3 返信 最新の回答 日時: Jun 13, 2018 8:27 AM ユーザー:直道羽21149169
    Illustrator CS6をAdobe Creative Cloudでアップデート失敗
    直道羽21149169 Level 1
      Illustrator CS6をAdobe Creative Cloudでアップデートしようとしても失敗してしまいます。対策を教えて頂けると助かります。
      Illustrator CS6のバージョンは16.0.4
      Adobe Creative Cloudのバージョンは 4.5.0.331
      OSはMac OS 10.13.4
      長くなりますが、以下がインストールログです。宜しくお願い致します。
      06/13/18 19:38:06:856 | [INFO] |  | OOBE | DE |  |  |  | 368257 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      06/13/18 19:38:06:856 | [INFO] |  | OOBE | DE |  |  |  | 368257 | START - Installer Session
      06/13/18 19:38:06:856 | [INFO] |  | OOBE | DE |  |  |  | 368257 | RIBS version: 11.0.0.11
      06/13/18 19:38:06:860 | [INFO] |  | OOBE | DE |  |  |  | 368257 | OSX version: 10.13.4
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ::START TIMER:: [Total Timer]
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | CHECK: Single instance running
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | CHECK : Credentials
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Load Deployment File
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | deploymentFile option not given
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | CHECK : Another Native OS installer already running
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Create Required Folders
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Assuming install mode
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Looking up install source path
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Sync Media DB ...
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ::START TIMER:: [Sync Media DB]
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Pre check media db sync
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | End of Pre check media db sync. Exit code: 0
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | :: END TIMER :: [Sync Media DB] took 264 milliseconds (0.264 seconds) DTR = 6378.79 KBPS (6.22929 MBPS)
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ready to initialize session to start with ...
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ::START TIMER:: [CreatePayloadSession]
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updated source path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7
      06/13/18 19:38:06:861 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {01B28172-9762-4081-B989-9EC12711D222}
      06/13/18 19:38:06:863 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:863 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:863 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16it_ITLanguagePack-161112181557/AdobeIllustrator16it_ITLanguagePack-1611121 81557.dmg
      06/13/18 19:38:06:863 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {03857558-D073-4441-8087-D23F41A6C365}
      06/13/18 19:38:06:866 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:867 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:867 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16en_GBLanguagePack-161112175918/AdobeIllustrator16en_GBLanguagePack-1611121 75918.dmg
      06/13/18 19:38:06:867 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {0C854632-12B3-479F-AFBE-67DC8E5542F2}
      06/13/18 19:38:06:869 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:870 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:870 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16uk_UALanguagePack-161112184007/AdobeIllustrator16uk_UALanguagePack-1611121 84007.dmg
      06/13/18 19:38:06:870 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {101F331A-355F-4CE4-B2B9-2E787EDF2C65}
      06/13/18 19:38:06:870 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:871 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16-mul-250113182442/AdobeIllustrator16-mul-250113182442.dmg
      06/13/18 19:38:06:871 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {15B9ED58-83C6-43FC-9C88-4D4560B29610}
      06/13/18 19:38:06:871 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:871 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:871 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16en_AELanguagePack-161112184208/AdobeIllustrator16en_AELanguagePack-1611121 84208.dmg
      06/13/18 19:38:06:871 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {1C77542D-0868-41C1-BFFD-F0F451BE1A2B}
      06/13/18 19:38:06:879 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:879 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:879 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16fi_FILanguagePack-161112181354/AdobeIllustrator16fi_FILanguagePack-1611121 81354.dmg
      06/13/18 19:38:06:879 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {2E3271FA-2778-41C0-A661-6960E17CFBB8}
      06/13/18 19:38:06:880 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:880 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:880 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16fr_FRLanguagePack-161112180334/AdobeIllustrator16fr_FRLanguagePack-1611121 80334.dmg
      06/13/18 19:38:06:880 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {412EBE1D-A277-47B0-9FD1-1A4ECB63F8F8}
