Hey guys,
question. i have a really big layout that has lots of "P" values. see screenshots below. How do i tell indesign to apply italics to all of the "P" it find before a "<" or ">" or "="?
Jonathan
Ah, for initial code to work your P must be uppercase - true, not with All Caps applied...
That's must be the case.
So, try to add case-insensitive ON/OFF:
(?i)\bP(?=[<>=])(?-i)
Well, you could start with this, and see how it works for you. Tested as a paragraph style option.
\bP(?=[<>=])
P(<|>|=)(\d+\.\d+|\d+)
This one only finds
P=1.234
P<1.234
P>1.234
P=1
P<1
P>1
this apply italic to the entire thing. i just want to apply italic to the "P"
did not worked
It does for me. Are you sure there is nothing unexpected between that P and the next character? And that you actually have applied this style to that paragraph?
i don't know what i am doing wrong.
Create a new text frame. Fill it with placeholder text. Type "P<0.01" somewhere inside. Then add this GREP style using the Paragraph panel menu to its containing paragraph only. That should work, right?
There could be an invisibly-thin or other code character in your original text. Typing it a-fresh will make sure the GREP Style works as intended.
Thank You, Jongware!
@Jonathan:
and if your test will pass it possibly indeed means the 'unexpected characters' in your text.
Then you can try to catch and eliminate them using this grep:
Find:
\bP.([<>=])
Change to:
P$1
Or just include that character in the initial code...
did a an empty text frame, applied the style. nothing. see below.
still does not work:
this one worked!!
would it help to share the file? i might be making a mistake with setting up the styles? if it works for you guys than it must be something i am doing wrong in the styles.
