Hello,
I am having issues with my Lightroom CC. If we imagine the image sliced in 4 different parts from top to bottom for reference of the problem to be understood verbally. If i change any settings lets say exposure, lightroom will only change it for the 1st part, then after a quater seccond will change for the second and then the third and then fourth. We can also see this as a slow refresh rate..... like we used to have in old TV's. Some time the image is stuck after it is done for the 1st part, then when we move the cursor over the rest of image it changes.
Do any one have any solution for the same?
A screenshot is always useful. Can you provided one. In meantime, and based on your describe it's worth checking whether disabling GPU support in Lightroom Performance tab helps.
See the line above the headlight?
Yes disabling the GPU works !! but earlier it was not the case and Lightroom use to work great with the GPU.
Above might be true, but something has recently changed on your system that has screwed GPU. The usual culprit on Windows boxes (especially Win 10) is an update that installs crappy GPU drivers.