      06/13/18 19:38:06:881 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:881 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:881 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16zh_CNLanguagePack-161112182559/AdobeIllustrator16zh_CNLanguagePack-1611121 82559.dmg
      06/13/18 19:38:06:881 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {4ADE0E5A-EE37-4316-9E4E-D139B31088FC}
      06/13/18 19:38:06:882 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:882 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:882 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16tr_TRLanguagePack-161112183804/AdobeIllustrator16tr_TRLanguagePack-1611121 83804.dmg
      06/13/18 19:38:06:882 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {54B0832C-A440-49A3-ADDD-D7B80FAA54A9}
      06/13/18 19:38:06:885 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:885 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:885 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16ko_KRLanguagePack-161112182401/AdobeIllustrator16ko_KRLanguagePack-1611121 82401.dmg
      06/13/18 19:38:06:886 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {5B4B29A2-FF6E-4C85-800E-3F5C50E4C702}
      06/13/18 19:38:06:887 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:888 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:888 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16fr_MALanguagePack-161112184609/AdobeIllustrator16fr_MALanguagePack-1611121 84609.dmg
      06/13/18 19:38:06:888 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {6EFE3961-43F5-4564-B124-25539038DCC3}
      06/13/18 19:38:06:889 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:889 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:889 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16cs_CZLanguagePack-161112182955/AdobeIllustrator16cs_CZLanguagePack-1611121 82955.dmg
      06/13/18 19:38:06:890 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {897BEABB-B1C8-4B3C-ACDE-A3B32055F942}
      06/13/18 19:38:06:892 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:892 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:892 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16de_DELanguagePack-161112175713/AdobeIllustrator16de_DELanguagePack-1611121 75713.dmg
      06/13/18 19:38:06:892 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {8F02D14F-3A91-469D-BFBB-480C4529F6C3}
      06/13/18 19:38:06:894 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:894 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:894 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16es_ESLanguagePack-161112180950/AdobeIllustrator16es_ESLanguagePack-1611121 80950.dmg
      06/13/18 19:38:06:894 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {A4EA541C-2828-4489-9646-0962268FEC85}
      06/13/18 19:38:06:895 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:895 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:895 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16es_MXLanguagePack-161112181151/AdobeIllustrator16es_MXLanguagePack-1611121 81151.dmg
      06/13/18 19:38:06:895 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {BB1CF6FB-9227-4B85-B79E-FF587A834898}
      06/13/18 19:38:06:896 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:896 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:896 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16pl_PLLanguagePack-161112183358/AdobeIllustrator16pl_PLLanguagePack-1611121 83358.dmg
      06/13/18 19:38:06:896 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {C03C79F9-0373-4CB9-97DD-9F26DFC18B2A}
      06/13/18 19:38:06:898 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:898 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:898 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16hu_HULanguagePack-161112183155/AdobeIllustrator16hu_HULanguagePack-1611121 83155.dmg
      06/13/18 19:38:06:899 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {C3DE41A0-6B11-4390-8054-906530857719}
      06/13/18 19:38:06:901 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:902 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:902 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16en_ILLanguagePack-161112184408/AdobeIllustrator16en_ILLanguagePack-1611121 84408.dmg
      06/13/18 19:38:06:902 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {C65F5762-6887-455F-AE43-85CDAE9FC9E5}
      06/13/18 19:38:06:903 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:903 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:903 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16da_DKLanguagePack-161112180745/AdobeIllustrator16da_DKLanguagePack-1611121 80745.dmg
      06/13/18 19:38:06:903 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {C9090F4B-EE70-44C5-AA19-A559D2BB5A55}
      06/13/18 19:38:06:904 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:904 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:904 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16ja_JPLanguagePack-161112180545/AdobeIllustrator16ja_JPLanguagePack-1611121 80545.dmg
