Rotating a warped object
Jun 13, 2018 Jun 13, 2018
I can make a object, do some warping or transforming, and it looks good. Then If I try to rotate it later, it distorts unpredictably. Any suggestions would be greatly appreciated.
I started with a shape made with the Rounded Rectangle tool.
Applied a Warp Effect.
The resulting warped image looks fine.
When that image gets rotated later using the Selection Tool, it weirds out.
7.1K
Community Expert , Jun 13, 2018 Jun 13, 2018
Go to Object > Expand Appearance, then it should rotate fine.
Adobe
Try using Object>Expand from from the top menu.
The warp you applied is a live effect. When you rotate, Illustrator reapplies the effect live to the object in its newly rotated position. As Larry suggests, before rotating, you'll have to make the effect permanent (no longer 'live') by choosing Object > Expand (Appearance).
Aug 09, 2022 Aug 09, 2022
Brilliant! Thank you Myra!
Oct 31, 2023 Oct 31, 2023
thanks
After applying the Effect as desired, drag the object to the Symbols palette. The copy on the page will then be a Symbol Instance, and transformations thereafter will include to any Effects applied.
That way, the effect will still be adjustable, by editing the Symbol.
JET
That did it! Thanks everyone for the help!
I learned something new today.
