clipping mask problem
Contributor ,
Jun 12, 2018 Jun 12, 2018
Hello
I downloaded this frame from freepik.com and i want to make clipping mask with it to put an image inside this frame
I tried too much but i can't
what can i do ??
843
Community Expert , Jun 13, 2018 Jun 13, 2018
Romeo,
One way to go about the suggestion from Peter without drawing is as follows, obviously working on a copy, leaving the original for the actual frame:
1) Select the whole structure of frame paths (or those that are to form the Clipping Mask), then Ctrl/Cmd+C+B to copy it behind the original frame structure, then (Ctrl/Cmd+G to Ungroup if Grouped and delete the unwanted bits and) Ctrl/Cmd+G to Group, then hide the original frame structure;
2) Object>Path>Offset Path by a positive amount suffici
Adobe
Contributor ,
Any help !!
Contributor ,
Thanks for your reply
Is drawing clipping path is the only solution for this ?!
is there any other solution without drawing ... for example by using pathfinder or anything else
Guide ,
Perhaps make a copy of it, ungroup, delete the extremities,
select all and use the ShapeBuilder tool, with a large gap detection set,( double click on the tool for options)
Then if needed use the blob brush to fill any gaps.
Next  Pathfinder > Unite
And  use as a clipping mask on  the image
Lastly paste the original on top ie
Edit > Paste in Front
Contributor ,
I tried to do these steps accurately but failed .... there is no path in the middle of the fame where i make the clipping mask with it ... i need a solution without drawing
Thanks for your reply bro
Why do you need a solution without drawing? Drawing a path would be the simplest and probably quickest way to do this.
Contributor ,
Because i'm not good enough in using pen tool to draw the path accurately
So this is the perfect opportunity to improve. Look closely at tromboniator's example. This isn't that difficult to do if you just take your time, concentrate, and follow the pieces of the frame. (Lock the frame's layer and work on a layer above or below.)
You really only need to do one side and either the top or the bottom, then duplicate, flip and join them. Plus, you can make as many adjustments as it takes to get it right after drawing. I'd guess tromboniator did it in just a few minutes. You won't do it that quickly, but it won't take all day either.
Yep, think in terms of shapes. And the great thing is that everything is editable—you're not drawing with a permanent marker! So you can learn, tweak, fail, tweak, and get better. Sometimes there just isn't a magic button for everything, you know?
Romeo,
2) Object>Path>Offset Path by a positive amount sufficient to close all gaps within the frame path structure;
3) Pathfinder>Unite or Merge;
4) Object>Path>Offset Path by the same amount as in 2), only negative;
5) Select the path from 4) and the image to be clipped and Ctrl/Cmd+7;
6) Show the original frame structure hidden in 2).
This should give you the exact shape desired.
Edit: I started on this post before posts #8&9 were, well, posted.
