When I start Adobe PS CC 2018 directly by clicking the App it starts as version 19.1.4. However, when I start it from LR Classic CC by right-clicking on an image using "Edit In" -> "Edit in Adobe Photoshop CC 2018..." it starts as 19.1.3. As far as I can tell I only have one version of PS on my system. I have tried reinstalling both PS and LR to clear this. Does anyone have any idea what the problem is?
Hi jerryn,
We're really sorry for all the trouble. Well' there's no way that you can keep both Photoshop 19.1.4 & 19.1.3 version installed on one computer at a time.
Could you please let us know what all version of Photoshop and Lightroom installed on your machine?
Mohit
Also worth indicating whether you're using Mac or Windows along with the version number/name
I could only find one PS version on my Mac in the Apps folder and it is version 19.1.4. I could not find version 19.1.3 anywhere. I did not notice this until a plug-in (TKActions) would only load if I started PS directly (19.1.4). Then I realized that I was starting another version with LR. Hope this helps
Could you please open Photoshop via Lightroom Edit-in option and go to Photoshop > help menu > system info and provide the dialogue information in your next reply.
Mohit
Thanks for taking the time to investigate this issue Mohit. Here is the information you requested:
Adobe Photoshop Version: 19.1.3 20180323.r.293 2018/03/23: 1163761 x64
Number of Launches: 48
Operating System: Mac OS 10.13.5
System architecture: Intel CPU Family:6, Model:158, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 4200 MHz
Built-in memory: 24576 MB
Free memory: 14663 MB
Memory available to Photoshop: 22005 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Touch Bar Property Feedback: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=1440, right=2560
Display: 2
Display Bounds: top=0, left=-2560, bottom=1440, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=8192
glgpu[0].GLName="AMD Radeon Pro 580 OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon Pro 580 OpenGL Engine"
glgpu[0].GLRendererID=16915464
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Mar 15 2018 15:35:11)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=8192
clgpu[0].CLName="AMD Radeon Pro 580 Compute Engine"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915456
clgpu[0].CLDriverVersion="1.2 (May 8 2018 15:48:59)"
clgpu[0].CLBandwidth=1.58395e+11
clgpu[0].CLCompute=1990.6
nativegpu[0].NativeName="AMD Radeon Pro 580"
License Type: Subscription
Serial number: 96040264879905689038
GUIDBucket:
Application folder: /Volumes/G-RAID/CCC-BACKUP/Applications/Adobe Photoshop CC 2018/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 465.6G, 205.9G free
Required Plug-ins folder: not set
Primary Plug-ins folder: not set
Installed components:
AIDE.framework AIDE 1.5.0.36540 79.574279
AdbePM.framework AdbePM 2.5.00.377243 1.578146
AdobeACE.framework AdobeACE 2.20.02.39705 79.589342
AdobeAGM.framework AdobeAGM 4.30.87.39705 79.589342
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
AdobeBIB.framework AdobeBIB 1.2.03.39705 79.589342
AdobeBIBUtils.framework AdobeBIBUtils 1.1.39705 79.589342
AdobeCoolType.framework AdobeCoolType 5.17.00.39705 79.589342
AdobeCrashReporter.framework AdobeCrashReporter 7.6.0
AdobeExtendScript.framework AdobeExtendScript 4.5.8.1 81.1150526
AdobeJP2K.framework AdobeJP2K 1.2.2.38423 79.266298
AdobeLinguistic.framework 22175
AdobeMPS.framework AdobeMPS 5.8.1.38423 79.582572
AdobeOwl.framework AdobeOwl 5.2.11
AdobePDFL.framework AdobePDFL 15.0.0.38423 79.226411
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.4.1.109.46827
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.38473 79.582907
AdobeSVGRE.framework AdobeSVGRE 6.0 79.588619
AdobeScCore.framework AdobeScCore 4.5.8.1 81.1150526
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.160451 79.160451
AdobeXMPFiles.framework AdobeXMPFiles 79.160451 79.160451
AdobeXMPScript.framework AdobeXMPScript 79.160451 79.160451
CITThreading.framework
Cg.framework NVIDIA Cg
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
LogSession.framework LogSession 7.4.1.109.46827
PlugPlugExternalObject.framework 8.5.0.87
PlugPlugOwl.framework PlugPlugOwl 8.5.0.87
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
WRServices.framework
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
ahclient.framework ahclient 3.0.0.6
aif.framework aif 6.0.00.1 1.
amtlib.framework amtlib 10.0.0.221
boost_date_time.framework boost_date_time 11.1.0.0
boost_filesystem.framework boost_filesystem 11.1.0.0
boost_signals.framework boost_signals 11.1.0.0
boost_system.framework boost_system 11.1.0.0
boost_threads.framework boost_threads 11.1.0.0
dvaaudiodevice.framework dvaaudiodevice 11.1.0.0
dvacore.framework dvacore 11.1.0.0
dvamarshal.framework dvamarshal 11.1.0.0
dvamediatypes.framework dvamediatypes 11.1.0.0
dvametadata.framework dvametadata 11.1.0.0
dvametadataapi.framework dvametadataapi 11.1.0.0
dvametadataUI.framework dvametadataUI 11.1.0.0
dvaplayer.framework dvaplayer 11.1.0.0
dvatransport.framework dvatransport 11.1.0.0
dvaui.framework dvaui 11.1.0.0
dvaunittesting.framework dvaunittesting 11.1.0.0
dynamiclink.framework dynamiclink 11.1.0.0
k2.framework k2 1
manta.framework manta 2.0.00.1 1.
mediacoreif.framework mediacoreif 11.1.0.0
Required plug-ins:
Alien Skin Blow Up 3 Blow Up 3 3.1.0.157 36824 Copyright (c) 2017 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Automation.8li.plugin”
Alien Skin Exposure X2 Autolayer Autolayer 2.7.0.174 37053 Copyright © 2012 Alien Skin Software, LLC - from the file “Alien Skin Exposure X2 Autolayer.8li.plugin”
Alien Skin Exposure X3 Autolayer Autolayer 3.5.4.137 40291 Copyright © 2012 Alien Skin Software, LLC - from the file “Alien Skin Exposure X3 Autolayer.8li.plugin”
Alien Skin Snap Art 4 Autolayer Autolayer 4.1.0.151 35726 Copyright © 2012 Alien Skin Software, LLC - from the file “Alien Skin Snap Art 4 Autolayer.8li.plugin”
Analog Efex Pro 2 5.0.0.0, Copyright c2000-2018, DxO Labs - from the file “Analog Efex Pro 2.plugin”
BackgroundFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “BackgroundFilter.plugin”
Blow Up Blow Up 3 3.1.0.157 36824 Copyright (c) 2017 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Photoshop.8bf.plugin”
Camera Raw 10.3 (933), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 10.3 (933), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Color Efex Pro 4 5.0.0.0, Copyright c2000-2018, DxO Labs - from the file “Color Efex Pro 4.plugin”
Dfine 2 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “Dfine2.plugin”
DxO FilmPack 5 NO VERSION - from the file “PhotoshopPlugin-filter.plugin”
DxO ViewPoint 3 automation DxO ViewPoint 3 Photoshop Plugin - from the file “PhotoshopPlugin-automationdvpv3.plugin”
DxO ViewPoint 3 DxO ViewPoint 3 Photoshop Plugin - from the file “PhotoshopPlugin-filterdvpv3.plugin”
Exposure X2 Exposure X2 2.7.0.174 37053 Copyright (c) 2017 Alien Skin Software, LLC - from the file “Alien Skin Exposure X2 Photoshop.8bf.plugin”
Exposure X3 Exposure X3 3.5.4.137 40291 Copyright (c) 2017 Alien Skin Software, LLC - from the file “Alien Skin Exposure X3 Photoshop.8bf.plugin”
FineStructuresFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “FineStructuresFilter.plugin”
HDR Efex Pro 2 5.0.0.0, Copyright c2000-2018, DxO Labs - from the file “HDR Efex Pro 2.plugin”
HotPixelsFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “HotPixelsFilter.plugin”
Merge to HDR Efex Pro 2 5.0.0.0, Copyright c2000-2018, DxO Labs - from the file “HDR Efex Pro 2 Automation.plugin”
Nik Collection Selective Tool 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “SelectivePalette.plugin”
ON1 Develop 2018 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Develop 2018-suite.plugin”
ON1 Develop 2018 Filter 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Develop 2018-suite.plugin”
ON1 Effects 2018 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Effects 2018-suite.plugin”
ON1 Effects 2018 Filter 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Effects 2018-suite.plugin”
ON1 Resize 2018 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Resize 2018-suite.plugin”
ON1 Resize 2018 Engine Automation 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Resize 2018-suite.plugin”
