I'm using Acrobat Pro XI to convert a large Visio document into a PDF. In the Visio document, I am using semi-transparent rectangle objects, which are all assigned to various layers, to create a switchable "highlighting" of signal flows. The highlighting layers each appear with a checkbox in the resulting PDF layer selector. When the PDF layers are switched off in the resulting PDF, everything looks great. When a highlighting layer is switched on in the PDF, the highlighting appears, but all the graphic objects, text and lines that are seen though it get blocky and blurry. It's kind of like an anti-alias gone very bad. The larger the Visio document is (in size) the worse the effect becomes. If I place the highlighting layer behind the all the other objects in the Visio drawing, then there is no bluing/blocking in the PDF, but that doesn't work for what I need to do. Any help is very much appreciated! Everything looks perfect in Visio itself. Any help is GREATLY appreciated!
Hi Everyone.... Here's what it looks like. Thanks!
Hello daveb13946958,
I've run across similar problems, did you find a solution yet?
Regards, Coen
Hello Coenv****
Thanks for chiming in with your confirming experience too! I regret that I am still struggling with this transparency-bluring issue. I'm still hoping someone for the community or a representative from Adobe themselves will jump-in and help us out! Best regards to everyone!
I've found out that, while using a rectangle you get the blurring issues. If you use a thick line, you get blocks in front of your text. it's still useless for me, but at least its different.
Highlight as seen in visio
Highlight as seen in Adobe Acrobat Pro