      06/13/18 19:38:06:904 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {CB6C00C6-AA00-436B-9B86-59D2876970B8}
      06/13/18 19:38:06:905 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:905 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:905 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16nl_NLLanguagePack-161112181758/AdobeIllustrator16nl_NLLanguagePack-1611121 81758.dmg
      06/13/18 19:38:06:905 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {CF3301F8-A60A-45CC-BE32-6BDB7F42BF30}
      06/13/18 19:38:06:905 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16fr_CALanguagePack-161112180121/AdobeIllustrator16fr_CALanguagePack-1611121 80121.dmg
      06/13/18 19:38:06:905 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {D12BF815-D8A8-4C55-B4B8-9BBEA831C272}
      06/13/18 19:38:06:906 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:906 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:906 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16zh_TWLanguagePack-161112182756/AdobeIllustrator16zh_TWLanguagePack-1611121 82756.dmg
      06/13/18 19:38:06:906 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {DD3C4D0B-F415-42FC-AE04-7574E86FC538}
      06/13/18 19:38:06:907 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:907 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:907 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16pt_BRLanguagePack-161112182000/AdobeIllustrator16pt_BRLanguagePack-1611121 82000.dmg
      06/13/18 19:38:06:907 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {EC878F2E-0C17-48D7-BB7D-9735ED157759}
      06/13/18 19:38:06:907 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16sv_SELanguagePack-161112182203/AdobeIllustrator16sv_SELanguagePack-1611121 82203.dmg
      06/13/18 19:38:06:908 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Updating media info for: {F64C00DE-E734-4694-810D-BD3A392BACE4}
      06/13/18 19:38:06:908 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Ignoring original data since install source is local
      06/13/18 19:38:06:908 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Type: 0, Volume Order: 1, Media Name: Adobe Illustrator CS6
      06/13/18 19:38:06:908 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Path: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7/payloads/Ad obeIllustrator16ru_RULanguagePack-161112183600/AdobeIllustrator16ru_RULanguagePack-1611121 83600.dmg
      06/13/18 19:38:06:908 | [INFO] |  | OOBE | DE |  |  |  | 368257 | --------------------  END  - Updating Media Sources -  END  --------------------
      06/13/18 19:38:06:928 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Supported RIBS version range: [0.0.0.0,11.0.0.11]
      06/13/18 19:38:06:929 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ----------------- CreatePayloadSession: machine is x86 ---------------
      06/13/18 19:38:07:367 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ______ Verify Dependency Subscribers ______
      06/13/18 19:38:07:367 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16it_ITLanguagePack 16.0.3.0 {01B28172-9762-4081-B989-9EC12711D222} requires a parent with following specification:
      06/13/18 19:38:07:368 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:368 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16it_ITLanguagePack
      06/13/18 19:38:07:368 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:368 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:369 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:369 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16en_GBLanguagePack 16.0.3.0 {03857558-D073-4441-8087-D23F41A6C365} requires a parent with following specification:
      06/13/18 19:38:07:369 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:369 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16en_GBLanguagePack
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16uk_UALanguagePack 16.0.3.0 {0C854632-12B3-479F-AFBE-67DC8E5542F2} requires a parent with following specification:
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16uk_UALanguagePack
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16en_AELanguagePack 16.0.3.0 {15B9ED58-83C6-43FC-9C88-4D4560B29610} requires a parent with following specification:
      06/13/18 19:38:07:370 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16en_AELanguagePack
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16fi_FILanguagePack 16.0.3.0 {1C77542D-0868-41C1-BFFD-F0F451BE1A2B} requires a parent with following specification:
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16fi_FILanguagePack
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16fr_FRLanguagePack 16.0.3.0 {2E3271FA-2778-41C0-A661-6960E17CFBB8} requires a parent with following specification:
      06/13/18 19:38:07:371 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16fr_FRLanguagePack
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16zh_CNLanguagePack 16.0.3.0 {412EBE1D-A277-47B0-9FD1-1A4ECB63F8F8} requires a parent with following specification:
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16zh_CNLanguagePack
