6 Replies Latest reply on Jun 14, 2018 3:47 AM by Laubender
    Set all text frame object style to [None]?
    neal derekl34934377 Level 1
      Attempting to add a line of code to the below jsx to apply “none” to all text frames within a document, while not affecting their present styling.
      The below resulted in “None” in the Extend Script console (also tried “[None]”), but doesn’t affect Indesign text frames whatsoever.
      Also tried searching the Jongware index to no avail.
      Thanks for any leads on this matter.
      Cheers.
      var doc = app.documents[0];
      var allTextContainers = [];
      var allStories = doc.stories.everyItem().getElements();
      var allStoriesLength = allStories.length;
      for(var n=0;n<allStoriesLength;n++)
          allTextContainers = allTextContainers.concat( allStories[n].textContainers );
      var allTextContainersLength = allTextContainers.length;
      for(var n=0;n<allTextContainersLength;n++)
          if( allTextContainers[n].constructor.name == "TextPath" ){ continue };
          allTextContainers[n].textFramePreferences.autoSizingType = AutoSizingTypeEnum.OFF;
      allTextContainers[n].textFramePreferences.useFixedColumnWidth = false;
      allTextContainers[n].appliedObjectStyle = "None";
      Syntax needed to set all txt frame object styles to [None].
