SOLVED
Regex help in Classification Rule Builder
Avatar
Level 2
Hello,
I am trying to create site sections in Adobe Analytics. I already have the page in this format test: testa: testb: testc:testd
The url can vary from test: testa: testb: testc:testd to testa: testb: testc to testa: testb to test.
My current regex formula only works for test: testa: testb: testc:testd and none of the shorter pages.
This is the current formula I am using and its proving to not be of use because shorter urls are not being identified for classification.
Do you have a recommendation on how to create a dynamic formula?
Tim
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
i use a solution similar pabloc82923542​ suggested and it works perfect.
within the ruleset define the following rules:
^([^\:]*)     sitesection1 is $1
^([^\:]*)\:([^\:]*)     sitesection2 is $2
^([^\:]*)\:([^\:]*)\:([^\:]*)     sitesection3 is $3
i hope i wrote it right for the first levels. if yes, those rules should put the right values in the corresponding classifications. just add more rules if you need more levels.
please let us know if those rule work!
regards
Avatar
Community Advisor
Not sure which variable you are trying to segment but have you thought of using SAINT upload to designate each one and then just do correlated reports as needed? Are you creating alot of new URLs regularly?
If not have you tried to add space designation?
\s
^(.+)\:(.+)\:(.+)\s\s
for 2 spaces etc
Avatar
Level 2
Hello,
Thanks for responding.
          This is for page formatting for site section. I want to establish Site Section 1, Site Section 2, Site Section 3, Site Section 4.
          The current issue is that since I formatted every / as a : I am trying to use : as a delimiter to build all 4 sections.
When I use ^(.+)\:(.+)\:(.+)\:(.+)\:(.+) it only accepts urls with multiple delimiters rather than if its a short url with one or 2 delimiters.
I would like to make a formula that accepts 1,2,3, or 4 delimiters. Let me know if that is helpful.
Avatar
Community Advisor
ok i think this may help you
Regular Expressions in Classification Rules
1,2,3,4 examples per each line:
^(.+)\:$     output is $0
^(.+)\:(.+)\:$     output is $1
^(.+)\:(.+)\:(.+)$     output is $2
^(.+)\:(.+)\:(.+)\:(.+)$     output is $3
bear in mid then each output has to be defined as well
A
$0: em:JuneSale:20130601
B
$1: em
C
$1: em
$2: JuneSale
D
$1: em
$2: JuneSale
$3: 20130601
Avatar
Level 2
Hello,
Yes I have read through the documentation.
If I use this formula ^(.+)\:(.+)\:(.+)\:(.+)$ I will only catch a url such as  test: test: test: test
It will not read a url as  test: test: test.
My issue is that the formula isnt dynamic enough for my use case.
Avatar
Level 1
I also seem to be having this same or similar issues
Avatar
Community Advisor
If you do theses:
test: test: test
test: test
Avatar
Level 2
This would not work based on my prior testing. If urls are two different delimiter lengths it would throw off the result.
Avatar
Correct answer by
Community Advisor
regards
Avatar
Level 2
Appreciate it @ursbuller it worked!