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16tr_TRLanguagePack 16.0.3.0 {4ADE0E5A-EE37-4316-9E4E-D139B31088FC} requires a parent with following specification:
      06/13/18 19:38:07:378 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16tr_TRLanguagePack
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ko_KRLanguagePack 16.0.3.0 {54B0832C-A440-49A3-ADDD-D7B80FAA54A9} requires a parent with following specification:
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16ko_KRLanguagePack
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16fr_MALanguagePack 16.0.3.0 {5B4B29A2-FF6E-4C85-800E-3F5C50E4C702} requires a parent with following specification:
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16fr_MALanguagePack
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16cs_CZLanguagePack 16.0.3.0 {6EFE3961-43F5-4564-B124-25539038DCC3} requires a parent with following specification:
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16cs_CZLanguagePack
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16de_DELanguagePack 16.0.3.0 {897BEABB-B1C8-4B3C-ACDE-A3B32055F942} requires a parent with following specification:
      06/13/18 19:38:07:379 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16de_DELanguagePack
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16es_ESLanguagePack 16.0.3.0 {8F02D14F-3A91-469D-BFBB-480C4529F6C3} requires a parent with following specification:
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16es_ESLanguagePack
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16es_MXLanguagePack 16.0.3.0 {A4EA541C-2828-4489-9646-0962268FEC85} requires a parent with following specification:
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16es_MXLanguagePack
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16pl_PLLanguagePack 16.0.3.0 {BB1CF6FB-9227-4B85-B79E-FF587A834898} requires a parent with following specification:
      06/13/18 19:38:07:380 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16pl_PLLanguagePack
      06/13/18 19:38:07:381 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:381 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:381 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:381 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16hu_HULanguagePack 16.0.3.0 {C03C79F9-0373-4CB9-97DD-9F26DFC18B2A} requires a parent with following specification:
      06/13/18 19:38:07:381 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:381 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16hu_HULanguagePack
      06/13/18 19:38:07:382 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:382 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:382 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16en_ILLanguagePack 16.0.3.0 {C3DE41A0-6B11-4390-8054-906530857719} requires a parent with following specification:
      06/13/18 19:38:07:383 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:383 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16en_ILLanguagePack
      06/13/18 19:38:07:383 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:384 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:384 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:384 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16da_DKLanguagePack 16.0.3.0 {C65F5762-6887-455F-AE43-85CDAE9FC9E5} requires a parent with following specification:
      06/13/18 19:38:07:384 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16da_DKLanguagePack
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16nl_NLLanguagePack 16.0.3.0 {CB6C00C6-AA00-436B-9B86-59D2876970B8} requires a parent with following specification:
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16nl_NLLanguagePack
      06/13/18 19:38:07:385 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16fr_CALanguagePack 16.0.3.0 {CF3301F8-A60A-45CC-BE32-6BDB7F42BF30} requires a parent with following specification:
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16fr_CALanguagePack
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16zh_TWLanguagePack 16.0.3.0 {D12BF815-D8A8-4C55-B4B8-9BBEA831C272} requires a parent with following specification:
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16zh_TWLanguagePack
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16pt_BRLanguagePack 16.0.3.0 {DD3C4D0B-F415-42FC-AE04-7574E86FC538} requires a parent with following specification:
      06/13/18 19:38:07:386 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16pt_BRLanguagePack
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16sv_SELanguagePack 16.0.3.0 {EC878F2E-0C17-48D7-BB7D-9735ED157759} requires a parent with following specification:
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Family: Illustrator
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16sv_SELanguagePack
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | MinVersion: 0.0.0.0
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This parent relationship is not satisfied, because this payload is not present in this session.
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | This payload will be ignored in this session.
