Hi there
If you have tried forcewin and the other non-invasive tricks
to no avail...
Here is the registry hokey pokey:
Close RoboHelp HTML.
You need to do this because the values we are about to change
will be destructively changed once we close RoboHelp HTML and
restart.
Open the Windows Registry Editor.
(All standard disclaimers apply. Back up the registry,
sacrifice a chicken, yadda yadda yadda)
Locate the following key:
HKEY_CURRENT_USER\Software\version\RoboHTML\version\MontereyFrame\
Double click the item labeled Preview in separate window and
ensure the value is set to 1. If it already is, terrific. If not,
change it to 1 and click the OK button. It doesn't matter if the
option is set to Hex or Decimal.
Double click the item labeled PreviewMaximized and ensure the
value is set to 0. If it already is, terrific. If not, change it to
0 and click the OK button. It doesn't matter if the option is set
to Hex or Decimal.
Double click the item labeled PreviewWindowCX. Make sure the
option is set to Decimal and set the value to 50. Then click the OK
button.
Double click the item labeled PreviewWindowCY. Make sure the
button.
Double click the item labeled PreviewWindowX. Make sure the
button.
Double click the item labeled PreviewWindowY. Make sure the
button.
Close the Windows Registry Editor.
Restart RoboHelp HTML and preview a topic.
The window should now be floating above the RoboHelp HTML
application in full view.
Post back with your RoboHelp version and I might be able to
be more specific.
Cheers... Rick
