how can i use the color library - to be save in a new folder under one name for one client, which i can open and bring it for any new project?
You can create a new library in the CC library for the swatches. You can even invite your client to it so that they can use it as well.
For the Illustrator library, please read: How to use and create swatches in Illustrator
You can also just create a new document and then go to Swatches Libraries > Other library and load an AI document that contains the swatches you want to use.
Or you can create an Illustrator template file that contains your swatches.
Or you can create a New document Profile that
...Copy link to clipboard
Which color library are you referring to?
- the CC library?
- an Illustrator swatches library?
- the swatches in the swatches panel of your document?
yes
yes
both, in library and in swatches
i have client that have the same specific swatches on all projects, and i need the option to upload/place/bring it each time to a new page/project
Or you can create a New document Profile that contains your swatches. Startup Profiles – A Great tool to Customize your New Documents « Adobe Illustrator blog (folders have different versions numbers now, but it still works exactly as described there)
the firt liks wast very helpful, let me explain:
when ever i open new doc and star working it is automatically opens a library, and save all vector files and new swatches there.
hoe can i now make oa order?
to have folders with the swatches/object i will choose.
i now have it all together, even from other project/client.
how can i open new library, give it a new name, put all in it, and have it for other time/projects ready?
Which library? Please show screenshots if you can't describe it.
Also: as many others in this forum I am not a native English speaker. If you check your spelling before posting, it will help everyone understand. Thank you.
