              The === matches type as well as value, == just matches value.
              I think this is because I missed out the .length inside the if, so it should look like this
              if ( changedResults.length === 0)
              but as long as it is working which is the main thing.
              Regards
              Malcolm
              • 4. Re: Multiples Find Replaces with TRY CATCH errors in alert and console
                You true, I change and also is working.
                Thanks a lot for your continuos help
                    if ( changedResults.length === 0)  {
