All of a sudden, another Premiere Pro CC-18 issue: audio track 2 has stopped functioning. It will play back audio; but you can no longer move it anywhere. You can delete it and copy it. It started with one project, and has now moved to another. I think it is always track 2, but who knows what might happen an hour from now? If I take the time to start brand new, it happens anyway.
[title edited by mod for clarity}
Make sure it is set to clip keyframes and not track keyframes.
Whats RL7000?
Can you go into more detail? What sort of media you are using, sequence settings?
When you say "no longer move it anywhere" do you mean you can place an audio track on track 2 but then it becomes locked in place, unable to moved, trimmed, or adjusted in anyway?
Thanks, Jeff. it is an MP3 audio download, placed into a relatively short sequence. Once in place on audio 2, it can no longer be trimmed, or adjusted. On the last attempt, it wouldn't even highlight, so right clicking was also inactive.
Is the track locked? Can you take a screenshot of your sequence like this?
track is not locked. here is the screen shot Hope that provides enough info
Whats RL7000?
hi jeff sorry, can't find that menu that shows options: clip key frames, track key frames.
Expand the track.
Thanks mucg!! That seemed to do it.