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | DW023: The extension payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ru_RULanguagePack 16.0.3.0 {F64C00DE-E734-4694-810D-BD3A392BACE4} requires a parent with following specification:
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ProductName: Adobe Illustrator CS6 Core_AdobeIllustrator16ru_RULanguagePack
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}: 0 (0,0)
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55}: 0 (0,0)
      06/13/18 19:38:07:387 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
      06/13/18 19:38:07:433 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Patch Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65} can be applied to product Adobe Illustrator CS6 Core 16.0.0.0 {AAF0D225-F129-40F2-916E-12E28DBD19ED}
      06/13/18 19:38:07:436 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Patch Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55} can be applied to product Adobe Illustrator CS6 Core_AdobeIllustrator16ja_JPLanguagePack 16.0.0.0 {A725EECB-379F-4432-A975-F2F120CBC6D1}
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Setting property "installSourcePath" to: /private/var/root/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.7
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Setting property "mode" to: silent
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Setting property "updateManifestPath" to: /Users/hatano/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeIllustrator16-mul/16.7/16.7.xml
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Setting property "workflow" to: updater
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Overwrite property "extensionsOnly" to: 1
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Overwrite property "mode" to: silent
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Overwrite property "patchesOnly" to: 1
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Overwrite property "updateManifestPath" to: /Users/hatano/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeIllustrator16-mul/16.7/16.7.xml
      06/13/18 19:38:07:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Overwrite property "workflow" to: updater
      06/13/18 19:38:07:604 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Found payload actions:
      06/13/18 19:38:07:604 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Deciding what installer mode to use...
      06/13/18 19:38:07:632 | [INFO] |  | OOBE | DE |  |  |  | 368257 | BEGIN Setting requested payload actions
      06/13/18 19:38:07:636 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Value returned on lookup of payload: Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65} is: false
      06/13/18 19:38:07:636 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Action string for Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}  is install
      06/13/18 19:38:07:637 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Value returned on lookup of payload: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55} is: true
      06/13/18 19:38:07:637 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Action string for Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55}  is install
      06/13/18 19:38:07:638 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END Setting requested payload actions
      06/13/18 19:38:07:681 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Collected advanced path check information for INSTALLDIR
      06/13/18 19:38:07:682 | [INFO] |  | OOBE | DE |  |  |  | 368257 | INSTALLDIR is a well-formed path
      06/13/18 19:38:07:682 | [INFO] |  | OOBE | DE |  |  |  | 368257 | INSTALLDIR is not the root path
      06/13/18 19:38:07:682 | [INFO] |  | OOBE | DE |  |  |  | 368257 | INSTALLDIR is on a local volume
      06/13/18 19:38:07:682 | [INFO] |  | OOBE | DE |  |  |  | 368257 | INSTALLDIR is on a writable volume
      06/13/18 19:38:07:682 | [INFO] |  | OOBE | DE |  |  |  | 368257 | INSTALLDIR is not on a case sensitive volume
      06/13/18 19:38:07:682 | [INFO] |  | OOBE | DE |  |  |  | 368257 | INSTALLDIR passed path basic path validation: /Applications
      06/13/18 19:38:07:761 | [INFO] |  | OOBE | DE |  |  |  | 368257 | BEGIN InstallOperationsQueue Unordered operations
      06/13/18 19:38:07:761 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}:  with operation install
      06/13/18 19:38:07:761 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55}:  with operation repair
      06/13/18 19:38:07:761 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END InstallOperationsQueue Unordered operations
      06/13/18 19:38:07:761 | [INFO] |  | OOBE | DE |  |  |  | 368257 | BEGIN InstallOperationsQueue Ordered operations
      06/13/18 19:38:07:762 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}:  with operation install
      06/13/18 19:38:07:762 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55}:  with operation repair
      06/13/18 19:38:07:762 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END InstallOperationsQueue Ordered operations
      06/13/18 19:38:07:795 | [WARN] |  | OOBE | DE |  |  |  | 368257 | DW035: Patcher: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55} has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
      06/13/18 19:38:07:799 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Payloads passed preflight validation.
