Every time I open a document in Acrobat Pro DC, the Tools Pane on the right side of the page opens along with the document. How can I prevent this from occurring? I have tried a forum hint of checking the preferences box in the documents section that reads "Restore last view settings . . ." hiding the Tools Pane and quitting Acrobat, but that doesn't work.
Any help?
Thanks.
I just went through the release notes of the updates for the continuous track and found this:
This is from What's new in 2015 releases of Adobe Acrobat DC
This verifies that you do not have access to this feature.
Which version of Acrobat do you have exactly? You can find the version number on the "About" screen. In my case, I am running 2018.011.20040, and in my case, when I hide the right hand pane, close Acrobat and re-open it, the pane remains hidden. If I remember correctly, this is a feature that was added with a patch after the original release of DC. This means that if you are running the non-subscription version, you may not have access to this change. Regardless of which version you are running, make sure that you are running the latest version by using "Check for updates" in Acrobat's Help menu.
I have version 2015.006.30418. I am running the the Classic version, and the update feature tells me there are no further updates.
