Hello there,
I am trying to distort one part of a rectangle while keeping the part beyond the row unchanged.
The first picture is my attempt at distorting the rectangle. The second is from a tutorial where the teacher has no issues throughout the process. Nothing beyond the teachers row moves while he is distorting the shape to fit the curve.
Thank you.
he uses the mesh to sub divide the envelope shape then watch how he drops the vertices down further (not the default sub divide) then he only edits the bezier handles for the lower portion that is bent.... any art contained inside the envlope shape is going to try to conform to its shape (when the bottom 'bends' it to bends... the top part literally has no curve so it doesn't)
play with AL the handles -- you see how they affect each other... when I pulled most of them in closer to the vertex pint
...Copy link to clipboard
Maybe sub-divide your blue shape some more... might even out the bends and get rid of the distortion.
I can't too much more from the images
Thank you but this is the same layout the person in the tutorial is using and he gets no distortion on the vertical lines. There has to be something that he is doing in the settings to make this work correctly.
Here is a link to the tutorial.
In that case: why don't you ask that person?
Could you please provide a screenshot of your Layers panel, with all shapes disclosed?
Thank you.
OK. I withdraw my question in #5.
Have just glimpsed into that video and saw what this guy wants to build. Now why do you you even use envelopes for that?
It can be cleanly built without them.
You need this:
Which is really just some quarter circles attached to some lines and then duplicated.
Then you use the live paint tool to get this:
Will take you about 5 minutes to build.
The hardest part is to not get lost in the stripes with the live paint tool.
kind of crazy they go to all that effort wrestling with meshes when they've drawn most of what they need in the first 90 seconds. i can only assume its in some attempt to teach meshes and symbols at the same time.
I don't think so.
I rather assume it's because they don't know the live paint tool.
This is great and will have to try it. Thank you!
I would still like to get to the bottom of my original question and know how that guy is able to distort the shape only above or below the row.
Note: I have asked the guy who made the vid but he does not reply. Doesn't seem to reply on any of his videos.
Can you perhaps upload your file?
What is the Object > Envelope Distort > Envelope Options > Fidelity settings?
play with AL the handles -- you see how they affect each other... when I pulled most of them in closer to the vertex pint seemed to dull the bump.Notice the ones that are horizontal... mess with those. and then mess with the vertical handles to get what you want. Tutorials are just starting points, you gotta play with settings until it is right for your file. Experiment
If you subdivide it one more time than the tut did... gives more control... see below.
You are awesome!