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Call PreSession Custom Hook
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 | BEGIN InstallOperationsQueue Unordered operations
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}:  with operation install
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 |   Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55}:  with operation repair
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END InstallOperationsQueue Unordered operations
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 | BEGIN InstallOperationsQueue Ordered operations
      06/13/18 19:38:07:840 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END InstallOperationsQueue Ordered operations
      06/13/18 19:38:08:088 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Calling the custom action code for pre-install for payload Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}
      06/13/18 19:38:08:088 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ::START TIMER:: [Payload Operation :{101F331A-355F-4CE4-B2B9-2E787EDF2C65}]
      06/13/18 19:38:08:093 | [INFO] |  | OOBE | DE |  |  |  | 368277 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      06/13/18 19:38:08:093 | [INFO] |  | OOBE | DE |  |  |  | 368277 | Installer Operation: PayloadInstaller
      06/13/18 19:38:08:093 | [INFO] |  | OOBE | DE |  |  |  | 368277 | Request to install payload
      06/13/18 19:38:08:120 | [INFO] |  | OOBE | DE |  |  |  | 368277 | Payload Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}: Calling ARKEngine from path /Library/Application Support/Adobe/Adobe Desktop Common/DEBox/DE6/resources
      06/13/18 19:38:08:755 | [INFO] |  | OOBE | DE |  |  |  | 368277 | CustomizedPatch property not found in database
      06/13/18 19:38:08:756 | [INFO] |  | OOBE | DE |  |  |  | 368277 | Beginning installation for payload at /private/tmp/.tempdirM7ueVgFD/Install.db
      06/13/18 19:38:08:812 | [ERROR] |  | OOBE | DE |  |  |  | 368277 | DS015: Unable to read symlink target of source file "/Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/boost_system.framework/Versions/A/CodeResources"(Seq 2)
      06/13/18 19:38:08:812 | [WARN] |  | OOBE | DE |  |  |  | 368277 | DW063: Command ARKCopySymlinkCommand failed.(Seq 2)
      06/13/18 19:38:08:812 | [INFO] |  | OOBE | DE |  |  |  | 368277 | Completing installation for payload at /private/tmp/.tempdirM7ueVgFD/Install.db
      06/13/18 19:38:09:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
      06/13/18 19:38:09:597 | [INFO] |  | OOBE | DE |  |  |  | 368257 | :: END TIMER :: [Payload Operation :{101F331A-355F-4CE4-B2B9-2E787EDF2C65}] took 1508 milliseconds (1.508 seconds) DTR = 4132.63 KBPS (4.03577 MBPS)
      06/13/18 19:38:09:607 | [INFO] |  | OOBE | DE |  |  |  | 368257 | User specified overrideFile:
      06/13/18 19:38:09:612 | [INFO] |  | OOBE | DE |  |  |  | 368257 | The csu inventory was not updated for payload Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}, value of local var is -1
      06/13/18 19:38:09:612 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65}
      06/13/18 19:38:09:797 | [WARN] |  | OOBE | DE |  |  |  | 368257 | DW035: Patcher: Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55} has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
      06/13/18 19:38:09:797 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Skipping payload Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack 16.0.3.0 {C9090F4B-EE70-44C5-AA19-A559D2BB5A55} as payload is not cached
      06/13/18 19:38:09:960 | [INFO] |  | OOBE | DE |  |  |  | 368257 | No operation.  We're done:
      06/13/18 19:38:12:238 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Total components installed: 0
      06/13/18 19:38:12:239 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Total components repaired: 0
      06/13/18 19:38:12:239 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Total components removed: 0
      06/13/18 19:38:12:239 | [WARN] |  | OOBE | DE |  |  |  | 368257 | DW050: The following payload errors were found during install:
      06/13/18 19:38:12:239 | [WARN] |  | OOBE | DE |  |  |  | 368257 | DW050:  - Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul: Install failed
      06/13/18 19:38:12:239 | [WARN] |  | OOBE | DE |  |  |  | 368257 | DW050:  - Adobe Illustrator CS6 Core_16.0.3_AdobeIllustrator16ja_JPLanguagePack: Patch already installed
      06/13/18 19:38:12:239 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Call PostSession Custom Hook
      06/13/18 19:38:12:239 | [INFO] |  | OOBE | DE |  |  |  | 368257 | :: END TIMER :: [Total Timer] took 6236 milliseconds (6.236 seconds) DTR = 3515.07 KBPS (3.43269 MBPS)
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | -------------------------------------- Summary --------------------------------------
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 |  - 0 fatal error(s), 1 error(s)
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | OSX version: 10.13.4
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ----------- Payload: Adobe Illustrator CS6 Core_16.0.4_AdobeIllustrator16-mul 16.0.4.0 {101F331A-355F-4CE4-B2B9-2E787EDF2C65} -----------
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | ERROR: DS015: Unable to read symlink target of source file "/Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/boost_system.framework/Versions/A/CodeResources"(Seq 2)
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Please search the above error string(s) to find when the error occurred.
