I have a document with several dozen images in it. They are all in exactly the right place - but they are all unanchored. Now I need to make some text edits, and before I do, I have to anchor all these images to the line of text before them. Is there a quick way to do that?
This will make the object into an Anchored object position in it's original position.
See screenshot below.
Previously mysterious blue square!!!
Thanks so much.
You're quite welcome!
What is its official name, the mysterious blue box?
It's officially the Anchored Object Control. You can turn it off and on by choosing View > Extras > Show/Hide Anchored Object Control.
Incidentally, it's not always blue. That's only because the default layer color of Layer 1 is blue. If you have a different layer color the selection color and the Anchored Object Control take on that color as shown below:
Good point Steve!
Jeff, another question about the MBB, if I may: what controls whether a newly-placed image is automatically anchored or not?
When you choose File > Place with your text cursor (Type Tool) inserted within existing text, the placed object (e.g., image or graphic) will automatically be anchored (inline). Conversely, if you choose File > Place with your text cursor or any other tool not inserted into existing text, the placed object will be unanchored. Try it yourself to see.
Hi Marie,
Not sure I understand.
Objects are never Anchored automatically.
If, however, you Place an image into a previously Anchored Graphic Frame, this content will be part of an object that is still Anchored.
Not sure if this answers your question.
Best,
Jeff
Thanks for that Steve! And thank you Jeff - it will still be the MBB to me.
Hi Marie,
also note if you want to un-anchor an anchored object with Cut/Paste In Place the pasted object will not be pasted in the same position as it was when anchored! Not so when using the menu command to un-anchor it.
Uwe
After reading Scotts answer, I think I understand your question. In other words, read Scott's answer.