ON1 Resize 2018 Engine Filter 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Resize 2018-suite.plugin”
ON1 Resize 2018 Filter 12.1.1, Copyright © 2018 ON1, Inc. All rights reserved. - from the file “ON1 Resize 2018-suite.plugin”
ShadowsFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “ShadowsFilter.plugin”
Sharpener Pro 3: (1) RAW Presharpener 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “SHP3RPS.plugin”
Sharpener Pro 3: (2) Output Sharpener 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “SHP3OS.plugin”
Silver Efex Pro 2 5.0.0.0, Copyright c2000-2018, DxO Labs - from the file “Silver Efex Pro 2.plugin”
SkinFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “SkinFilter.plugin”
SkyFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “SkyFilter.plugin”
Snap Art 4 Snap Art 4 4.1.0.151 35726 Copyright (c) 2016 Alien Skin Software, LLC - from the file “Alien Skin Snap Art 4 Photoshop.8bf.plugin”
StrongNoiseFilter 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “StrongNoiseFilter.plugin”
Viveza 2 5.0.0.0, Copyright ©2000-2018, DxO Labs - from the file “Viveza2.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
TK RapidMask2 V6 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.tk.rmtwovsix/index.html”
com.adobe.inapp.purchase 2.13.141 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_13_141/purchaseStock.html”
Libraries 2.13.141 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_13_141/index.html”
New Document 2.2.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.fnft-2.2.1/fnft.html?v=2.2.1.30”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_13_141/purchaseTypekit.html”
Start 2.2.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.start-2.2.1/index.html?v=2.2.1.67”
TK CxV6 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.tk.cxvsix/index.html”
TK Batch V6 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.tk.batchvsix/index.html”
TK Combo V6 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.tk.combovsix/index.html”
Installed TWAIN devices: NONE
Do you run Time Machine?
IIRC -I (a PC user) have read forums where Lightroom was loading 'old' versions of Photoshop from Time Machine backups.
That forum article article you mentioned was a major clue. I do run Time Machine but it is not normally active. I had forgotten that I also have applications backed up on an external RAID drive which is also where the LR files and catalog are stored. Looking there, I found the older version of PS (19.1.3). So I uninstalled both PS and LR and then deleted the older version of LR on the backup RAID drive. Then I reinstalled LR and PS on my main SSD. Now I only have the newer version of PS CC 2018 (19.1.4). However, now I cannot start PS from LR—I get a popup that says “The file could note be edited because Adobe Photoshop CC 2018 could not be launched". When I click OK PS does not appear but even though I had selected “Edit Original” it creates a -Edit.psd copy of the file! Any idea how to “relink” PS into LR?
You are part the way fixing the problem.
If I had read your report in detail I might have seen this line that gives a clue to the 19.1.3 version location-
Try the 'Mac OS' solutions at 'Edit In Photoshop' command missing
What file-type is the photo you are opening in PS with the [Ctrl+E] shortcut?
Normally a raw file (NEF, CR2,ARW, etc) does not give you a choice dialog, but opens directly. If you get a choice with a raw file, then your versions of LR and PS do not have compatible Camera Raw versions. Are you sure you have PS 19.1.4 and LR-Classic 7.3.1 ?
Only JPG, TIFF, PSD type files will give the options that include "Open Original".
Just wanted to let you know that all is well now. The final fix for this problem was to uninstall both LR and PS including preferences then to reinstall everything. Finally back to normal. Thanks to everyone for their help!