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | These errors resulted in installer Exit Code mentioned below.
      06/13/18 19:38:13:388 | [INFO] |  | OOBE | DE |  |  |  | 368257 | -------------------------------------------------------------------------------------
      06/13/18 19:38:13:389 | [INFO] |  | OOBE | DE |  |  |  | 368257 |
      06/13/18 19:38:13:389 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Exit Code: 7 - Unable to complete Silent workflow.
      06/13/18 19:38:13:389 | [INFO] |  | OOBE | DE |  |  |  | 368257 | Please see specific errors for troubleshooting. For example, ERROR: DS015 ...
      06/13/18 19:38:13:389 | [INFO] |  | OOBE | DE |  |  |  | 368257 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      06/13/18 19:38:13:390 | [INFO] |  | OOBE | DE |  |  |  | 368257 | END - Installer Session
      06/13/18 19:38:13:390 | [INFO] |  | OOBE | DE |  |  |  | 368257 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
        • 1. Re: Illustrator CS6をAdobe Creative Cloudでアップデート失敗
          assause Adobe Community Professional & MVP
          結論だけ先にいいますと、ありません。
          CS6については、永続版であっても、Creative Cloud提供版であっても、
          動作保証されているOSバージョン自体は共通して一貫しており、最終保証は10.9までです。
          よって、10.13ではインストール・起動・アップデート類が正常動作する保証はありませんし、
          生成されるデータの担保についてもありません。
          これはOSの後方互換性の問題でもあるので、Adobe製品の問題ではありません。
          プラットフォームのOS側の問題になってはきますし、開発環境も含めたOSメーカーの
          サポート期間・範囲の話にもなっています。
          導入から利用まですべて自己責任で対応するのであれば構いませんが、
          少なくとも公式には存在しない、というのが結論です。
          なおサポート総合案内 (Japan) から ダウンロード、インストール、セットアップ (Japan) に移動しました。
          • 2. Re: Illustrator CS6をAdobe Creative Cloudでアップデート失敗
            silk-m Most Valuable Participant
            エラーログは読んでいませんがIllustrator CS6 16.0.4をCreative Cloudでアップデートしてはいけません。CCアカウントが無いと体験版になって使えなくなります。こちらからアップデータをダウンロードしてアップデートして下さい。
            Adobe - Illustrator : For Macintosh : Adobe Illustrator 16.0.5 for Mac - All Languages
            但しmacOS 10.13.4でアップデータが正常に動作するかは保証しません。ターミナルでの操作が必要になるかもしれませんからこちらを参考にして下さい。
            CS5 イラストレーターのアップデートができません。High Sierra
            もしアップデートができなくてもIllustrator CS6 16.0.5はセキュリティーのアップデートだけだったと思いますから、機能的には16.0.4と変わり有りません。いずれにしろ動作保証はされていませんから、仕様は自己責任でお願いしま す。
            -- silk-m
            • 3. Re: Illustrator CS6をAdobe Creative Cloudでアップデート失敗
              直道羽21149169 Level 1
              ありがとうございました。インストーラーは立ち上がったものの、結局、アップデートは出来ず、諦めました。
