As usual I recently backed up all my LR folders using the "Export these Folders as a Catalogue" command, from my computer drive (C:\) to an external hard drive (F:\)
I have just realised that for the past few weeks I have been importing, codewording, processing and exporting all my new work to this backup catalogue (on F:\).
Of course, when I look at my computer C drive all my recent work (folders and Irdata) are not there.
My question is-: How can I move (or copy) this recent work (9 folders containing about 1500 images and their irdata) from the f:\ drive backup catalogue into the C:\ drive catalogue on my computer?
Then in future I could continue my usual backup practice.
Though I still have all my raw files I am rather nervous about losing such a lot of recent time and effort. I need advice. if anyone could kindly help it would be much appreciated.
I agree with Just Shoot Me​ that export as a catalog is not a proper backup procedure. However, you are lucky in that sense that Export as catalog copies all the data (catalog and images). When doing a (proper) backup, you should keep in mind that you need to copy the lrcat file AND your images. Best is to use a backup program to do so and let that one do the backups using backup rules.
More information on this may be found on the web(for example: What’s the Best Way to Back Up My Computer? ), t
...Copy link to clipboard
First using the Export As Catalog is not the way to Back Up your images. No images are ever actually IN LR. They are just Referenced into the LR Database file, IE the Catalog file, from where they are stored on your hard drives.
To properly back them up you Copy the actual Image files to an External drive or NAS or some other physical drive connected to your system other than the one the original images are stored on.
There is a way to get whatever edits you have done to the images in the Exported catalog on the F drive back into your original catalog.
You did an "Export as Catalog", to reverse the process you use the menu command File->Import from Another Catalog.
Thank you for your very helpful and speedy response. I'm now back in business with my C drive catalogue.
If you know of a good back up system I'd be glad to hear from you.
Best wishes
John B
I'm using this one: https://www.lupinho.net/en/hardlinkbackup/
The advantage here is that you will find back your directory structure but that ONLY modified files get copied. Each set, however, represents the whole structure. To understand the concept, you need to understand the concept of hardlinks (Hard Links and Junctions (Windows) ). I'm using the pro version but the free version works the same with some features less.
You may try the free version and if you need more features, you switch to the paid one. There are regularly updates.
Thanks for that. Jolly useful.
Best wishes,
John B
More information on this may be found on the web(for example: What’s the Best Way to Back Up My Computer? ), this is not necessarily a Lightroom problem.
Now for your immediate problem:
Questions to ask:
All your current data is on F: with the exported catalog? Your C: catalog contains only older edits or no edits at all or no images at all? Neither you C: catalog nor your F: catalog contain all data?
Method 1: (For merging a incomplete F: catalog to a incomplete C: catalog)
Method 2+3 will create a new catalog structure and is easiest when the structure on F: is complete and no files are missing on F:.
What was on C: will stay on C: and you should do absolutely a clean-up procedure deleting the older data (catalog and pictures) after you are sure that the new catalog works. For this I normally create a directory "to-delete" and I put all the data that should be deleted in. At a much later point of time, when I did not find problems in my workflow, I delete those files.
Method 2:
You may use "Export as Catalog" to get the data and edits back to C: . Disconnect F: then and open your newly created catalog fom C:
Method 3:
