I've installed Acrobat and it closes immediately after opening. I've completely uninstalled the program , ran the acrobat cleanup wizard, downloaded from the website and re-installed with the same issue. I've also tried to reset the preferences but the folders did not exist to rename. Please advise.
Thank you.
Hi Timk,
As per the issue description mentioned above, Acrobat is crashing when trying to launch, is that correct?
Try the troubleshooting steps given in the following help document:
Acrobat or Reader fresh installation crashes on first launch
If issue still persists, try the steps given in the following help documents:
Troubleshoot Mac OS 10.x system errors, freezes | Adobe software
Troubleshoot Windows system errors, freezes | Adobe software
Also, let us know dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version: Identify the product and its version for Acrobat and Reader DC
Let us know if you need any help.
Shivam
Same issue here, crash report attached.
Already tried every step on troubleshooting instructions, nothing works.
Date/Time: 2018-06-19 15:58:31 +0200
OS Version: Mac OS X 10.13.4 (Build 17E199)
Architecture: x86_64h
Report Version: 26
Data Source: Stackshots
Command: AdobeAcrobat
Path: /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
Identifier: com.adobe.Acrobat.Pro
Version: 18.011.20040 (18.011.20040)
Parent: launchd [1]
PID: 954
Event: hang
Duration: 1.10s (process was unresponsive for 29 seconds before sampling)
Steps: 11 (100ms sampling interval)
Hardware model: iMac18,3
Active cpus: 8
Time Awake Since Boot: 270s
Fan speed: 1201 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Hi Helmuth,
Sorry for the delay in response.
Could you try updating Acrobat to the latest patch using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. You may also download updates from here: Adobe software and product updates
Could you confirm if you have tried the troubleshooting steps given in the following link:
Also, let us know if Acrobat crashes when launching an application or when opening a pdf file?
Shivam
Tried all troubleshooting you posted.
Keeps being unusable.
Application crashes when opening a pdf:
Date/Time: 2018-09-03 20:14:45 +0200
OS Version: Mac OS X 10.13.6 (Build 17G65)
Report Version: 26
Version: 18.011.20058 (18.011.20058)
Parent: launchd [1]
PID: 14927
Event: hang
Duration: 1.00s (process was unresponsive for 19 seconds before sampling)
Steps: 10 (100ms sampling interval)
Active cpus: 8
Time Awake Since Boot: 350000s
Fan speed: 1196 rpm
Heaviest stack for the main thread of the target process:
10 start + 1 (libdyld.dylib + 4117) [0x7fff5384a015]
10 main + 86 (AdobeAcrobat + 3911) [0x10d566f47]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 29278) [0x10dd8e25e]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 35385) [0x10dd8fa39]
10 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885]
10 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34]
10 _DPSNextEvent + 2788 (AppKit + 269618) [0x7fff28fa8d32]
10 AEProcessAppleEvent + 55 (HIToolbox + 259232) [0x7fff2ad074a0]
10 aeProcessAppleEvent + 383 (AE + 38245) [0x7fff2cb0b565]
10 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 41 (AE + 38519) [0x7fff2cb0b677]
10 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 1788 (AE + 40400) [0x7fff2cb0bdd0]
10 _NSAppleEventManagerGenericHandler + 102 (Foundation + 300434) [0x7fff2db32592]
10 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 287 (Foundation + 300820) [0x7fff2db32714]
10 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 766 (AppKit + 288565) [0x7fff28fad735]
10 -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 235 (AppKit + 2358604) [0x7fff291a6d4c]
10 __69-[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:]_block_invoke + 891 (AppKit + 2360049) [0x7fff291a72f1]
10 -[NSApplication(NSAppleEventHandling) _openURLs:withCompletionHandler:] + 1026 (AppKit + 4613711) [0x7fff293cd64f]
10 withWindowOrderingObserverHeuristic + 479 (AppKit + 4614788) [0x7fff293cda84]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 39100) [0x10dd908bc]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 568618) [0x10de11d2a]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 14639669) [0x10eb7d235]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 571136) [0x10de12700]
10 ??? (<99007E2C-7C7E-301A-8EB7-2D07F8BC2553> + 266438) [0x11a9700c6]
10 ??? (<78EC052E-D928-3914-A227-AEA4F5631144> + 114511) [0x119ebcf4f]
10 ??? (<E0F67CDC-FECC-32D4-9348-979BAA1E9574> + 3496023) [0x1218d7857]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 4292188) [0x11820ae5c]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1322716) [0x117f35edc]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 574688) [0x10de134e0]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 577130) [0x10de13e6a]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579028) [0x10de145d4]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579508) [0x10de147b4]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 23542190) [0x10f3fa9ae]
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 738099) [0x10de3b333]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2378251) [0x118037a0b]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2329626) [0x11802bc1a]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2327452) [0x11802b39c]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2325571) [0x11802ac43]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1714449) [0x117f95911]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772296) [0x117fa3b08]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772034) [0x117fa3a02]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1769668) [0x117fa30c4]
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 838310) [0x117ebfaa6]
10 -[NSHost address] + 37 (CFNetwork + 1512687) [0x7fff2aa854ef]
10 -[NSHost blockingResolveUntil:] + 155 (CFNetwork + 633591) [0x7fff2a9aeaf7]
10 _dispatch_semaphore_wait_slow + 101 (libdispatch.dylib + 39289) [0x7fff53818979]
10 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246]
*10 semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90]
Process: AdobeAcrobat (Acrobat Pro DC) [14927]
Parent: launchd [1]
UID: 502
Task size: 224.47 MB
CPU Time: <0.001s (1970.0K cycles, 579.6K instructions, 3.40c/i)
Note: Unresponsive for 19 seconds before sampling
Note: 3 idle work queue threads omitted
Thread 0x6a5d2d DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
<thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
10 main + 86 (AdobeAcrobat + 3911) [0x10d566f47] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 29278) [0x10dd8e25e] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 35385) [0x10dd8fa39] 1-10
10 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
10 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
10 _DPSNextEvent + 2788 (AppKit + 269618) [0x7fff28fa8d32] 1-10
10 AEProcessAppleEvent + 55 (HIToolbox + 259232) [0x7fff2ad074a0] 1-10
10 aeProcessAppleEvent + 383 (AE + 38245) [0x7fff2cb0b565] 1-10
10 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 41 (AE + 38519) [0x7fff2cb0b677] 1-10
10 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 1788 (AE + 40400) [0x7fff2cb0bdd0] 1-10
10 _NSAppleEventManagerGenericHandler + 102 (Foundation + 300434) [0x7fff2db32592] 1-10
10 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 287 (Foundation + 300820) [0x7fff2db32714] 1-10
10 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 766 (AppKit + 288565) [0x7fff28fad735] 1-10
10 -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 235 (AppKit + 2358604) [0x7fff291a6d4c] 1-10
10 __69-[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:]_block_invoke + 891 (AppKit + 2360049) [0x7fff291a72f1] 1-10
10 -[NSApplication(NSAppleEventHandling) _openURLs:withCompletionHandler:] + 1026 (AppKit + 4613711) [0x7fff293cd64f] 1-10
10 withWindowOrderingObserverHeuristic + 479 (AppKit + 4614788) [0x7fff293cda84] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 39100) [0x10dd908bc] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 568618) [0x10de11d2a] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 14639669) [0x10eb7d235] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 571136) [0x10de12700] 1-10
10 ??? (<99007E2C-7C7E-301A-8EB7-2D07F8BC2553> + 266438) [0x11a9700c6] 1-10
10 ??? (<78EC052E-D928-3914-A227-AEA4F5631144> + 114511) [0x119ebcf4f] 1-10
10 ??? (<E0F67CDC-FECC-32D4-9348-979BAA1E9574> + 3496023) [0x1218d7857] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 4292188) [0x11820ae5c] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1322716) [0x117f35edc] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 574688) [0x10de134e0] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 577130) [0x10de13e6a] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579028) [0x10de145d4] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579508) [0x10de147b4] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 23542190) [0x10f3fa9ae] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 738099) [0x10de3b333] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2378251) [0x118037a0b] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2329626) [0x11802bc1a] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2327452) [0x11802b39c] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2325571) [0x11802ac43] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1714449) [0x117f95911] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772296) [0x117fa3b08] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772034) [0x117fa3a02] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1769668) [0x117fa30c4] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 838310) [0x117ebfaa6] 1-10
10 -[NSHost address] + 37 (CFNetwork + 1512687) [0x7fff2aa854ef] 1-10
10 -[NSHost blockingResolveUntil:] + 155 (CFNetwork + 633591) [0x7fff2a9aeaf7] 1-10
10 _dispatch_semaphore_wait_slow + 101 (libdispatch.dylib + 39289) [0x7fff53818979] 1-10
10 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246] 1-10
*10 semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90] 1-10
Thread 0x6a5d35 DispatchQueue 117 10 samples (1-10) priority 37 (base 37) cpu time <0.001s (1131.2K cycles, 357.4K instructions, 3.17c/i)
<thread QoS user initiated (requested user initiated), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 1-10
10 _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff53b62169] 1-10
10 _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff53812755] 1-10
10 _dispatch_root_queue_drain + 515 (libdispatch.dylib + 14761) [0x7fff538129a9] 1-10
10 _dispatch_async_redirect_invoke + 703 (libdispatch.dylib + 50995) [0x7fff5381b733] 1-10
10 _dispatch_continuation_pop + 472 (libdispatch.dylib + 85633) [0x7fff53823e81] 1-10
10 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 1-10
10 __NSOQSchedule_f + 369 (Foundation + 223511) [0x7fff2db1f917] 1-10
10 -[__NSOperationInternal _start:] + 778 (Foundation + 239854) [0x7fff2db238ee] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 17307662) [0x10ee0880e] 1-10
10 +[NSThread sleepForTimeInterval:] + 156 (Foundation + 849639) [0x7fff2dbb86e7] 1-10
10 __semwait_signal + 10 (libsystem_kernel.dylib + 118146) [0x7fff5399ad82] 1-10
Thread 0x6a7695 DispatchQueue 754 10 samples (1-10) priority 37 (base 37)
<thread QoS user initiated (requested user initiated, ipc override user initiated), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff53b61fd2] 1-10
10 _dispatch_workloop_worker_thread + 880 (libdispatch.dylib + 109857) [0x7fff53829d21] 1-10
10 _dispatch_root_queue_drain_deferred_wlh + 332 (libdispatch.dylib + 93965) [0x7fff53825f0d] 1-10
10 _dispatch_queue_invoke + 373 (libdispatch.dylib + 37222) [0x7fff53818166] 1-10
10 _dispatch_queue_serial_drain + 635 (libdispatch.dylib + 90647) [0x7fff53825217] 1-10
10 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 1-10
10 __18-[NSHost resolve:]_block_invoke + 366 (CFNetwork + 634158) [0x7fff2a9aed2e] 1-10
10 -[NSHost __resolveWithFlags:resultArray:handler:] + 224 (CFNetwork + 1507318) [0x7fff2aa83ff6] 1-10
10 getaddrinfo + 61 (libsystem_info.dylib + 35245) [0x7fff5393c9ad] 1-10
10 _getaddrinfo_internal + 242 (libsystem_info.dylib + 167746) [0x7fff5395cf42] 1-10
10 si_addrinfo + 1938 (libsystem_info.dylib + 37202) [0x7fff5393d152] 1-10
10 search_addrinfo + 306 (libsystem_info.dylib + 61330) [0x7fff53942f92] 1-10
10 mdns_addrinfo + 1197 (libsystem_info.dylib + 62621) [0x7fff5394349d] 1-10
10 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff5399bbea] 1-10
*10 ??? (kernel + 5263408) [0xffffff8000705030] 1-10
Thread 0x6a5d63 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
10 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
10 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
10 ??? (<ECB4421C-9DE6-3940-BA7B-CBC5A582784D> + 3781653) [0x10da63415] 1-10
10 ??? (<ECB4421C-9DE6-3940-BA7B-CBC5A582784D> + 52845) [0x10d6d4e6d] 1-10
10 ??? (<ECB4421C-9DE6-3940-BA7B-CBC5A582784D> + 53040) [0x10d6d4f30] 1-10
10 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
*10 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
Thread 0x6a5d64 10 samples (1-10) priority 31 (base 31)
Thread 0x6a5d65 10 samples (1-10) priority 31 (base 31)
Thread 0x6a5d78 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (360.1K cycles, 91.0K instructions, 3.96c/i)
10 _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
10 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
10 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
10 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
10 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
*10 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
Thread 0x6a5f93 10 samples (1-10) priority 31 (base 31)
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4614356) [0x10e1ed8d4] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4555602) [0x10e1df352] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 18049855) [0x10eebdb3f] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4573425) [0x10e1e38f1] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4636315) [0x10e1f2e9b] 1-10
Thread 0x6a5f95 10 samples (1-10) priority 31 (base 31)
<process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 26213884) [0x10f686dfc] 1-10
Thread 0x6a5f99 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (98.0K cycles, 19.9K instructions, 4.94c/i)
10 __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
10 ??? (<D7288EE1-0DB3-3731-8A36-3CEB2DDE9824> + 104767) [0x11776093f] 1-10
Thread 0x6a5fcb Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
10 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
Thread 0x6a5fdf 10 samples (1-10) priority 31 (base 31)
10 ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 1049145) [0x117d12239] 1-10
10 ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 595895) [0x117ca37b7] 1-10
10 ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 615786) [0x117ca856a] 1-10
10 ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 1052351) [0x117d12ebf] 1-10
10 ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 1058204) [0x117d1459c] 1-10
Thread 0x6a600b 10 samples (1-10) priority 31 (base 31)
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4599942) [0x10e1ea086] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4558862) [0x10e1e000e] 1-10
10 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff5399c142] 1-10
*10 hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 1-10
*10 unix_syscall64 + 616 (kernel + 6306152) [0xffffff8000803968] 1-10
*10 read_nocancel + 115 (kernel + 5532931) [0xffffff8000746d03] 1-10
*10 ??? (kernel + 5533541) [0xffffff8000746f65] 1-10
*10 soreceive + 5082 (kernel + 5735770) [0xffffff800077855a] 1-10
*10 sbwait + 406 (kernel + 5772870) [0xffffff8000781646] 1-10
*10 msleep + 98 (kernel + 5438898) [0xffffff800072fdb2] 1-10
*10 ??? (kernel + 5437670) [0xffffff800072f8e6] 1-10
*10 lck_mtx_sleep + 126 (kernel + 505086) [0xffffff800027b4fe] 1-10
*10 thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
*10 ??? (kernel + 554618) [0xffffff800028767a] 1-10
*10 machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
Thread 0x6a6011 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 46 (base 46)
10 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff5399acf2] 1-10
*10 ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
Thread 0x6a6042 10 samples (1-10) priority 31 (base 31)
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 27018295) [0x10f74b437] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 27026412) [0x10f74d3ec] 1-10
10 ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 27027880) [0x10f74d9a8] 1-10
Thread 0x6a606f 10 samples (1-10) priority 31 (base 31)
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 5392045) [0x1183176ad] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 3213033) [0x1181036e9] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 3742731) [0x118184c0b] 1-10
10 ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 3741733) [0x118184825] 1-10
Binary Images:
0x10d566000 - 0x10d566fff com.adobe.Acrobat.Pro 18.011.20058 (18.011.20058) <C8E55D09-69DB-3088-BBCD-BC349D00F1A8> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
0x10d6c8000 - ??? ??? <ECB4421C-9DE6-3940-BA7B-CBC5A582784D>
0x10dd87000 - ??? ??? <E12DD39E-D322-37FE-9DB1-F5C6EED666EF>
0x117747000 - ??? ??? <D7288EE1-0DB3-3731-8A36-3CEB2DDE9824>
0x117c12000 - ??? ??? <3FB068A4-9343-3185-870E-F922267BFA19>
0x117df3000 - ??? ??? <530D24AF-462E-3CD3-95AF-C8EF7C2533CF>
0x119ea1000 - ??? ??? <78EC052E-D928-3914-A227-AEA4F5631144>
0x11a92f000 - ??? ??? <99007E2C-7C7E-301A-8EB7-2D07F8BC2553>
0x121582000 - ??? ??? <E0F67CDC-FECC-32D4-9348-979BAA1E9574>
0x7fff28f67000 - 0x7fff29dc5fff com.apple.AppKit 6.9 (1561.60.100) <3C27CF6F-E640-3411-A87D-CCB2222CC754> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2a914000 - 0x7fff2acaefff com.apple.CFNetwork 902.1 (902.1) <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff2acc8000 - 0x7fff2afcdfff com.apple.HIToolbox 2.1.1 (911.10) <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2b988000 - 0x7fff2be29fff com.apple.CoreFoundation 6.9 (1454.90) <E5D594BF-9142-3325-A62D-CF4AAF472642> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2cb02000 - 0x7fff2cb76fff com.apple.AE 735.1 (735.1) <08EBA184-20F7-3725-AEA6-C314448161C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff2dae9000 - 0x7fff2deaffff com.apple.Foundation 6.9 (1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff5380f000 - 0x7fff53848fff libdispatch.dylib (913.60.2) <232C69BD-022E-3AB9-8807-79F9FA7CB5EC> /usr/lib/system/libdispatch.dylib
0x7fff53849000 - 0x7fff53866fff libdyld.dylib (551.4) <81BF3A82-5719-3B54-ABA9-76C82D932CAC> /usr/lib/system/libdyld.dylib
0x7fff53934000 - 0x7fff5397dfff libsystem_info.dylib (517.30.1) <AB634A98-B8AA-3804-8436-38261FC8EC4D> /usr/lib/system/libsystem_info.dylib
0x7fff5397e000 - 0x7fff539a4fff libsystem_kernel.dylib (4570.71.2) <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2> /usr/lib/system/libsystem_kernel.dylib
0x7fff53b5f000 - 0x7fff53b6afff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
*0xffffff7f82a20000 - 0xffffff7f82a2bfff com.apple.kec.pthread 1.0 (1) <E64F7A49-CBF0-3251-9F02-3655E3B3DD31> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.2) <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F> /System/Library/Kernels/kernel
Process: ACCFinderSync [329]
Path: /Applications/Utilities/Adobe Sync/*/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex/Contents/MacOS/ACCFinderSync
Parent: launchd [1]
UID: 502
Sudden Term: Tracked (allows idle exit)
Task size: 17.25 MB
CPU Time: <0.001s (426.5K cycles, 100.2K instructions, 4.26c/i)
Process: ACCFinderSync [14740]
Parent: launchd [1]
UID: 502
Task size: 32.11 MB
CPU Time: <0.001s (389.2K cycles, 90.2K instructions, 4.32c/i)
Process: accountsd [314]
Path: /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Parent: launchd [1]
UID: 502
Task size: 53.15 MB
Note: 1 idle work queue thread omitted
Thread 0xd57 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (accountsd + 2602) [0x10bea3a2a] 1-10
Binary Images:
0x10bea3000 - 0x10bea3fff accountsd (677.3.0.14) <34F8D127-6497-3DF1-8C4C-1F6C354AB66E> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Process: AcroCEF [14929]
Path: /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app/Contents/MacOS/AcroCEF
Parent: AdobeAcrobat (Acrobat Pro DC) [14927]
Responsible: AdobeAcrobat (Acrobat Pro DC) [14927]
UID: 502
Task size: 153.75 MB
CPU Time: 0.010s (23.8M cycles, 11.2M instructions, 2.13c/i)
Process: AcroCEF Helper [14930]
Path: /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper.app/Contents/MacOS/AcroCEF Helper
Parent: AcroCEF [14929]
UID: 502
Task size: 119.02 MB
Process: AcroCEF Helper [14946]
UID: 502
Task size: 102.54 MB
Process: adid [237]
Path: /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
Parent: launchd [1]
UID: 265
Task size: 8136 KB
Thread 0x78d DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (adid + 903416) [0x102cd98f8] 1-10
10 CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
Binary Images:
0x102bfd000 - 0x102d91fff adid (4.19) <FC2CF85B-F9E9-302E-8FB0-1DEE4BA24650> /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
Process: Adobe CEF Helper [452]
Path: /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
Parent: Creative Cloud [394]
Responsible: Creative Cloud [394]
UID: 502
Task size: 62.96 MB
Process: Adobe CEF Helper [458]
UID: 502
Task size: 193.13 MB
CPU Time: <0.001s (3.1M cycles, 1031.6K instructions, 3.05c/i)
Process: Adobe Desktop Service [457]
Path: /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
Parent: launchd [1]
UID: 502
Task size: 416.02 MB
CPU Time: <0.001s (31.8K cycles, 4.2K instructions, 7.63c/i)
Process: Adobe Installer [585]
Path: /Library/Application Support/Adobe/*/Adobe Installer
Parent: com.adobe.acc.installer.v2 [545]
Responsible: com.adobe.acc.installer.v2 [545]
UID: 0
Task size: 11.41 MB
Thread 0x1f45 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
10 start + 52 (Adobe Installer + 5028) [0x1019fe3a4] 1-10
10 ??? (Adobe Installer + 20192) [0x101a01ee0] 1-10
10 ??? (Adobe Installer + 21204) [0x101a022d4] 1-10
10 OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 187 (Adobe Installer + 100043) [0x101a156cb] 1-10
Thread 0x1f4d 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
10 listenerThread(void*) + 75 (Adobe Installer + 102363) [0x101a15fdb] 1-10
*10 ??? (kernel + 2877244) [0xffffff80004be73c] 1-10
*10 VNOP_READ + 106 (kernel + 2933994) [0xffffff80004cc4ea] 1-10
*10 apfs_fifospec_read + 31 (apfs + 252656) [0xffffff7f81945af0] 1-10
*10 fifo_read + 135 (kernel + 2972599) [0xffffff80004d5bb7] 1-10
Binary Images:
0x1019fd000 - 0x101a5afff Adobe Installer <90A6FA82-6455-3756-AC28-3A4BAC2212C9> /Library/Application Support/Adobe/*/Adobe Installer
*0xffffff7f81908000 - 0xffffff7f819e3fff com.apple.filesystems.apfs 748.51.0 (748.51.0) <F5310D5D-825A-3114-86DA-6E7D2A21133A> /System/Library/Extensions/apfs.kext/Contents/MacOS/apfs
Process: AdobeCRDaemon [447]
Path: /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
UID: 502
Task size: 10.96 MB
CPU Time: 0.001s (4.8M cycles, 3.9M instructions, 1.24c/i)
Process: AdobeCRDaemon [485]
Path: /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
Parent: Adobe Desktop Service [457]
Responsible: Adobe Desktop Service [457]
UID: 502
Task size: 11.02 MB
CPU Time: <0.001s (3.7M cycles, 3.8M instructions, 0.96c/i)
Process: AdobeCRDaemon [510]
Path: /Applications/Utilities/Adobe Sync/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
Parent: Core Sync [506]
Responsible: Core Sync [506]
UID: 502
Task size: 17.79 MB
CPU Time: <0.001s (3.6M cycles, 3.7M instructions, 0.97c/i)
Process: AdobeCRDaemon [14928]
Path: /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
UID: 502
Task size: 9412 KB
CPU Time: <0.001s (2.9M cycles, 3.7M instructions, 0.78c/i)
Process: AdobeIPCBroker [429]
Path: /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
Parent: launchd [1]
UID: 502
Task size: 25.15 MB
CPU Time: <0.001s (217.4K cycles, 64.3K instructions, 3.38c/i)
Process: AdobeResourceSynchronizer [14932]
Path: /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AdobeResourceSynchronizer.app/Contents/MacOS/AdobeResourceSynchronizer
UID: 502
Task size: 18.89 MB
Process: AGMService [86]
Path: /Library/Application Support/Adobe/*/AGMService
Parent: launchd [1]
UID: 0
Task size: 17.13 MB
Thread 0x284 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 start + 52 (AGMService + 8308) [0x100002074] 1-10
10 ??? (AGMService + 9707) [0x1000025eb] 1-10
10 ??? (AGMService + 118692) [0x10001cfa4] 1-10
10 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
Binary Images:
0x100000000 - 0x10024cfff AGMService <42106898-5812-3B90-BF32-D1FE1C07C98B> /Library/Application Support/Adobe/*/AGMService
Process: AirPlayUIAgent [390]
Path: /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Parent: launchd [1]
UID: 502
Task size: 15 MB
CPU Time: <0.001s (308.8K cycles, 72.9K instructions, 4.24c/i)
Thread 0x10b9 DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (153.4K cycles, 30.3K instructions, 5.06c/i)
<thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
10 NSApplicationMain + 804 (AppKit + 23154) [0x7fff28f6ca72] 1-10
10 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
10 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
10 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
10 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
Thread 0x10f7 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Thread 0x68948f 10 samples (1-10) priority 31 (base 31)
<process sudden termination clean, process unclamped, IO tier 0>
*10 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] 1-10
Binary Images:
0x106c80000 - 0x106c89fff com.apple.AirPlayUIAgent 2.0 (366.76.2) <F93D4FC6-1F74-3EB0-8802-85A42A590A16> /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Process: AirPlayXPCHelper [117]
Path: /usr/libexec/AirPlayXPCHelper
Parent: launchd [1]
UID: 0
Task size: 15.28 MB
CPU Time: <0.001s (183.5K cycles, 42.7K instructions, 4.30c/i)
Note: 2 idle work queue threads omitted
Thread 0x3e9 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), IO tier 0>
10 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
Thread 0x6a7702 10 samples (1-10) priority 31 (base 31)
<IO tier 0>
Binary Images:
0x10d319000 - 0x10d31afff AirPlayXPCHelper (366.76.2) <4C695B3B-8257-3350-85AE-D88FB08FF5A2> /usr/libexec/AirPlayXPCHelper
Process: airportd [162]
Path: /usr/libexec/airportd
Parent: launchd [1]
UID: 0
Task size: 20.16 MB
Thread 0x3e8 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from sharingd [389], IO tier 0>
10 ??? (airportd + 318747) [0x10e05ed1b] 1-10
Thread 0x480 DispatchQueue 83 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default, ipc override default), process sudden termination clean, process unclamped, process received importance donation from sharingd [389], IO tier 0>
10 ??? (airportd + 416478) [0x10e076ade] 1-10
10 CFReadStreamRead + 382 (CoreFoundation + 510318) [0x7fff2ba0496e] 1-10
*10 spec_read + 667 (kernel + 2976283) [0xffffff80004d6a1b] 1-10
*10 cdev_read + 379 (IO80211Family + 450730) [0xffffff7f81ad40aa] 1-10
Thread 0x407 DispatchQueue 84 10 samples (1-10) priority 31 (base 31)
10 ??? (airportd + 417681) [0x10e076f91] 1-10
Thread 0x47f DispatchQueue 85 10 samples (1-10) priority 31 (base 31)
10 ??? (airportd + 416952) [0x10e076cb8] 1-10
Thread 0x48b Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10e011000 - 0x10e146fff airportd (1361.7) <44A90813-5031-3F9E-BADC-1A0F8383050F> /usr/libexec/airportd
*0xffffff7f81a66000 - 0xffffff7f81b16fff com.apple.iokit.IO80211Family 12.0 (1200.12.2) <9CF530F9-ABD9-3A18-B611-42C5811D3FAF> /System/Library/Extensions/IO80211Family.kext/Contents/MacOS/IO80211Family
Process: akd [236]
Path: /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Parent: launchd [1]
UID: 0
Task size: 7096 KB
Thread 0x769 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (akd + 111269) [0x103ed32a5] 1-10
Binary Images:
0x103eb8000 - 0x103f65fff akd (181.0.0.42) <7038EF23-D871-3575-B216-EF30AF3148DB> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process: akd [362]
Parent: launchd [1]
UID: 502
Task size: 18.37 MB
Thread 0xfef DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (akd + 111269) [0x10fcb12a5] 1-10
Thread 0x1267c0 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10fc96000 - 0x10fd43fff akd (181.0.0.42) <7038EF23-D871-3575-B216-EF30AF3148DB> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process: AlertNotificationService [14326]
Path: /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Framework.framework/Versions/A/XPCServices/AlertNotificationService.xpc/Contents/MacOS/AlertNotificationService
Parent: launchd [1]
Responsible: Google Chrome (Chrome) [14319]
UID: 502
Task size: 9076 KB
Process: amfid [123]
Path: /usr/libexec/amfid
Parent: launchd [1]
UID: 0
Task size: 15.52 MB
Thread 0x2f9 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 0>
Binary Images:
0x10bbaf000 - 0x10bbb5fff amfid (270.70.1) <2935F22B-678C-3C31-A3A0-025DA73CA0C2> /usr/libexec/amfid
Process: analyticsd [198]
Path: /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
Parent: launchd [1]
UID: 263
Task size: 13.23 MB
Thread 0x487 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (analyticsd + 237679) [0x1088d906f] 1-10
Thread 0x6a72fe 10 samples (1-10) priority 4 (base 4)
<thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x10889f000 - 0x108947fff analyticsd (27.4) <19D56FFD-8618-3B31-9838-679108B6CAFA> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
Process: apfsd [208]
Path: /usr/libexec/apfsd
Parent: launchd [1]
UID: 0
Task size: 5316 KB
Thread 0x552 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 ??? (apfsd + 17913) [0x10d9335f9] 1-10
Binary Images:
0x10d92f000 - 0x10d938fff apfsd (748.77.8) <D7ECFD4A-CDF5-3F76-BCC4-EFBD3CC08C43> /usr/libexec/apfsd
Process: APFSUserAgent [368]
Path: /System/Library/CoreServices/APFSUserAgent
Parent: launchd [1]
UID: 502
Task size: 5600 KB
Thread 0x1045 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10903a000 - 0x10903efff APFSUserAgent (748.77.8) <49679BB1-8024-3139-BEE4-51C17095E8E1> /System/Library/CoreServices/APFSUserAgent
Process: apple.DevicePropertyReader [13371]
Path: /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Contents/MacOS/apple.DevicePropertyReader
Parent: launchd [1]
Responsible: PTPCamera [13369]
UID: 502
Task size: 10124 KB
Thread 0x5a12a2 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x100380000 - 0x100381fff com.apple.DevicePropertyReader 1.0 (1) <6B4D5A99-1F15-3D35-9610-E86DB992E531> /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Contents/MacOS/apple.DevicePropertyReader
Process: appleeventsd [64]
Path: /System/Library/CoreServices/appleeventsd
Parent: launchd [1]
UID: 55
Task size: 9260 KB
Thread 0x5ae DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
10 <truncated backtrace> 1-10
Binary Images:
0x104510000 - 0x104510fff appleeventsd (735.1) <88F1B1E2-2576-3E4C-84EA-CA77C9958C01> /System/Library/CoreServices/appleeventsd
Process: AppleSpell [597]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Parent: launchd [1]
UID: 502
Task size: 69.58 MB
Thread 0x202c DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (AppleSpell + 7064) [0x10aaa9b98] 1-10
10 -[NSSpellServer run] + 73 (Foundation + 2090637) [0x7fff2dce768d] 1-10
Binary Images:
0x10aaa8000 - 0x10abaafff com.apple.AppleSpell 2.4 (430.2) <724CCFE3-CF4C-39C4-8EE1-4126B2A532F7> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process: applessdstatistics [14620]
Path: /usr/libexec/applessdstatistics
Parent: launchd [1]
UID: 0
Task size: 4560 KB
Thread 0x685bfc DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
10 ??? (applessdstatistics + 5851) [0x1036176db] 1-10
10 _dispatch_group_wait_slow + 151 (libdispatch.dylib + 28265) [0x7fff53815e69] 1-10
Binary Images:
0x103616000 - 0x10364dfff applessdstatistics (118.70.3) <090263DD-A7A9-32D7-A5BD-89DE93AA9897> /usr/libexec/applessdstatistics
Process: apsd [94]
Path: /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Parent: launchd [1]
UID: 0
Task size: 45.79 MB
Thread 0x288 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (apsd + 532954) [0x10d4f01da] 1-10
Thread 0x9fd Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
Thread 0xa03 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10d46e000 - 0x10d56bfff apsd (625.1.2.1) <3D02BD05-5E7A-38CB-A02A-CC4BF2738997> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Process: aslmanager [156]
Path: /usr/sbin/aslmanager
Parent: launchd [1]
UID: 0
Task size: 6236 KB
Thread 0x3ae DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 3>
Binary Images:
0x10ae2d000 - 0x10ae36fff aslmanager (356.70.1) <194952A2-3DEC-3421-B419-31B84BBE7543> /usr/sbin/aslmanager
Process: aslmanager [5131]
Parent: launchd [1]
UID: 0
Task size: 3820 KB
Thread 0x335572 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3>
Binary Images:
0x105bbd000 - 0x105bc6fff aslmanager (356.70.1) <194952A2-3DEC-3421-B419-31B84BBE7543> /usr/sbin/aslmanager
Process: AssetCache [642]
Path: /usr/libexec/AssetCache/AssetCache
Parent: launchd [1]
UID: 235
Task size: 12.95 MB
Thread 0x3831 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (AssetCache + 9411) [0x10a76b4c3] 1-10
10 ??? (AssetCache + 96458) [0x10a7808ca] 1-10
10 ??? (AssetCache + 97282) [0x10a780c02] 1-10
Binary Images:
0x10a769000 - 0x10aad2fff AssetCache (214) <036DE5D5-8F7C-391E-A42D-04E08423858F> /usr/libexec/AssetCache/AssetCache
Process: AssetCacheLocatorService [6331]
Path: /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Parent: launchd [1]
UID: 502
Task size: 8580 KB
Thread 0x43486f DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 71 (AssetCacheLocatorService + 33045) [0x10aea2115] 1-10
10 -[AssetCacheLocatorService start] + 652 (AssetCacheLocatorService + 55904) [0x10aea7a60] 1-10
Thread 0x4348f9 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10ae9a000 - 0x10aed3fff com.apple.AssetCacheLocatorService 82.1 (82.1) <1B6C8446-9169-39DF-86E8-087BC1B143B8> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Process: assistant_service [1932]
Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
Parent: launchd [1]
UID: 502
Task size: 159.93 MB
Thread 0x34ee8 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (assistant_service + 6441) [0x1001ef929] 1-10
Thread 0x323dcf Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1001ee000 - 0x1001fbfff assistant_service (1737.24.34.0.1) <62E2432C-9F2E-3D49-B536-0DFF0BDCAD06> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
Process: assistantd [365]
Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
Parent: launchd [1]
UID: 502
Task size: 40.89 MB
Thread 0x1034 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (assistantd + 39854) [0x100968bae] 1-10
10 ??? (assistantd + 41614) [0x10096928e] 1-10
Binary Images:
0x10095f000 - 0x100da4fff assistantd (1737.24.34.0.1) <B5858C15-54B8-3BE9-B1B8-9A9848A27D42> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
Process: AudioComponentRegistrar [251]
Path: /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Parent: launchd [1]
UID: 0
Task size: 8172 KB
Thread 0x85f DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (AudioComponentRegistrar + 6938) [0x10d475b1a] 1-10
Binary Images:
0x10d474000 - 0x10d475fff AudioComponentRegistrar (975.4.21.23) <271C6C79-7CDD-3129-B995-805877449D2B> /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Process: AudioComponentRegistrar [668]
Parent: launchd [1]
UID: 502
Task size: 9780 KB
Thread 0x43fd DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (AudioComponentRegistrar + 6938) [0x10bc10b1a] 1-10
Binary Images:
0x10bc0f000 - 0x10bc10fff AudioComponentRegistrar (975.4.21.23) <271C6C79-7CDD-3129-B995-805877449D2B> /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Process: authd [141]
Path: /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
Parent: launchd [1]
UID: 0
Task size: 13.95 MB
Thread 0x3bb DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
Thread 0x3bc DispatchQueue 10 10 samples (1-10) priority 4 (base 4)
10 _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff53812b2c] 1-10
10 ??? (authd + 18417) [0x109b8f7f1] 1-10
10 au_sdev_read_aia + 528 (libbsm.0.dylib + 60396) [0x7fff51787bec] 1-10
10 fgetc + 52 (libsystem_c.dylib + 246895) [0x7fff538d546f] 1-10
10 __srget + 14 (libsystem_c.dylib + 273977) [0x7fff538dbe39] 1-10
10 __srefill1 + 24 (libsystem_c.dylib + 273694) [0x7fff538dbd1e] 1-10
10 __read_nocancel + 10 (libsystem_kernel.dylib + 117738) [0x7fff5399abea] 1-10
*10 ??? (kernel + 5069540) [0xffffff80006d5ae4] 1-10
Binary Images:
0x109b8b000 - 0x109baefff com.apple.authd 1.0 (58286.70.7) <A8257077-7DFA-3C3C-87AA-D9F5EB080BCC> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
0x7fff51779000 - 0x7fff51789fff libbsm.0.dylib (39) <6BC96A72-AFBE-34FD-91B1-748A530D8AE6> /usr/lib/libbsm.0.dylib
0x7fff53899000 - 0x7fff53922fff libsystem_c.dylib (1244.50.9) <1187BFE8-4576-3247-8177-481554E1F9E7> /usr/lib/system/libsystem_c.dylib
Process: autofsd [103]
Path: /usr/libexec/autofsd
Parent: launchd [1]
UID: 0
Task size: 5040 KB
Thread 0x4c6 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
Binary Images:
0x10ad2f000 - 0x10ad2ffff autofsd (270.40.1) <43CA7756-70DB-3568-8AD1-5C5D63F41672> /usr/libexec/autofsd
Process: avconferenced [2853]
Path: /usr/libexec/avconferenced
Parent: launchd [1]
UID: 502
Task size: 21.81 MB
Thread 0x7a140 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 ??? (avconferenced + 3829) [0x106d4bef5] 1-10
Binary Images:
0x106d4b000 - 0x106d4bfff avconferenced (1020.31) <693EF29B-A177-3237-8C04-5AFC844777D5> /usr/libexec/avconferenced
Process: awacsd [196]
Path: /usr/libexec/awacsd
Parent: launchd [1]
UID: 0
Task size: 14.15 MB
Thread 0x6dc DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
Thread 0x74b Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 20 (base 20)
Thread 0xa69 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
Binary Images:
0x10a7cf000 - 0x10a847fff awacsd (120) <82317BD3-321D-34BC-835F-393EBC355EC5> /usr/libexec/awacsd
Process: awdd [197]
Path: /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Parent: launchd [1]
UID: 0
Task size: 15.21 MB
Thread 0x482 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (awdd + 21935) [0x10d1dc5af] 1-10
Binary Images:
0x10d1d7000 - 0x10d2c7fff awdd (930) <AEDE667C-65A5-395E-90F3-962889B773C7> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Process: backgroundtaskmanagementagent [327]
Path: /System/Library/CoreServices/backgroundtaskmanagementagent
Parent: launchd [1]
UID: 502
Task size: 8800 KB
Thread 0xe0f DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10321d000 - 0x103235fff backgroundtaskmanagementagent (71.21) <80C0ABBE-8D6B-39AA-8446-84E19FA003F0> /System/Library/CoreServices/backgroundtaskmanagementagent
Process: backupd [14747]
Path: /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
Parent: launchd [1]
UID: 0
Task size: 25.20 MB
Thread 0x695a48 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3>
10 ??? (backupd + 70623) [0x10ee673df] 1-10
Binary Images:
0x10ee56000 - 0x10eee2fff backupd (283.8) <F8A3842C-A7C2-3198-B49B-D2512CE75868> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
Process: backupd-helper [88]
Path: /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
Parent: launchd [1]
UID: 0
Task size: 25.44 MB
Thread 0x29c DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (backupd-helper + 11557) [0x104c0ed25] 1-10
Binary Images:
0x104c0c000 - 0x104c27fff backupd-helper (283.8) <97CDFC29-4976-3F11-9C90-8A17D1B189C2> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
Process: bird [304]
Path: /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Parent: launchd [1]
UID: 502
Task size: 25.55 MB
Thread 0xcf5 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [300], process received importance donation from com.apple.appkit.xpc.openAndSavePanelService [14737], IO tier 0>
10 ??? (bird + 6065) [0x10048e7b1] 1-10
Binary Images:
0x10048d000 - 0x10048efff bird (575.14) <2CA8458A-F28D-309A-BA2B-EF46C73CDDD8> /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Process: bluetoothd [114]
Path: /usr/sbin/bluetoothd
Parent: launchd [1]
UID: 0
Task size: 13.61 MB
Thread 0x295 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (bluetoothd + 764173) [0x10e1b790d] 1-10
Thread 0x6df Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10e0fd000 - 0x10e35bfff bluetoothd (6007.4.10) <18B938D6-3E4C-3943-A508-7EE6EAA70385> /usr/sbin/bluetoothd
Process: bootinstalld [254]
Path: /usr/libexec/bootinstalld
Parent: launchd [1]
UID: 0
Task size: 10.37 MB
Thread 0x86c DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 ??? (bootinstalld + 21859) [0x10f384563] 1-10
Binary Images:
0x10f37f000 - 0x10f385fff bootinstalld (454.4) <20FE4EFF-9439-3B5C-99E5-44E6FAAE7510> /usr/libexec/bootinstalld
Process: Calendar [14699]
Path: /Applications/Calendar.app/Contents/MacOS/Calendar
Parent: launchd [1]
UID: 502
Task size: 111.99 MB
CPU Time: <0.001s (235.0K cycles, 57.6K instructions, 4.08c/i)
Thread 0x68ae8f DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (235.0K cycles, 57.6K instructions, 4.08c/i)
10 ??? (Calendar + 8179) [0x102003ff3] 1-10
Thread 0x68af53 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Thread 0x6a1f14 Thread name "NetworkLoad" 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, IO tier 0>
10 _runNetworkThread + 480 (GeoServices + 85274) [0x7fff4489cd1a] 1-10
Binary Images:
0x102002000 - 0x10229cfff com.apple.iCal 10.0 (2195.4.3) <41BE0747-F4AC-3600-9D65-355FCCA619C3> /Applications/Calendar.app/Contents/MacOS/Calendar
0x7fff44888000 - 0x7fff451cafff com.apple.GeoServices 1.0 (1363.24.8.15.58) <41BA60FF-66EB-342F-B14B-8CB2C9776745> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
Process: CalendarAgent [361]
Path: /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Parent: launchd [1]
UID: 502
Task size: 90.44 MB
Thread 0xfba DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (CalendarAgent + 6112) [0x10efc37e0] 1-10
Thread 0x12fa Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Thread 0x64313e Thread name "NetworkLoad" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10efc2000 - 0x10efc3fff CalendarAgent (399.2.2) <08EC4AE2-F0BC-39C0-AF42-7EC1D50464FE> /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Process: CallHistoryPluginHelper [444]
Path: /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Parent: launchd [1]
UID: 502
Task size: 22.17 MB
Thread 0x12f2 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (CallHistoryPluginHelper + 5507) [0x10aa99583] 1-10
Binary Images:
0x10aa98000 - 0x10aa99fff CallHistoryPluginHelper (823) <F1F6B8F5-0836-36CC-8EE9-6C6A8FF9FAA1> /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Process: callservicesd [317]
Path: /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Parent: launchd [1]
UID: 502
Task size: 38.60 MB
Thread 0xd91 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (callservicesd + 995987) [0x104e41293] 1-10
10 autoreleasepool<A>(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff4ebf7c68] 1-10
10 ??? (callservicesd + 996172) [0x104e4134c] 1-10
Binary Images:
0x104d4e000 - 0x104eb8fff callservicesd (975.11.5) <42834AA5-C905-3487-9904-FC5F8CF98E4C> /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
0x7fff4ebf4000 - 0x7fff4ebf9fff libswiftObjectiveC.dylib (900.8.49.1) <DCF880C2-D021-36E6-86A1-63845D04E99E> /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process: CalNCService [364]
Path: /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
Parent: launchd [1]
Responsible: CalendarAgent [361]
UID: 502
Task size: 36.57 MB
Thread 0x1033 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 111 (CalNCService + 48854) [0x109c82ed6] 1-10
10 -[NSXPCListener resume] + 165 (Foundation + 485365) [0x7fff2db5f7f5] 1-10
10 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff53ba39ca] 1-10
10 _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff53ba4d4b] 1-10
Binary Images:
0x109c77000 - 0x109c86fff com.apple.CalendarNotification.CalNCService 1.0 (550.4.2) <3E78A650-4787-3F8A-AFB1-0EA606B84B5D> /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
0x7fff53b94000 - 0x7fff53bc1fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
Process: captiveagent [6562]
Path: /usr/libexec/captiveagent
Parent: launchd [1]
UID: 258
Task size: 7420 KB
Thread 0x461a5e DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (captiveagent + 5136) [0x10d1c3410] 1-10
Thread 0x461a62 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Thread 0x461a71 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10d1c2000 - 0x10d1c9fff captiveagent (355.60.1) <32DDFC7A-1CED-3E2C-883E-4DF3B6EA7730> /usr/libexec/captiveagent
Process: cdpd [403]
Path: /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
Parent: launchd [1]
UID: 502
Task size: 12.08 MB
Thread 0x1132 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (cdpd + 5952) [0x1097d4740] 1-10
Binary Images:
0x1097d3000 - 0x1097d4fff cdpd (164.1) <C6876219-23A3-3F02-B75D-CA73FDFE32B7> /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
Process: cfprefsd [124]
Path: /usr/sbin/cfprefsd
Parent: launchd [1]
UID: 0
Task size: 5660 KB
Thread 0x2dd DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10a392000 - 0x10a392fff cfprefsd (1454.90) <465DD400-0C15-3770-B007-869D397BCF6A> /usr/sbin/cfprefsd
Process: cfprefsd [285]
Parent: launchd [1]
UID: 502
Task size: 11.09 MB
Thread 0xbec DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1002d5000 - 0x1002d5fff cfprefsd (1454.90) <465DD400-0C15-3770-B007-869D397BCF6A> /usr/sbin/cfprefsd
Process: cfprefsd [6558]
Parent: launchd [1]
UID: 205
Task size: 1728 KB
Thread 0x461988 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10c55d000 - 0x10c55dfff cfprefsd (1454.90) <465DD400-0C15-3770-B007-869D397BCF6A> /usr/sbin/cfprefsd
Process: ckkeyrolld [373]
Path: /usr/sbin/ckkeyrolld
Parent: launchd [1]
UID: 502
Task size: 15.23 MB
Thread 0x13db DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10eda6000 - 0x10edbcfff ckkeyrolld (736.16) <A5B47935-D097-3292-968D-0A62A928AEE0> /usr/sbin/ckkeyrolld
Process: cloudd [359]
Path: /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Parent: launchd [1]
UID: 502
Task size: 63.35 MB
Thread 0xfc2 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from bird [304], process received importance donation from SafariBookmarksSyncAgent (SafariSupport) [408], IO tier 0>
10 ??? (cloudd + 10314) [0x10b28a84a] 1-10
Thread 0x11e4 Thread name "com.apple.CFStream.LegacyThread" 10 samples (1-10) priority 31 (base 31)
10 _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1511541) [0x7fff2baf9075] 1-10
Thread 0x11ef Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
Thread 0x43486b Thread name "cloudd.mmcs" 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), process sudden termination clean, process unclamped, process received importance donation from bird [304], process received importance donation from SafariBookmarksSyncAgent (SafariSupport) [408], IO tier 1>
10 -[CKDMMCSEngineContext _MMCSThread] + 416 (CloudKitDaemon + 1971205) [0x7fff3dad1405] 1-10
Binary Images:
0x10b288000 - 0x10b28dfff cloudd (736.16) <EE134C1B-707B-30FA-8D0B-565FD4C011E9> /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
0x7fff3d8f0000 - 0x7fff3ddb0fff com.apple.cloudkit.CloudKitDaemon 736.16 (736.16) <59E250E2-70D8-32F6-A1D3-C6C5EBD666CC> /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Versions/A/CloudKitDaemon
Process: CloudKeychainProxy [291]
Path: /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Parent: launchd [1]
UID: 502
Task size: 20.32 MB
Thread 0xc44 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (CloudKeychainProxy + 38922) [0x10848480a] 1-10
Binary Images:
0x10847b000 - 0x10848efff com.apple.security.cloudkeychainproxy3 10.0 (58286.70.7) <A3C3C76E-D578-3FB3-A126-51A675FD7E2C> /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Process: cloudpaird [392]
Path: /System/Library/CoreServices/cloudpaird
Parent: launchd [1]
UID: 502
Task size: 18.80 MB
Thread 0x1351 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (cloudpaird + 68712) [0x10266cc68] 1-10
Binary Images:
0x10265c000 - 0x102687fff cloudpaird (6007.4.10) <38FB3A3D-043E-3AC7-889D-43236BBFB804> /System/Library/CoreServices/cloudpaird
Process: cloudphotosd [410]
Path: /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Parent: launchd [1]
UID: 502
Task size: 24.90 MB
CPU Time: <0.001s (288.3K cycles, 70.2K instructions, 4.11c/i)
Thread 0x135a DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (165.2K cycles, 36.4K instructions, 4.55c/i)
10 main + 115 (cloudphotosd + 736114) [0x10f787b72] 1-10
Thread 0x18ee Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x10f6d4000 - 0x10f7c3fff com.apple.cloudphotosd 3.0 (3291.13.210) <D3E54417-40DD-352F-9057-0CAEC442717A> /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Process: CMFSyncAgent [552]
Path: /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent.app/Contents/MacOS/CMFSyncAgent
Parent: launchd [1]
UID: 502
Task size: 6700 KB
Thread 0x1b87 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (CMFSyncAgent + 5409) [0x10e761521] 1-10
Binary Images:
0x10e760000 - 0x10e763fff com.apple.cmfsyncagent 10.0 (1000) <45D6871D-3AD5-3CBE-9561-F02403A28127> /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent.app/Contents/MacOS/CMFSyncAgent
Process: colorsync.displayservices [239]
Path: /usr/libexec/colorsync.displayservices
Parent: launchd [1]
UID: 0
Task size: 6092 KB
Thread 0x7ee DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (colorsync.displayservices + 12335) [0x109d2502f] 1-10
Binary Images:
0x109d22000 - 0x109d26fff colorsync.displayservices (3325) <65354026-157C-3043-BEC7-D4A8742A9B5F> /usr/libexec/colorsync.displayservices
Process: colorsync.useragent [546]
Path: /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
Parent: launchd [1]
UID: 502
Task size: 11.89 MB
Thread 0x1af6 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (colorsync.useragent + 10945) [0x10718bac1] 1-10
Binary Images:
0x107189000 - 0x10718cfff colorsync.useragent (3325) <3A0DE3FA-B902-3485-B4F6-E90B568BA422> /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
Process: colorsyncd [248]
Path: /usr/libexec/colorsyncd
Parent: launchd [1]
UID: 0
Task size: 6056 KB
Thread 0x81c DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (colorsyncd + 7903) [0x10250dedf] 1-10
Binary Images:
0x10250c000 - 0x10250efff colorsyncd (3325) <98DD19DF-929C-38BB-BA62-B2A178C203AF> /usr/libexec/colorsyncd
Process: com.adobe.acc.installer.v2 [545]
Path: /Library/PrivilegedHelperTools/com.adobe.acc.installer.v2
Parent: launchd [1]
UID: 0
Task size: 13.38 MB
Thread 0x1ae4 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 start + 52 (com.adobe.acc.installer.v2 + 4548) [0x1065591c4] 1-10
10 ??? (com.adobe.acc.installer.v2 + 15584) [0x10655bce0] 1-10
10 ??? (com.adobe.acc.installer.v2 + 5192) [0x106559448] 1-10
Binary Images:
0x106558000 - 0x106587fff com.adobe.acc.installer.v2 <C0A78625-5590-3CC4-B0F7-A20C3E79386E> /Library/PrivilegedHelperTools/com.adobe.acc.installer.v2
Process: com.apple.AccountPolicyHelper [269]
Path: /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Parent: launchd [1]
UID: 0
Task size: 4876 KB
Thread 0x96e DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x106eb7000 - 0x106ec1fff com.apple.AccountPolicyHelper 1.0 (1) <1CF6879C-2950-3952-B84E-7ADD5BFF0B21> /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Process: com.apple.AmbientDisplayAgent [12967]
Path: /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Parent: launchd [1]
UID: 0
Task size: 10.39 MB
Thread 0x57fe3c DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0>
10 main + 320 (com.apple.AmbientDisplayAgent + 11861) [0x10be8ce55] 1-10
Thread 0x57ff11 10 samples (1-10) priority 31 (base 31)
10 ??? (com.apple.AmbientDisplayAgent + 14076) [0x10be8d6fc] 1-10
Binary Images:
0x10be8a000 - 0x10be91fff com.apple.AmbientDisplayAgent 1.0 (110) <0E1D072D-BBAB-3B0F-8A1A-D9CA82A6E0A6> /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Process: com.apple.appkit.xpc.openAndSavePanelService [14737]
Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Architecture: x86_64
Parent: launchd [1]
Responsible: Preview [14729]
UID: 502
Task size: 53.21 MB
CPU Time: <0.001s (379.5K cycles, 129.8K instructions, 2.92c/i)
Thread 0x6931e7 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
<thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Preview [14729], IO tier 0>
10 main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 29592) [0x10111d398] 1-10
10 NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff5048eabe] 1-10
10 -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff50490c15] 1-10
10 _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff53ba4d77] 1-10
10 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff50490df0] 1-10
Thread 0x693217 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x101116000 - 0x101120fff com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <748F24AB-B4A8-3F68-BED4-4522AE356245> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
0x7fff5048c000 - 0x7fff5055bfff com.apple.ViewBridge 343.2 (343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process: com.apple.appstore.PluginXPCService [13342]
Path: /System/Library/PrivateFrameworks/StoreXPCServices.framework/Versions/A/XPCServices/com.apple.appstore.PluginXPCService.xpc/Contents/MacOS/com.apple.appstore.PluginXPCService
Parent: launchd [1]
UID: 502
Task size: 4496 KB
Thread 0x59fe4c DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10c6a0000 - 0x10c6a1fff com.apple.appstore.PluginXPCService 1.0 (658.1) <2D0A8871-08F0-35BB-AA93-8B52447E57BC> /System/Library/PrivateFrameworks/StoreXPCServices.framework/Versions/A/XPCServices/com.apple.appstore.PluginXPCService.xpc/Contents/MacOS/com.apple.appstore.PluginXPCService
Process: com.apple.audio.DriverHelper [177]
Path: /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Parent: launchd [1]
Responsible: coreaudiod [163]
UID: 202
Task size: 7152 KB
Thread 0x434 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102533000 - 0x102535fff com.apple.audio.DriverHelper 1.0 (1) <FD7ED2EE-FF98-375A-B6ED-70146A780CDF> /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Process: com.apple.audio.SandboxHelper [255]
Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Parent: launchd [1]
UID: 202
Task size: 8684 KB
Thread 0x87e DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x106fbf000 - 0x106fc3fff com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process: com.apple.audio.SandboxHelper [679]
Parent: launchd [1]
Responsible: assistantd [365]
UID: 502
Task size: 7712 KB
Thread 0x543b 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x104d91000 - 0x104d95fff com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process: com.apple.audio.SandboxHelper [13420]
Parent: launchd [1]
Responsible: WhatsApp [13411]
UID: 502
Task size: 8632 KB
Thread 0x5a59e3 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10e407000 - 0x10e40bfff com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process: com.apple.audio.SandboxHelper [14029]
Parent: launchd [1]
Responsible: Mail [13967]
UID: 502
Task size: 8624 KB
Thread 0x64b667 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Thread 0x64b66d 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10df12000 - 0x10df16fff com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process: com.apple.BKAgentService [2287]
Path: /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
Parent: launchd [1]
UID: 502
Task size: 15.70 MB
Thread 0x50cef DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 98 (com.apple.BKAgentService + 133351) [0x10e2dd8e7] 1-10
Binary Images:
0x10e2bd000 - 0x10e332fff com.apple.BKAgentService 1.11 (80) <70392DA3-A00E-3E60-91F5-DDCCEB1E0699> /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
Process: com.apple.CharacterPicker.FileService [608]
Path: /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.apple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
Parent: launchd [1]
UID: 502
Task size: 9636 KB
Thread 0x2453 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
10 main + 16 (com.apple.CharacterPicker.FileService + 3710) [0x10909ce7e] 1-10
Binary Images:
0x10909c000 - 0x1090a4fff com.apple.CharacterPicker.FileService 1.0 (1) <29ECA86B-046C-383B-8C0C-01CBDA74FA4E> /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.apple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
Process: com.apple.CloudPhotosConfiguration [509]
Path: /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Parent: launchd [1]
UID: 502
Task size: 21.44 MB
Thread 0x18ef DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 24 (com.apple.CloudPhotosConfiguration + 10395) [0x10734989b] 1-10
10 +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 10717) [0x1073499dd] 1-10
10 -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 10929) [0x107349ab1] 1-10
Binary Images:
0x107347000 - 0x107358fff com.apple.CloudPhotosConfiguration 3.0 (3291.13.210) <1A5B8C4D-1151-3C85-A1EA-F614FF24AA32> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Process: com.apple.cmio.registerassistantservice [273]
Path: /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
Parent: launchd [1]
UID: 0
Task size: 1020 KB
Thread 0x9e8 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10f3a8000 - 0x10f3a9fff com.apple.cmio.registerassistantservice 1.1 (1.1) <2BE013CC-784F-315D-BFBF-3DDD76A4389E> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
Process: com.apple.CodeSigningHelper [250]
Path: /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Parent: launchd [1]
UID: 0
Task size: 9928 KB
Thread 0x846 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10131d000 - 0x10131efff com.apple.CodeSigningHelper 1.0 (1) <7470BDAA-098A-3358-A0E8-34F91DD6CD78> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Process: com.apple.CommerceKit.TransactionService [13345]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Parent: launchd [1]
Responsible: storeassetd [4241]
UID: 502
Task size: 33.58 MB
Thread 0x59feb2 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Thread 0x5a1aa0 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x103d04000 - 0x103ee3fff com.apple.CommerceKit.TransactionService 1.0 (658.1) <C8722E58-2B7B-3D5E-9795-E7C79C6B5D38> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Process: com.apple.CommerceKit.TransactionService [13395]
Parent: launchd [1]
Responsible: storedownloadd [644]
UID: 502
Task size: 12.87 MB
Thread 0x5a1fb6 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x104ae6000 - 0x104cc5fff com.apple.CommerceKit.TransactionService 1.0 (658.1) <C8722E58-2B7B-3D5E-9795-E7C79C6B5D38> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Process: com.apple.ctkpcscd [165]
Path: /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Parent: launchd [1]
Responsible: securityd [98]
UID: 0
Task size: 8520 KB
Thread 0x40d DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10d95c000 - 0x10d966fff com.apple.ctkpcscd 1.0 (1) <718182BE-A017-368A-BD14-E2C276060B30> /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Process: com.apple.dock.extra [435]
Path: /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Parent: launchd [1]
Responsible: Dock [296]
UID: 502
Task size: 26.69 MB
CPU Time: <0.001s (361.9K cycles, 85.4K instructions, 4.24c/i)
Thread 0x129c DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (167.5K cycles, 35.0K instructions, 4.78c/i)
<thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
10 ??? (com.apple.dock.extra + 4160) [0x1020ae040] 1-10
10 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
10 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
Thread 0x12ac Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x1020ad000 - 0x1020b0fff com.apple.dock.extra 1.0 (1) <D6F5E0A6-F6BC-3701-BBC2-FC36DBBD5FD5> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Process: com.apple.geod [350]
Path: /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Parent: launchd [1]
UID: 502
Task size: 26.05 MB
CPU Time: <0.001s (160.1K cycles, 40.9K instructions, 3.92c/i)
Thread 0xee6 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (com.apple.geod + 117269) [0x10750da15] 1-10
Thread 0xefc Thread name "NetworkLoad" 10 samples (1-10) priority 4 (base 4)
Thread 0x140f Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1074f1000 - 0x107515fff com.apple.geod 1.0 (1363.24.8.15.58) <C57D1E31-9D64-378D-A547-87E54F334F42> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Process: com.apple.geod [6555]
Parent: launchd [1]
UID: 205
Task size: 17.09 MB
Thread 0x46196e DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (com.apple.geod + 117269) [0x10a252a15] 1-10
Thread 0x4619d3 Thread name "NetworkLoad" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10a236000 - 0x10a25afff com.apple.geod 1.0 (1363.24.8.15.58) <C57D1E31-9D64-378D-A547-87E54F334F42> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Process: com.apple.geod [6573]
Parent: launchd [1]
UID: 0
Task size: 18.47 MB
Thread 0x462f36 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (com.apple.geod + 117269) [0x1090f5a15] 1-10
Thread 0x462f44 Thread name "NetworkLoad" 10 samples (1-10) priority 4 (base 4)
10 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
10 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
10 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
Thread 0x462f5e Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1090d9000 - 0x1090fdfff com.apple.geod 1.0 (1363.24.8.15.58) <C57D1E31-9D64-378D-A547-87E54F334F42> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Process: com.apple.hiservices-xpcservice [606]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Parent: launchd [1]
UID: 502
Task size: 6300 KB
Thread 0x240d DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102b14000 - 0x102b18fff com.apple.hiservices-xpcservice 1.22 (624.1) <57D3EA7E-079E-3569-90BF-760970CEC426> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Process: com.apple.iCloudHelper [14838]
Path: /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Parent: launchd [1]
UID: 502
Task size: 16.26 MB
Thread 0x6a204b DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 166 (com.apple.iCloudHelper + 13784) [0x1059a25d8] 1-10
10 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
10 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
10 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
10 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
*10 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
Binary Images:
0x10599f000 - 0x1059b1fff com.apple.iCloudHelper 1.07 (267) <C3CFD1CF-B8DC-375D-AFE6-C017BB4F13A5> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Process: com.apple.ifdreader [212]
Path: /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Parent: launchd [1]
UID: 0
Task size: 9076 KB
Thread 0x559 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 1115 (com.apple.ifdreader + 6238) [0x10edfc85e] 1-10
Binary Images:
0x10edfb000 - 0x10ee07fff com.apple.ifdreader 1.0 (1) <88A3A996-79B8-327E-8EBE-928BA94E85BE> /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Process: com.apple.iTunesLibraryService [456]
Path: /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Parent: launchd [1]
UID: 502
Task size: 10.74 MB
Thread 0x15f3 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1035b6000 - 0x103685fff com.apple.iTunesLibraryService 12.8 (12.8.0) <B1A8AC6B-3939-3E21-A6DF-FA35822BC5EE> /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process: com.apple.iTunesLibraryService [4725]
Parent: launchd [1]
Responsible: assistant_service [1932]
UID: 502
Task size: 10.55 MB
Thread 0x323db2 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10e3ef000 - 0x10e4befff com.apple.iTunesLibraryService 12.8 (12.8.0) <B1A8AC6B-3939-3E21-A6DF-FA35822BC5EE> /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process: com.apple.MediaLibraryService [650]
Path: /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
Parent: launchd [1]
Responsible: cloudphotosd [410]
UID: 502
Task size: 33.13 MB
Thread 0x385c DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 100 (com.apple.MediaLibraryService + 4242) [0x10c03b092] 1-10
Binary Images:
0x10c03a000 - 0x10c044fff com.apple.MediaLibraryService 1.4.0 (751) <DDC29838-6393-3B83-AF5C-C2AFAA1BC6BB> /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
Process: com.apple.Notes.datastore [2086]
Path: /System/Library/PrivateFrameworks/NotesShared.framework/Versions/A/XPCServices/com.apple.Notes.datastore.xpc/Contents/MacOS/com.apple.Notes.datastore
Parent: launchd [1]
UID: 502
Task size: 7264 KB
Thread 0x46179 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 187 (com.apple.Notes.datastore + 8880) [0x1054582b0] 1-10
10 ??? (com.apple.Notes.datastore + 5610) [0x1054575ea] 1-10
Binary Images:
0x105456000 - 0x10545dfff com.apple.Notes.datastore 1.0 (876.1) <C1CC0FC3-7037-300D-B8FA-FCB2F625A233> /System/Library/PrivateFrameworks/NotesShared.framework/Versions/A/XPCServices/com.apple.Notes.datastore.xpc/Contents/MacOS/com.apple.Notes.datastore
Process: com.apple.notificationcenterui.WeatherSummary [412]
Path: /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
Parent: launchd [1]
Responsible: NotificationCenter (Notification Center) [351]
UID: 502
Task size: 15.17 MB
Thread 0x114a DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from NotificationCenter (Notification Center) [351], IO tier 0>
10 main + 147 (com.apple.notificationcenterui.WeatherSummary + 6381) [0x1045378ed] 1-10
Binary Images:
0x104536000 - 0x104538fff com.apple.notificationcenterui.WeatherSummary 1.0 (639.10) <65779B7C-13C9-350D-A85C-7E3FF02A7AE3> /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
0x7fff2b988000 - 0x7fff2be29fff com.apple.CoreFoundation 6.9 (1454.90) <E5D594BF-9142-3325-A62D-CF4AAF472642> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2dae9000 - 0x7fff2deaffff com.apple.Foundation 6.9 (1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff53849000 - 0x7fff53866fff libdyld.dylib (551.4) <81BF3A82-5719-3B54-ABA9-76C82D932CAC> /usr/lib/system/libdyld.dylib
0x7fff5397e000 - 0x7fff539a4fff libsystem_kernel.dylib (4570.71.2) <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2> /usr/lib/system/libsystem_kernel.dylib
Process: com.apple.PerformanceAnalysis.animationperfd [264]
Path: /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Parent: launchd [1]
UID: 0
Task size: 9664 KB
Thread 0x8ef DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
*10 ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
Thread 0x6a7953 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x105f6e000 - 0x105f77fff com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <0AA66B5A-1407-37B8-B870-6F82CDDF8DBA> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
0x7fff5380f000 - 0x7fff53848fff libdispatch.dylib (913.60.2) <232C69BD-022E-3AB9-8807-79F9FA7CB5EC> /usr/lib/system/libdispatch.dylib
*0xffffff7f82a20000 - 0xffffff7f82a2bfff com.apple.kec.pthread 1.0 (1) <E64F7A49-CBF0-3251-9F02-3655E3B3DD31> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.2) <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F> /System/Library/Kernels/kernel
Process: com.apple.photomodel [1069]
Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS/com.apple.photomodel
Parent: launchd [1]
Responsible: photolibraryd [527]
UID: 502
Sudden Term: Tracked (allows idle exit)
Task size: 20.34 MB
Note: 1 idle work queue thread omitted
Thread 0x18690 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x109ba0000 - 0x109ba5fff com.apple.photomodel 3.0 (3291.13.210) <C4CD8C02-A4B8-3D77-A904-FE28F1299640> /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS/com.apple.photomodel
Process: com.apple.photomoments [572]
Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Parent: launchd [1]
UID: 502
Task size: 23.56 MB
Thread 0x1e5a DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 502 (com.apple.photomoments + 6432) [0x102332920] 1-10
Thread 0x1f4f Thread name "NetworkLoad" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102331000 - 0x102336fff com.apple.photomoments 3.0 (3291.13.210) <AA1E8961-8AF9-3EFB-B686-E0B54CD96699> /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Process: com.apple.quicklook.ThumbnailsAgent [647]
Path: /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Parent: launchd [1]
UID: 502
Task size: 10.91 MB
Thread 0x3842 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (com.apple.quicklook.ThumbnailsAgent + 44149) [0x10366fc75] 1-10
Binary Images:
0x103665000 - 0x10367bfff com.apple.quicklook.ThumbnailsAgent (49.3) <2CCABD6D-4748-33E4-9287-7F84A1C0068A> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Process: com.apple.sbd [916]
Path: /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
Parent: launchd [1]
UID: 502
Task size: 22.64 MB
CPU Time: <0.001s (129.0K cycles, 40.8K instructions, 3.16c/i)
Thread 0x11eb2 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (com.apple.sbd + 263959) [0x10f1d8717] 1-10
Thread 0x323dc0 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
10 __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
10 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
Binary Images:
0x10f198000 - 0x10f1f6fff com.apple.sbd 1.0 (297.60.1) <F5852541-5EA4-3542-9E8B-09E6A283710C> /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
0x7fff2a914000 - 0x7fff2acaefff com.apple.CFNetwork 902.1 (902.1) <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff53b5f000 - 0x7fff53b6afff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
Process: com.apple.siri-distributed-evaluation [1643]
Path: /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
Parent: launchd [1]
UID: 502
Task size: 6580 KB
Thread 0x29eb0 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 278 (com.apple.siri-distributed-evaluation + 23706) [0x103e1dc9a] 1-10
Binary Images:
0x103e18000 - 0x103e1ffff com.apple.siri-distributed-evaluation 1.0 (1) <ED7885E1-6369-3D20-88AD-4C7A38634120> /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
Process: com.apple.speech.speechsynthesisd [2018]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Parent: launchd [1]
UID: 502
Task size: 27.63 MB
Thread 0x3caa3 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (com.apple.speech.speechsynthesisd + 6851) [0x10030aac3] 1-10
Binary Images:
0x100309000 - 0x10031bfff com.apple.speech.speechsynthesisd (7.8.1) <FE1B6A3D-027C-31CA-8307-81EA3024F86C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Process: com.apple.speech.speechsynthesisd [2122]
Parent: launchd [1]
UID: 0
Task size: 20.10 MB
Thread 0x48411 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (com.apple.speech.speechsynthesisd + 6851) [0x1003c0ac3] 1-10
Binary Images:
0x1003bf000 - 0x1003d1fff com.apple.speech.speechsynthesisd (7.8.1) <FE1B6A3D-027C-31CA-8307-81EA3024F86C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Process: com.apple.tonelibraryd [3827]
Path: /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple.tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd
Parent: launchd [1]
UID: 502
Task size: 4760 KB
Thread 0x2e7552 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10abb3000 - 0x10abb5fff com.apple.tonelibraryd 1.0 (1) <6565AA93-2C77-3F40-8302-F18604DB4598> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple.tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd
Process: com.apple.WeatherKitService [937]
Path: /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Parent: launchd [1]
UID: 502
Task size: 148.90 MB
Thread 0x12782 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10bea1000 - 0x10bebffff com.apple.WeatherKitService 2.0 (153.4.1) <7C726DFB-2DE6-3FB9-AD43-8D90659FEE60> /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Process: com.apple.WeatherKitService [6557]
Parent: launchd [1]
UID: 502
Task size: 50.59 MB
Thread 0x4619af DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x107889000 - 0x1078a7fff com.apple.WeatherKitService 2.0 (153.4.1) <7C726DFB-2DE6-3FB9-AD43-8D90659FEE60> /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Process: com.apple.WebKit.Networking [13970]
Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Parent: launchd [1]
UID: 502
Task size: 38.48 MB
CPU Time: <0.001s (317.9K cycles, 68.3K instructions, 4.66c/i)
Note: 2 idle work queue threads omitted
Thread 0x63d759 DispatchQueue 1 10 samples (1-10) priority 37 (base 37) cpu time <0.001s (168.6K cycles, 33.7K instructions, 5.00c/i)
<thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mail [13967], IO tier 0>
10 ??? (com.apple.WebKit.Networking + 5793) [0x1044e66a1] 1-10
10 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
Thread 0x63d763 10 samples (1-10) priority 37 (base 37)
10 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 40 (JavaScriptCore + 12744344) [0x7fff2f683698] 1-10
10 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 12743513) [0x7fff2f683359] 1-10
10 bmalloc::Scavenger::threadRunLoop() + 251 (JavaScriptCore + 12744027) [0x7fff2f68355b] 1-10
10 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 86 (JavaScriptCore + 12744870) [0x7fff2f6838a6] 1-10
10 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 27824) [0x7fff5179ecb0] 1-10
10 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
*10 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
Thread 0x63d775 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 37 (base 37)
Thread 0x63ff06 Thread name "com.apple.CFNetwork.CustomProtocols" 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Mail [13967], IO tier 0>
Binary Images:
0x1044e5000 - 0x1044e6fff com.apple.WebKit.Networking 13605 (13605.3.8) <557AF506-FABE-3607-B9A2-FD24A7CABD24> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
0x7fff2ea5c000 - 0x7fff2f742fff com.apple.JavaScriptCore 13605 (13605.3.8) <E6B49CDA-72F0-3E58-85EF-98AF10CE04B0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff51798000 - 0x7fff517eefff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
Process: com.apple.WebKit.WebContent [13969]
Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Parent: launchd [1]
UID: 502
Task size: 193.11 MB
Thread 0x63d756 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
10 ??? (com.apple.WebKit.WebContent + 5793) [0x10dced6a1] 1-10
10 NSApplicationMain + 804 (AppKit + 23154) [0x7fff28f6ca72] 1-10
10 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
10 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
10 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
10 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
Thread 0x63d76e Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
10 _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
Thread 0x63d76f 10 samples (1-10) priority 37 (base 37)
<thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0>
Thread 0x63d776 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 37 (base 37)
Thread 0x63d77f Thread name "WebCore: Scrolling" 10 samples (1-10) priority 46 (base 46)
10 WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 13865) [0x7fff2ea5f629] 1-10
10 WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 228 (JavaScriptCore + 12712596) [0x7fff2f67ba94] 1-10
10 WebCore::ScrollingThread::initializeRunLoop() + 253 (WebCore + 264893) [0x7fff38d69abd] 1-10
10 CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
Binary Images:
0x10dcec000 - 0x10dcedfff com.apple.WebKit.WebContent 13605 (13605.3.8) <8D62BE72-9344-303A-A15A-A8B5AC3BFCA3> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
0x7fff28f67000 - 0x7fff29dc5fff com.apple.AppKit 6.9 (1561.60.100) <3C27CF6F-E640-3411-A87D-CCB2222CC754> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2acc8000 - 0x7fff2afcdfff com.apple.HIToolbox 2.1.1 (911.10) <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff38d29000 - 0x7fff3a3fcfff com.apple.WebCore 13605 (13605.3.8) <2F0DA536-2C93-3EB2-9FFE-13AE1B40C4DC> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
Process: com.apple.WebKit.WebContent [14688]
Parent: launchd [1]
UID: 502
Task size: 108.36 MB
Thread 0x689643 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
10 ??? (com.apple.WebKit.WebContent + 5793) [0x10adfd6a1] 1-10
Thread 0x68965d Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Thread 0x68967d 10 samples (1-10) priority 37 (base 37)
Thread 0x689680 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 37 (base 37)
Thread 0x689686 Thread name "WebCore: Scrolling" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x10adfc000 - 0x10adfdfff com.apple.WebKit.WebContent 13605 (13605.3.8) <8D62BE72-9344-303A-A15A-A8B5AC3BFCA3> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process: CommCenter [295]
Path: /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
Parent: launchd [1]
UID: 502
Task size: 31.63 MB
CPU Time: <0.001s (519.5K cycles, 162.2K instructions, 3.20c/i)
Note: 3 idle work queue threads omitted
Thread 0xc82 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 0>
10 ??? (CommCenter + 396898) [0x10da73e62] 1-10
10 ??? (CommCenter + 398500) [0x10da744a4] 1-10
Thread 0xd67 10 samples (1-10) priority 31 (base 31)
10 ATCSThreadStartStub(void*) + 30 (libATCommandStudioDynamic.dylib + 21438) [0x7fff510623be] 1-10
10 ATCSTimerDriver::startATCSTimerDispatcher(void*) + 9 (libATCommandStudioDynamic.dylib + 24189) [0x7fff51062e7d] 1-10
10 ATCSTimerDriver::timerDispatcher() + 47 (libATCommandStudioDynamic.dylib + 24499) [0x7fff51062fb3] 1-10
10 ATCSCondition::wait(ATCSMutex*, int) + 123 (libATCommandStudioDynamic.dylib + 22347) [0x7fff5106274b] 1-10
Thread 0xd74 10 samples (1-10) priority 31 (base 31)
10 ??? (CommCenter + 4606456) [0x10de779f8] 1-10
Thread 0xd75 10 samples (1-10) priority 31 (base 31)
10 ??? (CommCenter + 586189) [0x10daa21cd] 1-10
Thread 0xd88 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (79.8K cycles, 20.3K instructions, 3.93c/i)
10 ??? (CommCenter + 4271617) [0x10de25e01] 1-10
10 ??? (CommCenter + 4272063) [0x10de25fbf] 1-10
Binary Images:
0x10da13000 - 0x10e167fff CommCenter (5793) <6F9ADD82-C588-3CCD-953E-F05EEECE4C2F> /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
0x7fff5105d000 - 0x7fff510a2fff libATCommandStudioDynamic.dylib (1992) <9C49CEB1-E998-366E-AA69-B39A40EA5C23> /usr/lib/libATCommandStudioDynamic.dylib
Process: commerce [349]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
Parent: launchd [1]
UID: 502
Task size: 50.21 MB
Thread 0xee5 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
10 ??? (commerce + 132208) [0x10e152470] 1-10
Thread 0x17c2 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
Binary Images:
0x10e132000 - 0x10e343fff commerce (658.1) <EEA40253-8DD2-38B0-9C5D-775302C0D1BC> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
Process: configd [67]
Path: /usr/libexec/configd
Parent: launchd [1]
UID: 0
Task size: 13.74 MB
CPU Time: <0.001s (1334.6K cycles, 444.9K instructions, 3.00c/i)
Thread 0x272 DispatchQueue 1 Thread name "SCDynamicStore" 10 samples (1-10) priority 37 (base 37) cpu time <0.001s (1334.6K cycles, 444.9K instructions, 3.00c/i)
<thread QoS user initiated (requested user initiated), process sudden termination clean, IO tier 0>
10 ??? (configd + 12387) [0x10344e063] 1-10
10 ??? (configd + 17462) [0x10344f436] 1-10
Thread 0x2d2 Thread name "Main plugin thread" 10 samples (1-10) priority 31 (base 31)
10 ??? (configd + 20390) [0x10344ffa6] 1-10
Thread 0x315 Thread name "InterfaceNamer thread" 10 samples (1-10) priority 31 (base 31)
10 ??? (configd + 76327) [0x10345da27] 1-10
Thread 0x31a 10 samples (1-10) priority 31 (base 31)
10 pppcntl_run_thread + 704 (PPPController + 56719) [0x103534d8f] 1-10
Thread 0x31e Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
10 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff5399acf2] 1-10
Thread 0x3cb 10 samples (1-10) priority 31 (base 31)
10 captived_thread + 267 (CaptiveNetworkSupport + 18849) [0x1046049a1] 1-10
Thread 0x3d8 10 samples (1-10) priority 31 (base 31)
10 ??? (EAPOLController + 18669) [0x10358b8ed] 1-10
Binary Images:
0x10344b000 - 0x1034a5fff configd (963.50.8) <3EC09458-0806-3C00-B0A1-C110B418F3C3> /usr/libexec/configd
0x103527000 - 0x103564fff com.apple.SystemConfiguration.PPPController 1.10 (1.10) <BE2873E8-2F5F-3F32-8DC3-197CB344F048> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
0x103587000 - 0x10358dfff com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0) <0A38C3FD-2851-36EB-BD17-756ED276BEFB> /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
0x104600000 - 0x104620fff com.apple.SystemConfiguration.CaptiveNetworkSupport 16.0.0 (1.0) <6BBDFDEF-5517-322C-894F-5421AA407BF8> /System/Library/SystemConfiguration/CaptiveNetworkSupport.bundle/Contents/MacOS/CaptiveNetworkSupport
Process: ContactsAccountsService [322]
Path: /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Parent: launchd [1]
UID: 502
Task size: 16.20 MB
Thread 0xddf DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (ContactsAccountsService + 13639) [0x10f7bb547] 1-10
Binary Images:
0x10f7b8000 - 0x10f7bffff ContactsAccountsService (1808.8) <F9C4F587-62A6-309A-B160-B379DF438137> /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Process: ContactsAgent [443]
Path: /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
Parent: launchd [1]
UID: 502
Task size: 16.41 MB
Thread 0x12e0 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 102 (ContactsAgent + 8795) [0x7fff3e21e25b] 1-10
Binary Images:
0x10fced000 - 0x10fcedfff ContactsAgent (12) <6FFF41A8-B6BF-3712-AB6A-2EE13F554297> /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
0x7fff3e21c000 - 0x7fff3e232fff com.apple.ContactsAgent 1.0 (1) <A1E5B0AA-EF48-36CE-A1BD-0B2F2758E0E3> /System/Library/PrivateFrameworks/ContactsAgent.framework/Versions/A/ContactsAgent
Process: contactsdonationagent [2085]
Path: /System/Library/PrivateFrameworks/ContactsDonation.framework/Versions/A/Support/contactsdonationagent
Parent: launchd [1]
UID: 502
Task size: 22.87 MB
Thread 0x46161 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (contactsdonationagent + 13693) [0x1060eb57d] 1-10
Binary Images:
0x1060e8000 - 0x10613ffff contactsdonationagent (38.2) <00D93B5E-2868-3D03-82DD-33DC19F55EE9> /System/Library/PrivateFrameworks/ContactsDonation.framework/Versions/A/Support/contactsdonationagent
Process: ContainerMetadataExtractor [434]
Path: /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadataExtractor.xpc/Contents/MacOS/ContainerMetadataExtractor
Parent: launchd [1]
Responsible: bird [304]
UID: 502
Task size: 12.75 MB
Thread 0x1294 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (ContainerMetadataExtractor + 14876) [0x10b4c1a1c] 1-10
Binary Images:
0x10b4be000 - 0x10b4c5fff com.apple.CloudDocsDaemon.container-metadata-extractor 1.0 (575.14) <7A6A7700-3A76-39E0-A515-C531D19806EE> /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadataExtractor.xpc/Contents/MacOS/ContainerMetadataExtractor
Process: ContextService [618]
Path: /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
Parent: launchd [1]
UID: 502
Task size: 8916 KB
Thread 0x2c82 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
10 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
Binary Images:
0x103e64000 - 0x10426ffff com.apple.siri.context.service 1.0 (1) <11C06E93-8975-3430-A164-D89A0A555D1A> /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
Process: Core Sync [506]
Path: /Applications/Utilities/Adobe Sync/*/Core Sync.app/Contents/MacOS/Core Sync
Parent: launchd [1]
UID: 502
Task size: 40.67 MB
CPU Time: 0.001s (2.2M cycles, 621.0K instructions, 3.55c/i)
Process: coreaudiod [163]
Path: /usr/sbin/coreaudiod
Parent: launchd [1]
UID: 202
Task size: 16.70 MB
Thread 0x3f4 DispatchQueue 1 10 samples (1-10) priority 63 (base 63)
<process sudden termination dirty, IO tier 0>
10 ??? (coreaudiod + 171569) [0x1081dbe31] 1-10
Thread 0x41b Thread name "HAL Async Logger" 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, IO tier 0>
10 ??? (coreaudiod + 263571) [0x1081f2593] 1-10
10 ??? (coreaudiod + 262405) [0x1081f2105] 1-10
10 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246] 1-10
*10 semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90] 1-10
Thread 0x48d Thread name "Audio HAL Overload Reporting Spool" 10 samples (1-10) priority 31 (base 31)
Thread 0x4ac Thread name "SystemSoundServer" 10 samples (1-10) priority 61 (base 61)
10 CAPThread::Entry(CAPThread*) + 77 (AudioToolbox + 69913) [0x7fff2a372119] 1-10
10 GenericRunLoopThread::Entry(void*) + 158 (AudioToolbox + 70666) [0x7fff2a37240a] 1-10
Binary Images:
0x1081b2000 - 0x108341fff coreaudiod (93.13.6.1) <877517E9-45F2-3674-9AB3-E106607B679E> /usr/sbin/coreaudiod
0x7fff2a361000 - 0x7fff2a5effff com.apple.audio.toolbox.AudioToolbox 1.14 (1.14) <E0B8B5D8-80A0-308B-ABD6-F8612102B5D8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
Process: coreauthd [270]
Path: /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Parent: launchd [1]
UID: 0
Task size: 10.09 MB
Thread 0x9a3 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (coreauthd + 33981) [0x107cb34bd] 1-10
Binary Images:
0x107cab000 - 0x107cd6fff coreauthd (425.70.1) <E802A99A-0734-3DB7-8510-6FE801E68778> /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Process: coreauthd [332]
Parent: launchd [1]
UID: 502
Task size: 11.16 MB
Thread 0xe39 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (coreauthd + 33981) [0x1073644bd] 1-10
Binary Images:
0x10735c000 - 0x107387fff coreauthd (425.70.1) <E802A99A-0734-3DB7-8510-6FE801E68778> /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Process: corebrightnessd [116]
Path: /usr/libexec/corebrightnessd
Parent: launchd [1]
UID: 0
Task size: 55.15 MB
Thread 0x296 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 main + 582 (corebrightnessd + 5961) [0x10daf9749] 1-10
Binary Images:
0x10daf8000 - 0x10daf9fff corebrightnessd (592.70.11) <F1409A70-1C86-3917-B330-A43EE595D721> /usr/libexec/corebrightnessd
Process: coreduetd [89]
Path: /usr/libexec/coreduetd
Parent: launchd [1]
UID: 0
Task size: 39.21 MB
Thread 0x29d DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (coreduetd + 225624) [0x10be75158] 1-10
Binary Images:
0x10be3e000 - 0x10bed4fff coreduetd (915.50.54) <C036A795-056D-362E-9C00-95D1A15670EB> /usr/libexec/coreduetd
Process: CoreLocationAgent [348]
Path: /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
Parent: launchd [1]
UID: 502
Task size: 16.85 MB
Thread 0xecb DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
Thread 0xf10 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 37 (base 37)
<thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0>
Binary Images:
0x1000a2000 - 0x1000a8fff com.apple.CoreLocationAgent 1486.12 (1486.12) <81888D2C-6E76-3157-8AFE-B391723C5CDC> /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
Process: coreservicesd [143]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
Parent: launchd [1]
UID: 0
Task size: 13.98 MB
Thread 0x377 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 _CoreServicesServerMain + 710 (CarbonCore + 563987) [0x7fff2cc00b13] 1-10
Thread 0x3c9 10 samples (1-10) priority 31 (base 31)
10 fmodWatchConsumer + 290 (CarbonCore + 307304) [0x7fff2cbc2068] 1-10
Thread 0x3ca 10 samples (1-10) priority 31 (base 31)
10 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff5399c142] 1-10
*10 hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 1-10
*10 unix_syscall64 + 616 (kernel + 6306152) [0xffffff8000803968] 1-10
*10 read_nocancel + 115 (kernel + 5532931) [0xffffff8000746d03] 1-10
*10 ??? (kernel + 5533541) [0xffffff8000746f65] 1-10
*10 ??? (kernel + 2958502) [0xffffff80004d24a6] 1-10
*10 ??? (kernel + 5438002) [0xffffff800072fa32] 1-10
*10 thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
*10 ??? (kernel + 554618) [0xffffff800028767a] 1-10
*10 machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
Binary Images:
0x10f72e000 - 0x10f72efff coreservicesd (1178.4) <0B40BA4C-501A-3249-8EA7-9A954D104C3D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
0x7fff2cb77000 - 0x7fff2ce4efff com.apple.CoreServices.CarbonCore 1178.4 (1178.4) <0D5E19BF-18CB-3FA4-8A5F-F6C787C5EE08> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
Process: CoreServicesUIAgent [13376]
Path: /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Parent: launchd [1]
UID: 502
Task size: 19.85 MB
CPU Time: <0.001s (273.4K cycles, 75.2K instructions, 3.63c/i)
Thread 0x5a16f8 DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (153.3K cycles, 40.9K instructions, 3.75c/i)
Thread 0x5a1703 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 37 (base 37)
<thread QoS user initiated (requested user interactive), process sudden termination dirty, IO tier 0>
Binary Images:
0x10dce4000 - 0x10dd13fff com.apple.coreservices.uiagent 180.7.6 (180.7.6) <1CE9BAFA-C20F-39C7-9BDE-D484BE211D38> /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Process: corespotlightd [404]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
Parent: launchd [1]
UID: 502
Task size: 25.89 MB
Thread 0x1354 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (corespotlightd + 38395) [0x107d195fb] 1-10
Thread 0x16b5 10 samples (1-10) priority 31 (base 31)
10 <truncated backtrace> 1-10
Binary Images:
0x107d10000 - 0x107d1cfff corespotlightd (1191.4.13) <811549E5-277A-36A6-B74B-8832EC988C48> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
Process: coresymbolicationd [621]
Path: /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Parent: launchd [1]
UID: 0
Task size: 6592 KB
Thread 0x2ec2 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x108d67000 - 0x108d72fff coresymbolicationd (64026.2) <150AABEC-EC13-355E-9733-94A7574EA8B2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Process: crashpad_handler [14321]
Path: /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Framework.framework/Versions/A/Helpers/crashpad_handler
Parent: launchd [1]
Responsible: Google Chrome (Chrome) [14319]
UID: 502
Task size: 9128 KB
Thread 0x67510f DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested user interactive), process unclamped, IO tier 0>
10 ??? (crashpad_handler + 19428) [0x1033b3be4] 1-10
10 ??? (crashpad_handler + 30381) [0x1033b66ad] 1-10
10 ??? (crashpad_handler + 213369) [0x1033e3179] 1-10
10 ??? (crashpad_handler + 211822) [0x1033e2b6e] 1-10
Thread 0x675111 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process unclamped, IO tier 0>
10 ??? (crashpad_handler + 189130) [0x1033dd2ca] 1-10
10 ??? (crashpad_handler + 184201) [0x1033dbf89] 1-10
10 ??? (crashpad_handler + 221694) [0x1033e51fe] 1-10
10 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 39246) [0x7fff5381894e] 1-10
10 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 78430) [0x7fff5399125e] 1-10
Thread 0x675112 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x1033af000 - 0x103416fff crashpad_handler (0) <89815085-974F-3592-A3D6-E3087F1A8542> /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Framework.framework/Versions/A/Helpers/crashpad_handler
Process: CrashReporterSupportHelper [355]
Path: /System/Library/CoreServices/CrashReporterSupportHelper
Parent: launchd [1]
UID: 0
Task size: 5540 KB
Thread 0xf50 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (CrashReporterSupportHelper + 8490) [0x10c5ae12a] 1-10
Binary Images:
0x10c5ac000 - 0x10c5aefff CrashReporterSupportHelper (938.4.1) <854C933E-AC36-3638-A76B-F9CA2004B9A4> /System/Library/CoreServices/CrashReporterSupportHelper
Process: Creative Cloud [394]
Path: /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
Parent: launchd [1]
UID: 502
Task size: 169.04 MB
CPU Time: <0.001s (533.4K cycles, 189.0K instructions, 2.82c/i)
Process: ctkahp (Smartcard Agent) [261]
Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Parent: launchd [1]
UID: 0
Task size: 10176 KB
Thread 0x8ad DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 685 (ctkahp + 10627) [0x1048da983] 1-10
Binary Images:
0x1048d8000 - 0x1048edfff com.apple.ctkahp 1.0 (1) <E71E82FF-6955-3F74-A94C-062EBE5F4A5E> /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process: ctkahp (Smartcard Agent) [326]
Parent: launchd [1]
UID: 502
Task size: 10.31 MB
Thread 0xe01 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 685 (ctkahp + 10627) [0x1019d6983] 1-10
Binary Images:
0x1019d4000 - 0x1019e9fff com.apple.ctkahp 1.0 (1) <E71E82FF-6955-3F74-A94C-062EBE5F4A5E> /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process: ctkahp (Smartcard Agent) [7777]
Parent: launchd [1]
UID: 0
Task size: 10.22 MB
Thread 0x4a5b46 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 685 (ctkahp + 10627) [0x10ea25983] 1-10
Binary Images:
0x10ea23000 - 0x10ea38fff com.apple.ctkahp 1.0 (1) <E71E82FF-6955-3F74-A94C-062EBE5F4A5E> /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process: ctkd [172]
Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Parent: launchd [1]
UID: 259
Task size: 9888 KB
Thread 0x42f DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1015c7000 - 0x1015d5fff ctkd (281.50.22) <E10EFE63-B99D-3B51-8A27-75CBA24F0F82> /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process: ctkd [330]
Parent: launchd [1]
UID: 502
Task size: 10.11 MB
Thread 0xe30 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x103841000 - 0x10384ffff ctkd (281.50.22) <E10EFE63-B99D-3B51-8A27-75CBA24F0F82> /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process: ctkd [7778]
Parent: launchd [1]
UID: 0
Task size: 10.13 MB
Thread 0x4a5b55 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x100b04000 - 0x100b12fff ctkd (281.50.22) <E10EFE63-B99D-3B51-8A27-75CBA24F0F82> /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process: cupsd [215]
Path: /usr/sbin/cupsd
Parent: launchd [1]
UID: 0
Task size: 14.64 MB
CPU Time: <0.001s (38.5K cycles, 14.6K instructions, 2.63c/i)
Thread 0x58e DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (38.5K cycles, 14.6K instructions, 2.63c/i)
10 ??? (cupsd + 95390) [0x1008c949e] 1-10
10 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff5399bbea] 1-10
*10 ??? (kernel + 5263408) [0xffffff8000705030] 1-10
Thread 0x9ef 10 samples (1-10) priority 4 (base 4)
10 ??? (cupsd + 267948) [0x1008f36ac] 1-10
Binary Images:
0x1008b2000 - 0x100906fff cupsd (462.2.4) <71AC0E67-CEEB-35ED-8E57-E2547A8957D9> /usr/sbin/cupsd
Process: CVMServer [238]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Parent: launchd [1]
UID: 0
Task size: 2780 KB
Thread 0x7d6 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10d3c2000 - 0x10d3cbfff CVMServer (162.9) <C679EB4C-B2ED-361A-ACF8-701750092336> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process: dasd [105]
Path: /usr/libexec/dasd
Parent: launchd [1]
UID: 0
Task size: 12.53 MB
Thread 0x29f DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (dasd + 5977) [0x10074f759] 1-10
Thread 0x6a5619 10 samples (1-10) priority 4 (base 4)
<thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
*10 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] 1-10
Binary Images:
0x10074e000 - 0x10074ffff dasd (626.60.2) <C9006AD5-7EB0-3BAD-92C5-2D1395F6E31E> /usr/libexec/dasd
Process: DataDetectorsSourceAccess [10611]
Path: /usr/libexec/DataDetectorsSourceAccess
Parent: launchd [1]
UID: 257
Task size: 6680 KB
Thread 0x51e3b3 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (DataDetectorsSourceAccess + 6003) [0x100253773] 1-10
Binary Images:
0x100252000 - 0x100253fff DataDetectorsSourceAccess (590.3) <AD510217-DEE0-3BF6-9605-9D522C0AEC13> /usr/libexec/DataDetectorsSourceAccess
Process: dbfseventsd [500]
Path: /Library/DropboxHelperTools/*/dbfseventsd
Parent: Dropbox [334]
Responsible: Dropbox [334]
UID: 0
Task size: 844 KB
CPU Time: <0.001s (69.3K cycles, 22.2K instructions, 3.12c/i)
Thread 0x18b2 DispatchQueue 140735545517656 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (69.3K cycles, 22.2K instructions, 3.12c/i)
10 ??? (dbfseventsd + 4884) [0x100001314] 1-10
10 ??? (dbfseventsd + 5139) [0x100001413] 1-10
Binary Images:
0x100000000 - 0x10000afff dbfseventsd <1F6C7C58-8553-3992-B509-6FB5841E0D40> /Library/DropboxHelperTools/*/dbfseventsd
Process: dbfseventsd [501]
Parent: dbfseventsd [500]
UID: 0
Task size: 4596 KB
CPU Time: <0.001s (344.1K cycles, 111.5K instructions, 3.09c/i)
Thread 0x18b3 DispatchQueue 140735545517656 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (344.1K cycles, 111.5K instructions, 3.09c/i)
<IO tier 0>
10 ??? (dbfseventsd + 5753) [0x100001679] 1-10
Binary Images:
Process: dbfseventsd [508]
Parent: dbfseventsd [501]
UID: 502
Task size: 380 KB
CPU Time: <0.001s (281.6K cycles, 129.8K instructions, 2.17c/i)
Thread 0x18e6 DispatchQueue 140735545517656 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (281.6K cycles, 129.8K instructions, 2.17c/i)
<IO tier 0>
10 ??? (dbfseventsd + 12657) [0x100003171] 1-10
*10 ??? (kernel + 5555689) [0xffffff800074c5e9] 1-10
*10 ??? (kernel + 5437670) [0xffffff800072f8e6] 1-10
*10 lck_mtx_sleep + 126 (kernel + 505086) [0xffffff800027b4fe] 1-10
Binary Images:
Process: deleted [445]
Path: /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Parent: launchd [1]
UID: 502
Task size: 10.82 MB
Thread 0x1336 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10dc1a000 - 0x10dc69fff deleted (275.50.16) <2C603149-CAD5-3BA8-B39F-D9232E821ACB> /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Process: diagnostics_agent [396]
Path: /System/Library/CoreServices/diagnostics_agent
Parent: launchd [1]
UID: 502
Task size: 16.70 MB
Thread 0x1352 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 3>
10 ??? (diagnostics_agent + 21724) [0x10172e4dc] 1-10
Binary Images:
0x101729000 - 0x101746fff diagnostics_agent (938.4.1) <D40D8F7D-D9D3-39EA-A535-E700EB826A0D> /System/Library/CoreServices/diagnostics_agent
Process: diskarbitrationd [83]
Path: /usr/libexec/diskarbitrationd
Parent: launchd [1]
UID: 0
Task size: 7740 KB
CPU Time: <0.001s (533.1K cycles, 274.6K instructions, 1.94c/i)
Thread 0x280 DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (533.1K cycles, 274.6K instructions, 1.94c/i)
10 ??? (diskarbitrationd + 27830) [0x10b9accb6] 1-10
Binary Images:
0x10b9a6000 - 0x10b9bdfff diskarbitrationd (297.70.1) <190EF73F-C204-31BC-BD51-E1BE4DEAF90A> /usr/libexec/diskarbitrationd
Process: diskmanagementd [229]
Path: /usr/libexec/diskmanagementd
Parent: launchd [1]
UID: 0
Task size: 18.99 MB
Thread 0x74c DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), IO tier 0>
10 ??? (diskmanagementd + 49804) [0x10b64328c] 1-10
Thread 0x13a4 10 samples (1-10) priority 31 (base 31)
10 ??? (diskmanagementd + 76451) [0x10b649aa3] 1-10
Thread 0x750e 10 samples (1-10) priority 31 (base 31)
Thread 0x7f80 10 samples (1-10) priority 31 (base 31)
Thread 0x87a8 10 samples (1-10) priority 31 (base 31)
Thread 0xbdb0 10 samples (1-10) priority 31 (base 31)
Thread 0xf860 10 samples (1-10) priority 31 (base 31)
Thread 0x13535 10 samples (1-10) priority 31 (base 31)
Thread 0x5a044b 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10b637000 - 0x10b831fff diskmanagementd (1429) <B1F49E51-9C20-3670-9D83-F2DAD960CD12> /usr/libexec/diskmanagementd
Process: diskspaced [1788]
Path: /System/Library/PrivateFrameworks/StorageManagement.framework/Versions/A/Resources/diskspaced
Parent: launchd [1]
UID: 502
Task size: 10032 KB
Thread 0x2f936 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
Binary Images:
0x10f39a000 - 0x10f39efff diskspaced (60) <39D1E240-DAEF-3869-8778-18DC88CA7F38> /System/Library/PrivateFrameworks/StorageManagement.framework/Versions/A/Resources/diskspaced
Process: DiskUnmountWatcher [707]
Path: /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
Architecture: x86_64
Parent: launchd [1]
UID: 502
Task size: 4364 KB
Thread 0x6f39 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10b6ee000 - 0x10b6eefff DiskUnmountWatcher (157) <D55A63EB-FE63-3FA4-B217-E5DA1DA50B85> /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
Process: displaypolicyd [104]
Path: /usr/libexec/displaypolicyd
Parent: launchd [1]
UID: 244
Task size: 9916 KB
Thread 0x28e DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
10 ??? (displaypolicyd + 10537) [0x10ca60929] 1-10
10 ??? (displaypolicyd + 9717) [0x10ca605f5] 1-10
Thread 0x4f7 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
10 ??? (displaypolicyd + 94635) [0x10ca751ab] 1-10
10 __accept + 10 (libsystem_kernel.dylib + 114382) [0x7fff53999ece] 1-10
*10 accept_nocancel + 417 (kernel + 5787665) [0xffffff8000785011] 1-10
Thread 0x880 10 samples (1-10) priority 20 (base 20)
10 ??? (displaypolicyd + 119276) [0x10ca7b1ec] 1-10
10 ??? (displaypolicyd + 118820) [0x10ca7b024] 1-10
Thread 0x8ae 10 samples (1-10) priority 20 (base 20)
10 ??? (displaypolicyd + 62677) [0x10ca6d4d5] 1-10
10 ??? (displaypolicyd + 51415) [0x10ca6a8d7] 1-10
Thread 0x8af 10 samples (1-10) priority 20 (base 20)
10 ??? (displaypolicyd + 62690) [0x10ca6d4e2] 1-10
10 ??? (displaypolicyd + 53266) [0x10ca6b012] 1-10
Binary Images:
0x10ca5e000 - 0x10ca91fff displaypolicyd (3.20.13) <31BC90AD-12FD-3ABD-956F-15E192DD8541> /usr/libexec/displaypolicyd
Process: distnoted [120]
Path: /usr/sbin/distnoted
Parent: launchd [1]
UID: 241
Task size: 5644 KB
CPU Time: 0.007s (28.1M cycles, 9.9M instructions, 2.82c/i)
Note: 9 idle work queue threads omitted
Thread 0x3b7 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (distnoted + 16199) [0x10e732f47] 1-10
Thread 0x6a5d71 DispatchQueue 29 1 sample (5) priority 37 (base 37) cpu time <0.001s (75.3K cycles, 28.4K instructions, 2.65c/i)
<DispatchQueue not seen for 4 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0>
1 ??? [0x7000047dc8e0] 5
1 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 5
1 _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff53b61fd2] 5
1 _dispatch_workloop_worker_thread + 880 (libdispatch.dylib + 109857) [0x7fff53829d21] 5
1 _dispatch_root_queue_drain_deferred_wlh + 332 (libdispatch.dylib + 93965) [0x7fff53825f0d] 5
1 _dispatch_queue_invoke + 373 (libdispatch.dylib + 37222) [0x7fff53818166] 5
1 _dispatch_queue_serial_drain + 222 (libdispatch.dylib + 90234) [0x7fff5382507a] 5
1 _dispatch_mach_invoke + 534 (libdispatch.dylib + 22898) [0x7fff53814972] 5
1 _dispatch_mach_msg_invoke + 488 (libdispatch.dylib + 28770) [0x7fff53816062] 5
1 _dispatch_client_callout4 + 9 (libdispatch.dylib + 28073) [0x7fff53815da9] 5
1 _xpc_connection_mach_event + 1092 (libxpc.dylib + 40753) [0x7fff53b9df31] 5
1 _xpc_connection_call_event_handler + 35 (libxpc.dylib + 46963) [0x7fff53b9f773] 5
1 ??? (distnoted + 23509) [0x10e734bd5] 5
1 xpc_dictionary_get_bool + 35 (libxpc.dylib + 21352) [0x7fff53b99368] 5
1 _xpc_dictionary_look_up_fast + 68 (libxpc.dylib + 21483) [0x7fff53b993eb] 5
1 _xpc_dictionary_look_up + 668 (libxpc.dylib + 20411) [0x7fff53b98fbb] 5
1 _xpc_serializer_advance + 27 (libxpc.dylib + 30357) [0x7fff53b9b695] 5
*1 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 5
*1 thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 5
*1 ??? (kernel + 554223) [0xffffff80002874ef] (running) 5
Thread 0x6a278c DispatchQueue 35 1 sample (5) priority 37 (base 37) cpu time <0.001s
1 ??? [0x2e6d6f6300000018] 5
1 _dispatch_mach_send_barrier_drain_invoke + 412 (libdispatch.dylib + 115086) [0x7fff5382b18e] 5
1 _dispatch_mach_send_invoke + 674 (libdispatch.dylib + 115890) [0x7fff5382b4b2] 5
1 _dispatch_mach_send_drain + 241 (libdispatch.dylib + 29259) [0x7fff5381624b] 5
1 _dispatch_continuation_pop + 86 (libdispatch.dylib + 85247) [0x7fff53823cff] 5
1 _dispatch_mach_barrier_invoke + 605 (libdispatch.dylib + 27981) [0x7fff53815d4d] 5
1 _dispatch_set_priority_and_voucher_slow + 314 (libdispatch.dylib + 81547) [0x7fff53822e8b] 5
1 _dispatch_set_priority_and_mach_voucher_slow + 160 (libdispatch.dylib + 81097) [0x7fff53822cc9] 5
1 __bsdthread_ctl + 10 (libsystem_kernel.dylib + 114526) [0x7fff53999f5e] 5
*1 hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 5
*1 unix_syscall64 + 647 (kernel + 6306183) [0xffffff8000803987] (running) 5
Thread 0x6a5d6f DispatchQueue 130 1 sample (5) priority 37 (base 37) cpu time <0.001s (56.4K cycles, 21.7K instructions, 2.60c/i)
<DispatchQueue not seen for 4 samples, thread QoS user initiated (requested user initiated), process sudden termination dirty, IO tier 0>
1 ??? [0x10f201880] 5
1 _dispatch_queue_serial_drain + 635 (libdispatch.dylib + 90647) [0x7fff53825217] 5
1 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 5
1 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 5
1 ??? (distnoted + 24249) [0x10e734eb9] 5
1 ??? (distnoted + 6463) [0x10e73093f] 5
1 ??? (distnoted + 8379) [0x10e7310bb] 5
1 ??? (distnoted + 22870) [0x10e734956] 5
1 xpc_connection_send_message + 89 (libxpc.dylib + 43885) [0x7fff53b9eb6d] 5
1 _xpc_connection_enqueue + 136 (libxpc.dylib + 39563) [0x7fff53b9da8b] 5
1 dispatch_mach_send_with_result + 50 (libdispatch.dylib + 116564) [0x7fff5382b754] 5
1 _dispatch_mach_send_msg + 394 (libdispatch.dylib + 116330) [0x7fff5382b66a] 5
1 _dispatch_mach_send_drain + 325 (libdispatch.dylib + 29343) [0x7fff5381629f] 5
1 _dispatch_mach_msg_send + 799 (libdispatch.dylib + 25466) [0x7fff5381537a] 5
1 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 5
*1 hndl_mach_scall64 + 22 (kernel + 125414) [0xffffff800021e9e6] 5
*1 mach_call_munger64 + 509 (kernel + 1513245) [0xffffff800037171d] 5
*1 mach_msg_overwrite_trap + 891 (kernel + 398667) [0xffffff800026154b] 5
*1 ipc_kmsg_send + 599 (kernel + 322519) [0xffffff800024ebd7] 5
*1 ipc_mqueue_send + 95 (kernel + 337375) [0xffffff80002525df] 5
*1 ipc_mqueue_post + 620 (kernel + 338284) [0xffffff800025296c] 5
*1 knote + 175 (kernel + 5240911) [0xffffff80006ff84f] 5
*1 ??? (kernel + 5237875) [0xffffff80006fec73] 5
*1 ??? (kernel + 5240563) [0xffffff80006ff6f3] 5
*1 workq_kern_threadreq + 507 (pthread + 24284) [0xffffff7f82a25edc] 5
*1 workqueue_run_threadreq_and_unlock + 4687 (pthread + 13219) [0xffffff7f82a233a3] 5
*1 thread_wakeup_thread + 61 (kernel + 559757) [0xffffff8000288a8d] 5
*1 waitq_wakeup64_thread + 165 (kernel + 742165) [0xffffff80002b5315] (running) 5
Thread 0x6a71f6 1 sample (5) priority 37 (base 37)
<Thread not seen for 4 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0>
1 ??? [0x1800009000] 5
1 __workq_kernreturn + 10 (libsystem_kernel.dylib + 119434) [0x7fff5399b28a] 5
*1 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] (runnable) 5
Binary Images:
0x10e72f000 - 0x10e737fff distnoted (1454.90) <3A0A8968-10C3-3D51-BAEE-6B3BA785B324> /usr/sbin/distnoted
0x7fff53b94000 - 0x7fff53bc1fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
Process: distnoted [287]
Parent: launchd [1]
UID: 502
Task size: 9840 KB
CPU Time: 0.010s (41.8M cycles, 22.5M instructions, 1.85c/i)
Note: 12 idle work queue threads omitted
Thread 0xc1d DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
10 ??? (distnoted + 16199) [0x1045e7f47] 1-10
Thread 0x6a61f9 DispatchQueue 23 1 sample (5) priority 37 (base 37) cpu time <0.001s (73.0K cycles, 21.8K instructions, 3.34c/i)
1 ??? [0x7fe7e2d4a600] 5
1 _xpc_connection_mach_event + 1068 (libxpc.dylib + 40729) [0x7fff53b9df19] 5
1 _xpc_connection_unpack_message + 97 (libxpc.dylib + 41714) [0x7fff53b9e2f2] 5
1 _xpc_serializer_unpack + 735 (libxpc.dylib + 29128) [0x7fff53b9b1c8] 5
1 _xpc_dictionary_wire_length + 0 (libxpc.dylib + 30116) [0x7fff53b9b5a4] (running) 5
Binary Images:
0x1045e4000 - 0x1045ecfff distnoted (1454.90) <3A0A8968-10C3-3D51-BAEE-6B3BA785B324> /usr/sbin/distnoted
Process: distnoted [641]
Parent: launchd [1]
UID: 89
Task size: 3840 KB
CPU Time: 0.001s (5.6M cycles, 849.6K instructions, 6.57c/i)
Thread 0x379c DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (distnoted + 16199) [0x10c753f47] 1-10
Thread 0x6a5d74 1 sample (5) priority 37 (base 37) cpu time <0.001s
<Thread in another stack for 4 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0>
1 ??? [0x70000bbcd8e0] 5
1 _dispatch_workloop_worker_thread + 518 (libdispatch.dylib + 109495) [0x7fff53829bb7] 5
1 _dispatch_event_loop_merge + 117 (libdispatch.dylib + 129100) [0x7fff5382e84c] 5
1 _dispatch_mach_merge_msg + 42 (libdispatch.dylib + 113259) [0x7fff5382aa6b] (running) 5
Binary Images:
0x10c750000 - 0x10c758fff distnoted (1454.90) <3A0A8968-10C3-3D51-BAEE-6B3BA785B324> /usr/sbin/distnoted
Process: distnoted [6561]
Parent: launchd [1]
UID: 205
Task size: 3120 KB
CPU Time: 0.001s (5.3M cycles, 739.9K instructions, 7.19c/i)
Thread 0x4619e7 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (distnoted + 16199) [0x10409cf47] 1-10
Thread 0x6a5e32 1 sample (5) priority 37 (base 37) cpu time <0.001s
*1 wq_unpark_continue + 644 (pthread + 15879) [0xffffff7f82a23e07] 5
*1 _setup_wqthread + 813 (pthread + 17598) [0xffffff7f82a244be] 5
*1 kevent_id_internal + 55 (kernel + 5264583) [0xffffff80007054c7] 5
*1 ??? (kernel + 5255434) [0xffffff800070310a] 5
*1 kqueue_scan + 77 (kernel + 5260509) [0xffffff80007044dd] 5
*1 ??? (kernel + 5263124) [0xffffff8000704f14] 5
*1 ??? (kernel + 359179) [0xffffff8000257b0b] 5
*1 mach_msg_receive_results + 545 (kernel + 396625) [0xffffff8000260d51] 5
*1 ipc_kmsg_copyout + 31 (kernel + 334367) [0xffffff8000251a1f] 5
*1 ipc_kmsg_copyout_header + 815 (kernel + 330831) [0xffffff8000250c4f] 5
*1 ipc_right_copyout + 260 (kernel + 372916) [0xffffff800025b0b4] (running) 5
Binary Images:
0x104099000 - 0x1040a1fff distnoted (1454.90) <3A0A8968-10C3-3D51-BAEE-6B3BA785B324> /usr/sbin/distnoted
Process: distnoted [6575]
Parent: launchd [1]
UID: 0
Task size: 3132 KB
CPU Time: <0.001s (798.7K cycles, 290.1K instructions, 2.75c/i)
Thread 0x462f5d DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (distnoted + 16199) [0x107118f47] 1-10
Thread 0x6a5dea 1 sample (5) priority 37 (base 37)
Binary Images:
0x107115000 - 0x10711dfff distnoted (1454.90) <3A0A8968-10C3-3D51-BAEE-6B3BA785B324> /usr/sbin/distnoted
Process: dmd [382]
Path: /usr/libexec/dmd
Parent: launchd [1]
UID: 502
Task size: 12.31 MB
Thread 0x134f DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (dmd + 271704) [0x10f1cc558] 1-10
10 ??? (dmd + 232339) [0x10f1c2b93] 1-10
Binary Images:
0x10f18a000 - 0x10f1dcfff dmd (10.48) <4BADAEBD-D0FA-39C2-A0F1-A85124F1B807> /usr/libexec/dmd
Process: dmd [460]
Parent: launchd [1]
UID: 0
Task size: 11.46 MB
Thread 0x154b DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (dmd + 271704) [0x102969558] 1-10
10 ??? (dmd + 243607) [0x102962797] 1-10
10 ??? (dmd + 232339) [0x10295fb93] 1-10
Binary Images:
0x102927000 - 0x102979fff dmd (10.48) <4BADAEBD-D0FA-39C2-A0F1-A85124F1B807> /usr/libexec/dmd
Process: Dock [296]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
Parent: launchd [1]
UID: 502
Task size: 152.89 MB
Thread 0xc91 DispatchQueue 1 10 samples (1-10) priority 47 (base 47)
<process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 ??? (Dock + 24889) [0x1078fa139] 1-10
10 autoreleasepool<A>(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff4ebf7c68] 1-10
10 ??? (Dock + 1722302) [0x107a987be] 1-10
10 ??? (Dock + 1722509) [0x107a9888d] 1-10
10 ??? (Dock + 1722382) [0x107a9880e] 1-10
Thread 0x1282 10 samples (1-10) priority 31 (base 31)
<process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 ??? (Dock + 142843) [0x107916dfb] 1-10
Binary Images:
0x1078f4000 - 0x107e1cfff com.apple.dock 1.8 (1849.16) <2FA55534-87F6-3967-8AFF-589C0DA1467E> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
0x7fff4ebf4000 - 0x7fff4ebf9fff libswiftObjectiveC.dylib (900.8.49.1) <DCF880C2-D021-36E6-86A1-63845D04E99E> /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process: DocumentPopoverViewService [14734]
Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewService.xpc/Contents/MacOS/DocumentPopoverViewService
Parent: launchd [1]
Responsible: Preview [14729]
UID: 502
Task size: 36.91 MB
Thread 0x692f76 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
<thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
10 main + 37 (DocumentPopoverViewService + 4317) [0x10c8df0dd] 1-10
10 NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff5048eabe] 1-10
10 -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff50490c15] 1-10
10 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff53ba39ca] 1-10
10 _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff53ba4d77] 1-10
10 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
10 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff50490df0] 1-10
10 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
Thread 0x692fab Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
10 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
10 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
10 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
Binary Images:
0x10c8de000 - 0x10c8e5fff com.apple.appkit.xpc.documentPopoverViewService 6.9 (1) <C2FA80BC-5559-3B57-8E76-15405A4806CF> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewService.xpc/Contents/MacOS/DocumentPopoverViewService
0x7fff5048c000 - 0x7fff5055bfff com.apple.ViewBridge 343.2 (343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process: dprivacyd [2134]
Path: /usr/libexec/dprivacyd
Parent: launchd [1]
UID: 0
Task size: 7772 KB
Thread 0x48f33 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10bc40000 - 0x10bc40fff dprivacyd (142.70.1) <00206B9B-F631-3F17-B56D-181915533A65> /usr/libexec/dprivacyd
Process: Dropbox [334]
Path: /Applications/Dropbox.app/Contents/MacOS/Dropbox
Parent: launchd [1]
UID: 502
Task size: 317.92 MB
CPU Time: <0.001s (1599.0K cycles, 1013.5K instructions, 1.58c/i)
Process: Dropbox [339]
Parent: launchd [1]
UID: 502
Task size: 9572 KB
Process: Dropbox [341]
UID: 502
Task size: 11.20 MB
Process: DropboxActivityProvider [471]
Path: /Applications/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider
Parent: launchd [1]
UID: 502
Task size: 59.96 MB
CPU Time: <0.001s (668.8K cycles, 181.9K instructions, 3.68c/i)
Process: DropboxFolderTagger [502]
Path: /Applications/Dropbox.app/Contents/XPCServices/DropboxFolderTagger.xpc/Contents/MacOS/DropboxFolderTagger
Parent: launchd [1]
UID: 502
Task size: 14.22 MB
Process: EscrowSecurityAlert [915]
Path: /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Parent: launchd [1]
UID: 502
Task size: 22.21 MB
Thread 0x11eab DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (EscrowSecurityAlert + 18185) [0x10c48c709] 1-10
10 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
10 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
10 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
10 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
*10 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
Binary Images:
0x10c488000 - 0x10c48dfff com.apple.EscrowSecurityAlert 1.0 (1) <9C289894-1B14-3C87-8A2E-87702CF0013B> /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Process: ethcheck [210]
Path: /usr/libexec/firmwarecheckers/ethcheck/ethcheck
Parent: launchd [1]
UID: 0
Task size: 3804 KB
Thread 0x593 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x109c7e000 - 0x109c85fff ethcheck (25.50.1) <FC4392A0-243E-3F2F-88F8-A49C43265ACD> /usr/libexec/firmwarecheckers/ethcheck/ethcheck
Process: filecoordinationd [321]
Path: /usr/sbin/filecoordinationd
Parent: launchd [1]
UID: 0
Task size: 7448 KB
Thread 0xdcb DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x107745000 - 0x107745fff filecoordinationd (1454.90) <3C05FCCF-7704-3833-9292-C5D732E17C90> /usr/sbin/filecoordinationd
Process: fileproviderd [371]
Path: /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
Parent: launchd [1]
UID: 502
Task size: 12.64 MB
Thread 0x127c DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (fileproviderd + 10191) [0x104c727cf] 1-10
Binary Images:
0x104c70000 - 0x104ca9fff fileproviderd (125.15) <E6C02333-F680-32D9-B352-B61D9CDAB1DB> /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
Process: Finder [300]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Parent: launchd [1]
UID: 502
Task size: 202.27 MB (+1556 KB)
CPU Time: 0.030s (129.4M cycles, 67.3M instructions, 1.92c/i)
Thread 0xc9c DispatchQueue 1 10 samples (1-10) priority 47 (base 47) cpu time 0.025s (108.0M cycles, 58.4M instructions, 1.85c/i)
<process frontmost, thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 ??? (Finder + 23182) [0x103b7fa8e] 1-10
1 -[NSApplication run] + 812 (AppKit + 223413) [0x7fff28f9d8b5] 1
1 ??? (Finder + 125336) [0x103b98998] 1
1 -[NSApplication(NSEvent) sendEvent:] + 2060 (AppKit + 8216740) [0x7fff2973d0a4] 1
1 -[NSApplication _handleKeyFocusNotification:withEvent:] + 83 (AppKit + 4576849) [0x7fff293c4651] 1
1 -[NSWindow becomeKeyWindow] + 1357 (AppKit + 1460464) [0x7fff290cb8f0] 1
1 -[NSWindow(NSWindow_Theme) acquireKeyAppearance] + 170 (AppKit + 1463144) [0x7fff290cc368] 1
1 -[NSWindow _setFrameNeedsDisplay:] + 178 (AppKit + 1468133) [0x7fff290cd6e5] 1
1 -[NSThemeFrame _windowChangedKeyState] + 46 (AppKit + 1482617) [0x7fff290d0f79] 1
1 -[NSView _windowChangedKeyState] + 253 (AppKit + 906394) [0x7fff2904449a] 1
1 -[NSSplitView _windowChangedKeyState] + 70 (AppKit + 1484135) [0x7fff290d1567] 1
1 -[NSBrowser _windowChangedKeyState] + 42 (AppKit + 4780852) [0x7fff293f6334] 1
1 -[NSControl _windowChangedKeyState] + 48 (AppKit + 906003) [0x7fff29044313] 1
1 -[NSTableView _windowChangedKeyState] + 50 (AppKit + 1485173) [0x7fff290d1975] 1
1 -[NSTableRowView _windowChangedKeyState] + 44 (AppKit + 1488554) [0x7fff290d26aa] 1
1 ??? (Finder + 2532107) [0x103de430b] 1
1 ??? (Finder + 2527696) [0x103de31d0] 1
1 +[NSColor colorWithCalibratedWhite:alpha:] + 54 (AppKit + 1003516) [0x7fff2905bffc] 1
1 +[NSObject allocWithZone:] + 16 (libobjc.A.dylib + 44841) [0x7fff52c26f29] 1
1 class_createInstance + 87 (libobjc.A.dylib + 27882) [0x7fff52c22cea] 1
1 calloc + 30 (libsystem_malloc.dylib + 17806) [0x7fff539f558e] 1
1 malloc_zone_calloc + 87 (libsystem_malloc.dylib + 15484) [0x7fff539f4c7c] 1
1 nano_calloc + 72 (libsystem_malloc.dylib + 37253) [0x7fff539fa185] 1
1 OSAtomicDequeue + 17 (libsystem_platform.dylib + 6381) [0x7fff53b588ed] (running) 1
<process dropped importance donation from WindowServer [214]>
9 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 2-10
9 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 2-10
9 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 2-10
9 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 2-10
9 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 2-10
9 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 2-10
9 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 2-10
9 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 2-10
9 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 2-10
9 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 2-10
*9 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 2-10
Thread 0xdfd Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 47 (base 47) cpu time 0.003s (13.5M cycles, 5.7M instructions, 2.38c/i)
*1 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1
Thread 0x3df2 10 samples (1-10) priority 37 (base 37)
<process frontmost, thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [214], IO tier 0>
*1 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1
*9 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 2-10
Thread 0x3df4 Thread name "com.apple.coreanimation.render-server" 10 samples (1-10) priority 55 (base 55)
<process frontmost, process sudden termination dirty, process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 thread_fun + 25 (QuartzCore + 6986) [0x7fff36d6eb4a] 1-10
10 CA::Render::Server::server_thread(void*) + 870 (QuartzCore + 7878) [0x7fff36d6eec6] 1-10
Thread 0x2e3a1a 10 samples (1-10) priority 31 (base 31)
<process frontmost, thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [214], IO tier 0>
10 DRThreadObject::SymbolRoutine(DRThreadObject*) + 9 (DiscRecording + 12709) [0x7fff2d8451a5] 1-10
10 DRThreadObject::StartRoutine(DRThreadObject*) + 111 (DiscRecording + 13067) [0x7fff2d84530b] 1-10
10 DRWorkLoop::WorkLoopEntry(DRWorkLoop*) + 9 (DiscRecording + 13859) [0x7fff2d845623] 1-10
10 DRWorkLoop::WorkLoop() + 237 (DiscRecording + 14115) [0x7fff2d845723] 1-10
Binary Images:
0x103b7a000 - 0x104233fff com.apple.finder 10.13.5 (10.13.5) <3A746B08-E656-3128-B33A-2E61EF388C7B> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
0x7fff2b988000 - 0x7fff2be29fff com.apple.CoreFoundation 6.9 (1454.90) <E5D594BF-9142-3325-A62D-CF4AAF472642> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2d842000 - 0x7fff2d8fcfff com.apple.DiscRecording 9.0.3 (9030.4.5) <35D1FF9A-432C-39AD-9C1F-9022246EC5C0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff36d6d000 - 0x7fff36fb9fff com.apple.QuartzCore 1.11 (584.62) <1950D993-DE48-3C97-95A5-66D98BDFC95D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff52c1c000 - 0x7fff5300afff libobjc.A.dylib (723) <DD9E5EC5-B507-3249-B700-93433E2D5EDF> /usr/lib/libobjc.A.dylib
0x7fff53849000 - 0x7fff53866fff libdyld.dylib (551.4) <81BF3A82-5719-3B54-ABA9-76C82D932CAC> /usr/lib/system/libdyld.dylib
0x7fff5397e000 - 0x7fff539a4fff libsystem_kernel.dylib (4570.71.2) <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2> /usr/lib/system/libsystem_kernel.dylib
0x7fff539f1000 - 0x7fff53a10fff libsystem_malloc.dylib (140.50.6) <7FD43735-9DDD-300E-8C4A-F909A74BDF49> /usr/lib/system/libsystem_malloc.dylib
0x7fff53b57000 - 0x7fff53b5efff libsystem_platform.dylib (161.50.1) <6355EE2D-5456-3CA8-A227-B96E8F1E2AF8> /usr/lib/system/libsystem_platform.dylib
*0xffffff7f82a20000 - 0xffffff7f82a2bfff com.apple.kec.pthread 1.0 (1) <E64F7A49-CBF0-3251-9F02-3655E3B3DD31> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.2) <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F> /System/Library/Kernels/kernel
Process: findmydeviced [199]
Path: /usr/libexec/findmydeviced
Parent: launchd [1]
UID: 0
Sudden Term: Tracked (allows idle exit)
Task size: 20.98 MB
Note: 1 idle work queue thread omitted
Thread 0x490 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (findmydeviced + 89436) [0x10e1ddd5c] 1-10
10 -[FMDaemon run] + 139 (FMCore + 20903) [0x7fff40c8a1a7] 1-10
Thread 0xa04 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10e1c8000 - 0x10e23bfff findmydeviced (287.6.0.1) <43176402-163B-320D-BC53-73503BCD94A0> /usr/libexec/findmydeviced
0x7fff2dae9000 - 0x7fff2deaffff com.apple.Foundation 6.9 (1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff40c85000 - 0x7fff40ca4fff com.apple.icloud.FMCore 1.0 (1) <F570DEE9-2386-33BE-8913-F61CEE2BF93D> /System/Library/PrivateFrameworks/FMCore.framework/Versions/A/FMCore
Process: Firewall [6323]
Path: /usr/libexec/ApplicationFirewall/Firewall
Parent: launchd [1]
UID: 502
Task size: 3976 KB
Thread 0x431f85 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
10 ??? (Firewall + 3428) [0x10ab5dd64] 1-10
10 ??? (Firewall + 3363) [0x10ab5dd23] 1-10
Binary Images:
0x10ab5d000 - 0x10ab5dfff Firewall (176) <7B5B79C1-8A71-3D51-8553-47AF59739F12> /usr/libexec/ApplicationFirewall/Firewall
Process: Flux [331]
Path: /Users/USER/*/Flux.app/Contents/MacOS/Flux
Parent: launchd [1]
UID: 502
Task size: 41.27 MB
CPU Time: <0.001s (720.2K cycles, 277.0K instructions, 2.60c/i)
Process: fmfd [413]
Path: /usr/libexec/fmfd
Parent: launchd [1]
UID: 502
Task size: 49.36 MB
Thread 0x114d DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (fmfd + 22649) [0x1012a7879] 1-10
Thread 0x1b70 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
10 __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
10 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
Binary Images:
0x1012a2000 - 0x1012f8fff fmfd (298.12.1) <5398AEFB-077E-3B4A-94D6-BF15EB619E66> /usr/libexec/fmfd
0x7fff2a914000 - 0x7fff2acaefff com.apple.CFNetwork 902.1 (902.1) <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff53b5f000 - 0x7fff53b6afff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
Process: followupd [407]
Path: /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Parent: launchd [1]
UID: 502
Task size: 8752 KB
Thread 0x1356 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (followupd + 64449) [0x1005e2bc1] 1-10
Binary Images:
0x1005d3000 - 0x1005e8fff followupd (72) <64120FA7-E09B-30B7-A243-67B1CFB5FABE> /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Process: fontd [315]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
Parent: launchd [1]
UID: 502
Task size: 17.19 MB
Thread 0xd76 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user initiated), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 main_handler + 4510 (libATSServer.dylib + 514060) [0x7fff29efe80c] 1-10
Binary Images:
0x10d088000 - 0x10d08bfff fontd (445.4) <1D3EAA8B-B624-3947-AC19-1E7F72DD4912> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
0x7fff29e81000 - 0x7fff29f16fff libATSServer.dylib (445.4) <FC5D665A-64F4-344E-865C-93C1B61CC684> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
Process: fontd [13113]
Parent: launchd [1]
UID: 97
Task size: 13.30 MB
Thread 0x588a53 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10377b000 - 0x10377efff fontd (445.4) <1D3EAA8B-B624-3947-AC19-1E7F72DD4912> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
Process: fontworker [14247]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontworker
Parent: launchd [1]
UID: 502
Task size: 7400 KB
Thread 0x66fd9f DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
*10 ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
Thread 0x66fda1 10 samples (1-10) priority 31 (base 31)
<process sudden termination clean, IO tier 0>
Binary Images:
0x1063dc000 - 0x1063f7fff fontworker (221.4) <561DFBD6-FCA1-3FE5-BB61-B08612E79B8C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontworker
0x7fff5380f000 - 0x7fff53848fff libdispatch.dylib (913.60.2) <232C69BD-022E-3AB9-8807-79F9FA7CB5EC> /usr/lib/system/libdispatch.dylib
Process: fpsd [2286]
Path: /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
Parent: launchd [1]
UID: 265
Task size: 4672 KB
Thread 0x50ce2 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
10 ??? (fpsd + 35365) [0x10edd7a25] 1-10
Thread 0x50ced 10 samples (1-10) priority 4 (base 4)
<thread QoS background, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x10edcf000 - 0x10ee2dfff fpsd (2.13.25) <B7A2A99D-8181-3964-8348-ED12C722AAA6> /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
Process: fseventsd [59]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Parent: launchd [1]
UID: 0
Task size: 13.94 MB
CPU Time: <0.001s (1313.5K cycles, 459.6K instructions, 2.86c/i)
Thread 0x26e DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (fseventsd + 7094) [0x1074eabb6] 1-10
10 mach_msg_server + 369 (libsystem_kernel.dylib + 77668) [0x7fff53990f64] 1-10
Thread 0x2aa 10 samples (1-10) priority 49 (base 49) cpu time <0.001s (242.2K cycles, 85.4K instructions, 2.84c/i)
<IO tier 0>
10 ??? (fseventsd + 51109) [0x1074f57a5] 1-10
10 ??? (fseventsd + 49987) [0x1074f5343] 1-10
10 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
*10 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
Thread 0x2bb 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), IO tier 0 and passive>
10 ??? (fseventsd + 15743) [0x1074ecd7f] 1-10
Thread 0x2bc 10 samples (1-10) priority 50 (base 50) cpu time <0.001s (60.7K cycles, 10.0K instructions, 6.07c/i)
<IO tier 0>
Thread 0x2bd 10 samples (1-10) priority 31 (base 31)
10 ??? (fseventsd + 34901) [0x1074f1855] 1-10
Thread 0x6a14e7 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (187.0K cycles, 78.2K instructions, 2.39c/i)
10 ??? (fseventsd + 34975) [0x1074f189f] 1-10
Thread 0x6a14e8 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (325.0K cycles, 98.8K instructions, 3.29c/i)
Thread 0x6a14e9 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (173.3K cycles, 73.9K instructions, 2.35c/i)
Thread 0x6a14ea 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (325.4K cycles, 113.2K instructions, 2.87c/i)
Thread 0x6a155c 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x1074e9000 - 0x1074f9fff fseventsd (1239.50.1) <357B06BE-3F03-37A6-8569-4A06ED093172> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Process: gamecontrollerd [418]
Path: /usr/libexec/gamecontrollerd
Parent: launchd [1]
UID: 247
Task size: 10092 KB
Note: 2 idle work queue threads omitted
Thread 0x1181 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (gamecontrollerd + 39515) [0x100a95a5b] 1-10
10 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 684117) [0x7fff2db90055] 1-10
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
Binary Images:
0x100a8c000 - 0x100a98fff gamecontrollerd (6.20.11) <2B65303C-C2A6-3693-BC89-A96D78FFBA91> /usr/libexec/gamecontrollerd
Process: garcon [328]
Path: /Applications/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Parent: launchd [1]
UID: 502
Task size: 26.38 MB
CPU Time: <0.001s (272.8K cycles, 75.2K instructions, 3.63c/i)
Process: garcon [14730]
Parent: launchd [1]
UID: 502
Task size: 24.06 MB
Process: garcon [14739]
Parent: launchd [1]
UID: 502
Task size: 24.87 MB
CPU Time: <0.001s (357.9K cycles, 94.3K instructions, 3.80c/i)
Process: Google Chrome (Chrome) [14319]
Path: /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
Parent: launchd [1]
UID: 502
Task size: 343.24 MB
CPU Time: <0.001s (475.2K cycles, 169.6K instructions, 2.80c/i)
Process: Google Chrome Helper (Chrome Helper) [14323]
Path: /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
Parent: Google Chrome (Chrome) [14319]
UID: 502
Task size: 117.37 MB
CPU Time: <0.001s (33.5K cycles, 6.6K instructions, 5.10c/i)
Process: Google Chrome Helper (Chrome Helper) [14334]
UID: 502
Task size: 315.52 MB
Process: Google Chrome Helper (Chrome Helper) [14913]
UID: 502
Task size: 113.01 MB
CPU Time: 0.002s (6.4M cycles, 4.2M instructions, 1.54c/i)
Process: Google Chrome Helper (Chrome Helper) [14915]
UID: 502
Task size: 78.07 MB
Process: Google Chrome Helper (Chrome Helper) [14916]
UID: 502
Task size: 83.90 MB
Process: Google Chrome Helper (Chrome Helper) [14917]
UID: 502
Task size: 70.16 MB
Process: Google Chrome Helper (Chrome Helper) [14918]
UID: 502
Task size: 71.08 MB
Process: Google Chrome Helper (Chrome Helper) [14919]
UID: 502
Task size: 75.62 MB
Process: Google Chrome Helper (Chrome Helper) [14920]
UID: 502
Task size: 41.21 MB
Process: Google Chrome Helper (Chrome Helper) [14921]
UID: 502
Task size: 78.32 MB
Process: Google Chrome Helper (Chrome Helper) [14922]
UID: 502
Task size: 67.20 MB
Process: Google Chrome Helper (Chrome Helper) [14923]
UID: 502
Task size: 35.90 MB
Process: GSSCred [282]
Path: /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
Parent: launchd [1]
UID: 0
Task size: 4560 KB
Thread 0xb72 DispatchQueue 8 10 samples (1-10) priority 20 (base 20)
10 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 1-10
10 _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff53b62169] 1-10
10 _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff53812755] 1-10
10 _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff53812b2c] 1-10
10 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 1-10
10 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 1-10
10 ??? (GSSCred + 11241) [0x10f6a5be9] 1-10
10 au_sdev_read_aia + 528 (libbsm.0.dylib + 60396) [0x7fff51787bec] 1-10
10 fgetc + 52 (libsystem_c.dylib + 246895) [0x7fff538d546f] 1-10
10 __srget + 14 (libsystem_c.dylib + 273977) [0x7fff538dbe39] 1-10
10 __srefill1 + 24 (libsystem_c.dylib + 273694) [0x7fff538dbd1e] 1-10
10 __read_nocancel + 10 (libsystem_kernel.dylib + 117738) [0x7fff5399abea] 1-10
*10 ??? (kernel + 2877244) [0xffffff80004be73c] 1-10
*10 VNOP_READ + 106 (kernel + 2933994) [0xffffff80004cc4ea] 1-10
*10 spec_read + 667 (kernel + 2976283) [0xffffff80004d6a1b] 1-10
*10 ??? (kernel + 5069540) [0xffffff80006d5ae4] 1-10
Thread 0xb74 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
Binary Images:
0x10f6a3000 - 0x10f6aafff GSSCred (520.50.6) <D2BF6D9C-2994-393F-8073-8A2350302B05> /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
0x7fff51779000 - 0x7fff51789fff libbsm.0.dylib (39) <6BC96A72-AFBE-34FD-91B1-748A530D8AE6> /usr/lib/libbsm.0.dylib
0x7fff53899000 - 0x7fff53922fff libsystem_c.dylib (1244.50.9) <1187BFE8-4576-3247-8177-481554E1F9E7> /usr/lib/system/libsystem_c.dylib
Process: hidd [115]
Path: /usr/libexec/hidd
Parent: launchd [1]
UID: 261
Task size: 12.05 MB
CPU Time: 0.004s (12.5M cycles, 4.3M instructions, 2.89c/i)
Thread 0x38d DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (729.2K cycles, 332.9K instructions, 2.19c/i)
<thread QoS default (requested default), process sudden termination clean, IO tier 0>
10 ??? (hidd + 3707) [0x10d5b1e7b] 1-10
10 CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
Thread 0x3c2 Thread name "IOHIDService - RunLoopCompatibilityThread" 10 samples (1-10) priority 63 (base 63)
10 __IOHIDServiceRunLoopCompatibilityThread + 312 (IOKit + 337348) [0x7fff2e2185c4] 1-10
Thread 0x6a77ae 10 samples (1-10) priority 63 (base 63)
10 _dispatch_worker_thread + 251 (libdispatch.dylib + 20051) [0x7fff53813e53] 1-10
Thread 0x6a77b0 10 samples (1-10) priority 63 (base 63) cpu time 0.002s (7.2M cycles, 2.7M instructions, 2.66c/i)
Binary Images:
0x10d5b1000 - 0x10d5b1fff hidd (1035.70.7) <219D5BE8-3DB0-37E6-9F4D-EBA624A8EB99> /usr/libexec/hidd
0x7fff2e1c6000 - 0x7fff2e261fff com.apple.framework.IOKit 2.0.2 (1445.71.1) <2EA4F383-CAA9-3AF0-99C5-90C22ADAA6B6> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
Process: HP Device Monitor [385]
Path: /Library/Printers/hp/Frameworks/HPDeviceMonitoring.framework/Versions/1.0/Helpers/HP Device Monitor Manager.app/Contents/Library/LoginItems/HP Device Monitor.app/Contents/MacOS/HP Device Monitor
Parent: launchd [1]
UID: 502
Task size: 41.22 MB
CPU Time: 0.002s (6.2M cycles, 1968.1K instructions, 3.16c/i)
Process: icdd [384]
Path: /System/Library/Image Capture/Support/icdd
Parent: launchd [1]
UID: 502
Task size: 20.62 MB
CPU Time: <0.001s (230.9K cycles, 62.8K instructions, 3.68c/i)
Thread 0x10c4 DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (121.5K cycles, 30.7K instructions, 3.96c/i)
10 ??? (icdd + 73164) [0x10e288dcc] 1-10
10 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
Binary Images:
0x10e277000 - 0x10e2a9fff icdd (1302.2) <62A2CD68-1146-3FF1-AED6-B1C7FBC50248> /System/Library/Image Capture/Support/icdd
Process: iconservicesagent [82]
Path: /System/Library/CoreServices/iconservicesagent
Parent: launchd [1]
UID: 0
Task size: 7800 KB
Thread 0x622 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Thread 0x5a1eed 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10f066000 - 0x10f06efff iconservicesagent (97.6) <4197DEE5-3700-3F06-8FBB-28364ABC3D35> /System/Library/CoreServices/iconservicesagent
Process: iconservicesagent [311]
Parent: launchd [1]
UID: 502
Task size: 39.05 MB
Thread 0xd3c DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10fa5f000 - 0x10fa67fff iconservicesagent (97.6) <4197DEE5-3700-3F06-8FBB-28364ABC3D35> /System/Library/CoreServices/iconservicesagent
Process: iconservicesd [81]
Path: /System/Library/CoreServices/iconservicesd
Parent: launchd [1]
UID: 240
Task size: 8012 KB
Thread 0x569 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x105484000 - 0x105487fff iconservicesd (97.6) <DC6C1F18-4616-391E-B801-103A9BB458FF> /System/Library/CoreServices/iconservicesd
Process: identityservicesd [318]
Path: /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Parent: launchd [1]
UID: 502
Task size: 34.62 MB
Thread 0xda5 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 main + 290 (identityservicesd + 414659) [0x10a95b3c3] 1-10
Thread 0xf6c Thread name "TransportThread Primary" 10 samples (1-10) priority 31 (base 31)
Thread 0xf6d Thread name "TransportThread URGENT" 10 samples (1-10) priority 31 (base 31)
Thread 0xf6e Thread name "TransportThread Default" 10 samples (1-10) priority 31 (base 31)
Thread 0xf6f Thread name "TransportThread Sync" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10a8f6000 - 0x10af84fff com.apple.identityservicesd 10.0 (1000) <D2F48622-D0BD-304C-AF71-46944207FDCA> /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Process: imagent [320]
Path: /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Parent: launchd [1]
UID: 502
Task size: 29.27 MB
Thread 0xdc2 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (imagent + 40241) [0x10f23fd31] 1-10
Binary Images:
0x10f236000 - 0x10f298fff com.apple.imagent 10.0 (1000) <614B404E-5715-3065-AA27-5ABD0DAE4E19> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Process: IMAutomaticHistoryDeletionAgent [1065]
Path: /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
Parent: launchd [1]
UID: 502
Task size: 17.40 MB
Thread 0x18626 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1060a8000 - 0x1060aafff com.apple.IMAutomaticHistoryDeletionAgent 10.0 (1000) <E2BB3C1A-9BC5-3520-9A5B-AFFDB2A308F0> /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
Process: IMDPersistenceAgent [352]
Path: /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Parent: launchd [1]
UID: 502
Task size: 39.48 MB
Thread 0xf22 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (IMDPersistenceAgent + 5695) [0x104d3663f] 1-10
10 _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff53ba4d4b] 1-10
Binary Images:
0x104d35000 - 0x104d36fff com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000) <A973549C-70C8-324A-BD15-05738DC877D9> /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Process: imklaunchagent [342]
Path: /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Parent: launchd [1]
UID: 502
Task size: 14.14 MB
CPU Time: <0.001s (259.3K cycles, 69.7K instructions, 3.72c/i)
Thread 0xe98 DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (143.0K cycles, 35.6K instructions, 4.01c/i)
<thread QoS default (requested default), process sudden termination dirty, IO tier 0>
10 ??? (imklaunchagent + 25774) [0x10dfa64ae] 1-10
Binary Images:
0x10dfa0000 - 0x10dfacfff imklaunchagent (356.2) <763C8926-FA13-3DFD-A5BC-13189EE734D1> /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Process: imklaunchagent [7765]
Parent: launchd [1]
UID: 0
Task size: 12.70 MB
CPU Time: <0.001s (198.2K cycles, 57.2K instructions, 3.47c/i)
Thread 0x4a5a5c DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (101.9K cycles, 25.9K instructions, 3.94c/i)
10 ??? (imklaunchagent + 25774) [0x10e4b04ae] 1-10
Binary Images:
0x10e4aa000 - 0x10e4b6fff imklaunchagent (356.2) <763C8926-FA13-3DFD-A5BC-13189EE734D1> /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Process: IMRemoteURLConnectionAgent [400]
Path: /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Parent: launchd [1]
Responsible: identityservicesd [318]
UID: 502
Task size: 15.09 MB
Thread 0x110c DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (IMRemoteURLConnectionAgent + 5800) [0x10438c6a8] 1-10
Thread 0x111b Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Thread 0x6a7908 10 samples (1-10) priority 4 (base 4)
<thread QoS background, process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x10438b000 - 0x104395fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <EED530F3-18E2-3EE6-A9E2-93FB49407363> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process: IMRemoteURLConnectionAgent [411]
Parent: launchd [1]
Responsible: callservicesd [317]
UID: 502
Task size: 4740 KB
Thread 0x12b3 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1017e2000 - 0x1017ecfff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <EED530F3-18E2-3EE6-A9E2-93FB49407363> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process: IMRemoteURLConnectionAgent [419]
Parent: launchd [1]
Responsible: imagent [320]
UID: 502
Task size: 13.17 MB
Thread 0x119d DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (IMRemoteURLConnectionAgent + 5800) [0x101a4e6a8] 1-10
Thread 0x11a1 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x101a4d000 - 0x101a57fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <EED530F3-18E2-3EE6-A9E2-93FB49407363> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process: installd [643]
Path: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Parent: launchd [1]
UID: 0
Task size: 183.56 MB
Thread 0x3835 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (installd + 6979) [0x104c9db43] 1-10
Binary Images:
0x104c9c000 - 0x104c9dfff installd (733) <D294CEB0-F980-309C-9015-2C2E228603DC> /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Process: ioupsd [241]
Path: /usr/libexec/ioupsd
Parent: powerd [69]
Responsible: powerd [69]
UID: 0
Task size: 4444 KB
Thread 0x7f9 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (ioupsd + 5356) [0x10c3874ec] 1-10
Thread 0x807 10 samples (1-10) priority 31 (base 31)
<IO tier 0>
Binary Images:
0x10c386000 - 0x10c388fff ioupsd (703.71.1) <5D3D666A-C653-39AB-8207-5B78C4DEFA4F> /usr/libexec/ioupsd
Process: iTunesHelper (iTunes Helper) [338]
Path: /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
Parent: launchd [1]
UID: 502
Task size: 11.61 MB
CPU Time: <0.001s (204.3K cycles, 53.8K instructions, 3.80c/i)
Thread 0xe7a DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (102.0K cycles, 24.2K instructions, 4.22c/i)
<thread QoS default (requested user interactive), IO tier 0>
10 ??? (iTunesHelper + 73490) [0x10a1cff12] 1-10
Thread 0xe80 DispatchQueue 10 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested user initiated), IO tier 0>
10 _dispatch_root_queue_drain + 515 (libdispatch.dylib + 14761) [0x7fff538129a9] 1-10
10 _dispatch_queue_override_invoke + 880 (libdispatch.dylib + 60613) [0x7fff5381dcc5] 1-10
10 __thr_AMRegisterForCallbacks + 426 (MobileDevice + 954529) [0x7fff4729a0a1] 1-10
Thread 0xe8f Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
10 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff5399acf2] 1-10
Binary Images:
0x10a1be000 - 0x10a1e0fff com.apple.iTunesHelper 12.8 (12.8.0) <C6617165-F0B3-30F8-BFDB-8BBD654A7FA5> /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
0x7fff471b1000 - 0x7fff4730cfff com.apple.mobiledevice 988.70.1.100.34 (988.70.1.100.34) <5D9B7AC8-4B6C-3CBF-BCB1-558D2B754C21> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
Process: kdc [106]
Path: /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Parent: launchd [1]
UID: 0
Task size: 8544 KB
Thread 0x64c DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
10 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
Binary Images:
0x103133000 - 0x103165fff kdc (520.50.6) <2432ABB6-F460-3769-BA87-B200BD9190E2> /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Process: KernelEventAgent [112]
Path: /usr/sbin/KernelEventAgent
Parent: launchd [1]
UID: 0
Task size: 4452 KB
Thread 0x293 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 main + 1562 (KernelEventAgent + 6866) [0x10afb1ad2] 1-10
Thread 0x2b0 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10afb0000 - 0x10afb5fff KernelEventAgent (103) <05F599D6-5623-38A9-BC77-75E5499CBBA9> /usr/sbin/KernelEventAgent
Process: kextd [58]
Path: /usr/libexec/kextd
Parent: launchd [1]
UID: 0
Task size: 23.76 MB
Thread 0x26d DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (kextd + 16821) [0x10aa6b1b5] 1-10
Binary Images:
0x10aa67000 - 0x10aa8afff kextd (502.60.2) <C091C31D-DA00-33D1-9FBB-C32F72A3BAC3> /usr/libexec/kextd
Process: keybagd [74]
Path: /usr/libexec/keybagd
Parent: launchd [1]
UID: 0
Task size: 4592 KB
Thread 0x2b5 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10114d000 - 0x10116efff keybagd (304.60.2) <B20506A7-38A5-3605-93E2-3BB74E41D5D5> /usr/libexec/keybagd
Process: keyboardservicesd [598]
Path: /usr/libexec/keyboardservicesd
Parent: launchd [1]
UID: 502
Task size: 16.93 MB
Thread 0x2033 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (keyboardservicesd + 2895) [0x10f7a1b4f] 1-10
Binary Images:
0x10f7a1000 - 0x10f7a1fff keyboardservicesd (99.8) <91BE95B1-5D24-3669-9E92-FBC39996217A> /usr/libexec/keyboardservicesd
Process: KeychainSyncingOverIDSProxy [7784]
Path: /System/Library/Frameworks/Security.framework/Versions/A/Resources/KeychainSyncingOverIDSProxy.bundle/Contents/MacOS/KeychainSyncingOverIDSProxy
Parent: launchd [1]
UID: 502
Task size: 10.53 MB
Thread 0x4a5bf2 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (KeychainSyncingOverIDSProxy + 26080) [0x1045225e0] 1-10
10 ??? (KeychainSyncingOverIDSProxy + 25854) [0x1045224fe] 1-10
Binary Images:
0x10451c000 - 0x104532fff com.apple.security.keychainsyncingoveridsproxy 1.0 (58286.70.7) <8BA21B4D-6D5D-3766-B147-5DB50F6DC749> /System/Library/Frameworks/Security.framework/Versions/A/Resources/KeychainSyncingOverIDSProxy.bundle/Contents/MacOS/KeychainSyncingOverIDSProxy
Process: knowledge-agent [391]
Path: /usr/libexec/knowledge-agent
Parent: launchd [1]
UID: 502
Task size: 22.03 MB
Thread 0x1360 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (knowledge-agent + 19649) [0x10710ccc1] 1-10
Binary Images:
0x107108000 - 0x10710ffff knowledge-agent (915.50.54) <4984B6EF-1A93-3BD6-AE93-500B8D46FBAC> /usr/libexec/knowledge-agent
Process: LaterAgent [13366]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
Parent: launchd [1]
UID: 502
Task size: 18.76 MB
CPU Time: <0.001s (241.0K cycles, 63.1K instructions, 3.82c/i)
Thread 0x5a0b79 DispatchQueue 1 10 samples (1-10) priority 20 (base 20) cpu time <0.001s (122.0K cycles, 31.9K instructions, 3.82c/i)
10 ??? (LaterAgent + 5863) [0x104b816e7] 1-10
10 NSApplicationMain + 804 (AppKit + 23154) [0x7fff28f6ca72] 1-10
10 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
10 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
10 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
10 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
Thread 0x5a0bb9 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested user interactive), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
10 _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
Binary Images:
0x104b80000 - 0x104b88fff com.apple.lateragent 1.0 (658.1) <27E333B7-4633-3380-9C54-7A4B4B40A1CC> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
0x7fff28f67000 - 0x7fff29dc5fff com.apple.AppKit 6.9 (1561.60.100) <3C27CF6F-E640-3411-A87D-CCB2222CC754> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2acc8000 - 0x7fff2afcdfff com.apple.HIToolbox 2.1.1 (911.10) <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process: launchd [1]
Path: /sbin/launchd
Parent: kernel_task [0]
UID: 0
Task size: 22.06 MB
CPU Time: <0.001s (2.6M cycles, 1004.4K instructions, 2.61c/i)
Thread 0x197 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
Process: launchservicesd [96]
Path: /System/Library/CoreServices/launchservicesd
Parent: launchd [1]
UID: 0
Task size: 14.74 MB
CPU Time: <0.001s (2.5M cycles, 1019.0K instructions, 2.48c/i)
Note: 3 idle work queue threads omitted
Thread 0x368 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10e235000 - 0x10e240fff launchservicesd (822.36) <C15B0302-8F27-33DD-8363-72733613A446> /System/Library/CoreServices/launchservicesd
Process: locationd [101]
Path: /usr/libexec/locationd
Parent: launchd [1]
UID: 205
Task size: 22.50 MB
Thread 0x486 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (locationd + 25884) [0x1025eb51c] 1-10
10 ??? (locationd + 18862) [0x1025e99ae] 1-10
10 ??? (locationd + 17316) [0x1025e93a4] 1-10
Thread 0x4b2 10 samples (1-10) priority 4 (base 4)
10 ??? (locationd + 224577) [0x10261bd41] 1-10
Thread 0x4b3 10 samples (1-10) priority 4 (base 4)
10 ??? (locationd + 224591) [0x10261bd4f] 1-10
10 ??? (locationd + 228270) [0x10261cbae] 1-10
10 ??? (locationd + 216966) [0x102619f86] 1-10
10 ??? (locationd + 217825) [0x10261a2e1] 1-10
Thread 0x4b4 10 samples (1-10) priority 4 (base 4)
10 ??? (locationd + 224605) [0x10261bd5d] 1-10
10 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff5399bbea] 1-10
*10 ??? (kernel + 5263408) [0xffffff8000705030] 1-10
Binary Images:
0x1025e5000 - 0x102a74fff locationd (2245.0.41) <562CD6E3-B6CD-3325-8386-5B89134A28B3> /usr/libexec/locationd
Process: logd [73]
Path: /usr/libexec/logd
Parent: launchd [1]
UID: 0
Task size: 40.12 MB
Thread 0x2ca DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10bce1000 - 0x10bd02fff logd (829.70.1) <E971BF3A-BB5F-37FC-85A8-16DB1A0B292E> /usr/libexec/logd
Process: logind [110]
Path: /System/Library/CoreServices/logind
Parent: launchd [1]
UID: 0
Task size: 6312 KB
Thread 0x292 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (logind + 6151) [0x106dbb807] 1-10
Binary Images:
0x106dba000 - 0x106dc5fff logind (39) <83CEBE5C-FAA9-3406-A5B8-48B2A64B0352> /System/Library/CoreServices/logind
Process: loginitemregisterd [2756]
Path: /usr/libexec/loginitemregisterd
Parent: launchd [1]
UID: 502
Task size: 5272 KB
Thread 0x6e13a DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
10 <truncated backtrace> 1-10
Binary Images:
0x102dea000 - 0x102debfff loginitemregisterd (1205.70.9) <D522D8C4-C03A-3E51-8670-E24D485D7978> /usr/libexec/loginitemregisterd
Process: loginwindow [109]
Path: /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Parent: launchd [1]
UID: 502
Task size: 101.46 MB
CPU Time: <0.001s (309.3K cycles, 67.1K instructions, 4.61c/i)
Thread 0x28d DispatchQueue 1 10 samples (1-10) priority 47 (base 47) cpu time <0.001s (186.7K cycles, 35.1K instructions, 5.32c/i)
<thread QoS user interactive (requested user interactive), process unclamped, IO tier 0>
10 ??? (loginwindow + 25722) [0x10f38847a] 1-10
Binary Images:
0x10f382000 - 0x10f479fff com.apple.loginwindow 9.0 (1791.5) <A098FF8A-30CA-3E69-8896-D270E6C8F518> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Process: loginwindow [7763]
Parent: WindowServer [214]
Responsible: WindowServer [214]
UID: 0
Task size: 75.26 MB
CPU Time: <0.001s (218.9K cycles, 62.8K instructions, 3.49c/i)
Thread 0x4a596b DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (114.1K cycles, 31.4K instructions, 3.63c/i)
10 ??? (loginwindow + 25722) [0x10f36247a] 1-10
Binary Images:
0x10f35c000 - 0x10f453fff com.apple.loginwindow 9.0 (1791.5) <A098FF8A-30CA-3E69-8896-D270E6C8F518> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Process: lsd [203]
Path: /usr/libexec/lsd
Parent: launchd [1]
UID: 0
Task size: 13.15 MB
Thread 0x4d6 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, IO tier 0>
10 _LSServerMain + 633 (LaunchServices + 211380) [0x7fff2cec09b4] 1-10
Binary Images:
0x1037ed000 - 0x1037edfff lsd (822.36) <CC4F5CDC-59A2-36F2-8080-63C5E039C61C> /usr/libexec/lsd
0x7fff2ce8d000 - 0x7fff2d04afff com.apple.LaunchServices 822.36 (822.36) <6E68C090-B12D-3D3D-9617-E5D82C36B2D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
Process: lsd [299]
Parent: launchd [1]
UID: 502
Task size: 14.61 MB
Thread 0xc9a DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10a503000 - 0x10a503fff lsd (822.36) <CC4F5CDC-59A2-36F2-8080-63C5E039C61C> /usr/libexec/lsd
Process: Mail [13967]
Path: /Applications/Mail.app/Contents/MacOS/Mail
Parent: launchd [1]
UID: 502
Task size: 333.85 MB
CPU Time: 0.001s (4.2M cycles, 2.3M instructions, 1.81c/i)
Thread 0x63d61c DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time 0.001s (4.0M cycles, 2.3M instructions, 1.75c/i)
Thread 0x63d67e 10 samples (1-10) priority 37 (base 37)
<thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0>
10 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 40 (JavaScriptCore + 12744344) [0x7fff2f683698] 1-10
10 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 12743513) [0x7fff2f683359] 1-10
10 bmalloc::Scavenger::threadRunLoop() + 251 (JavaScriptCore + 12744027) [0x7fff2f68355b] 1-10
10 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 86 (JavaScriptCore + 12744870) [0x7fff2f6838a6] 1-10
10 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 27824) [0x7fff5179ecb0] 1-10
Thread 0x63d696 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0>
Thread 0x63d6fc Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 46 (base 46)
Thread 0x63d720 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Thread 0x63d744 Thread name "com.apple.coreanimation.render-server" 10 samples (1-10) priority 55 (base 55)
<process sudden termination dirty, process unclamped, IO tier 0>
Thread 0x63ff07 Thread name "com.apple.CFNetwork.CustomProtocols" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10a97b000 - 0x10ad3cfff com.apple.mail 11.5 (3445.9.1) <0DBBA67B-E375-3EB6-9606-7C7661C100CC> /Applications/Mail.app/Contents/MacOS/Mail
0x7fff2ea5c000 - 0x7fff2f742fff com.apple.JavaScriptCore 13605 (13605.3.8) <E6B49CDA-72F0-3E58-85EF-98AF10CE04B0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff51798000 - 0x7fff517eefff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
Process: mapspushd [894]
Path: /System/Library/CoreServices/mapspushd
Architecture: x86_64
Parent: launchd [1]
UID: 502
Task size: 17.71 MB
Thread 0x110ea DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 258 (mapspushd + 6201) [0x10e78a839] 1-10
10 -[MapsPushDaemonLocalProxy runServer] + 171 (mapspushd + 70648) [0x10e79a3f8] 1-10
Binary Images:
0x10e789000 - 0x10e7a6fff mapspushd (2131.25.4.7.1) <428440A8-FFD5-3A45-8446-7FDF507A8222> /System/Library/CoreServices/mapspushd
Process: mDNSResponder [193]
Path: /usr/sbin/mDNSResponder
Parent: launchd [1]
UID: 65
Task size: 12.20 MB
CPU Time: <0.001s (68.0K cycles, 27.5K instructions, 2.47c/i)
Thread 0x467 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), IO tier 0>
10 main + 1682 (mDNSResponder + 6341) [0x102a1b8c5] 1-10
Thread 0x488 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (68.0K cycles, 27.5K instructions, 2.47c/i)
Binary Images:
0x102a1a000 - 0x102abffff mDNSResponder (878.70.2) <DA0CE58D-1F50-3E0D-801E-E77F9BD63FC6> /usr/sbin/mDNSResponder
Process: mDNSResponderHelper [195]
Path: /usr/sbin/mDNSResponderHelper
Parent: launchd [1]
UID: 0
Task size: 6740 KB
CPU Time: <0.001s (59.8K cycles, 10.4K instructions, 5.74c/i)
Thread 0x475 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Thread 0x476 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (59.8K cycles, 10.4K instructions, 5.74c/i)
10 idletimer + 72 (mDNSResponderHelper + 30166) [0x1067a25d6] 1-10
10 sleep + 41 (libsystem_c.dylib + 509318) [0x7fff53915586] 1-10
10 __semwait_signal + 10 (libsystem_kernel.dylib + 118146) [0x7fff5399ad82] 1-10
*10 semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90] 1-10
Binary Images:
0x10679b000 - 0x1067a7fff mDNSResponderHelper (878.70.2) <82B0E433-EEC2-3276-8138-E4834473EA6A> /usr/sbin/mDNSResponderHelper
Process: mds [80]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
Parent: launchd [1]
UID: 0
Task size: 135.21 MB
CPU Time: <0.001s (743.2K cycles, 129.2K instructions, 5.75c/i)
Thread 0x27f DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (mds + 47809) [0x10d3dbac1] 1-10
Thread 0x60d 10 samples (1-10) priority 50 (base 50) cpu time <0.001s (120.5K cycles, 15.4K instructions, 7.85c/i)
<IO tier 0 and passive>
10 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff5399c142] 1-10
*10 hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 1-10
*10 unix_syscall64 + 616 (kernel + 6306152) [0xffffff8000803968] 1-10
*10 read_nocancel + 115 (kernel + 5532931) [0xffffff8000746d03] 1-10
*10 ??? (kernel + 5533541) [0xffffff8000746f65] 1-10
*10 ??? (kernel + 2958502) [0xffffff80004d24a6] 1-10
*10 ??? (kernel + 5438002) [0xffffff800072fa32] 1-10
*10 thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
*10 ??? (kernel + 554618) [0xffffff800028767a] 1-10
*10 machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
Thread 0x652 10 samples (1-10) priority 31 (base 31)
10 _handleExceptions + 111 (SpotlightIndex + 1352295) [0x7fff4e2e1267] 1-10
Binary Images:
0x10d3d0000 - 0x10d580fff mds (1191.4.13) <EAF89F8E-7545-30BB-B5DF-D75BDE3768F6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
0x7fff4e197000 - 0x7fff4e3d5fff com.apple.spotlight.index 10.7.0 (1191.4.13) <14C6EDFD-B843-35A4-AEA6-F485D756FF88> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
Process: mds_stores [217]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Parent: launchd [1]
UID: 0
Task size: 310.00 MB
Thread 0x62c DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (mds_stores + 13320) [0x103663408] 1-10
Thread 0x64b 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x103660000 - 0x1036a8fff mds_stores (1191.4.13) <03908635-85F3-3CE1-AD80-55F43D9B7C65> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Process: mdworker [595]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Parent: launchd [1]
UID: 502
Task size: 11.81 MB
Thread 0x1fe6 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
10 ??? (mdworker + 36518) [0x106cfaea6] 1-10
Binary Images:
0x106cf2000 - 0x106d56fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [596]
Parent: launchd [1]
UID: 89
Task size: 11.59 MB
Thread 0x2022 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x105856ea6] 1-10
Binary Images:
0x10584e000 - 0x1058b2fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14251]
Parent: launchd [1]
UID: 502
Task size: 94.83 MB
Thread 0x66fe07 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
10 ??? (mdworker + 36518) [0x10512fea6] 1-10
Thread 0x66fe10 10 samples (1-10) priority 4 (base 4)
<thread QoS maintenance (requested maintenance), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
10 ??? (mdworker + 49340) [0x1051330bc] 1-10
10 ??? (mdworker + 59776) [0x105135980] 1-10
Thread 0x67011c 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x1051445d9] 1-10
Binary Images:
0x105127000 - 0x10518bfff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14252]
Parent: launchd [1]
UID: 502
Task size: 91.88 MB
Thread 0x66fe08 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x108c31ea6] 1-10
Thread 0x66fe0f 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x108c350bc] 1-10
10 ??? (mdworker + 59776) [0x108c37980] 1-10
Thread 0x66ffed 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x108c465d9] 1-10
Binary Images:
0x108c29000 - 0x108c8dfff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14266]
Parent: launchd [1]
UID: 502
Task size: 84.11 MB
Thread 0x6704b6 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x10a59eea6] 1-10
Thread 0x6704d5 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10a5a20bc] 1-10
10 ??? (mdworker + 59776) [0x10a5a4980] 1-10
Thread 0x67098f 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x10a5b35d9] 1-10
Binary Images:
0x10a596000 - 0x10a5fafff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14568]
Parent: launchd [1]
UID: 502
Task size: 96.05 MB
Thread 0x6839bc DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
10 ??? (mdworker + 36518) [0x10eaf8ea6] 1-10
Thread 0x6839d4 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10eafc0bc] 1-10
10 ??? (mdworker + 59776) [0x10eafe980] 1-10
Thread 0x6839d5 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x10eb0d5d9] 1-10
Binary Images:
0x10eaf0000 - 0x10eb54fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14569]
Parent: launchd [1]
UID: 502
Task size: 81.36 MB
Thread 0x6839bd DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x10bfc3ea6] 1-10
Thread 0x6839d3 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10bfc70bc] 1-10
10 ??? (mdworker + 59776) [0x10bfc9980] 1-10
Thread 0x683db8 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x10bfd85d9] 1-10
Binary Images:
0x10bfbb000 - 0x10c01ffff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14603]
Parent: launchd [1]
UID: 502
Task size: 67.07 MB
Thread 0x685174 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x10cb41ea6] 1-10
Thread 0x685189 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10cb450bc] 1-10
10 ??? (mdworker + 59776) [0x10cb47980] 1-10
Thread 0x685537 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x10cb565d9] 1-10
Binary Images:
0x10cb39000 - 0x10cb9dfff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14635]
Parent: launchd [1]
UID: 89
Task size: 21.38 MB
Thread 0x6868e2 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x1011c8ea6] 1-10
Thread 0x6868ed 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x1011cc0bc] 1-10
10 ??? (mdworker + 59776) [0x1011ce980] 1-10
Thread 0x699be7 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x1011dd5d9] 1-10
Binary Images:
0x1011c0000 - 0x101224fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14687]
Parent: launchd [1]
UID: 502
Task size: 65.77 MB
Thread 0x689375 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x106318ea6] 1-10
Thread 0x689388 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10631c0bc] 1-10
10 ??? (mdworker + 59776) [0x10631e980] 1-10
Thread 0x68ac2b 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x10632d5d9] 1-10
Thread 0x6a3cbe 10 samples (1-10) priority 4 (base 4)
*10 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] 1-10
Binary Images:
0x106310000 - 0x106374fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14759]
Parent: launchd [1]
UID: 502
Task size: 28.50 MB
Thread 0x6985bc DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 2>
10 ??? (mdworker + 36518) [0x10f958ea6] 1-10
Thread 0x6985dc 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), process sudden termination clean, IO tier 2>
10 ??? (mdworker + 49340) [0x10f95c0bc] 1-10
10 ??? (mdworker + 59776) [0x10f95e980] 1-10
Binary Images:
0x10f950000 - 0x10f9b4fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14760]
Parent: launchd [1]
UID: 502
Task size: 28.79 MB
Thread 0x698650 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (mdworker + 36518) [0x100b80ea6] 1-10
Thread 0x698654 10 samples (1-10) priority 20 (base 20)
10 ??? (mdworker + 49340) [0x100b840bc] 1-10
10 ??? (mdworker + 59776) [0x100b86980] 1-10
Binary Images:
0x100b78000 - 0x100bdcfff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14785]
Parent: launchd [1]
UID: 502
Task size: 85.07 MB
Thread 0x69a1a5 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x102219ea6] 1-10
Thread 0x69a1b9 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10221d0bc] 1-10
10 ??? (mdworker + 59776) [0x10221f980] 1-10
Thread 0x69a1bb 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x10222e5d9] 1-10
Binary Images:
0x102211000 - 0x102275fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14786]
Parent: launchd [1]
UID: 89
Task size: 31.31 MB
Thread 0x69a22e DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x105d11ea6] 1-10
Thread 0x69a235 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x105d150bc] 1-10
10 ??? (mdworker + 59776) [0x105d17980] 1-10
Thread 0x69a2a1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 120281) [0x105d265d9] 1-10
Binary Images:
0x105d09000 - 0x105d6dfff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14839]
Parent: launchd [1]
UID: 502
Task size: 23.91 MB
Thread 0x6a2170 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x10cdbdea6] 1-10
Thread 0x6a2176 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10cdc10bc] 1-10
10 ??? (mdworker + 59776) [0x10cdc3980] 1-10
Binary Images:
0x10cdb5000 - 0x10ce19fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14906]
Parent: launchd [1]
UID: 502
Task size: 13.13 MB
Thread 0x6a4eaa DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x103c2cea6] 1-10
Thread 0x6a4ec0 10 samples (1-10) priority 4 (base 4)
10 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
10 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
10 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
10 ??? (mdworker + 49340) [0x103c300bc] 1-10
10 ??? (mdworker + 59776) [0x103c32980] 1-10
Binary Images:
0x103c24000 - 0x103c88fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14907]
Parent: launchd [1]
UID: 502
Task size: 13.14 MB
Thread 0x6a4ea9 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x10e68dea6] 1-10
Thread 0x6a4ebd 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10e6910bc] 1-10
10 ??? (mdworker + 59776) [0x10e693980] 1-10
Binary Images:
0x10e685000 - 0x10e6e9fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14908]
Parent: launchd [1]
UID: 502
Task size: 13.11 MB
Thread 0x6a4eab DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x1063e4ea6] 1-10
Thread 0x6a4ebe 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x1063e80bc] 1-10
10 ??? (mdworker + 59776) [0x1063ea980] 1-10
Binary Images:
0x1063dc000 - 0x106440fff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [14909]
Parent: launchd [1]
UID: 502
Task size: 13.25 MB
Thread 0x6a4eac DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 36518) [0x10de62ea6] 1-10
10 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
10 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
10 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
10 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
*10 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
Thread 0x6a4ebf 10 samples (1-10) priority 4 (base 4)
10 ??? (mdworker + 49340) [0x10de660bc] 1-10
10 ??? (mdworker + 59776) [0x10de68980] 1-10
Binary Images:
0x10de5a000 - 0x10debefff mdworker (1191.4.13) <87A9C611-DF89-361F-80D4-6C5B6B98C8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdwrite [1943]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
Parent: launchd [1]
UID: 502
Task size: 9656 KB
Thread 0x353b4 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
Binary Images:
0x10ef3b000 - 0x10ef4efff mdwrite (1191.4.13) <9CDB5D38-9D0E-3251-B058-7A5A97C6B0A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
Process: media-indexer [446]
Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
Parent: launchd [1]
Responsible: assistantd [365]
UID: 502
Task size: 182.96 MB
Thread 0x13b3 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 138 (media-indexer + 5526) [0x10c071596] 1-10
10 -[NSXPCListener resume] + 165 (Foundation + 485365) [0x7fff2db5f7f5] 1-10
10 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff53ba39ca] 1-10
Binary Images:
0x10c070000 - 0x10c07afff com.apple.siri.media-indexer 1.0 (1) <715A5B9E-1FF2-35E4-94DA-FDA833F04EAE> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
0x7fff53b94000 - 0x7fff53bc1fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
Process: mediaremoteagent [402]
Path: /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
Parent: launchd [1]
UID: 502
Task size: 5724 KB
Thread 0x1353 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10b531000 - 0x10b532fff mediaremoteagent (4015.730.1) <972920D4-F537-3E26-8F68-17131C5947AD> /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
Process: mediaremoted [62]
Path: /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Parent: launchd [1]
UID: 0
Task size: 23.86 MB
Thread 0x271 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 382 (mediaremoted + 274974) [0x10e75b21e] 1-10
Binary Images:
0x10e718000 - 0x10e7eefff mediaremoted (4015.730.1) <2BB5FBA7-1C3D-3811-82E2-78FD599D9C5E> /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Process: mobileassetd [200]
Path: /usr/libexec/mobileassetd
Parent: launchd [1]
UID: 0
Task size: 22 MB
Thread 0x4c2 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (mobileassetd + 115537) [0x109518351] 1-10
Binary Images:
0x1094fc000 - 0x109551fff mobileassetd (437.60.1) <CC6C867B-44D6-3D0A-BAA7-598659629484> /usr/libexec/mobileassetd
Process: MobileDeviceUpdater [367]
Path: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/MobileDeviceUpdater.app/Contents/MacOS/MobileDeviceUpdater
Parent: launchd [1]
UID: 502
Task size: 20.12 MB
CPU Time: <0.001s (293.4K cycles, 75.3K instructions, 3.90c/i)
Thread 0x103a DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (180.1K cycles, 40.1K instructions, 4.49c/i)
10 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
10 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
Thread 0x1112 DispatchQueue 10 10 samples (1-10) priority 4 (base 4)
Thread 0x113f Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 4 (base 4)
Thread 0x1140 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user interactive), thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x104fc0000 - 0x104fcafff com.apple.MobileDeviceUpdater 1.0 (1) <599EEAB7-2F80-3E3D-908F-1D1387C4BE6F> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/MobileDeviceUpdater.app/Contents/MacOS/MobileDeviceUpdater
Process: MTLCompilerService [3810]
Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Parent: launchd [1]
Responsible: Finder [300]
UID: 502
Task size: 12.02 MB
Thread 0x2e334c DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x100639000 - 0x10063afff com.apple.MTLCompilerService 125.30 (125.30) <119AB920-2898-3677-BA46-65DFB417F14F> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process: MTLCompilerService [4229]
Parent: launchd [1]
UID: 0
Task size: 18.62 MB
Thread 0x302399 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102650000 - 0x102651fff com.apple.MTLCompilerService 125.30 (125.30) <119AB920-2898-3677-BA46-65DFB417F14F> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process: navd [1778]
Path: /System/Library/CoreServices/navd
Parent: launchd [1]
UID: 502
Task size: 19.07 MB
Thread 0x2f260 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (navd + 6710) [0x100c61a36] 1-10
Binary Images:
0x100c60000 - 0x100c7ffff navd (2131.25.4.7.1) <59A8AAC6-A55B-3E8D-B51A-80821C7F104E> /System/Library/CoreServices/navd
Process: nbagent [395]
Path: /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
Parent: launchd [1]
UID: 502
Task size: 17.54 MB
CPU Time: <0.001s (307.0K cycles, 66.8K instructions, 4.60c/i)
Thread 0x1350 DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (152.7K cycles, 32.3K instructions, 4.73c/i)
Thread 0x15e8 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x109864000 - 0x109870fff com.apple.nbagent 1.0 (1) <5138B275-4575-35F6-A63D-178645547340> /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
0x7fff2b988000 - 0x7fff2be29fff com.apple.CoreFoundation 6.9 (1454.90) <E5D594BF-9142-3325-A62D-CF4AAF472642> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Process: nbagent [7769]
Parent: launchd [1]
UID: 0
Task size: 17.87 MB
CPU Time: <0.001s (314.8K cycles, 75.8K instructions, 4.15c/i)
Thread 0x4a5a82 DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (160.7K cycles, 36.5K instructions, 4.40c/i)
Thread 0x4a5bb4 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x108e8b000 - 0x108e97fff com.apple.nbagent 1.0 (1) <5138B275-4575-35F6-A63D-178645547340> /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
0x7fff53849000 - 0x7fff53866fff libdyld.dylib (551.4) <81BF3A82-5719-3B54-ABA9-76C82D932CAC> /usr/lib/system/libdyld.dylib
0x7fff5397e000 - 0x7fff539a4fff libsystem_kernel.dylib (4570.71.2) <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2> /usr/lib/system/libsystem_kernel.dylib
Process: nbstated [95]
Path: /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
Parent: launchd [1]
UID: 0
Task size: 3780 KB
Thread 0x2a1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x10bc41000 - 0x10bc42fff nbstated (20.1) <BC75E6EC-8C65-3057-8225-3A6A2FDC56A2> /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.2) <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F> /System/Library/Kernels/kernel
Process: nehelper [160]
Path: /usr/libexec/nehelper
Parent: launchd [1]
UID: 0
Sudden Term: Tracked (allows idle exit)
Task size: 9708 KB
Note: 1 idle work queue thread omitted
Thread 0x3e7 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (nehelper + 121522) [0x101fa0ab2] 1-10
Binary Images:
0x101f83000 - 0x101facfff nehelper (767.70.1) <DB91075B-5DDD-348B-A9D0-062A9BB6F0FC> /usr/libexec/nehelper
0x7fff2dae9000 - 0x7fff2deaffff com.apple.Foundation 6.9 (1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: netbiosd [1930]
Path: /usr/sbin/netbiosd
Parent: launchd [1]
UID: 222
Task size: 8828 KB
Thread 0x34e92 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3>
Binary Images:
0x10bc12000 - 0x10bc59fff netbiosd (407.60.1) <CAA09527-78DB-35A0-A059-842911551CFD> /usr/sbin/netbiosd
Process: networkserviceproxy [363]
Path: /usr/libexec/networkserviceproxy
Parent: launchd [1]
UID: 502
Task size: 13.06 MB
Thread 0xff1 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (networkserviceproxy + 96518) [0x10a831906] 1-10
Binary Images:
0x10a81a000 - 0x10a837fff networkserviceproxy (269.50.9) <6BDFC1CB-F368-344B-ABBC-4970DE070FC3> /usr/libexec/networkserviceproxy
Process: nfcd [223]
Path: /usr/libexec/nfcd
Parent: launchd [1]
UID: 260
Task size: 7568 KB
Thread 0x700 DispatchQueue 1 10 samples (1-10) priority 50 (base 50)
10 ??? (nfcd + 268610) [0x104315942] 1-10
Binary Images:
0x1042d4000 - 0x1043acfff nfcd (286.2) <2D303965-BBCE-3813-B94B-1F28050DC618> /usr/libexec/nfcd
Process: node [507]
Path: /Applications/Utilities/Adobe Creative Cloud Experience/CCXProcess.app/Contents/libs/node
Parent: launchd [1]
UID: 502
Task size: 72.04 MB
Thread 0x18de DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
10 start + 52 (node + 4660) [0x100001234] 1-10
10 node::Start(int, char**) + 744 (node + 9234813) [0x1008ce97d] 1-10
10 uv_run + 321 (node + 10887823) [0x100a6228f] 1-10
Thread 0x1972 DispatchQueue 10 10 samples (1-10) priority 37 (base 37)
<thread QoS user initiated (requested user initiated), process unclamped, IO tier 0>
Thread 0x18df 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process unclamped, IO tier 0>
10 node::DebugSignalThreadMain(void*) + 49 (node + 9238196) [0x1008cf6b4] 1-10
10 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246] 1-10
Thread 0x18e0 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
10 v8::base::ThreadEntry(void*) + 87 (node + 10974039) [0x100a77357] 1-10
10 v8::platform::WorkerThread::Run() + 43 (node + 9652395) [0x1009348ab] 1-10
10 v8::platform::TaskQueue::GetNext() + 57 (node + 9651881) [0x1009346a9] 1-10
Thread 0x18e1 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
Thread 0x18e2 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
Thread 0x18e3 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
Thread 0x18f8 10 samples (1-10) priority 31 (base 31)
10 worker + 227 (node + 10879689) [0x100a602c9] 1-10
10 uv_cond_wait + 9 (node + 10933402) [0x100a6d49a] 1-10
Thread 0x18f9 10 samples (1-10) priority 31 (base 31)
Thread 0x18fa 10 samples (1-10) priority 31 (base 31)
Thread 0x18fb 10 samples (1-10) priority 31 (base 31)
Thread 0x1904 10 samples (1-10) priority 31 (base 31)
10 vcfoundation::thread::Thread::ThreadProc(void*) + 9 (VulcanMessage5.dylib + 121849) [0x1063a5bf9] 1-10
10 vcfoundation::thread::AbstractThread::Run() + 50 (VulcanMessage5.dylib + 114904) [0x1063a40d8] 1-10
10 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005 (VulcanMessage5.dylib + 59247) [0x10639676f] 1-10
10 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50 (VulcanMessage5.dylib + 56502) [0x106395cb6] 1-10
10 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29 (VulcanMessage5.dylib + 110253) [0x1063a2ead] 1-10
10 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166 (VulcanMessage5.dylib + 110426) [0x1063a2f5a] 1-10
10 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37 (VulcanMessage5.dylib + 111321) [0x1063a32d9] 1-10
10 vcfoundation::ncomm::Connection::ReadIn() + 22 (VulcanMessage5.dylib + 112050) [0x1063a35b2] 1-10
10 vcfoundation::io::Serializer::Deserialize() + 9 (VulcanMessage5.dylib + 96045) [0x10639f72d] 1-10
10 vcfoundation::io::Serializer::InternalDeserialize() + 30 (VulcanMessage5.dylib + 96134) [0x10639f786] 1-10
10 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46 (VulcanMessage5.dylib + 94952) [0x10639f2e8] 1-10
10 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50 (VulcanMessage5.dylib + 116542) [0x1063a473e] 1-10
10 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82 (VulcanMessage5.dylib + 116744) [0x1063a4808] 1-10
10 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21 (VulcanMessage5.dylib + 119885) [0x1063a544d] 1-10
10 __recvfrom + 10 (libsystem_kernel.dylib + 117810) [0x7fff5399ac32] 1-10
*10 recvfrom_nocancel + 229 (kernel + 5798757) [0xffffff8000787b65] 1-10
*10 ??? (kernel + 5799263) [0xffffff8000787d5f] 1-10
*10 soreceive + 5082 (kernel + 5735770) [0xffffff800077855a] 1-10
*10 sbwait + 406 (kernel + 5772870) [0xffffff8000781646] 1-10
*10 msleep + 98 (kernel + 5438898) [0xffffff800072fdb2] 1-10
*10 ??? (kernel + 5437670) [0xffffff800072f8e6] 1-10
*10 lck_mtx_sleep + 126 (kernel + 505086) [0xffffff800027b4fe] 1-10
Thread 0x19c7 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
10 __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
10 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
Thread 0x19cb Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 46 (base 46)
*10 ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
Binary Images:
0x100000000 - 0x10120afff node <83F2B4BE-EDC4-3BE2-A571-1306637AFC42> /Applications/Utilities/Adobe Creative Cloud Experience/CCXProcess.app/Contents/libs/node
0x106388000 - 0x1063c0fff VulcanMessage5.dylib (1) <1D3CED35-E99B-3AAB-9C60-C6F853ED3BFB> /Applications/Utilities/Adobe Creative Cloud Experience/CCXProcess.app/Contents/js/node_modules/node-vulcanjs/build/Release/VulcanMessage5.dylib
0x7fff2a914000 - 0x7fff2acaefff com.apple.CFNetwork 902.1 (902.1) <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff5380f000 - 0x7fff53848fff libdispatch.dylib (913.60.2) <232C69BD-022E-3AB9-8807-79F9FA7CB5EC> /usr/lib/system/libdispatch.dylib
0x7fff53b5f000 - 0x7fff53b6afff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
*0xffffff7f82a20000 - 0xffffff7f82a2bfff com.apple.kec.pthread 1.0 (1) <E64F7A49-CBF0-3251-9F02-3655E3B3DD31> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process: node [553]
Path: /Library/Application Support/Adobe/*/CCLibrary.app/Contents/libs/node
Parent: launchd [1]
UID: 502
Task size: 62.18 MB
Thread 0x1bdd DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
10 start + 52 (node + 4916) [0x100001334] 1-10
10 node::Start(int, char**) + 744 (node + 103490) [0x100019442] 1-10
10 uv_run + 321 (node + 10582435) [0x100a179a3] 1-10
Thread 0x1c0b DispatchQueue 10 10 samples (1-10) priority 37 (base 37)
Thread 0x1be3 10 samples (1-10) priority 31 (base 31)
10 node::DebugSignalThreadMain(void*) + 49 (node + 106882) [0x10001a182] 1-10
Thread 0x1be4 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
10 v8::base::ThreadEntry(void*) + 87 (node + 11046615) [0x100a88ed7] 1-10
10 v8::platform::WorkerThread::Run() + 43 (node + 9725723) [0x10094671b] 1-10
10 v8::platform::TaskQueue::GetNext() + 57 (node + 9725209) [0x100946519] 1-10
Thread 0x1be5 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
Thread 0x1be6 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
Thread 0x1be7 Thread name "V8 WorkerThread" 10 samples (1-10) priority 31 (base 31)
Thread 0x1c02 10 samples (1-10) priority 31 (base 31)
10 worker + 227 (node + 10574277) [0x100a159c5] 1-10
10 uv_cond_wait + 9 (node + 10628598) [0x100a22df6] 1-10
10 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
*10 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
Thread 0x1c03 10 samples (1-10) priority 31 (base 31)
Thread 0x1c04 10 samples (1-10) priority 31 (base 31)
Thread 0x1c05 10 samples (1-10) priority 31 (base 31)
Thread 0x1c0e 10 samples (1-10) priority 31 (base 31)
10 vcfoundation::thread::Thread::ThreadProc(void*) + 9 (VulcanMessage5.dylib + 121849) [0x105796bf9] 1-10
10 vcfoundation::thread::AbstractThread::Run() + 50 (VulcanMessage5.dylib + 114904) [0x1057950d8] 1-10
10 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005 (VulcanMessage5.dylib + 59247) [0x10578776f] 1-10
10 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50 (VulcanMessage5.dylib + 56502) [0x105786cb6] 1-10
10 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29 (VulcanMessage5.dylib + 110253) [0x105793ead] 1-10
10 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166 (VulcanMessage5.dylib + 110426) [0x105793f5a] 1-10
10 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37 (VulcanMessage5.dylib + 111321) [0x1057942d9] 1-10
10 vcfoundation::ncomm::Connection::ReadIn() + 22 (VulcanMessage5.dylib + 112050) [0x1057945b2] 1-10
10 vcfoundation::io::Serializer::Deserialize() + 9 (VulcanMessage5.dylib + 96045) [0x10579072d] 1-10
10 vcfoundation::io::Serializer::InternalDeserialize() + 30 (VulcanMessage5.dylib + 96134) [0x105790786] 1-10
10 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46 (VulcanMessage5.dylib + 94952) [0x1057902e8] 1-10
10 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50 (VulcanMessage5.dylib + 116542) [0x10579573e] 1-10
10 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82 (VulcanMessage5.dylib + 116744) [0x105795808] 1-10
10 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21 (VulcanMessage5.dylib + 119885) [0x10579644d] 1-10
Thread 0x1c3e Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
Thread 0x1c45 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x100000000 - 0x10121efff node <B6428FA6-DB25-350A-8347-D1163EB8E066> /Library/Application Support/Adobe/*/CCLibrary.app/Contents/libs/node
0x105779000 - 0x1057b1fff VulcanMessage5.dylib (1) <1D3CED35-E99B-3AAB-9C60-C6F853ED3BFB> /Applications/Utilities/Adobe Creative Cloud Experience/CCXProcess.app/Contents/js/node_modules/node-vulcanjs/build/Release/VulcanMessage5.dylib
Process: normalizerd [3898]
Path: /System/Library/PrivateFrameworks/PSNormalizer.framework/Versions/A/XPCServices/normalizerd.xpc/Contents/MacOS/normalizerd
Parent: launchd [1]
UID: 0
Task size: 5968 KB
Thread 0x2efc0e DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10a38f000 - 0x10a391fff com.apple.print.normalizerd 13 (21) <E04B0509-96E7-3F50-9132-AEDE6889C027> /System/Library/PrivateFrameworks/PSNormalizer.framework/Versions/A/XPCServices/normalizerd.xpc/Contents/MacOS/normalizerd
Process: NotificationCenter (Notification Center) [351]
Path: /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
Parent: launchd [1]
UID: 502
Task size: 74.48 MB
CPU Time: <0.001s (275.2K cycles, 62.5K instructions, 4.40c/i)
Thread 0xeed DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (155.4K cycles, 32.5K instructions, 4.78c/i)
<thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from SystemUIServer [298], IO tier 0>
10 ??? (NotificationCenter + 406396) [0x10caa237c] 1-10
10 autoreleasepool<A>(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff4ebf7c68] 1-10
10 ??? (NotificationCenter + 410062) [0x10caa31ce] 1-10
10 ??? (NotificationCenter + 407733) [0x10caa28b5] 1-10
Thread 0x1009 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x10ca3f000 - 0x10cb8bfff com.apple.notificationcenterui 1.0 (639.10) <17FC9FF4-18B5-3E93-8068-D5FDA66E2A15> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
0x7fff4ebf4000 - 0x7fff4ebf9fff libswiftObjectiveC.dylib (900.8.49.1) <DCF880C2-D021-36E6-86A1-63845D04E99E> /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process: notifyd [118]
Path: /usr/sbin/notifyd
Parent: launchd [1]
UID: 0
Task size: 2684 KB
CPU Time: <0.001s (805.9K cycles, 241.4K instructions, 3.34c/i)
Note: 2 idle work queue threads omitted
Thread 0x2a7 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 0>
Binary Images:
Process: nsurlsessiond [202]
Path: /usr/libexec/nsurlsessiond
Parent: launchd [1]
UID: 242
Task size: 39.77 MB
Thread 0x4ce DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 551 (nsurlsessiond + 23942) [0x101c40d86] 1-10
10 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
Binary Images:
0x101c3b000 - 0x101c9bfff nsurlsessiond (902.1) <14B09C13-A68B-3C84-A79F-49F498A4A115> /usr/libexec/nsurlsessiond
Process: nsurlsessiond [353]
Parent: launchd [1]
UID: 502
Task size: 22.89 MB
CPU Time: <0.001s (144.2K cycles, 51.3K instructions, 2.81c/i)
Thread 0xf23 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from bird [304], IO tier 0>
10 main + 551 (nsurlsessiond + 23942) [0x10cb4fd86] 1-10
Thread 0x1325 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
Thread 0x1326 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10cb4a000 - 0x10cbaafff nsurlsessiond (902.1) <14B09C13-A68B-3C84-A79F-49F498A4A115> /usr/libexec/nsurlsessiond
Process: nsurlstoraged [219]
Path: /usr/libexec/nsurlstoraged
Parent: launchd [1]
UID: 243
Task size: 6852 KB
Thread 0x668 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 _nsurlstoraged_main + 614 (CFNetwork + 282702) [0x7fff2a95904e] 1-10
10 CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
Binary Images:
0x103a4e000 - 0x103a66fff nsurlstoraged (902.1) <078D6D11-303D-33FB-8526-95D19ADA0014> /usr/libexec/nsurlstoraged
Process: nsurlstoraged [340]
Parent: launchd [1]
UID: 502
Task size: 20.79 MB
Thread 0xe81 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x104de5000 - 0x104dfdfff nsurlstoraged (902.1) <078D6D11-303D-33FB-8526-95D19ADA0014> /usr/libexec/nsurlstoraged
Process: ocspd [14427]
Path: /usr/sbin/ocspd
Parent: launchd [1]
UID: 0
Task size: 6980 KB
Thread 0x67d095 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (ocspd + 16964) [0x102ee8244] 1-10
10 ??? (ocspd + 61711) [0x102ef310f] 1-10
10 ??? (ocspd + 62525) [0x102ef343d] 1-10
10 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 78358) [0x7fff53991216] 1-10
Binary Images:
0x102ee4000 - 0x102efefff ocspd (55135.30.1) <E0CAB0EF-50AC-3C84-B9D8-D9606F53E120> /usr/sbin/ocspd
Process: opendirectoryd [93]
Path: /usr/libexec/opendirectoryd
Parent: launchd [1]
UID: 0
Task size: 35.29 MB (+28 KB)
CPU Time: <0.001s (1075.4K cycles, 416.5K instructions, 2.58c/i)
Thread 0x2d6 DispatchQueue 10 10 samples (1-10) priority 31 (base 31)
10 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 1-10
10 _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff53b62169] 1-10
10 _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff53812755] 1-10
10 _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff53812b2c] 1-10
10 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 1-10
10 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 1-10
10 ??? (opendirectoryd + 178966) [0x104a55b16] 1-10
Thread 0x2f0 DispatchQueue 10 10 samples (1-10) priority 31 (base 31)
10 ??? (SystemCache + 187866) [0x104c8ddda] 1-10
10 mach_msg_server + 369 (libsystem_kernel.dylib + 77668) [0x7fff53990f64] 1-10
Thread 0x310 DispatchQueue 10 10 samples (1-10) priority 31 (base 31)
10 ??? (SystemCache + 188078) [0x104c8deae] 1-10
Thread 0x2d8 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Thread 0x339 DispatchQueue 1693 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (365.1K cycles, 156.0K instructions, 2.34c/i)
<thread QoS default (requested default, requested override default), process sudden termination dirty, IO tier 0>
10 _dispatch_async_redirect_invoke + 703 (libdispatch.dylib + 50995) [0x7fff5381b733] 1-10
10 _dispatch_continuation_pop + 472 (libdispatch.dylib + 85633) [0x7fff53823e81] 1-10
10 __identitysvc + 10 (libsystem_kernel.dylib + 115658) [0x7fff5399a3ca] 1-10
Binary Images:
0x104a2a000 - 0x104aa8fff opendirectoryd (483.70.1) <AD43C574-A9F7-3311-A4E9-95237667082A> /usr/libexec/opendirectoryd
0x104c60000 - 0x104c9afff com.apple.opendirectoryd.module.SystemCache 10.13 (483.70.1) <5BF0EF4E-BF8E-3AB7-B7CE-505CCA97A5F0> /System/Library/OpenDirectory/Modules/SystemCache.bundle/Contents/MacOS/SystemCache
0x7fff53899000 - 0x7fff53922fff libsystem_c.dylib (1244.50.9) <1187BFE8-4576-3247-8177-481554E1F9E7> /usr/lib/system/libsystem_c.dylib
Process: OSDUIHelper [2598]
Path: /System/Library/CoreServices/OSDUIHelper.app/Contents/MacOS/OSDUIHelper
Parent: launchd [1]
UID: 502
Task size: 28.05 MB
CPU Time: <0.001s (300.0K cycles, 61.5K instructions, 4.88c/i)
Thread 0x5d968 DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (141.8K cycles, 30.6K instructions, 4.64c/i)
<thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
10 ??? (OSDUIHelper + 8026) [0x1072fcf5a] 1-10
Thread 0x5d99b Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x1072fb000 - 0x10730dfff com.apple.OSDUIHelper 1.0 (1) <4B4855F1-A9E2-3BA1-8BE3-610F3732A580> /System/Library/CoreServices/OSDUIHelper.app/Contents/MacOS/OSDUIHelper
Process: PAH_Extension (com.apple.PressAndHold) [344]
Path: /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
Parent: launchd [1]
UID: 502
Task size: 17.86 MB
Thread 0xeb7 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
<thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
10 NSExtensionMain + 51 (Foundation + 2245225) [0x7fff2dd0d269] 1-10
10 +[PKService _defaultRun:arguments:] + 17 (PlugInKit + 90033) [0x7fff4a954fb1] 1-10
10 +[PKService main] + 55 (PlugInKit + 88985) [0x7fff4a954b99] 1-10
10 -[PKService run] + 704 (PlugInKit + 89997) [0x7fff4a954f8d] 1-10
10 _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff53ba4d77] 1-10
10 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff50490df0] 1-10
Thread 0xeef Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x10e073000 - 0x10e07afff com.apple.PressAndHold 1.3 (36) <C5B7DB6D-E598-3F5E-A648-5D997574895B> /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
0x7fff4a93f000 - 0x7fff4a964fff com.apple.pluginkit.framework 1.0 (1) <2DCA499B-D7D0-383E-B686-998456FDDF8D> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff5048c000 - 0x7fff5055bfff com.apple.ViewBridge 343.2 (343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process: parsecd [346]
Path: /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
Parent: launchd [1]
UID: 502
Task size: 27.64 MB
Thread 0xebc DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 2509 (parsecd + 134057) [0x106d66ba9] 1-10
Binary Images:
0x106d46000 - 0x106da1fff parsecd (184.3.12) <FF942712-7913-3E85-B524-6E6425392288> /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
Process: passd [323]
Path: /System/Library/PrivateFrameworks/PassKitCore.framework/passd
Parent: launchd [1]
UID: 502
Task size: 26.43 MB
Thread 0xde1 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (passd + 7684) [0x106450e04] 1-10
Binary Images:
0x10644f000 - 0x106569fff passd (1418.8.9.1) <E5C353D6-C273-3E6D-92C9-96A3B3355E77> /System/Library/PrivateFrameworks/PassKitCore.framework/passd
Process: pboard [303]
Path: /usr/libexec/pboard
Parent: launchd [1]
UID: 502
Task size: 8004 KB
Thread 0xce4 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (pboard + 3412) [0x10b36bd54] 1-10
Binary Images:
0x10b36b000 - 0x10b36bfff pboard (1454.90) <2134A60F-377D-3FFC-ACFF-0DBC69A87A41> /usr/libexec/pboard
Process: pbs [437]
Path: /System/Library/CoreServices/pbs
Parent: launchd [1]
UID: 502
Task size: 8268 KB
Thread 0x12bf DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x103f00000 - 0x103f12fff pbs (301.10) <E6B08812-02BA-39A6-8AF9-DC799BAE6B3B> /System/Library/CoreServices/pbs
Process: periodic-wrapper [1064]
Path: /usr/libexec/periodic-wrapper
Parent: launchd [1]
UID: 0
Task size: 892 KB
Thread 0x185a2 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3>
Binary Images:
0x10df4f000 - 0x10df4ffff periodic-wrapper (52) <072A803B-2745-37D9-8B47-09DFD036CB7F> /usr/libexec/periodic-wrapper
Process: periodic-wrapper [10584]
Parent: launchd [1]
UID: 0
Task size: 844 KB
Thread 0x51e344 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
Binary Images:
0x107f92000 - 0x107f92fff periodic-wrapper (52) <072A803B-2745-37D9-8B47-09DFD036CB7F> /usr/libexec/periodic-wrapper
Process: periodic-wrapper [11021]
Parent: launchd [1]
UID: 0
Task size: 828 KB
Thread 0x52f3e4 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
Binary Images:
0x1080e0000 - 0x1080e0fff periodic-wrapper (52) <072A803B-2745-37D9-8B47-09DFD036CB7F> /usr/libexec/periodic-wrapper
Process: personad [2093]
Path: /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/Support/personad
Parent: launchd [1]
UID: 502
Task size: 7076 KB
Thread 0x468f6 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (personad + 95061) [0x101362355] 1-10
Binary Images:
0x10134b000 - 0x10136afff personad (47) <DD612E24-9DCD-3D1D-9ED1-D8039B02B995> /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/Support/personad
Process: photoanalysisd [405]
Path: /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
Parent: launchd [1]
UID: 502
Task size: 40.77 MB
Thread 0x1361 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 403 (photoanalysisd + 6294) [0x108feb896] 1-10
Binary Images:
0x108fea000 - 0x108febfff photoanalysisd (3271.10.210) <8B9B8FF5-B9D1-33CA-A1D5-34AE3935313B> /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
Process: photolibraryd [527]
Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
Parent: launchd [1]
UID: 502
Task size: 21.50 MB
Thread 0x1bed DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
Binary Images:
0x10a646000 - 0x10a96dfff photolibraryd (3291.13.210) <378EF9EB-2CE7-3C0F-88A7-23CD4EDF3DE4> /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
Process: pkd [307]
Path: /usr/libexec/pkd
Parent: launchd [1]
UID: 502
Task size: 19.07 MB
Thread 0xd15 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (pkd + 13765) [0x1043f65c5] 1-10
Binary Images:
0x1043f3000 - 0x104419fff pkd (212.50.1) <361A4190-31E0-3928-BD7E-9BCD5AA231EA> /usr/libexec/pkd
Process: pkd [7772]
Parent: launchd [1]
UID: 0
Task size: 13.37 MB
Thread 0x4a5a93 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (pkd + 13765) [0x1023265c5] 1-10
Binary Images:
0x102323000 - 0x102349fff pkd (212.50.1) <361A4190-31E0-3928-BD7E-9BCD5AA231EA> /usr/libexec/pkd
Process: powerd [69]
Path: /System/Library/CoreServices/powerd.bundle/powerd
Parent: launchd [1]
UID: 0
Task size: 9960 KB
CPU Time: <0.001s (863.9K cycles, 281.6K instructions, 3.07c/i)
Thread 0x274 DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (725.9K cycles, 248.9K instructions, 2.92c/i)
10 ??? (powerd + 172235) [0x1096980cb] 1-10
Binary Images:
0x10966e000 - 0x1096a8fff powerd (703.71.1) <82BA3EF4-1A03-3292-A7FA-95B595883B9B> /System/Library/CoreServices/powerd.bundle/powerd
Process: Preview [14729]
Path: /Applications/Preview.app/Contents/MacOS/Preview
Parent: launchd [1]
UID: 502
Task size: 69.40 MB
Thread 0x692c6a DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested user interactive), process unclamped, IO tier 0>
Thread 0x692cf1 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x105c4a000 - 0x105e54fff com.apple.Preview 10.0 (944.5) <25FC88BD-78BA-35BF-BA16-CAE7AF7D1011> /Applications/Preview.app/Contents/MacOS/Preview
Process: printtool [13422]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool
Parent: launchd [1]
UID: 502
Task size: 14.78 MB
CPU Time: <0.001s (207.5K cycles, 53.5K instructions, 3.88c/i)
Thread 0x5a5cb2 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from Totals [2061], IO tier 0>
10 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
Binary Images:
0x103960000 - 0x103970fff printtool (503.2) <610D3ED6-2A84-3D31-98FE-A069F8FF991A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool
Process: PrintUITool [423]
Path: /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
Parent: launchd [1]
UID: 502
Task size: 19.68 MB
Thread 0x11d2 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (PrintUITool + 33729) [0x10ffdb3c1] 1-10
Binary Images:
0x10ffd3000 - 0x10ffebfff PrintUITool (180.1) <D967DD0E-515F-35C7-B0CE-4F2AA719EF2C> /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
Process: ProtectedCloudKeySyncing [356]
Path: /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
Parent: launchd [1]
UID: 502
Task size: 14.27 MB
Thread 0xf7d DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (ProtectedCloudKeySyncing + 150808) [0x109d1cd18] 1-10
Binary Images:
0x109cf8000 - 0x109d28fff ProtectedCloudKeySyncing (475.71.1) <9C4D0E9F-4C20-3D80-9DB3-5BFA70FDED9C> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
Process: PTPCamera [13369]
Path: /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
Parent: launchd [1]
UID: 502
Task size: 18.45 MB
Thread 0x5a10f5 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
10 ICD_main + 24 (ICADevices + 44146) [0x7fff2e039c72] 1-10
10 ICAApplicationMain + 406 (ICADevices + 8406) [0x7fff2e0310d6] 1-10
10 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
10 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
10 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
10 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
Thread 0x5a1112 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
10 _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
Thread 0x5a1113 10 samples (1-10) priority 31 (base 31)
10 -[PTPTransport callbackThreadFunction] + 291 (PTPCamera + 13432) [0x104de0478] 1-10
Thread 0x6a72d8 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x104ddd000 - 0x104e15fff com.apple.PTPCamera 10.1 (10.1) <4E22B156-1091-3436-9D21-298367EE2922> /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
0x7fff28f67000 - 0x7fff29dc5fff com.apple.AppKit 6.9 (1561.60.100) <3C27CF6F-E640-3411-A87D-CCB2222CC754> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2acc8000 - 0x7fff2afcdfff com.apple.HIToolbox 2.1.1 (911.10) <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2e02f000 - 0x7fff2e05afff com.apple.ICADevices 10.0 (10.1) <38E34731-7FE3-3EDC-95E7-C99FF8C2C2C7> /System/Library/Frameworks/ICADevices.framework/Versions/A/ICADevices
Process: quicklookd (Quick Look Helper) [14879]
Path: /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Parent: launchd [1]
UID: 0
Task size: 13.83 MB
Thread 0x6a3ad0 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (quicklookd + 18485) [0x105e13835] 1-10
Thread 0x6a3ad7 10 samples (1-10) priority 4 (base 4)
10 ??? (quicklookd + 32798) [0x105e1701e] 1-10
Thread 0x6a3ae8 10 samples (1-10) priority 4 (base 4)
10 ??? (quicklookd + 230472) [0x105e47448] 1-10
Binary Images:
0x105e0f000 - 0x105e68fff com.apple.QuickLookDaemon 5.0 (743.13) <BAB0BCCE-6EF6-3F6F-8E4A-7D5F072CD1AE> /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Process: quicklookd (Quick Look Helper) [14896]
Parent: launchd [1]
UID: 502
Task size: 16.08 MB
Thread 0x6a48cd DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (quicklookd + 18485) [0x1080e5835] 1-10
Thread 0x6a48d3 10 samples (1-10) priority 4 (base 4)
10 ??? (quicklookd + 32798) [0x1080e901e] 1-10
Thread 0x6a48d9 10 samples (1-10) priority 4 (base 4)
10 ??? (quicklookd + 230472) [0x108119448] 1-10
Binary Images:
0x1080e1000 - 0x10813afff com.apple.QuickLookDaemon 5.0 (743.13) <BAB0BCCE-6EF6-3F6F-8E4A-7D5F072CD1AE> /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Process: QuickLookUIService [2882]
Path: /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
Parent: launchd [1]
UID: 502
Task size: 334.43 MB
CPU Time: 0.004s (17.9M cycles, 8.9M instructions, 2.01c/i)
Thread 0x8aeb4 DispatchQueue 1 10 samples (1-10) priority 46 (base 46) cpu time 0.003s (13.7M cycles, 7.3M instructions, 1.87c/i)
10 main + 40 (QuickLookUIService + 5681) [0x10dcaa631] 1-10
10 NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff5048eabe] 1-10
10 -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff50490c15] 1-10
10 NSApplicationMain + 804 (AppKit + 23154) [0x7fff28f6ca72] 1-10
1 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff50490df0] 1
1 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1
1 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1
1 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1
1 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1
1 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1
1 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1
1 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1
1 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1
1 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1
*1 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1
9 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 579 (ViewBridge + 20439) [0x7fff50490fd7] 2-10
9 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 2-10
9 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 2-10
9 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 2-10
9 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 2-10
9 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 2-10
9 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 2-10
9 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 2-10
9 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 2-10
9 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 2-10
*9 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 2-10
Thread 0x8aef7 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46) cpu time <0.001s (339.0K cycles, 92.0K instructions, 3.68c/i)
Thread 0x8aeff 10 samples (1-10) priority 31 (base 31)
10 ??? (AppleVPA + 165954) [0x7fff3bf1a842] 1-10
Binary Images:
0x10dca9000 - 0x10dcb1fff com.apple.quicklook.QuickLookUIService 1.0 (1) <4913266C-EEE2-3BB5-B358-84E54ED5812A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
0x7fff3bef2000 - 0x7fff3bf31fff com.apple.AppleVPAFramework 3.8.1 (3.8.1) <54722119-4264-396C-A0F0-33B44B2AB317> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
Process: racoon [278]
Path: /usr/sbin/racoon
Parent: launchd [1]
UID: 0
Task size: 7636 KB
Thread 0xb07 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination dirty, IO tier 0>
Binary Images:
0x106c6b000 - 0x106cd1fff racoon (317) <18CB0007-0809-3339-B31C-E8F451A8E669> /usr/sbin/racoon
Process: rapportd [345]
Path: /usr/libexec/rapportd
Parent: launchd [1]
UID: 502
Task size: 12.59 MB
Thread 0xeba DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (rapportd + 111280) [0x106acf2b0] 1-10
Binary Images:
0x106ab4000 - 0x106ae0fff rapportd (152.1) <1FBBDFD8-4B91-3D49-8937-4AA956EC8982> /usr/libexec/rapportd
Process: rcd [2861]
Path: /System/Library/CoreServices/rcd.app/Contents/MacOS/rcd
Parent: launchd [1]
UID: 502
Task size: 17.91 MB
Thread 0x85a1c DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
10 main + 395 (rcd + 11816) [0x101a48e28] 1-10
Binary Images:
0x101a46000 - 0x101a49fff com.apple.rcd 353 (353) <95977CD5-0324-3329-A581-435F5CDA3917> /System/Library/CoreServices/rcd.app/Contents/MacOS/rcd
Process: recentsd [616]
Path: /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
Architecture: x86_64
Parent: launchd [1]
UID: 502
Task size: 25.63 MB
Thread 0x2c41 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (recentsd + 12503) [0x1056b80d7] 1-10
Thread 0x6a7300 10 samples (1-10) priority 4 (base 4)
<thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x1056b5000 - 0x1056dcfff recentsd (139.3) <BACF2CF2-7850-35E9-B9C9-66A0AF4D23B7> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
Process: ReportCrash [357]
Path: /System/Library/CoreServices/ReportCrash
Parent: launchd [1]
UID: 502
Task size: 7700 KB
Thread 0x1324 10 samples (1-10) priority 4 (base 4)
10 <truncated backtrace> 1-10
Thread 0x675b9f 10 samples (1-10) priority 4 (base 4)
10 ??? (ReportCrash + 8835) [0x10c396283] 1-10
10 mach_msg_server_once + 271 (libsystem_kernel.dylib + 76903) [0x7fff53990c67] 1-10
Binary Images:
0x10c394000 - 0x10c3b2fff ReportCrash (938.4.1) <8D0DFC9D-9AE7-3DB1-81F9-CE4537DDCC31> /System/Library/CoreServices/ReportCrash
Process: ReportCrash [818]
Parent: launchd [1]
UID: 0
Task size: 7528 KB
Thread 0xd939 10 samples (1-10) priority 4 (base 4)
Thread 0x58aac2 10 samples (1-10) priority 4 (base 4)
10 ??? (ReportCrash + 8835) [0x10a3ca283] 1-10
Binary Images:
0x10a3c8000 - 0x10a3e6fff ReportCrash (938.4.1) <8D0DFC9D-9AE7-3DB1-81F9-CE4537DDCC31> /System/Library/CoreServices/ReportCrash
Process: reversetemplated [617]
Path: /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/reversetemplated
Parent: launchd [1]
UID: 502
Task size: 68.05 MB
Thread 0x2c6c DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (reversetemplated + 5396) [0x1042f5514] 1-10
Thread 0x2c7e 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user initiated), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 40 (JavaScriptCore + 12744344) [0x7fff2f683698] 1-10
10 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 12743513) [0x7fff2f683359] 1-10
10 bmalloc::Scavenger::threadRunLoop() + 251 (JavaScriptCore + 12744027) [0x7fff2f68355b] 1-10
10 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 86 (JavaScriptCore + 12744870) [0x7fff2f6838a6] 1-10
10 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 27824) [0x7fff5179ecb0] 1-10
Binary Images:
0x1042f4000 - 0x1042f5fff reversetemplated (680.18.10) <3D802013-2BB2-3EFB-A221-DFC2DAE4A8FA> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/reversetemplated
0x7fff2ea5c000 - 0x7fff2f742fff com.apple.JavaScriptCore 13605 (13605.3.8) <E6B49CDA-72F0-3E58-85EF-98AF10CE04B0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff51798000 - 0x7fff517eefff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
Process: revisiond [111]
Path: /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
Parent: launchd [1]
UID: 0
Task size: 28.04 MB
Thread 0x2a0 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (revisiond + 51430) [0x10a7e68e6] 1-10
10 ??? (revisiond + 50100) [0x10a7e63b4] 1-10
Thread 0x733 10 samples (1-10) priority 4 (base 4)
10 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff5399c142] 1-10
*10 hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 1-10
*10 unix_syscall64 + 616 (kernel + 6306152) [0xffffff8000803968] 1-10
*10 read_nocancel + 115 (kernel + 5532931) [0xffffff8000746d03] 1-10
*10 ??? (kernel + 5533541) [0xffffff8000746f65] 1-10
*10 ??? (kernel + 2877244) [0xffffff80004be73c] 1-10
*10 VNOP_READ + 106 (kernel + 2933994) [0xffffff80004cc4ea] 1-10
*10 spec_read + 667 (kernel + 2976283) [0xffffff80004d6a1b] 1-10
*10 ??? (AppleFSCompressionTypeDataless + 6621) [0xffffff7f82f2a9dd] 1-10
*10 thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
*10 ??? (kernel + 554618) [0xffffff800028767a] 1-10
*10 machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
Binary Images:
0x10a7da000 - 0x10a824fff revisiond (285.3) <87E156AF-1F11-3053-AB8E-92FA96315A75> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
*0xffffff7f82f29000 - 0xffffff7f82f2afff com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 96.60.1 (1.0.0d1) <3B67C87D-2D57-3C8A-AC27-474171D2C9A1> /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSCompressionTypeDataless
Process: routined [354]
Path: /usr/libexec/routined
Parent: launchd [1]
UID: 502
Task size: 44.95 MB
Thread 0xf2a DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (routined + 6339) [0x1007488c3] 1-10
10 -[RTLifeCycleManager start] + 184 (libcoreroutine.dylib + 299745) [0x7fff518872e1] 1-10
Thread 0x13565 Thread name "NetworkLoad" 10 samples (1-10) priority 4 (base 4)
10 _runNetworkThread + 480 (GeoServices + 85274) [0x7fff4489cd1a] 1-10
Binary Images:
0x100747000 - 0x100748fff routined (558.0.10) <C88D9D9E-40AA-357B-81C8-48024578C28A> /usr/libexec/routined
0x7fff44888000 - 0x7fff451cafff com.apple.GeoServices 1.0 (1363.24.8.15.58) <41BA60FF-66EB-342F-B14B-8CB2C9776745> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff5183e000 - 0x7fff51ae7fff libcoreroutine.dylib (558.0.10) <C8A827CD-C62A-3C4B-BA8D-D2A77077E0AA> /usr/lib/libcoreroutine.dylib
Process: rtcreportingd [1074]
Path: /usr/libexec/rtcreportingd
Parent: launchd [1]
UID: 0
Task size: 12.62 MB
Thread 0x1860a DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 ??? (rtcreportingd + 62373) [0x109c363a5] 1-10
Thread 0x35359 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 20 (base 20)
Binary Images:
0x109c27000 - 0x109c4cfff rtcreportingd (9.32.65) <EFC4632F-3351-37CE-B75B-D04E9A2B5AFD> /usr/libexec/rtcreportingd
Process: SafariBookmarksSyncAgent (SafariSupport) [408]
Path: /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
Parent: launchd [1]
UID: 502
Task size: 27.60 MB
Thread 0x113a DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 ??? (SafariBookmarksSyncAgent + 6986) [0x102414b4a] 1-10
10 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 684117) [0x7fff2db90055] 1-10
Thread 0x12ad 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested user initiated), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
Binary Images:
0x102413000 - 0x10249cfff com.apple.SafariBookmarksSyncAgent 13605 (13605.3.8) <51DB9B84-B411-3F90-A2F4-E2FC240139EF> /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
Process: SafeEjectGPUAgent [426]
Path: /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/MacOS/SafeEjectGPUAgent
Parent: launchd [1]
UID: 502
Task size: 8476 KB
Thread 0x1201 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, IO tier 0>
Binary Images:
0x109b58000 - 0x109b5afff SafeEjectGPUAgent (10) <F9D51D1D-2E0E-3E70-84C1-88167F2AE79F> /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/MacOS/SafeEjectGPUAgent
Process: SafeEjectGPUService [427]
Path: /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
Parent: launchd [1]
UID: 502
Task size: 10032 KB
Thread 0x1204 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10d55b000 - 0x10d561fff com.apple.SafeEjectGPUService 1.0 (1) <938712E7-D649-3BD8-854A-14D6A4393F69> /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
Process: sandboxd [620]
Path: /usr/libexec/sandboxd
Parent: launchd [1]
UID: 0
Task size: 8532 KB
Thread 0x2eb6 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Thread 0x2ec9 10 samples (1-10) priority 31 (base 31)
10 SpotlightQueryThread(void*) + 475 (DebugSymbols + 7675) [0x7fff3fe13dfb] 1-10
Binary Images:
0x100a8a000 - 0x100aa1fff sandboxd (765.70.1) <1DBF5AB7-4A3A-334C-95BB-318A6290F414> /usr/libexec/sandboxd
0x7fff3fe12000 - 0x7fff3fe52fff com.apple.DebugSymbols 181.0 (181.0) <299A0238-ED78-3676-B131-274D972824AA> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
Process: ScopedBookmarkAgent [571]
Path: /System/Library/CoreServices/ScopedBookmarkAgent
Parent: launchd [1]
UID: 502
Task size: 10232 KB
Thread 0x1e3e DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102674000 - 0x102678fff ScopedBookmarkAgent (309.1) <C9E84CE8-50A5-3290-B4CF-346C9891500F> /System/Library/CoreServices/ScopedBookmarkAgent
Process: secd [290]
Path: /usr/libexec/secd
Parent: launchd [1]
UID: 502
Task size: 37.54 MB
Thread 0xc3b DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10df4e000 - 0x10e161fff secd (58286.70.7) <123A9D66-B10C-3CE0-8768-DB4A52DA4F22> /usr/libexec/secd
Process: secinitd [222]
Path: /usr/libexec/secinitd
Parent: launchd [1]
UID: 0
Task size: 13.26 MB
Thread 0x6b5 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1068fb000 - 0x106900fff secinitd (30) <446DA163-D6EA-3CD3-B222-9B567850F7B6> /usr/libexec/secinitd
Process: secinitd [324]
Parent: launchd [1]
UID: 502
Task size: 17.76 MB
Thread 0xdec DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10048c000 - 0x100491fff secinitd (30) <446DA163-D6EA-3CD3-B222-9B567850F7B6> /usr/libexec/secinitd
Process: secinitd [6556]
Parent: launchd [1]
UID: 205
Task size: 10.21 MB
Thread 0x46197a DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x108211000 - 0x108216fff secinitd (30) <446DA163-D6EA-3CD3-B222-9B567850F7B6> /usr/libexec/secinitd
Process: secinitd [6574]
Parent: launchd [1]
UID: 0
Task size: 12.82 MB
Thread 0x462f3a DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1002e3000 - 0x1002e8fff secinitd (30) <446DA163-D6EA-3CD3-B222-9B567850F7B6> /usr/libexec/secinitd
Process: securityd [98]
Path: /usr/sbin/securityd
Parent: launchd [1]
UID: 0
Task size: 14.32 MB
Thread 0x28a DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
10 ??? (securityd + 91823) [0x108df86af] 1-10
10 ??? (securityd + 500767) [0x108e5c41f] 1-10
10 ??? (securityd + 27997) [0x108de8d5d] 1-10
Thread 0x2d1 10 samples (1-10) priority 31 (base 31)
10 ??? (securityd + 26603) [0x108de87eb] 1-10
10 ??? (securityd + 331658) [0x108e32f8a] 1-10
10 au_sdev_read_aia + 528 (libbsm.0.dylib + 60396) [0x7fff51787bec] 1-10
10 fgetc + 52 (libsystem_c.dylib + 246895) [0x7fff538d546f] 1-10
10 __srget + 14 (libsystem_c.dylib + 273977) [0x7fff538dbe39] 1-10
10 __srefill1 + 24 (libsystem_c.dylib + 273694) [0x7fff538dbd1e] 1-10
10 __read_nocancel + 10 (libsystem_kernel.dylib + 117738) [0x7fff5399abea] 1-10
*10 ??? (kernel + 5069540) [0xffffff80006d5ae4] 1-10
Thread 0x3f6 10 samples (1-10) priority 31 (base 31)
10 ??? (securityd + 187066) [0x108e0faba] 1-10
10 ??? (securityd + 491013) [0x108e59e05] 1-10
10 SCardGetStatusChange + 373 (PCSC + 6588) [0x7fff360e19bc] 1-10
10 _dispatch_semaphore_wait_slow + 101 (libdispatch.dylib + 39289) [0x7fff53818979] 1-10
*10 semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90] 1-10
Thread 0x69fd98 10 samples (1-10) priority 31 (base 31)
10 ??? (securityd + 26912) [0x108de8920] 1-10
Thread 0x6a5a1f 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x108de2000 - 0x108eb1fff securityd (58286.70.7) <DE6CF660-60E1-3367-8931-AF923935D0DC> /usr/sbin/securityd
0x7fff360e0000 - 0x7fff360ebfff com.apple.pcsc 8.0 (1) <C74764E9-1571-305F-9B0B-C8D84E708FE7> /System/Library/Frameworks/PCSC.framework/Versions/A/PCSC
0x7fff51779000 - 0x7fff51789fff libbsm.0.dylib (39) <6BC96A72-AFBE-34FD-91B1-748A530D8AE6> /usr/lib/libbsm.0.dylib
Process: securityd_service [284]
Path: /usr/libexec/securityd_service
Parent: launchd [1]
UID: 0
Task size: 5908 KB
Thread 0xbc9 DispatchQueue 11 10 samples (1-10) priority 20 (base 20)
Binary Images:
0x10254a000 - 0x102559fff securityd_service (58286.70.7) <89C31036-704E-3B11-962D-CE9572AEBE54> /usr/libexec/securityd_service
Process: sharedfilelistd [253]
Path: /System/Library/CoreServices/sharedfilelistd
Parent: launchd [1]
UID: 0
Task size: 7116 KB
Thread 0x86d DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x10215f000 - 0x10217efff sharedfilelistd (71.21) <BDA36713-1726-3C6C-9E01-1BC9F9405C98> /System/Library/CoreServices/sharedfilelistd
Process: sharedfilelistd [306]
Parent: launchd [1]
UID: 502
Task size: 15.01 MB
Thread 0xd11 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x108afc000 - 0x108b1bfff sharedfilelistd (71.21) <BDA36713-1726-3C6C-9E01-1BC9F9405C98> /System/Library/CoreServices/sharedfilelistd
Process: sharingd [389]
Path: /usr/libexec/sharingd
Parent: launchd [1]
UID: 502
Task size: 60.18 MB
CPU Time: <0.001s (412.0K cycles, 189.0K instructions, 2.18c/i)
Thread 0x110f DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (345.0K cycles, 169.0K instructions, 2.04c/i)
<thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [300], IO tier 0>
10 main + 814 (sharingd + 1315104) [0x1016a5120] 1-10
Thread 0x112d Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
10 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
10 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
10 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
10 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff5399acf2] 1-10
Thread 0x120e6 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x101564000 - 0x101780fff sharingd (1050.22.2) <CBEBBE60-4870-3050-B4CA-35C3E27BBAF8> /usr/libexec/sharingd
Process: signpost_notificationd [252]
Path: /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/XPCServices/signpost_notificationd.xpc/Contents/MacOS/signpost_notificationd
Parent: launchd [1]
UID: 0
Task size: 5848 KB
Thread 0x870 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10aaea000 - 0x10aaedfff com.apple.signpost.signpost-notificationd 1.2.6 (2.6) <91C0917A-2E0A-36CB-86CB-C3A970600B20> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/XPCServices/signpost_notificationd.xpc/Contents/MacOS/signpost_notificationd
Process: silhouette [1066]
Path: /usr/libexec/silhouette
Parent: launchd [1]
UID: 502
Task size: 12.50 MB
Thread 0x185f5 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (silhouette + 13051) [0x10d4542fb] 1-10
Binary Images:
0x10d451000 - 0x10d458fff silhouette (14) <1AFD52BF-B8AF-3E31-92C1-A83FB99BBF7B> /usr/libexec/silhouette
Process: siriknowledged [4728]
Path: /usr/libexec/siriknowledged
Parent: launchd [1]
UID: 502
Task size: 18.80 MB
Thread 0x323df7 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10700b000 - 0x107026fff siriknowledged (96) <9714AF85-B9F1-3627-B240-17A69C90A0FB> /usr/libexec/siriknowledged
Process: smd [551]
Path: /usr/libexec/smd
Parent: launchd [1]
UID: 0
Task size: 4088 KB
Thread 0x1b54 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x104e0d000 - 0x104e13fff smd (1205.70.9) <0D22CC48-4121-3C1E-B9BC-198536BF4B6C> /usr/libexec/smd
Process: soagent [399]
Path: /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent
Parent: launchd [1]
UID: 502
Task size: 45.72 MB
Thread 0x1116 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (soagent + 4673) [0x10bf8f241] 1-10
10 CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
10 __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
10 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
10 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
*10 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
Binary Images:
0x10bf8e000 - 0x10bf8ffff com.apple.soagent 7.0 (5500) <AE6A29F2-7090-3BA6-9844-D43EFAD667E2> /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent
Process: SocialPushAgent [377]
Path: /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
Parent: launchd [1]
UID: 502
Task size: 12.44 MB
Thread 0x1349 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (SocialPushAgent + 19604) [0x10db06c94] 1-10
Binary Images:
0x10db02000 - 0x10db18fff com.apple.SocialPushAgent 60 (60) <C9793DCE-EBA5-3718-B9C5-E654E11401ED> /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
Process: socketfilterfw [213]
Path: /usr/libexec/ApplicationFirewall/socketfilterfw
Parent: launchd [1]
UID: 0
Task size: 13.93 MB
Thread 0x579 DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
10 ??? (socketfilterfw + 24753) [0x10e4c60b1] 1-10
10 ??? (socketfilterfw + 19285) [0x10e4c4b55] 1-10
Thread 0x604 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 20 (base 20)
Binary Images:
0x10e4c0000 - 0x10e4d0fff socketfilterfw (176) <607AFEB4-9CF7-308A-B11C-DA8624E60E6F> /usr/libexec/ApplicationFirewall/socketfilterfw
Process: softwareupdate_notify_agent [534]
Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
Task size: 11.41 MB
Thread 0x1a5d DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
10 ??? (softwareupdate_notify_agent + 9414) [0x100b6c4c6] 1-10
Binary Images:
0x100b6a000 - 0x100b6cfff softwareupdate_notify_agent (1091.8) <EF39C2A2-B158-31E5-A331-F7244FE56A1A> /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
Process: softwareupdated [536]
Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
Task size: 687.33 MB
Thread 0x1a67 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (softwareupdated + 6899) [0x100f0daf3] 1-10
Thread 0x5a00c4 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user initiated), thread darwinbg, process darwinbg, IO tier 2>
Binary Images:
0x100f0c000 - 0x100f0dfff softwareupdated (1091.8) <AEFBAAB3-E8EA-3BD0-8F7E-C5CFC521DB04> /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
Process: spindump [448]
Path: /usr/sbin/spindump
Parent: launchd [1]
UID: 0
Task size: 116.30 MB (+316 KB)
Pageins: 29 pages
CPU Time: 0.067s (287.1M cycles, 256.4M instructions, 1.12c/i)
Note: 6 idle work queue threads omitted
Thread 0x13ed DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Thread 0x5f929 10 samples (1-10) priority 31 (base 31)
Thread 0x6a7a31 10 samples (1-10) priority 63 (base 63) cpu time 0.017s (66.8M cycles, 32.2M instructions, 2.08c/i)
<process sudden termination dirty, IO tier 0>
10 ??? (spindump + 215209) [0x1043b28a9] 1-10
10 __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 118890) [0x7fff5399b06a] 1-10
*10 stack_snapshot_with_config + 172 (kernel + 5519708) [0xffffff800074395c] 1-10
*10 kern_stack_snapshot_internal + 649 (kernel + 257657) [0xffffff800023ee79] (running) 1-10
Thread 0x6a7a2f DispatchQueue 286 1 sample (1) priority 31 (base 31)
<thread QoS default (requested default, ipc override default), process sudden termination dirty, IO tier 0>
1 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 1
1 _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff53b61fd2] 1
1 _dispatch_workloop_worker_thread + 880 (libdispatch.dylib + 109857) [0x7fff53829d21] 1
1 _dispatch_root_queue_drain_deferred_wlh + 332 (libdispatch.dylib + 93965) [0x7fff53825f0d] 1
1 _dispatch_queue_invoke + 373 (libdispatch.dylib + 37222) [0x7fff53818166] 1
1 _dispatch_queue_serial_drain + 635 (libdispatch.dylib + 90647) [0x7fff53825217] 1
1 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 1
1 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 1
1 SLSRegisterUpdateInformationHandler + 723 (SkyLight + 472528) [0x7fff4d6e65d0] 1
1 SLSMainConnectionID + 435 (SkyLight + 1911081) [0x7fff4d845929] 1
1 dispatch_once_f + 41 (libdispatch.dylib + 7531) [0x7fff53810d6b] 1
1 __SLSInitialize_block_invoke + 77 (SkyLight + 1434992) [0x7fff4d7d1570] 1
1 initDisplayMappings + 29 (SkyLight + 9973) [0x7fff4d6756f5] 1
1 initDisplayState + 98 (SkyLight + 10262) [0x7fff4d675816] 1
1 CGSScoreboard + 67 (SkyLight + 11407) [0x7fff4d675c8f] 1
1 SLSServerPort + 175 (SkyLight + 2162519) [0x7fff4d882f57] 1
1 get_session_port + 36 (SkyLight + 11783) [0x7fff4d675e07] 1
1 CGSLookupServerRootPort + 65 (SkyLight + 12131) [0x7fff4d675f63] 1
1 task_get_special_port + 96 (libsystem_kernel.dylib + 49594) [0x7fff5398a1ba] 1
*1 hndl_mach_scall64 + 22 (kernel + 125414) [0xffffff800021e9e6] 1
*1 mach_call_munger64 + 509 (kernel + 1513245) [0xffffff800037171d] 1
*1 ipc_kmsg_get + 0 (kernel + 321120) [0xffffff800024e660] (running) 1
Binary Images:
0x10437e000 - 0x1043c9fff spindump (252) <5DE7946C-781D-32CC-B6A8-35900863EAB6> /usr/sbin/spindump
0x7fff4d673000 - 0x7fff4d90ffff com.apple.SkyLight 1.600.0 (312.103) <27F91170-846C-3E9E-9B8A-788F27C7DAF5> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
Process: spindump_agent [466]
Path: /usr/libexec/spindump_agent
Parent: launchd [1]
UID: 502
Task size: 5812 KB
CPU Time: 0.008s (37.1M cycles, 25.2M instructions, 1.47c/i)
Thread 0x1776 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10c7a2000 - 0x10c7a6fff spindump_agent (252) <75D7F39F-CE51-31AA-9F32-87C3A8F2CDAF> /usr/libexec/spindump_agent
Process: Spotlight [325]
Path: /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
Parent: launchd [1]
UID: 502
Task size: 51.88 MB
Thread 0xdf4 DispatchQueue 1 10 samples (1-10) priority 46 (base 46)
<thread QoS user interactive (requested user interactive), process unclamped, IO tier 0>
10 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
10 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
Thread 0xea5 10 samples (1-10) priority 31 (base 31)
10 ??? (Spotlight + 179552) [0x10c5c9d60] 1-10
Thread 0xfb8 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 46 (base 46)
Binary Images:
0x10c59e000 - 0x10c5f5fff com.apple.Spotlight 1.0 (1191.4.13) <360AD860-E239-3A5A-A150-580967496521> /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
0x7fff2b988000 - 0x7fff2be29fff com.apple.CoreFoundation 6.9 (1454.90) <E5D594BF-9142-3325-A62D-CF4AAF472642> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff53849000 - 0x7fff53866fff libdyld.dylib (551.4) <81BF3A82-5719-3B54-ABA9-76C82D932CAC> /usr/lib/system/libdyld.dylib
0x7fff5397e000 - 0x7fff539a4fff libsystem_kernel.dylib (4570.71.2) <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2> /usr/lib/system/libsystem_kernel.dylib
Process: storeaccountd [360]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
Parent: launchd [1]
UID: 502
Task size: 16.63 MB
Thread 0xfb7 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
10 ??? (storeaccountd + 7185) [0x10e73fc11] 1-10
Binary Images:
0x10e73e000 - 0x10e744fff storeaccountd (658.1) <CFC6235D-9AD7-3FFC-8174-6E85FB2F71FC> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.2) <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F> /System/Library/Kernels/kernel
Process: storeassetd [4241]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
Parent: launchd [1]
UID: 502
Sudden Term: Tracked
Task size: 23.89 MB
Note: 1 idle work queue thread omitted
Thread 0x302de4 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (storeassetd + 199657) [0x10a2bcbe9] 1-10
Thread 0x59ff24 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
Binary Images:
0x10a28c000 - 0x10a380fff storeassetd (658.1) <B0E99899-93BE-34B9-935A-2B428D3772E6> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
0x7fff2dae9000 - 0x7fff2deaffff com.apple.Foundation 6.9 (1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: storedownloadd [644]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Parent: launchd [1]
UID: 502
Task size: 45.82 MB (-8192 B)
CPU Time: <0.001s (71.0K cycles, 34.1K instructions, 2.08c/i)
Thread 0x3836 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (storedownloadd + 114080) [0x1075e0da0] 1-10
Thread 0x5a1b8d Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Thread 0x5a1c0d 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user initiated), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
Binary Images:
0x1075c5000 - 0x10774efff storedownloadd (658.1) <47FCD85D-1398-3752-9EDD-5C9D7BE7F6AD> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Process: storeuid [4238]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeuid.app/Contents/MacOS/storeuid
Parent: launchd [1]
UID: 502
Task size: 21.67 MB
CPU Time: <0.001s (279.4K cycles, 73.3K instructions, 3.81c/i)
Thread 0x302d7b DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (153.3K cycles, 39.5K instructions, 3.89c/i)
<thread QoS background (requested utility), process sudden termination dirty, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
10 ??? (storeuid + 31301) [0x1024bda45] 1-10
Thread 0x302df7 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user interactive), process sudden termination dirty, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
Binary Images:
0x1024b6000 - 0x1024ccfff com.apple.storeuid 1.0 (658.1) <7E670B73-F36F-3A77-8F05-BF74265D2B9A> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeuid.app/Contents/MacOS/storeuid
Process: SubmitDiagInfo [469]
Path: /System/Library/CoreServices/SubmitDiagInfo
Parent: launchd [1]
UID: 0
Task size: 38.04 MB
Thread 0x1781 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
10 ??? (SubmitDiagInfo + 74154) [0x10df7f1aa] 1-10
Thread 0x4adb5 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
Binary Images:
0x10df6d000 - 0x10df92fff SubmitDiagInfo (938.4.1) <ECD332E2-ED63-365E-8B60-C7BA7603B97D> /System/Library/CoreServices/SubmitDiagInfo
Process: suggestd [406]
Path: /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
Parent: launchd [1]
UID: 502
Sudden Term: Tracked (allows idle exit)
Task size: 135.23 MB
Thread 0x135b DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from corespotlightd [404], IO tier 0>
10 ??? (suggestd + 11128) [0x105fb5b78] 1-10
Binary Images:
0x105fb3000 - 0x105fb9fff suggestd (680.18.10) <EDF0D90D-1CE5-32D5-BA00-592941F6AB4F> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
Process: suhelperd [540]
Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
Task size: 11.28 MB
Thread 0x1a76 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (suhelperd + 8888) [0x1076fa2b8] 1-10
10 ??? (suhelperd + 26532) [0x1076fe7a4] 1-10
Binary Images:
0x1076f8000 - 0x107724fff suhelperd (1091.8) <2C8E6797-D5AF-35D5-987D-2A331DCEFEB1> /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
Process: swcd [366]
Path: /usr/libexec/swcd
Parent: launchd [1]
UID: 502
Task size: 10.02 MB
Thread 0x1036 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (swcd + 4265) [0x104f630a9] 1-10
Binary Images:
0x104f62000 - 0x104f75fff swcd (180.2) <57DBDBC2-826F-3544-B7BB-AD471F038B35> /usr/libexec/swcd
Process: symptomsd [204]
Path: /usr/libexec/symptomsd
Parent: launchd [1]
UID: 24
Task size: 12.70 MB
CPU Time: <0.001s (396.5K cycles, 73.9K instructions, 5.37c/i)
Thread 0x4e8 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (symptomsd + 6082) [0x10cf427c2] 1-10
Binary Images:
0x10cf41000 - 0x10cf42fff symptomsd (820.60.2) <21D359F9-D69F-3E18-8876-2B62B2827098> /usr/libexec/symptomsd
Process: sysdiagnose [645]
Path: /usr/bin/sysdiagnose
Parent: launchd [1]
UID: 0
Task size: 7436 KB
Thread 0x3849 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 0 and passive>
*10 ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
Binary Images:
0x10ff14000 - 0x10ff83fff sysdiagnose (510.60.3) <FCCBDBA6-4C4F-381C-B56F-FF493C0BC794> /usr/bin/sysdiagnose
Process: syslogd [53]
Path: /usr/sbin/syslogd
Parent: launchd [1]
UID: 0
Task size: 3420 KB
CPU Time: 0.002s (6.8M cycles, 4.7M instructions, 1.45c/i)
Note: 5 idle work queue threads omitted
Thread 0x399 DispatchQueue 10 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (1037.1K cycles, 409.2K instructions, 2.53c/i)
<thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2 and passive>
10 ??? (syslogd + 35599) [0x10080ab0f] 1-10
Thread 0x3b0 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x100802000 - 0x10081afff syslogd (356.70.1) <F949D6BA-807A-3D42-B4D3-C8D36B3D5D08> /usr/sbin/syslogd
0x7fff5380f000 - 0x7fff53848fff libdispatch.dylib (913.60.2) <232C69BD-022E-3AB9-8807-79F9FA7CB5EC> /usr/lib/system/libdispatch.dylib
0x7fff53b5f000 - 0x7fff53b6afff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
Process: sysmond [271]
Path: /usr/libexec/sysmond
Parent: launchd [1]
UID: 0
Task size: 5224 KB
Thread 0x9dd DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10c0b3000 - 0x10c0b8fff sysmond (100) <94C03EE8-2AB7-39BC-ACFE-608FDEEEE836> /usr/libexec/sysmond
Process: syspolicyd [207]
Path: /usr/libexec/syspolicyd
Parent: launchd [1]
UID: 0
Task size: 24.39 MB
Thread 0x51a DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (syspolicyd + 108588) [0x1024ae82c] 1-10
Binary Images:
0x102494000 - 0x1024b7fff syspolicyd (45.60.3) <9986A79A-A78F-34C0-B53F-43F55F9A1652> /usr/libexec/syspolicyd
Process: system_installd [646]
Path: /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
Task size: 10.21 MB
Thread 0x383f DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (system_installd + 6866) [0x10d9fead2] 1-10
Binary Images:
0x10d9fd000 - 0x10d9fefff system_installd (733) <20DBBEE5-E8E6-3D32-A67A-7410C1E5A289> /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
Process: systemsoundserverd [266]
Path: /usr/sbin/systemsoundserverd
Parent: launchd [1]
UID: 0
Task size: 10.16 MB
Thread 0x929 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10bbd4000 - 0x10bbf8fff systemsoundserverd (975.4.21.23) <D11B8B7C-09DE-3E9D-8ED5-CBC0BBD78DA6> /usr/sbin/systemsoundserverd
Process: systemstats [65]
Path: /usr/sbin/systemstats
Parent: launchd [1]
UID: 0
Task size: 12.43 MB
Thread 0x279 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (systemstats + 69518) [0x10043ff8e] 1-10
10 ??? (systemstats + 108288) [0x100449700] 1-10
Binary Images:
0x10042f000 - 0x100550fff systemstats (403.50.9) <D1E75C38-62CE-3D77-9ED3-5F6D38EF0676> /usr/sbin/systemstats
Process: systemstats [272]
Parent: systemstats [65]
Responsible: systemstats [65]
UID: 0
Task size: 9420 KB
Thread 0x9e3 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
10 ??? (systemstats + 69518) [0x10a1a8f8e] 1-10
10 ??? (systemstats + 108423) [0x10a1b2787] 1-10
Thread 0x6a3dbe 10 samples (1-10) priority 4 (base 4)
<thread QoS background, thread darwinbg, process darwinbg, IO tier 2>
*10 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] 1-10
Binary Images:
0x10a198000 - 0x10a2b9fff systemstats (403.50.9) <D1E75C38-62CE-3D77-9ED3-5F6D38EF0676> /usr/sbin/systemstats
*0xffffff7f82a20000 - 0xffffff7f82a2bfff com.apple.kec.pthread 1.0 (1) <E64F7A49-CBF0-3251-9F02-3655E3B3DD31> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process: SystemUIServer [298]
Path: /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
Parent: launchd [1]
UID: 502
Task size: 44.83 MB
Thread 0xc98 DispatchQueue 1 10 samples (1-10) priority 47 (base 47)
<process frontmost, thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
10 ??? (SystemUIServer + 21334) [0x10ec34356] 1-10
Thread 0xd50 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 47 (base 47)
Binary Images:
0x10ec2f000 - 0x10ec80fff com.apple.systemuiserver 1.7 (462) <8CF2AC4F-92D8-34A1-8276-36030158E6DD> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
Process: tailspind [13044]
Path: /usr/libexec/tailspind
Parent: launchd [1]
UID: 0
Task size: 5556 KB
Thread 0x583afa DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x1023e5000 - 0x1023eafff tailspind (53) <416365DB-81DC-372C-8B47-9D2B71A6EBF1> /usr/libexec/tailspind
Process: talagent [297]
Path: /System/Library/CoreServices/talagent
Parent: launchd [1]
UID: 502
Task size: 17.59 MB
CPU Time: <0.001s (271.8K cycles, 70.8K instructions, 3.84c/i)
Thread 0xc92 DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (124.1K cycles, 34.1K instructions, 3.64c/i)
10 ??? (talagent + 7033) [0x1099b7b79] 1-10
10 ??? (talagent + 35747) [0x1099beba3] 1-10
Binary Images:
0x1099b6000 - 0x1099ddfff talagent (301.10) <4AABD2AA-DB4D-38F9-85E0-78127E9EB6AA> /System/Library/CoreServices/talagent
Process: taskgated [425]
Path: /usr/libexec/taskgated
Parent: launchd [1]
UID: 0
Task size: 7728 KB
Thread 0x11e2 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (taskgated + 5829) [0x103d266c5] 1-10
10 ??? (taskgated + 17599) [0x103d294bf] 1-10
10 ??? (taskgated + 18337) [0x103d297a1] 1-10
Binary Images:
0x103d25000 - 0x103d2ffff taskgated (55172.1.1) <0681B002-DD3C-334A-B811-A8E2F6A8CCDA> /usr/libexec/taskgated
Process: tccd [267]
Path: /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Parent: launchd [1]
UID: 0
Task size: 10.51 MB
Thread 0x928 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (tccd + 8897) [0x10d0062c1] 1-10
Binary Images:
0x10d004000 - 0x10d016fff tccd (221.50.6) <1EF6CAA2-ACAD-3D9B-9400-9D71135EA333> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Process: tccd [310]
Parent: launchd [1]
UID: 502
Task size: 12.63 MB
Thread 0xd32 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (tccd + 8897) [0x1068672c1] 1-10
Binary Images:
0x106865000 - 0x106877fff tccd (221.50.6) <1EF6CAA2-ACAD-3D9B-9400-9D71135EA333> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Process: TeamViewer_Desktop [7770]
Path: /Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop
Parent: launchd [1]
UID: 0
Task size: 19.48 MB
CPU Time: 0.002s (6.8M cycles, 3.3M instructions, 2.09c/i)
Thread 0x4a5a7f DispatchQueue 1 10 samples (1-10) priority 20 (base 20) cpu time <0.001s (115.7K cycles, 25.9K instructions, 4.46c/i)
10 ??? (TeamViewer_Desktop + 412291) [0x1083e3a83] 1-10
Thread 0x4a5acf 10 samples (1-10) priority 20 (base 20) cpu time 0.002s (6.6M cycles, 3.2M instructions, 2.05c/i)
<thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
10 ??? (TeamViewer_Desktop + 10930572) [0x108deb98c] 1-10
10 ??? (TeamViewer_Desktop + 10189802) [0x108d36bea] 1-10
10 ??? (TeamViewer_Desktop + 10023989) [0x108d0e435] 1-10
10 ??? (TeamViewer_Desktop + 10024197) [0x108d0e505] 1-10
10 ??? (TeamViewer_Desktop + 10034266) [0x108d10c5a] 1-10
10 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff5399bbea] 1-10
*10 ??? (kernel + 5263408) [0xffffff8000705030] 1-10
Thread 0x4a5b3e 10 samples (1-10) priority 20 (base 20)
10 ??? (TeamViewer_Desktop + 10298952) [0x108d51648] 1-10
10 ??? (TeamViewer_Desktop + 9591469) [0x108ca4aad] 1-10
10 ??? (TeamViewer_Desktop + 10209296) [0x108d3b810] 1-10
10 ??? (TeamViewer_Desktop + 10931713) [0x108debe01] 1-10
10 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
*10 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
Binary Images:
0x10837f000 - 0x109020fff TeamViewer_Desktop (0) <0CEFBA22-C435-39F8-B54D-5A387C205EEB> /Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop
Process: thermald [218]
Path: /usr/libexec/thermald
Parent: launchd [1]
UID: 0
Task size: 10.45 MB
Thread 0x643 DispatchQueue 1 10 samples (1-10) priority 63 (base 63)
10 ??? (thermald + 25408) [0x101f8c340] 1-10
10 __ioctl + 10 (libsystem_kernel.dylib + 115706) [0x7fff5399a3fa] 1-10
*10 ioctl + 1324 (kernel + 5538652) [0xffffff800074835c] 1-10
*10 fo_ioctl + 67 (kernel + 5209187) [0xffffff80006f7c63] 1-10
*10 ??? (kernel + 2879371) [0xffffff80004bef8b] 1-10
*10 VNOP_IOCTL + 191 (kernel + 2934463) [0xffffff80004cc6bf] 1-10
*10 spec_ioctl + 113 (kernel + 2977457) [0xffffff80004d6eb1] 1-10
*10 xcpm_cpu_control + 1157 (kernel + 1720981) [0xffffff80003a4295] 1-10
*10 ??? (kernel + 5437670) [0xffffff800072f8e6] 1-10
*10 lck_mtx_sleep + 126 (kernel + 505086) [0xffffff800027b4fe] 1-10
Binary Images:
0x101f86000 - 0x101f90fff thermald (79) <E999A330-401D-30DE-844B-42BEA31085D4> /usr/libexec/thermald
Process: timed [97]
Path: /usr/libexec/timed
Parent: launchd [1]
UID: 266
Task size: 8288 KB
Thread 0x38e DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), process sudden termination clean, IO tier 0>
10 ??? (timed + 11190) [0x10fe64bb6] 1-10
10 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
Binary Images:
0x10fe62000 - 0x10fea3fff timed (224.5.2) <D1F66A15-DF6E-3CD4-A14F-CBB41BBA760D> /usr/libexec/timed
Process: Totals [2061]
Path: /Applications/Totals.app/Contents/MacOS/Totals
Parent: launchd [1]
UID: 502
Task size: 847.70 MB
Process: trustd [168]
Path: /usr/libexec/trustd
Parent: launchd [1]
UID: 0
Task size: 19.51 MB
Thread 0x421 Thread name "com.apple.CFStream.LegacyThread" 10 samples (1-10) priority 4 (base 4)
10 _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1511541) [0x7fff2baf9075] 1-10
Thread 0x436 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Thread 0xa70 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
10 __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
10 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
Thread 0xa74 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10c397000 - 0x10c3eafff trustd (58286.70.7) <1A3F2B80-150C-3D57-86DC-714F735D544F> /usr/libexec/trustd
0x7fff2a914000 - 0x7fff2acaefff com.apple.CFNetwork 902.1 (902.1) <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process: trustd [289]
Parent: launchd [1]
UID: 502
Task size: 33.82 MB
Thread 0xc31 10 samples (1-10) priority 4 (base 4)
Thread 0xc33 Thread name "com.apple.CFStream.LegacyThread" 10 samples (1-10) priority 4 (base 4)
Thread 0x1358 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Thread 0x1364 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102da7000 - 0x102dfafff trustd (58286.70.7) <1A3F2B80-150C-3D57-86DC-714F735D544F> /usr/libexec/trustd
Process: trustd [607]
Parent: launchd [1]
UID: 89
Task size: 11.55 MB
Thread 0x241f DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Thread 0x2422 Thread name "com.apple.CFStream.LegacyThread" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x102f0e000 - 0x102f61fff trustd (58286.70.7) <1A3F2B80-150C-3D57-86DC-714F735D544F> /usr/libexec/trustd
Process: trustd [6560]
Parent: launchd [1]
UID: 205
Task size: 8244 KB
Thread 0x4619bd 10 samples (1-10) priority 4 (base 4)
Thread 0x4619ca Thread name "com.apple.CFStream.LegacyThread" 10 samples (1-10) priority 4 (base 4)
Thread 0x4619e1 Thread name "com.apple.NSURLConnectionLoader" 10 samples (1-10) priority 4 (base 4)
Thread 0x4619e2 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x108a96000 - 0x108ae9fff trustd (58286.70.7) <1A3F2B80-150C-3D57-86DC-714F735D544F> /usr/libexec/trustd
Process: tzd [7360]
Path: /usr/libexec/tzd
Parent: launchd [1]
UID: 0
Task size: 16.14 MB
Thread 0x494119 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (tzd + 8046) [0x104042f6e] 1-10
Binary Images:
0x104041000 - 0x104062fff tzd (66) <7799C694-4FD9-36FF-AFF4-482D27A68AD8> /usr/libexec/tzd
Process: uninstalld [57]
Path: /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld
Parent: launchd [1]
UID: 0
Task size: 8684 KB
Note: 2 idle work queue threads omitted
Thread 0x26c DispatchQueue 1 10 samples (1-10) priority 20 (base 20)
<thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 3>
10 ??? (uninstalld + 8630) [0x10d3191b6] 1-10
Binary Images:
0x10d317000 - 0x10d31ffff uninstalld (221) <2123F9B1-761F-3773-BF3B-BE375F536412> /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld
Process: universalaccessd [7768]
Path: /usr/sbin/universalaccessd
Parent: launchd [1]
UID: 0
Task size: 12.28 MB
CPU Time: <0.001s (697.6K cycles, 187.5K instructions, 3.72c/i)
Note: 3 idle work queue threads omitted
Thread 0x4a5a5d DispatchQueue 1 10 samples (1-10) priority 31 (base 31) cpu time <0.001s (203.3K cycles, 52.8K instructions, 3.85c/i)
10 ??? (universalaccessd + 5404) [0x10b97451c] 1-10
Binary Images:
0x10b973000 - 0x10b974fff universalaccessd (361.13.8) <49824643-6666-3926-9A21-AE02E0ECDFD6> /usr/sbin/universalaccessd
Process: USBAgent [691]
Path: /usr/libexec/USBAgent
Parent: launchd [1]
UID: 502
Task size: 7748 KB
Thread 0x61ae DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10b739000 - 0x10b73cfff USBAgent (929.50.8) <39BE7E23-4390-3A94-B60D-BCD6E04F4962> /usr/libexec/USBAgent
Process: usbd [211]
Path: /usr/libexec/usbd
Parent: launchd [1]
UID: 0
Task size: 8808 KB
Thread 0x558 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 ??? (usbd + 4362) [0x1052f110a] 1-10
Binary Images:
0x1052f0000 - 0x1052f6fff usbd (929.50.8) <3A77CB81-E019-3812-956D-5CC79A5428CA> /usr/libexec/usbd
Process: usbmuxd [99]
Path: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Parent: launchd [1]
UID: 213
Task size: 7516 KB
Thread 0x47b DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (usbmuxd + 8444) [0x1016920fc] 1-10
10 CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
Thread 0x48f Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x101690000 - 0x1016aafff usbmuxd (423.50.301) <590F0D43-E2E6-3B15-8C61-46DD53BD4013> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Process: useractivityd [401]
Path: /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
Parent: launchd [1]
UID: 502
Task size: 14.28 MB
Thread 0x111a DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (useractivityd + 79606) [0x101b0e6f6] 1-10
Binary Images:
0x101afb000 - 0x101bdffff useractivityd (98.10) <F6361A1D-1065-307F-8CF8-9BEEE217A387> /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
Process: UserEventAgent [54]
Path: /usr/libexec/UserEventAgent
Parent: launchd [1]
UID: 0
Task size: 19.92 MB
CPU Time: <0.001s (256.5K cycles, 90.2K instructions, 2.84c/i)
Thread 0x26a DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (UserEventAgent + 5276) [0x10e33949c] 1-10
Thread 0x456 10 samples (1-10) priority 31 (base 31)
10 ??? (MemoryMonitor + 5816) [0x1111896b8] 1-10
Thread 0x457 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10e338000 - 0x10e33afff UserEventAgent (227.50.8) <8C5040B9-992A-3A6D-A72D-87E5284F9AF6> /usr/libexec/UserEventAgent
0x111188000 - 0x111189fff com.apple.MemoryMonitor 74.50.5 (1) <304B70F8-BF8A-3557-B7FB-C2D2FB2EB229> /System/Library/UserEventPlugins/MemoryMonitor.plugin/Contents/MacOS/MemoryMonitor
Process: UserEventAgent [292]
Parent: launchd [1]
UID: 502
Task size: 31.74 MB
Thread 0xc79 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (UserEventAgent + 5276) [0x10c01c49c] 1-10
Thread 0xcc5 Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10c01b000 - 0x10c01dfff UserEventAgent (227.50.8) <8C5040B9-992A-3A6D-A72D-87E5284F9AF6> /usr/libexec/UserEventAgent
Process: UserEventAgent [7766]
Parent: launchd [1]
UID: 0
Task size: 12.48 MB
Thread 0x4a5a81 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (UserEventAgent + 5276) [0x10983349c] 1-10
Thread 0x4a5b5f Thread name "com.apple.CFSocket.private" 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x109832000 - 0x109834fff UserEventAgent (227.50.8) <8C5040B9-992A-3A6D-A72D-87E5284F9AF6> /usr/libexec/UserEventAgent
Process: usernoted [347]
Path: /usr/sbin/usernoted
Parent: launchd [1]
UID: 502
Task size: 17.70 MB
Thread 0xec5 DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
<thread QoS default (requested default), IO tier 0>
10 ??? (usernoted + 14973) [0x104faba7d] 1-10
10 autoreleasepool<A>(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff4ebf7c68] 1-10
10 ??? (usernoted + 17134) [0x104fac2ee] 1-10
Binary Images:
0x104fa8000 - 0x105111fff usernoted (639.10) <9EF2BB69-F7A3-3008-8870-6FE36C11F2B9> /usr/sbin/usernoted
0x7fff4ebf4000 - 0x7fff4ebf9fff libswiftObjectiveC.dylib (900.8.49.1) <DCF880C2-D021-36E6-86A1-63845D04E99E> /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process: VDCAssistant [209]
Path: /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant
Parent: launchd [1]
UID: 262
Task size: 13.55 MB
Thread 0x8d1 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
Thread 0x8d7 10 samples (1-10) priority 97 (base 97)
<process sudden termination clean, IO tier 0>
10 ??? (VDCAssistant + 22546) [0x10d065812] 1-10
Binary Images:
0x10d060000 - 0x10d0ebfff VDCAssistant (4995) <643318C5-476A-3053-8B6E-547C1664B40A> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant
Process: videosubscriptionsd [436]
Path: /usr/libexec/videosubscriptionsd
Parent: launchd [1]
UID: 502
Task size: 23.17 MB
Thread 0x1365 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10961e000 - 0x10961efff videosubscriptionsd (260) <14A1974F-EA14-344B-BC08-2AC6BA5F7688> /usr/libexec/videosubscriptionsd
Process: ViewBridgeAuxiliary [442]
Path: /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
Parent: launchd [1]
UID: 502
Task size: 12.45 MB
CPU Time: <0.001s (296.4K cycles, 79.9K instructions, 3.71c/i)
Thread 0x12d6 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
10 ViewBridgeAuxiliaryMain + 29 (ViewBridge + 484884) [0x7fff50502614] 1-10
10 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff53ba39ca] 1-10
10 _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff53ba4d4b] 1-10
Binary Images:
0x10312d000 - 0x10312dfff com.apple.ViewBridgeAuxiliary (343.2) <F6020B34-99DE-3B76-931F-69DAA4B54848> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
0x7fff5048c000 - 0x7fff5055bfff com.apple.ViewBridge 343.2 (343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff53b94000 - 0x7fff53bc1fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
Process: VTDecoderXPCService [455]
Path: /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Parent: launchd [1]
Responsible: Creative Cloud [394]
UID: 502
Task size: 7936 KB
Thread 0x14fe DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (VTDecoderXPCService + 3990) [0x104b11f96] 1-10
Binary Images:
0x104b11000 - 0x104b11fff com.apple.coremedia.videodecoder 1.0 (1) <7DFD41E8-04BE-3F69-9E06-BE0A582DEE41> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Process: VTDecoderXPCService [14325]
Parent: launchd [1]
Responsible: Google Chrome (Chrome) [14319]
UID: 502
Task size: 10.36 MB
Thread 0x6751b8 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (VTDecoderXPCService + 3990) [0x10a4bef96] 1-10
Binary Images:
0x10a4be000 - 0x10a4befff com.apple.coremedia.videodecoder 1.0 (1) <7DFD41E8-04BE-3F69-9E06-BE0A582DEE41> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Process: warmd [79]
Path: /usr/libexec/warmd
Parent: launchd [1]
UID: 0
Task size: 18.16 MB
CPU Time: <0.001s (223.0K cycles, 51.3K instructions, 4.35c/i)
Thread 0x363 DispatchQueue 11 10 samples (1-10) priority 31 (base 31)
10 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
Thread 0x378 10 samples (1-10) priority 31 (base 31)
Binary Images:
0x10591c000 - 0x10593cfff warmd (66) <350BB46E-33AF-3991-82D9-34C552ABD5D6> /usr/libexec/warmd
Process: watchdogd [216]
Path: /usr/libexec/watchdogd
Parent: launchd [1]
UID: 0
Task size: 4520 KB
Thread 0x5c7 DispatchQueue 1 Thread name "com.apple.watchdogd.main-thread" 10 samples (1-10) priority 31 (base 31)
10 ??? [0x104e1c92d] 1-10
Thread 0x5d4 Thread name "com.apple.watchdogd.watchdog-thread" 10 samples (1-10) priority 97 (base 97)
<IO tier 0>
10 ??? [0x104e1d776] 1-10
Binary Images:
Process: WeatherProStatusItem [383]
Path: /Applications/WeatherPro.app/Contents/Library/LoginItems/WeatherProStatusItem.app/Contents/MacOS/WeatherProStatusItem
Parent: launchd [1]
UID: 502
Task size: 43.53 MB
CPU Time: <0.001s (267.6K cycles, 65.0K instructions, 4.12c/i)
Process: WeTransfer [417]
Path: /Applications/WeTransfer.app/Contents/MacOS/WeTransfer
Parent: launchd [1]
UID: 502
Task size: 40.82 MB
Process: WhatsApp [13411]
Path: /Applications/WhatsApp.app/Contents/MacOS/WhatsApp
Parent: launchd [1]
UID: 502
Task size: 118.42 MB
CPU Time: <0.001s (139.0K cycles, 31.9K instructions, 4.36c/i)
Process: WhatsApp Helper (WhatsApp) [13414]
Path: /Applications/WhatsApp.app/Contents/Frameworks/WhatsApp Helper.app/Contents/MacOS/WhatsApp Helper
Parent: WhatsApp [13411]
Responsible: WhatsApp [13411]
UID: 502
Task size: 99.69 MB
Process: WhatsApp Helper (WhatsApp) [13415]
UID: 502
Task size: 264.67 MB
Process: WiFiAgent [369]
Path: /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
Parent: launchd [1]
UID: 502
Task size: 18.56 MB
CPU Time: <0.001s (295.4K cycles, 80.9K instructions, 3.65c/i)
Thread 0x134d DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (200.2K cycles, 48.1K instructions, 4.17c/i)
10 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
10 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
10 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
10 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
Thread 0x1500 Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
<thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
10 _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
Thread 0x150b Thread name "Cloud Sync Engine" 10 samples (1-10) priority 4 (base 4)
10 ??? (WiFiAgent + 4874) [0x10a1ea30a] 1-10
Binary Images:
0x10a1e9000 - 0x10a1fafff com.apple.wifi.WiFiAgent 13.0 (1361.7) <DB56701D-BE2B-3FF2-8CAB-7B2F947AE94F> /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
0x7fff28f67000 - 0x7fff29dc5fff com.apple.AppKit 6.9 (1561.60.100) <3C27CF6F-E640-3411-A87D-CCB2222CC754> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2acc8000 - 0x7fff2afcdfff com.apple.HIToolbox 2.1.1 (911.10) <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process: WiFiAgent [7771]
Parent: launchd [1]
UID: 0
Task size: 13.97 MB
CPU Time: <0.001s (247.0K cycles, 71.4K instructions, 3.46c/i)
Thread 0x4a5a88 DispatchQueue 1 10 samples (1-10) priority 4 (base 4) cpu time <0.001s (105.0K cycles, 31.6K instructions, 3.33c/i)
Thread 0x4a5bab Thread name "com.apple.NSEventThread" 10 samples (1-10) priority 4 (base 4)
Thread 0x4a5bad Thread name "Cloud Sync Engine" 10 samples (1-10) priority 4 (base 4)
10 ??? (WiFiAgent + 4874) [0x100c0730a] 1-10
Binary Images:
0x100c06000 - 0x100c17fff com.apple.wifi.WiFiAgent 13.0 (1361.7) <DB56701D-BE2B-3FF2-8CAB-7B2F947AE94F> /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
Process: WiFiProxy [335]
Path: /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
Parent: launchd [1]
Responsible: SystemUIServer [298]
UID: 502
Task size: 13.32 MB
Thread 0xe57 DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 main + 413 (WiFiProxy + 23143) [0x10559fa67] 1-10
10 -[NSXPCListener resume] + 165 (Foundation + 485365) [0x7fff2db5f7f5] 1-10
Binary Images:
0x10559a000 - 0x1055a1fff com.apple.WiFiProxy 13.0 (1361.7) <B4128D27-7EAE-3B81-8613-803442B6D39E> /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
Process: WindowServer [214]
Path: /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
Parent: launchd [1]
UID: 88
Task size: 577.48 MB (+272 KB)
CPU Time: 0.024s (99.9M cycles, 64.7M instructions, 1.54c/i)
Thread 0x57d DispatchQueue 1 10 samples (1-10) priority 79 (base 79) cpu time 0.016s (68.6M cycles, 50.4M instructions, 1.36c/i)
<IO tier 0>
10 ??? (WindowServer + 3550) [0x100e68dde] 1-10
10 SLXServer + 832 (SkyLight + 2412204) [0x7fff4d8bfeac] 1-10
10 CGXRunOneServicesPass + 460 (SkyLight + 2409414) [0x7fff4d8bf3c6] 1-10
1 run_one_server_pass + 279 (SkyLight + 2409810) [0x7fff4d8bf552] 1
1 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 78358) [0x7fff53991216] 1
*1 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1
1 run_one_server_pass + 949 (SkyLight + 2410480) [0x7fff4d8bf7f0] 2
1 post_port_data + 235 (SkyLight + 2411284) [0x7fff4d8bfb14] 2
1 eventNotificationHandler(unsigned int, mach_msg_header_t*, void*) + 9 (SkyLight + 2283933) [0x7fff4d8a099d] 2
1 CGXRunOneEventPass + 1028 (SkyLight + 2273973) [0x7fff4d89e2b5] 2
1 sHIDContinuation(_SLSEventRecord*, void*) + 954 (SkyLight + 901674) [0x7fff4d74f22a] 2
1 add_events_to_tap + 388 (SkyLight + 458811) [0x7fff4d6e303b] 2
1 post_events_after_tap_id + 136 (SkyLight + 460090) [0x7fff4d6e353a] 2
1 sPostContinuation(_SLSEventRecord*, void*) + 734 (SkyLight + 2276434) [0x7fff4d89ec52] 2
1 WSFindWindow + 279 (SkyLight + 937837) [0x7fff4d757f6d] 2
1 CGXIsPointInWindow + 572 (SkyLight + 935165) [0x7fff4d7574fd] 2
1 CGXFindSurfaceInWindow + 275 (SkyLight + 1260720) [0x7fff4d7a6cb0] 2
1 CARenderContextHitTest + 28 (QuartzCore + 926840) [0x7fff36e4f478] 2
1 CA::Render::Context::hit_test(CA::Vec2<double> const&, unsigned int) + 194 (QuartzCore + 934976) [0x7fff36e51440] 2
1 CA::Render::Update::~Update() + 646 (QuartzCore + 449746) [0x7fff36ddacd2] 2
1 CA::Render::BackdropGroup::sweep_buffers(unsigned int) + 123 (QuartzCore + 450447) [0x7fff36ddaf8f] (running) 2
1 run_one_server_pass + 279 (SkyLight + 2409810) [0x7fff4d8bf552] 3
1 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 78358) [0x7fff53991216] 3
*1 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 3
1 run_one_server_pass + 337 (SkyLight + 2409868) [0x7fff4d8bf58c] 4
1 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 4
*1 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 4
2 run_one_server_pass + 279 (SkyLight + 2409810) [0x7fff4d8bf552] 5-6
2 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 78358) [0x7fff53991216] 5-6
*2 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 5-6
4 run_one_server_pass + 337 (SkyLight + 2409868) [0x7fff4d8bf58c] 7-10
4 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 7-10
*4 ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 7-10
Thread 0x676 10 samples (1-10) priority 31 (base 31)
10 ??? (CoreDisplay + 718867) [0x7fff2b953813] 1-10
10 ??? (CoreDisplay + 718469) [0x7fff2b953685] 1-10
Thread 0x8fe Thread name "com.apple.coreanimation.render-server" 10 samples (1-10) priority 79 (base 79) cpu time 0.004s (16.2M cycles, 7.4M instructions, 2.20c/i)
<IO tier 0>
10 thread_fun + 25 (QuartzCore + 6986) [0x7fff36d6eb4a] 1-10
10 CA::Render::Server::server_thread(void*) + 870 (QuartzCore + 7878) [0x7fff36d6eec6] 1-10
Thread 0x6a7016 10 samples (1-10) priority 79 (base 79) cpu time 0.001s (5.1M cycles, 2.9M instructions, 1.76c/i)
<IO tier 0>
10 _dispatch_worker_thread + 251 (libdispatch.dylib + 20051) [0x7fff53813e53] 1-10
10 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 39246) [0x7fff5381894e] 1-10
10 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 78430) [0x7fff5399125e] 1-10
Thread 0x6a77cc 10 samples (1-10) priority 79 (base 79) cpu time <0.001s (485.7K cycles, 179.9K instructions, 2.70c/i)
<IO tier 0>
Thread 0x6a791a 10 samples (1-10) priority 79 (base 79)
<IO tier 0>
Thread 0x6a79ac 10 samples (1-10) priority 79 (base 79)
<IO tier 0>
Binary Images:
0x100e68000 - 0x100e68fff WindowServer (312.103) <A149C5C8-3348-3127-B711-8D7FDA5E1194> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
0x7fff2b8a4000 - 0x7fff2b987fff com.apple.CoreDisplay 99.14 (99.14) <A1B91ADD-828D-33A0-8A92-CC3F83DF89D0> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff36d6d000 - 0x7fff36fb9fff com.apple.QuartzCore 1.11 (584.62) <1950D993-DE48-3C97-95A5-66D98BDFC95D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
Process: wirelessproxd [358]
Path: /usr/sbin/wirelessproxd
Architecture: x86_64
Parent: launchd [1]
UID: 0
Task size: 9528 KB
Thread 0xf9b DispatchQueue 1 10 samples (1-10) priority 4 (base 4)
10 ??? (wirelessproxd + 97475) [0x10b6bfcc3] 1-10
Binary Images:
0x10b6a8000 - 0x10b70bfff wirelessproxd (169.3) <5F95E232-E8AB-389B-8D0A-419BA25A05A2> /usr/sbin/wirelessproxd
Process: WirelessRadioManagerd [316]
Path: /usr/sbin/WirelessRadioManagerd
Parent: launchd [1]
UID: 0
Task size: 17.57 MB
Thread 0xd8b DispatchQueue 1 10 samples (1-10) priority 31 (base 31)
10 ??? (WirelessRadioManagerd + 217216) [0x102de6080] 1-10
Binary Images:
0x102db1000 - 0x102e5bfff WirelessRadioManagerd (664) <0BE0AB05-5AA7-3B96-9CAA-CF76CD8617A1> /usr/sbin/WirelessRadioManagerd
Process: writeconfig [2110]
Path: /System/Library/PrivateFrameworks/SystemAdministration.framework/XPCServices/writeconfig.xpc/Contents/MacOS/writeconfig
Parent: launchd [1]
UID: 0
Task size: 7472 KB
Thread 0x4807c DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
10 <truncated backtrace> 1-10
Binary Images:
0x10179a000 - 0x1017b2fff com.apple.systemadministration.writeconfig 1.0 (1) <5641DED6-703B-34EB-AFD4-1A70531B2123> /System/Library/PrivateFrameworks/SystemAdministration.framework/XPCServices/writeconfig.xpc/Contents/MacOS/writeconfig
Process: XprotectService [13413]
Path: /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
Parent: launchd [1]
Responsible: CoreServicesUIAgent [13376]
UID: 502
Task size: 12.27 MB
Thread 0x5a5787 DispatchQueue 11 10 samples (1-10) priority 4 (base 4)
Binary Images:
0x10d522000 - 0x10d52ffff com.apple.XprotectFramework.AnalysisService 1.0 (1) <A9E8D623-B719-3ADC-9345-B5B715596751> /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
Process: kernel_task [0]
Path: /System/Library/Kernels/kernel
UID: 0
Version: Darwin Kernel Version 17.7.0: Thu Jun 21 22:53:14 PDT 2018; root:xnu-4570.71.2~1/RELEASE_X86_64
Task size: 3680.89 MB (-148 KB)
CPU Time: 0.024s (43.3M cycles, 74.4M instructions, 0.58c/i)
Thread 0x65 Thread name "VM_pageout_scan" 10 samples (1-10) priority 91 (base 91)
<IO tier 0>
*10 vm_pageout_continue + 0 (kernel + 1143792) [0xffffff80003173f0] 1-10
Thread 0x66 Thread name "idle #0" 10 samples (1-10) priority 0 (base 0) idle time 0.831s (48.4M cycles, 6.8M instructions, 7.10c/i)
<IO tier 0>
*2 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 1-2
*2 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 1-2
*2 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 1-2
*2 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 1-2
*1 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 3
*1 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 4
*1 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 4
*1 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 4
*1 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 4
*6 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 5-10
Thread 0x67 Thread name "sched_maintenance_thread" 10 samples (1-10) priority 95 (base 95) cpu time <0.001s (95.3K cycles, 44.0K instructions, 2.17c/i)
<IO tier 0>
*10 sched_timeshare_maintenance_continue + 0 (kernel + 555536) [0xffffff8000287a10] 1-10
Thread 0x68 10 samples (1-10) priority 80 (base 80) cpu time <0.001s (681.7K cycles, 323.7K instructions, 2.11c/i)
<IO tier 0>
*10 ??? (kernel + 654832) [0xffffff800029fdf0] 1-10
Thread 0x69 10 samples (1-10) priority 93 (base 93)
<IO tier 0>
*10 ??? (kernel + 656032) [0xffffff80002a02a0] 1-10
Thread 0x6a 10 samples (1-10) priority 80 (base 80)
<IO tier 0>
*10 ??? (kernel + 656624) [0xffffff80002a04f0] 1-10
Thread 0x6b 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
*10 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 1-10
*10 ??? (kernel + 749027) [0xffffff80002b6de3] 1-10
*10 thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
*10 ??? (kernel + 554618) [0xffffff800028767a] 1-10
*10 machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
Thread 0x6c 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x6d Thread name "thread_call_daemon" 10 samples (1-10) priority 94 (base 94)
<IO tier 0>
*10 ??? (kernel + 675264) [0xffffff80002a4dc0] 1-10
Thread 0x6e 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
*10 mapping_replenish + 465 (kernel + 1507505) [0xffffff80003700b1] 1-10
Thread 0x6f Thread name "IOServiceTerminateThread" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (266.9K cycles, 135.6K instructions, 1.97c/i)
<IO tier 0>
*10 IOService::terminateThread(void*, int) + 132 (kernel + 6786516) [0xffffff8000878dd4] 1-10
Thread 0x70 Thread name "AppleACPIButton" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 IOWorkLoop::threadMain() + 0 (kernel + 6911232) [0xffffff8000897500] 1-10
Thread 0x72 Thread name "AppleVTD" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x74 Thread name "IOPMrootDomain" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (582.2K cycles, 417.2K instructions, 1.40c/i)
<IO tier 0>
Thread 0x76 Thread name "AppleCredentialManager" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x79 Thread name "AppleKeyStore" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x8a 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
*10 ??? (kernel + 1088304) [0xffffff8000309b30] 1-10
Thread 0x8b 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x8e Thread name "idle #2" 10 samples (1-10) priority 0 (base 0) idle time 0.861s (39.9M cycles, 4.8M instructions, 8.35c/i)
<IO tier 0>
*1 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 1
*2 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 2-3
*2 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 2-3
*2 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 2-3
*2 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 2-3
*2 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 4-5
*5 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 6-10
*5 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 6-10
*5 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 6-10
*5 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 6-10
Thread 0x91 Thread name "idle #4" 10 samples (1-10) priority 0 (base 0) idle time 0.853s (41.0M cycles, 4.1M instructions, 9.93c/i)
<IO tier 0>
*3 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 2-4
*3 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 2-4
*3 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 2-4
*3 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 2-4
*1 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 5
Thread 0x94 Thread name "idle #6" 10 samples (1-10) priority 0 (base 0) idle time 0.863s (37.6M cycles, 4.2M instructions, 9.02c/i)
<IO tier 0>
*2 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 1-2
*2 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 3-4
*2 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 3-4
*2 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 3-4
*2 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 3-4
Thread 0x97 Thread name "idle #1" 10 samples (1-10) priority 0 (base 0) idle time 0.792s (53.4M cycles, 5.5M instructions, 9.64c/i)
<IO tier 0>
*1 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 1
*1 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 1
*1 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 1
*1 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 1
*1 idle_thread + 0 (kernel + 567888) [0xffffff800028aa50] (runnable) 2
*8 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 3-10
*8 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 3-10
*8 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 3-10
*8 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 3-10
Thread 0x9a Thread name "idle #3" 10 samples (1-10) priority 0 (base 0) idle time 0.794s (54.6M cycles, 5.7M instructions, 9.52c/i)
<IO tier 0>
*4 call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 1-4
*4 idle_thread + 32 (kernel + 567920) [0xffffff800028aa70] 1-4
*4 processor_idle + 210 (kernel + 566434) [0xffffff800028a4a2] 1-4
*4 machine_idle + 778 (kernel + 1610874) [0xffffff800038947a] (runnable) 1-4
Thread 0x9d Thread name "idle #5" 10 samples (1-10) priority 0 (base 0) idle time 0.795s (52.1M cycles, 5.3M instructions, 9.79c/i)
<IO tier 0>
Thread 0xa0 Thread name "idle #7" 10 samples (1-10) priority 0 (base 0) idle time 0.894s (56.3M cycles, 5.7M instructions, 9.83c/i)
<IO tier 0>
Thread 0xa5 Thread name "AppleACPIEC" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xb8 Thread name "AppleSMC" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (153.7K cycles, 31.9K instructions, 4.82c/i)
<IO tier 0>
Thread 0xbb Thread name "AppleACPIButton" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xcb Thread name "AppleUSBHostResources" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xcd Thread name "AppleUSBLegacyRoot" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xcf Thread name "AppleUSBXHCISPT" 10 samples (1-10) priority 81 (base 81) cpu time 0.001s (2.1M cycles, 457.2K instructions, 4.62c/i)
<IO tier 0>
Thread 0xd2 Thread name "AppleIntelPchSeriesAHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xe3 Thread name "IONVMeController" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (168.7K cycles, 53.6K instructions, 3.14c/i)
<IO tier 0>
*10 IOWorkLoop::threadMain() + 29 (kernel + 6911261) [0xffffff800089751d] 1-10
Thread 0xe4 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xe5 Thread name "AppleSDXCSlot" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xf7 Thread name "AppleUSBXHCIAR" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0xf9 Thread name "AppleThunderboltHAL" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x129 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 2728624) [0xffffff800049a2b0] 1-10
Thread 0x12b 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 5663072) [0xffffff8000766960] 1-10
Thread 0x12c 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 5081296) [0xffffff80006d88d0] 1-10
Thread 0x12d 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 5141664) [0xffffff80006e74a0] 1-10
Thread 0x12e 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x12f 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x130 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x131 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x132 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x133 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x134 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (269.8K cycles, 77.3K instructions, 3.49c/i)
<IO tier 0>
*10 ??? (kernel + 3151217) [0xffffff8000501571] 1-10
Thread 0x135 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x136 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x137 Thread name "VM_memorystatus" 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
*10 ??? (kernel + 5464048) [0xffffff8000735ff0] 1-10
Thread 0x139 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 sockwall_gc_thread + 0 (ALF + 23952) [0xffffff7f83d77d90] 1-10
Thread 0x13c 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x13e Thread name "IOHIDSystem" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x141 Thread name "AirPort_BrcmNIC" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x142 Thread name "BCM5701Enet" 10 samples (1-10) priority 82 (base 82) cpu time <0.001s (54.8K cycles, 10.6K instructions, 5.17c/i)
<IO tier 0>
Thread 0x149 Thread name "AppleUSB20XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x14c Thread name "AppleUSB30XHCITypeCPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x14e Thread name "AppleUSB20XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x150 Thread name "AppleUSB30XHCITypeCPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x151 Thread name "AppleUSB20XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x157 Thread name "AppleUSB20XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x15b Thread name "AppleUSB20XHCIPort" 10 samples (1-10) priority 81 (base 81) cpu time 0.002s (2.2M cycles, 931.6K instructions, 2.39c/i)
<IO tier 0>
Thread 0x15d Thread name "AppleUSB20XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x15f Thread name "AppleUSB20XHCITypeCPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x161 Thread name "AppleUSB20XHCITypeCPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x163 Thread name "AppleUSB30XHCIPort" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (949.2K cycles, 380.3K instructions, 2.50c/i)
<IO tier 0>
Thread 0x165 Thread name "AppleUSB30XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x167 Thread name "AppleUSB30XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x169 Thread name "AppleUSB30XHCIPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x16d 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 swcrypto_threadpool_worker_thread(void*, int) + 108 (apfs + 127926) [0xffffff7f819273b6] 1-10
Thread 0x16e 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x16f 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x170 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x17d 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 5950810) [0xffffff80007acd5a] 1-10
*10 mach_msg_receive + 178 (kernel + 397666) [0xffffff8000261162] 1-10
*10 ipc_mqueue_receive + 119 (kernel + 339479) [0xffffff8000252e17] 1-10
Thread 0x17f 10 samples (1-10) priority 91 (base 91)
<IO tier 2>
*10 ??? (kernel + 1149504) [0xffffff8000318a40] 1-10
Thread 0x180 10 samples (1-10) priority 31 (base 31)
<IO tier 0>
*10 vm_pageout_garbage_collect + 0 (kernel + 1142144) [0xffffff8000316d80] 1-10
Thread 0x181 10 samples (1-10) priority 31 (base 31)
<IO tier 0>
*10 vm_pressure_thread + 0 (kernel + 1143392) [0xffffff8000317260] 1-10
Thread 0x182 10 samples (1-10) priority 91 (base 91)
<IO tier 0>
*10 ??? (kernel + 1088876) [0xffffff8000309d6c] 1-10
Thread 0x183 Thread name "VM_cswap_trigger" 10 samples (1-10) priority 91 (base 91)
<IO tier 0>
*10 ??? (kernel + 900016) [0xffffff80002dbbb0] 1-10
Thread 0x184 Thread name "VM_compressor" 10 samples (1-10) priority 91 (base 91)
<IO tier 0>
*10 vm_pageout_iothread_internal_continue + 0 (kernel + 1144192) [0xffffff8000317580] 1-10
Thread 0x185 Thread name "VM_compressor" 10 samples (1-10) priority 91 (base 91)
<IO tier 0>
Thread 0x186 10 samples (1-10) priority 91 (base 91)
<IO tier 2 and passive>
*10 ??? (kernel + 924672) [0xffffff80002e1c00] 1-10
Thread 0x187 10 samples (1-10) priority 91 (base 91)
<IO tier 0>
*10 ??? (kernel + 926128) [0xffffff80002e21b0] 1-10
Thread 0x188 10 samples (1-10) priority 91 (base 91)
*10 ??? (kernel + 926784) [0xffffff80002e2440] 1-10
Thread 0x1a9 Thread name "AppleUSBController" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1aa Thread name "AppleUSBRootHubDevice" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1ae Thread name "AppleUSB30HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1b0 Thread name "AppleUSB30HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1b2 Thread name "AppleUSB30HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1b4 Thread name "AppleUSB30HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1c4 Thread name "AppleUSB20HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1c6 Thread name "AppleUSB20HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1c8 Thread name "AppleUSB20HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1ca Thread name "AppleUSB20HubPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x1e2 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (13.0K cycles, 4.5K instructions, 2.88c/i)
<IO tier 0>
*10 ??? (kernel + 5882764) [0xffffff800079c38c] 1-10
Thread 0x31b 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (140.6K cycles, 36.0K instructions, 3.91c/i)
<IO tier 0>
*10 ??? (kernel + 3152705) [0xffffff8000501b41] 1-10
Thread 0x31c Thread name "ifnet_start_en0" 10 samples (1-10) priority 82 (base 82) cpu time <0.001s (32.9K cycles, 7.4K instructions, 4.47c/i)
<IO tier 0>
*10 ??? (kernel + 3187575) [0xffffff800050a377] 1-10
*10 msleep + 98 (kernel + 5438898) [0xffffff800072fdb2] 1-10
Thread 0x31d 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
*10 ??? (kernel + 3188069) [0xffffff800050a565] 1-10
Thread 0x3ce Thread name "dlil_input_en1" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 3155295) [0xffffff800050255f] 1-10
Thread 0x3cf Thread name "ifnet_start_en1" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x499 Thread name "dlil_input_p2p0" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x49a Thread name "ifnet_start_p2p0" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x4fa Thread name "dlil_input_awdl0" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x4fb Thread name "ifnet_start_awdl0" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x5aa Thread name "IOGraphicsSystemWorkLoop" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5b4 Thread name "dlil_input_en2" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5b5 Thread name "ifnet_start_en2" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x5b7 Thread name "dlil_input_en3" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5b8 Thread name "ifnet_start_en3" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x5bd Thread name "AppleHDAController" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5c1 10 samples (1-10) priority 97 (base 97)
<IO tier 0>
*10 AppleOSXWatchdog::watchdogMainThread() + 133 (AppleOSXWatchdog + 5613) [0xffffff7f8397e5ed] 1-10
Thread 0x5c4 Thread name "AppleMCCSParameterHandler" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5c9 Thread name "X86PlatformPlugin" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5d5 Thread name "AppleIntelSlowAdaptiveClockingManager" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5d7 Thread name "AppleGPUWrangler" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5e3 Thread name "IOFBController" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5e6 Thread name "IOBluetoothHCIController" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5e8 Thread name "IOBluetoothSerialManager" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5ea Thread name "IOSurfaceRoot" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5ec Thread name "AppleSSE" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5ee 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5f7 Thread name "AppleGFXHDAController" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x601 Thread name "AMDRadeonX4000_AMDAccelEventMachine" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (11.3K cycles, 4.8K instructions, 2.36c/i)
<IO tier 0>
Thread 0x602 Thread name "AMDRadeonX4000_AMDEllesmereGraphicsAccelerator" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (872.9K cycles, 311.7K instructions, 2.80c/i)
<IO tier 0>
Thread 0x603 Thread name "IOAccelFenceMachine" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (203.3K cycles, 66.0K instructions, 3.08c/i)
<IO tier 0>
Thread 0x605 Thread name "AMDRadeonX4000_AMDCPEvent" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x607 Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x608 Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x609 Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x60a Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x60b Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x60c Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x615 Thread name "AppleGFXHDADriver" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x620 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (1638.4K cycles, 539.6K instructions, 3.04c/i)
<IO tier 0>
*10 IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 312 (kernel + 6925672) [0xffffff800089ad68] 1-10
*10 IOWorkQueue::processWorkCallFromSingleThreadAction(OSObject*, void*, void*, void*, void*) + 45 (IOBluetoothFamily + 218593) [0xffffff7f82de75e1] 1-10
*10 IOWorkQueue::processWorkCallFromSingleThreadWL() + 284 (IOBluetoothFamily + 218888) [0xffffff7f82de7708] 1-10
*10 IOEventSource::sleepGate(void*, unsigned int) + 76 (kernel + 6919260) [0xffffff800089945c] 1-10
*10 IOWorkLoop::sleepGate(void*, unsigned int) + 123 (kernel + 6913051) [0xffffff8000897c1b] 1-10
Thread 0x625 Thread name "AppleIntelMEIDriver" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x62e Thread name "AppleHDADriver" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x638 Thread name "X86PlatformShim" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x63a 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
*10 ??? (kernel + 1681935) [0xffffff800039aa0f] 1-10
Thread 0x63b 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
*10 ??? (kernel + 1683474) [0xffffff800039b012] 1-10
Thread 0x63c 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x63d 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x63e 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x63f 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x640 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x641 10 samples (1-10) priority 95 (base 95)
<IO tier 0>
Thread 0x65e Thread name "IGAccelEventMachine" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x660 Thread name "IntelAccelerator" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x661 Thread name "IOAccelFenceMachine" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x753 Thread name "AMDRadeonX4000_AMDAccelDisplayPipe" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (556.0K cycles, 205.0K instructions, 2.71c/i)
<IO tier 0>
Thread 0xacd Thread name "ifnet_start_utun0" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x10d4 Thread name "ifnet_start_utun1" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x50cb8 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x50cb9 Thread name "IOTimeSyncMachNanoPort" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x466580 Thread name "thread call kernel-high #3" 10 samples (1-10) priority 92 (base 92) cpu time 0.012s (25.6M cycles, 67.9M instructions, 0.38c/i)
<IO tier 0>
*10 ??? (kernel + 676096) [0xffffff80002a5100] 1-10
Thread 0x4665c3 Thread name "thread call kernel-high #4" 10 samples (1-10) priority 92 (base 92)
<IO tier 0>
Thread 0x46c5de Thread name "ifnet_start_utun2" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x4754d0 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x50f533 Thread name "thread call high #5" 10 samples (1-10) priority 93 (base 93) cpu time 0.002s (2.2M cycles, 830.8K instructions, 2.67c/i)
<IO tier 0>
Thread 0x576f31 Thread name "thread call high #5" 10 samples (1-10) priority 93 (base 93) cpu time <0.001s (675.6K cycles, 248.1K instructions, 2.72c/i)
<IO tier 0>
Thread 0x57a6ac Thread name "thread call high #5" 10 samples (1-10) priority 93 (base 93)
<IO tier 0>
Thread 0x583b00 Thread name "kperf sampling" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
*10 ??? (kernel + 1348696) [0xffffff8000349458] 1-10
Thread 0x584080 10 samples (1-10) priority 81 (base 81)
<IO tier 0 and passive>
*10 tx_flush_thread + 121 (apfs + 705194) [0xffffff7f819b42aa] 1-10
*10 ??? (kernel + 5437432) [0xffffff800072f7f8] 1-10
*10 lck_mtx_sleep_deadline + 139 (kernel + 505659) [0xffffff800027b73b] 1-10
Thread 0x5a1138 Thread name "dlil_input_en8" 10 samples (1-10) priority 81 (base 81)
<IO tier 0>
Thread 0x5a1139 Thread name "ifnet_start_en8" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x6087a8 Thread name "ifnet_start_utun3" 10 samples (1-10) priority 82 (base 82)
<IO tier 0>
Thread 0x688b84 Thread name "thread call high #5" 10 samples (1-10) priority 93 (base 93) cpu time <0.001s (42.0K cycles, 14.3K instructions, 2.94c/i)
<IO tier 0>
Thread 0x6a2559 Thread name "thread call kernel #3" 10 samples (1-10) priority 81 (base 81) cpu time <0.001s (97.6K cycles, 40.2K instructions, 2.43c/i)
<IO tier 0>
Binary Images:
*0xffffff7f81908000 - 0xffffff7f819e3fff com.apple.filesystems.apfs 748.51.0 (748.51.0) <F5310D5D-825A-3114-86DA-6E7D2A21133A> /System/Library/Extensions/apfs.kext/Contents/MacOS/apfs
*0xffffff7f82db2000 - 0xffffff7f82e38fff com.apple.iokit.IOBluetoothFamily 6.0.7 (6.0.7f10) <74C48C9C-2C96-3786-9ED7-F351FAA0E33C> /System/Library/Extensions/IOBluetoothFamily.kext/Contents/MacOS/IOBluetoothFamily
*0xffffff7f8397d000 - 0xffffff7f8397efff com.apple.driver.AppleOSXWatchdog 1.0 (1) <10AB980B-BF01-317D-8CE7-51079C8E304C> /System/Library/Extensions/AppleOSXWatchdog.kext/Contents/MacOS/AppleOSXWatchdog
*0xffffff7f83d72000 - 0xffffff7f83d78fff com.apple.nke.applicationfirewall 5.0 (183) <CBC1954F-5BBE-3FD5-B1BD-24E999226FEF> /System/Library/Extensions/ALF.kext/Contents/MacOS/ALF
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.2) <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F> /System/Library/Kernels/kernel
Kextstat:
Index Refs Address Size Wired Name (Version) UUID <Linked Against>
1 110 0xffffff7f80a00000 0x9e30 0x9e30 com.apple.kpi.bsd (17.7.0) 8CF59A67-A723-4FB8-A127-09A4B32E1874
2 10 0xffffff7f80f21000 0x3990 0x3990 com.apple.kpi.dsep (17.7.0) E085363B-71AD-4ED8-A63E-3EEC4F643ED9
3 136 0xffffff7f80a29000 0x21150 0x21150 com.apple.kpi.iokit (17.7.0) 695D2CC5-AB90-4CD4-9862-2C50A3A989B8
4 141 0xffffff7f80a0a000 0xd430 0xd430 com.apple.kpi.libkern (17.7.0) 26F1FC40-6578-4254-AF12-3D397814B5CB
5 125 0xffffff7f80a18000 0x3f60 0x3f60 com.apple.kpi.mach (17.7.0) 05B0DB8B-BF52-4A99-B18A-BE623583B448
6 80 0xffffff7f80a1c000 0xce70 0xce70 com.apple.kpi.private (17.7.0) 409868DB-B2D5-4249-A98A-3C2BC6E7A754
7 85 0xffffff7f80a8e000 0x5ea0 0x5ea0 com.apple.kpi.unsupported (17.7.0) 37241BAB-747F-4D47-BBD5-C01F3577D845
8 8 0xffffff7f81162000 0xb0000 0xb0000 com.apple.kec.corecrypto (1.0) B081B8C1-1DFF-342F-8DF2-C3AA925ECA3A <7 6 5 4 3 1>
9 1 0xffffff7f81a02000 0x10000 0x10000 com.apple.kec.Libm (1) BC3F7DA4-03EA-30F7-B44A-62C249D51C10 <4>
10 0 0xffffff7f82a20000 0xf000 0xf000 com.apple.kec.pthread (1) E64F7A49-CBF0-3251-9F02-3655E3B3DD31 <7 6 5 4 3 1>
11 34 0xffffff7f80fbe000 0x9000 0x9000 com.apple.iokit.IOACPIFamily (1.4) 95DA39BB-7C39-3742-A2E5-86C555E21D67 <7 6 4 3>
12 45 0xffffff7f80a94000 0x35000 0x35000 com.apple.iokit.IOPCIFamily (2.9) AEA4C7F5-CCB0-338B-B471-CF28A9792522 <7 6 5 4 3>
13 8 0xffffff7f80fc7000 0x1d000 0x1d000 com.apple.driver.AppleSMC (3.1.9) 2D1E4A3F-A19E-3F12-878D-807CB79CD55F <12 11 7 6 5 4 3 1>
14 2 0xffffff7f82af2000 0x9c000 0x9c000 com.apple.driver.AppleACPIPlatform (6.1) B0282791-F78C-3A3D-A829-629AD847C7EA <13 12 11 7 6 5 4 3 1>
15 11 0xffffff7f80e13000 0x30000 0x30000 com.apple.iokit.IONetworkingFamily (3.4) 5A99D802-B477-3D83-9F76-304605479B9F <7 6 5 4 3 1>
16 2 0xffffff7f80e4a000 0x2d000 0x2d000 com.apple.iokit.IOTimeSyncFamily (680.15) 6DD2AAD0-FC4B-32EC-B0FD-AC55A727A789 <15 5 4 3 1>
17 7 0xffffff7f818f0000 0x7000 0x7000 com.apple.iokit.IOReportFamily (31) D2F2FBDF-4EE4-38BA-99F5-B699F886F413 <5 4 3>
18 4 0xffffff7f82ce3000 0x7000 0x7000 com.apple.driver.IOSlaveProcessor (1) 582BDE04-9EB3-3A87-8842-4FF06D1F72C6 <4 3>
19 3 0xffffff7f83746000 0x18000 0x18000 com.apple.driver.AppleSEPManager (1.0.1) 52D654B2-BC1C-3DB9-895A-8EAE7993B17B <18 12 8 7 6 5 4 3 1>
20 1 0xffffff7f80fe6000 0x8000 0x8000 com.apple.driver.AppleBusPowerController (1.0) 79B78C02-CBE8-3C9B-A19D-D8AB5875A429 <13 11 6 5 4 3>
21 7 0xffffff7f80fee000 0x8000 0x8000 com.apple.driver.usb.AppleUSBCommon (1.0) E7111D99-B893-3F96-9741-71C88BC6F66B <5 4 3 1>
22 17 0xffffff7f80ff6000 0x79000 0x79000 com.apple.iokit.IOUSBHostFamily (1.2) CE61D704-9BFF-308E-BC1C-56FF071DBB74 <21 20 7 6 5 4 3 1>
23 3 0xffffff7f825db000 0x1d000 0x1d000 com.apple.driver.KernelRelayHost (1) 49218104-0F45-3612-AF32-76BE251F5B29 <22 5 4 3>
24 1 0xffffff7f83773000 0x3c000 0x3c000 com.apple.driver.AppleCredentialManager (1.0) 56F9E63D-81D4-35B8-83E9-E4BD2202AAB2 <23 19 18 8 7 6 5 4 3 1>
25 8 0xffffff7f80c51000 0x28000 0x28000 com.apple.iokit.IOStorageFamily (2.1) F27A8A2A-6662-3608-83BD-415037509E01 <7 6 5 4 3 1>
26 3 0xffffff7f80a4b000 0x2b000 0x2b000 com.apple.iokit.IOSCSIArchitectureModelFamily (404.30.2) 4734E6C9-B881-32C8-BE1F-4D9848A52895 <6 5 4 3 1>
27 1 0xffffff7f82a4b000 0x19000 0x19000 com.apple.iokit.IOSCSIBlockCommandsDevice (404.30.2) 34091931-8856-37D2-B4BB-82F28AC66162 <26 25 6 5 4 3 1>
28 1 0xffffff7f82a68000 0x2e000 0x2e000 com.apple.iokit.IOUSBMassStorageDriver (140.70.2) 91925DA5-1D2A-3444-A53B-1432B6363BA7 <26 25 22 6 5 4 3 1>
29 6 0xffffff7f81218000 0x15000 0x15000 com.apple.driver.AppleMobileFileIntegrity (1.0.5) 4FAE8181-B0B4-3A30-B0F3-77F48D2486E5 <8 7 6 5 4 3 2 1>
30 1 0xffffff7f82a9d000 0x12000 0x12000 com.apple.driver.AppleUSBTDM (439.70.3) 1CE56483-ADE1-3C2B-ABF6-2F7BA1E3B14E <29 28 27 26 25 22 7 6 5 4 3 1>
31 0 0xffffff7f837af000 0x64000 0x64000 com.apple.driver.AppleKeyStore (2) D3957B25-2814-309B-B9AF-780544562883 <30 29 24 23 19 18 8 7 6 5 4 3 1>
32 2 0xffffff7f81558000 0xc000 0xc000 com.apple.driver.AppleEffaceableStorage (1.0) CA2AB641-FF39-316A-BA4F-5AF561C66AC7 <7 5 4 3 1>
33 0 0xffffff7f8387c000 0xc000 0xc000 com.apple.driver.AppleFDEKeyStore (28.30) 691E35C5-E9F8-33D8-8492-9731EC9D2A6D <32 8 7 6 5 4 3 1>
34 0 0xffffff7f83ca1000 0x19000 0x19000 com.apple.driver.DiskImages (480.60.1) 7D6AED48-938B-315C-A581-356240778C5F <25 7 6 5 4 3 1>
35 2 0xffffff7f8122d000 0x5000 0x5000 com.apple.kext.AppleMatch (1.0.0d1) 2D2996CA-A15E-39E6-9D6B-2BE6DF131972 <4 1>
36 1 0xffffff7f81232000 0x21000 0x21000 com.apple.security.sandbox (300.0) BDFF700A-6746-3643-A0A1-852628695B04 <35 29 25 7 6 5 4 3 2 1>
37 0 0xffffff7f818e6000 0x9000 0x9000 com.apple.security.quarantine (3) 80C4548A-999E-3F96-85B0-6C6F95A542A7 <36 35 7 6 5 4 2 1>
38 0 0xffffff7f83c9e000 0x2000 0x2000 com.apple.security.TMSafetyNet (8) 5B78C369-AA3C-326F-8AE3-C200955DD9A7 <7 6 5 4 2 1>
39 0 0xffffff7f83d72000 0x8000 0x8000 com.apple.nke.applicationfirewall (183) CBC1954F-5BBE-3FD5-B1BD-24E999226FEF <7 6 5 4 3 1>
40 0 0xffffff7f84082000 0x3000 0x3000 com.apple.driver.AppleAPIC (1.7) 9E5B1713-854A-32DC-89E7-E1765F4B3AE3 <12 4 3>
41 9 0xffffff7f80f2d000 0x7b000 0x7b000 com.apple.iokit.IOHIDFamily (2.0.0) 42CD66DF-534C-38D7-A73D-D4AA7343201D <7 6 5 4 3 2 1>
42 2 0xffffff7f82a2f000 0x4000 0x4000 com.apple.iokit.IOSMBusFamily (1.1) 9CFF73D8-2872-3FC0-AEE5-334587EAA4D0 <5 4 3>
43 0 0xffffff7f82b97000 0x7000 0x7000 com.apple.driver.AppleACPIEC (6.1) 4044E1DF-C416-3F42-B056-C07B8D2B305C <42 41 17 14 11 7 6 5 4 3 1>
44 0 0xffffff7f8372a000 0x4000 0x4000 com.apple.driver.AppleSMBIOS (2.1) 93D205A0-CB89-3661-9164-52C412DF576C <7 4 3>
45 0 0xffffff7f825d0000 0x8000 0x8000 com.apple.driver.AppleRTC (2.0) 9405586F-1673-31BE-8789-C5F501198B93 <11 7 5 4 3 1>
46 0 0xffffff7f82ba1000 0x4000 0x4000 com.apple.driver.AppleACPIButtons (6.1) EFE249E3-EE2D-3C1D-817B-6187E020735A <41 17 14 11 7 6 5 4 3 1>
47 2 0xffffff7f81090000 0x5000 0x5000 com.apple.driver.AppleEFIRuntime (2.1) 45F80912-F34B-3EE9-AA62-F35448246837 <7 6 5 4 3>
48 2 0xffffff7f81095000 0xb000 0xb000 com.apple.driver.AppleEFINVRAM (2.1) F35A52E2-CF80-3BA9-92B5-25EFE216094F <47 7 6 5 4 3 2 1>
49 1 0xffffff7f8137e000 0x4c000 0x4c000 com.apple.driver.usb.AppleUSBXHCI (1.2) 7C64428D-A72C-351E-919A-0D40E625562E <22 21 11 7 6 5 4 3 1>
50 0 0xffffff7f8149e000 0x2e000 0x2e000 com.apple.driver.usb.AppleUSBXHCIPCI (1.2) 7570F212-6A40-31D3-825D-5F3123FD4EF2 <49 22 21 12 11 7 6 5 4 3 1>
51 1 0xffffff7f810a0000 0x9b000 0x9b000 com.apple.iokit.IOUSBFamily (900.4.1) 2837DD62-F2B0-3357-A164-D44FEF6810E0 <22 21 12 7 5 4 3 1>
52 1 0xffffff7f82c80000 0x1a000 0x1a000 com.apple.iokit.IOAHCIFamily (288) 50673EBC-47A0-329A-B58C-081A6EDF6BF4 <5 4 3 1>
53 0 0xffffff7f83c7b000 0x14000 0x14000 com.apple.driver.AppleAHCIPort (329.50.2) 312FA732-CA91-3180-8373-5BE2E893339F <52 12 5 4 3 1>
55 0 0xffffff7f81499000 0x5000 0x5000 com.apple.driver.usb.AppleUSBHostPacketFilter (1.0) 4A6B061E-BBA5-3F4C-91C8-5069CBC5D3B2 <22 21 7 6 5 4 3 1>
56 1 0xffffff7f812f4000 0xa000 0xa000 com.apple.driver.AppleIntelLpssI2C (3.0.60) D509CBB9-DD4A-3A86-A2C2-5C89B8C04B4C <12 11 7 5 4 3>
57 2 0xffffff7f81a2c000 0x2a000 0x2a000 com.apple.driver.corecapture (1.0.4) C208BB9A-2092-3E61-A62C-5F24C4909F8B <7 6 5 4 3 1>
58 2 0xffffff7f81a5f000 0x7000 0x7000 com.apple.driver.mDNSOffloadUserClient (1.0.1b8) F1A6427C-3264-3012-8FA4-846E5A06DDEF <15 4 3 1>
59 1 0xffffff7f81a66000 0xf6000 0xf6000 com.apple.iokit.IO80211Family (1200.12.2) 9CF530F9-ABD9-3A18-B611-42C5811D3FAF <57 29 15 8 7 6 5 4 3 1>
60 0 0xffffff7f81b67000 0x7b7000 0x7b7000 com.apple.driver.AirPort.BrcmNIC (1241.31.1a9) C18307D7-A92F-326C-B275-DFE0DB5CC9AD <59 58 57 15 12 7 6 5 4 3 1>
61 0 0xffffff7f83984000 0x40000 0x40000 com.apple.iokit.IONVMeFamily (2.1.0) 040156DF-597C-3DF1-B702-BD9AC66A176F <48 29 25 17 12 7 6 5 4 3 1>
62 3 0xffffff7f823a3000 0x7000 0x7000 com.apple.iokit.IOEthernetAVBController (1.1.0) 0B1D1184-C655-3A04-A741-4704652016B6 <15 5 4 3 1>
63 0 0xffffff7f82cf1000 0x44000 0x44000 com.apple.iokit.AppleBCM5701Ethernet (10.3.1) 2741164A-412A-3562-AA38-CAA0290AD2E8 <62 58 15 12 11 6 5 4 3 1>
64 0 0xffffff7f83931000 0x12000 0x12000 com.apple.driver.AppleSDXC (1.7.6) F1F2828F-D89D-3091-9824-9F2A6C1CD5BE <25 17 12 5 4 3 1>
65 6 0xffffff7f824a5000 0xec000 0xec000 com.apple.iokit.IOThunderboltFamily (6.7.8) 1792148D-F8B9-3CDE-88F3-59E53A50649F <5 4 3 1>
66 0 0xffffff7f8404d000 0x1d000 0x1d000 com.apple.driver.AppleThunderboltNHI (4.7.2) 0438C821-F27D-3AB7-904B-B5C7C9F5AC32 <65 12 11 6 5 4 3 1>
68 1 0xffffff7f81908000 0xe5000 0xe5000 com.apple.filesystems.apfs (748.51.0) F5310D5D-825A-3114-86DA-6E7D2A21133A <32 25 8 7 6 5 4 3 1>
69 1 0xffffff7f812fe000 0x8000 0x8000 com.apple.driver.AppleIntelLpssDmac (3.0.60) 9F53D989-E3B1-3677-AF70-4FB767FC9B18 <12 11 5 4 3>
70 1 0xffffff7f81306000 0x19000 0x19000 com.apple.driver.AppleIntelLpssI2CController (3.0.60) 031167DC-90DF-39E5-A23C-A5A3B910D4E8 <69 56 11 7 5 4 3>
71 0 0xffffff7f83d7c000 0xe000 0xe000 com.apple.driver.AppleHPM (3.1.3) CF66C362-7649-3E78-A170-67CE8E4A01ED <70 65 11 5 4 3 1>
72 0 0xffffff7f83761000 0x5000 0x5000 com.apple.driver.AppleThunderboltPCIDownAdapter (2.1.3) 4C938DD2-AEA9-3D36-BCB9-8CF72108050D <65 12 5 4 3 1>
73 1 0xffffff7f825b0000 0xf000 0xf000 com.apple.driver.AppleThunderboltDPAdapterFamily (5.5.5) C8D87A2B-6071-3B09-A4F9-32ADB5BEDC87 <65 11 5 4 3 1>
74 0 0xffffff7f825bf000 0x6000 0x6000 com.apple.driver.AppleThunderboltDPInAdapter (5.5.5) 6748C5EB-BB07-3EDE-9380-308D262EBC1F <73 65 5 4 3 1>
75 0 0xffffff7f80f25000 0x5000 0x5000 com.apple.AppleSystemPolicy (1.0) 153CF29A-7684-3332-A4A7-4012672C4D60 <7 6 5 4 3 2 1>
76 1 0xffffff7f8115a000 0x8000 0x8000 com.apple.filesystems.hfs.encodings.kext (1) F737F125-223E-3B67-B4FF-5AB56291D4FE <7 6 5 4 3 1>
77 0 0xffffff7f812d3000 0xd000 0xd000 com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0) DA62C15B-A42F-3641-A439-C60EC8B1193F <6 4 3 2 1>
78 0 0xffffff7f82467000 0xd000 0xd000 com.apple.BootCache (40) D4B1BD0D-E85C-3EAA-B921-F540E223A140 <7 6 5 4 3 1>
79 0 0xffffff7f82f29000 0x3000 0x3000 com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) 3B67C87D-2D57-3C8A-AC27-474171D2C9A1 <7 6 4 3 2 1>
80 0 0xffffff7f83aaf000 0x67000 0x67000 com.apple.filesystems.hfs.kext (407.50.6) 09445723-F283-31E5-B409-43D905BA81C6 <76 7 6 5 4 3 1>
82 0 0xffffff7f81077000 0x8000 0x8000 com.apple.driver.usb.AppleUSBHostCompositeDevice (1.2) 83156A35-0541-3EE0-89AF-2D79952EE17A <22 21 6 5 4 3 1>
83 0 0xffffff7f812e3000 0x8000 0x8000 com.apple.driver.usb.networking (5.0.0) 706A04C1-25AD-3BE8-A6A6-F0C814B7118C <22 6 5 4 3 1>
85 0 0xffffff7f8143c000 0x4000 0x4000 com.apple.driver.AppleUSBHostMergeProperties (1.2) D0D53B0A-CE40-3A08-9695-050DDFD705A7 <4 3 1>
86 0 0xffffff7f813d0000 0x35000 0x35000 com.apple.driver.usb.AppleUSBHub (1.2) 212690CE-F664-386F-915A-83BE8A20568F <22 21 11 5 4 3 1>
91 20 0xffffff7f81253000 0x49000 0x49000 com.apple.iokit.IOGraphicsFamily (519.20) 0E507098-E375-39B7-9AE2-AFF2C7A5D961 <12 7 5 4 3 1>
92 1 0xffffff7f82ac2000 0xf000 0xf000 com.apple.driver.AppleSMBusController (1.0.18d1) 42F7ACFC-82B8-3A3C-9C1D-B2EEBDE3680B <42 12 11 5 4 3>
93 0 0xffffff7f83a5e000 0x10000 0x10000 com.apple.driver.AppleMCCSControl (1.5.5) 8025FFC5-B9D5-3B12-ACF3-C27A43838AC0 <92 91 13 12 11 7 5 4 3 1>
96 0 0xffffff7f82ba9000 0x16000 0x16000 com.apple.driver.AppleThunderboltIP (3.1.1) BF0DE571-A2D0-3533-94F2-058034930B61 <65 15 12 5 4 3 1>
98 7 0xffffff7f81564000 0xa000 0xa000 com.apple.AppleGraphicsDeviceControl (3.20.13) 55E796DB-EFBA-34DB-8148-E834A4383AD2 <91 12 7 6 5 4 3 1>
99 2 0xffffff7f815ef000 0x1f0000 0x1f0000 com.apple.kext.AMDSupport (1.6.8) 7437A67E-1E39-3A88-B158-DE99F959A0B6 <98 91 12 11 7 5 4 3 1>
100 4 0xffffff7f82bc9000 0xa000 0xa000 com.apple.driver.IOPlatformPluginFamily (6.0.0d8) 344AAFD5-4547-377C-B3BF-477D78BF7025 <11 7 6 5 4 3>
101 1 0xffffff7f82bfe000 0x17000 0x17000 com.apple.driver.X86PlatformPlugin (1.0.0) 75F8D5F2-9BB7-3709-987C-35B5C1FCB727 <100 51 22 13 11 7 6 5 4 3 1>
102 0 0xffffff7f8397d000 0x4000 0x4000 com.apple.driver.AppleOSXWatchdog (1) 10AB980B-BF01-317D-8CE7-51079C8E304C <12 7 6 5 4 3 1>
103 0 0xffffff7f848df000 0x6000 0x6000 com.apple.driver.AppleSMCLMU (211) 8CD5D253-5FB2-33B7-A2FE-9BB15D95ED1D <91 13 5 4 3>
104 3 0xffffff7f82f2d000 0x19000 0x19000 com.apple.iokit.IOSurface (211.15) 37BCC686-AF99-3381-AC4F-E54A347E0F40 <7 6 5 4 3 1>
105 3 0xffffff7f82f48000 0x99000 0x99000 com.apple.iokit.IOAcceleratorFamily2 (378.26) AE312652-F3AF-3BFD-AEFF-FE4CCCC33BA9 <104 91 29 12 7 6 5 4 3 1>
106 0 0xffffff7f83d8d000 0x1e1000 0x1e1000 com.apple.driver.AppleIntelKBLGraphicsFramebuffer (10.3.6) 3DEB3CA0-CD20-3952-A76D-A07AC3B1C4FA <105 98 91 17 12 11 7 6 5 4 3 1>
107 3 0xffffff7f8158b000 0x10000 0x10000 com.apple.iokit.IONDRVSupport (519.20) 64AB0898-0DF1-32DF-850A-8840C3478439 <91 12 7 5 4 3>
110 0 0xffffff7f83135000 0x3000 0x3000 com.apple.driver.AppleSMBusPCI (1.0.14d1) 60757613-A302-3BB0-B68B-653306645108 <12 5 4 3>
111 1 0xffffff7f812a9000 0x5000 0x5000 com.apple.iokit.IOSlowAdaptiveClockingFamily (1.0.0) CBE56568-AC91-3F56-A06E-9A29D6F70BDA <7 6 5 4 3 1>
112 0 0xffffff7f839ee000 0x2000 0x2000 com.apple.driver.AppleIntelSlowAdaptiveClocking (4.0.0) 7DFBC6BB-39A0-3639-9683-99472E9AAC69 <111 4 3>
113 0 0xffffff7f815a8000 0xb000 0xb000 com.apple.AppleGPUWrangler (3.20.13) A8DD5AC6-488A-38A0-A3D3-F3F361EF5D49 <98 91 12 7 6 5 4 3 1>
114 0 0xffffff7f81212000 0x3000 0x3000 com.apple.driver.eficheck (1) 2AB9331F-103D-3D56-886C-7BEBA27EAB56 <47 12 4 3 1>
115 6 0xffffff7f82db2000 0xe9000 0xe9000 com.apple.iokit.IOBluetoothFamily (6.0.7f10) 74C48C9C-2C96-3786-9ED7-F351FAA0E33C <22 17 11 7 6 5 4 3 1>
116 3 0xffffff7f83a07000 0xb000 0xb000 com.apple.iokit.IOBluetoothHostControllerTransport (6.0.7f10) 5BCBD46F-D98E-32E9-95F2-D89CAB6939E9 <115 22 12 11 7 6 5 4 3 1>
117 2 0xffffff7f83a19000 0x20000 0x20000 com.apple.iokit.IOBluetoothHostControllerUSBTransport (6.0.7f10) A90B564F-12FF-339E-9797-E901C2C67B04 <116 115 22 12 11 7 6 5 4 3 1>
118 1 0xffffff7f83a39000 0xc000 0xc000 com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport (6.0.7f10) 6D229D60-BBAE-3DAF-9E92-9B64237D1448 <117 116 115 22 12 11 7 6 5 4 3>
119 0 0xffffff7f83a59000 0x3000 0x3000 com.apple.iokit.BroadcomBluetooth20703USBTransport (6.0.7f10) 15BB7D39-3C4D-3D93-9F73-2DE34E4B1512 <118 117 116 115 22 12 11 7 6 5 4 3>
120 2 0xffffff7f825fb000 0xab000 0xab000 com.apple.vecLib.kext (1.2.0) F41EEA34-47C4-3ADE-BA77-D7A3CCA437B9 <9 6 5 4 3>
121 5 0xffffff7f826a6000 0x3f000 0x3f000 com.apple.iokit.IOAudioFamily (206.5) 2F090399-C028-3F14-AE4F-BF49A3D602E5 <120 5 4 3 1>
122 2 0xffffff7f826ed000 0xc000 0xc000 com.apple.iokit.IOHDAFamily (281.52) 3D7ADFBB-A913-31F3-A713-32A20B7B2249 <5 4 3 1>
123 1 0xffffff7f826fc000 0x1d000 0x1d000 com.apple.driver.AppleHDAController (281.52) 0CEE0F18-1D22-3D90-9FD5-ECCD63F81428 <122 121 91 12 7 6 5 4 3 1>
124 0 0xffffff7f817fd000 0x68000 0x68000 com.apple.kext.AMD9500Controller (1.6.8) 6D8E467F-75AC-304C-8099-685F160F57C0 <99 98 91 12 11 5 4 3 1>
126 0 0xffffff7f83f9b000 0x7c000 0x7c000 com.apple.driver.AppleGFXHDA (100.1.17) DFF05138-2992-3118-941D-1C403C4EE0F6 <121 107 91 12 7 6 5 4 3 1>
127 0 0xffffff7f83b2f000 0x6000 0x6000 com.apple.driver.AppleIntelPCHPMC (2.0.1) 2FE2B500-B29A-355E-9350-049A22C12112 <100 13 12 11 4 3>
128 0 0xffffff7f83b39000 0x5000 0x5000 com.apple.Dont_Steal_Mac_OS_X (7.0.0) 6F899B4B-5B97-3559-85B1-7798E34AE7EE <13 8 7 4 3 1>
131 0 0xffffff7f82ff1000 0xee000 0xee000 com.apple.driver.AppleIntelKBLGraphics (10.3.6) BA844F0E-48A7-3293-8F11-ED1616E6A748 <105 104 91 12 7 6 5 4 3 1>
132 0 0xffffff7f83a79000 0x12000 0x12000 com.apple.driver.pmtelemetry (1) 8163B2F1-7332-3811-B253-96BB4FD30750 <7 6 5 4 3>
133 1 0xffffff7f839f6000 0xe000 0xe000 com.apple.iokit.IOSerialFamily (11) 6FE74518-ECD9-32D6-88BE-8F5BCAC911D4 <7 6 5 4 3 1>
134 0 0xffffff7f83a49000 0xa000 0xa000 com.apple.iokit.IOBluetoothSerialManager (6.0.7f10) CE7E273D-4839-3223-8608-FCBB4C708435 <133 7 5 4 3 1>
135 0 0xffffff7f83813000 0xc000 0xc000 com.apple.driver.AppleSSE (1.0) 61602D2B-CD0E-371F-AB92-39DFC768AF93 <23 19 18 7 5 4 3 1>
136 0 0xffffff7f83730000 0x6000 0x6000 com.apple.iokit.IOUserEthernet (1.0.1) E3D78FE7-50D1-39D3-A58E-61CE8E37874F <15 6 5 4 3 1>
137 0 0xffffff7f82d9d000 0x8000 0x8000 com.apple.driver.AppleHV (1) 438226E9-F69D-33F8-8A5F-B5FDD05BCD3B <7 6 5 4 3 1>
138 1 0xffffff7f823aa000 0x98000 0x98000 com.apple.plugin.IOgPTPPlugin (680.15) AF4DE083-B00F-373D-9241-8ACE6742D61F <62 41 16 15 6 5 4 3 1>
139 0 0xffffff7f82455000 0x10000 0x10000 com.apple.iokit.IOAVBFamily (680.2) 9395D958-419A-35BD-8B31-F31E70ABCF94 <138 62 16 15 6 5 4 3 1>
140 0 0xffffff7f81570000 0x3000 0x3000 com.apple.AGDCPluginDisplayMetrics (3.20.13) A3AA8AC5-6BF9-38E6-955D-1F1CCE6CFC03 <98 7 6 5 4 3 1>
141 1 0xffffff7f81574000 0x3000 0x3000 com.apple.driver.AppleGraphicsControl (3.20.13) 21FE5549-B94B-3EF9-9BF1-76114C50CB52 <7 5 4 3 1>
142 0 0xffffff7f81577000 0x12000 0x12000 com.apple.driver.AppleGraphicsDevicePolicy (3.20.13) 88C6EFDE-DBA9-3FD2-892F-AF527A14EAA9 <141 98 91 12 11 7 6 5 4 3 1>
143 0 0xffffff7f848bc000 0x12000 0x12000 com.apple.kext.AMDRadeonX4000HWServices (1.6.8) 57CD6989-C376-3DF2-B953-B9A7A676A3CD <91 12 11 7 5 4 3 1>
144 0 0xffffff7f83138000 0x4ba000 0x4ba000 com.apple.kext.AMDRadeonX4000 (1.6.8) 3A5B2002-9BF9-36B4-BBC4-15B37FCEAD7B <105 104 91 12 7 5 4 3 1>
145 0 0xffffff7f84087000 0x82b000 0x82b000 com.apple.kext.AMDRadeonX4200HWLibs (1.0) 1064BF42-16EA-3C36-A8F7-70E91CAD9DCD <12 5 4 3 1>
146 0 0xffffff7f8383e000 0x29000 0x29000 com.apple.kext.AMDFramebuffer (1.6.8) 9684DD2E-CC02-3A7D-B285-F201ABE99887 <99 91 12 11 7 5 4 3 1>
147 0 0xffffff7f8382f000 0x5000 0x5000 com.apple.driver.AppleUpstreamUserClient (3.6.5) BA12F5B7-39D0-366F-B8EC-4BCAAFD285AA <91 12 11 7 5 4 3 1>
148 1 0xffffff7f8271f000 0x13000 0x13000 com.apple.kext.OSvKernDSPLib (526) C618CB87-7AA5-3DAE-9399-1CC9D9447F06 <5 4>
149 1 0xffffff7f82732000 0x143000 0x143000 com.apple.driver.DspFuncLib (281.52) 2239A97C-1C33-37BB-A79B-156177CB886C <148 121 120 48 6 5 4 3 1>
150 0 0xffffff7f82880000 0xb7000 0xb7000 com.apple.driver.AppleHDA (281.52) 119A5EAE-5FD8-3CF3-A0CA-73EDDDC23DBE <149 123 122 121 107 91 6 5 4 3 1>
152 1 0xffffff7f839de000 0x5000 0x5000 com.apple.kext.triggers (1.0) 00226670-5F9E-31BC-B59C-A0B2FE6D7797 <7 6 5 4 3 1>
153 0 0xffffff7f839e3000 0x9000 0x9000 com.apple.filesystems.autofs (3.0) 1F7A2090-68A9-3215-8E5B-2F73A2279027 <152 7 6 5 4 3 2 1>
154 1 0xffffff7f82c15000 0x7000 0x7000 com.apple.driver.X86PlatformShim (1.0.0) 78933162-E3FE-3568-B4E0-6A6BD9DEA64A <101 100 13 7 4 3>
155 0 0xffffff7f83888000 0x19000 0x19000 com.apple.driver.AGPM (110.23.37) 57080476-7028-3602-AE28-C557A2BFC7CA <107 100 98 91 12 6 5 4 3>
156 0 0xffffff7f839d2000 0x4000 0x4000 com.apple.driver.ApplePlatformEnabler (2.7.0d0) F39E7EE5-9C96-325F-BAF7-E28E86070422 <7 5 4 3>
158 0 0xffffff7f83c3e000 0x5000 0x5000 com.apple.driver.AudioAUUC (1.70) 71FC1A81-3747-3E5A-857E-8C657B2D2BD9 <121 91 12 11 7 5 4 3 1>
159 1 0xffffff7f82eaf000 0x1a000 0x1a000 com.apple.driver.IOBluetoothHIDDriver (6.0.7f10) CAF1C524-21D1-3125-A1B6-5451B0417FAB <115 41 5 4 3>
160 1 0xffffff7f838e9000 0xe000 0xe000 com.apple.driver.AppleHSBluetoothDriver (133) 2B16EA18-F505-32FF-B9B9-833C1A92CFF6 <159 115 41 6 5 4 3 1>
161 1 0xffffff7f81a12000 0x16000 0x16000 com.apple.driver.AppleInputDeviceSupport (1404.3) EB469126-F55F-34A9-AD44-4971CE1310E8 <5 4 3 1>
162 1 0xffffff7f82476000 0x29000 0x29000 com.apple.driver.AppleMultitouchDriver (1404.4) 34A060D4-F873-3870-AE38-1C32DBC10757 <161 41 17 7 5 4 3 1>
163 0 0xffffff7f83909000 0xa000 0xa000 com.apple.driver.AppleTopCaseHIDEventDriver (133) E0094B50-6B11-3FD6-9446-8D68D4A7EF37 <162 160 41 6 5 4 3 1>
164 0 0xffffff7f838da000 0xb000 0xb000 com.apple.driver.AppleHIDKeyboard (205) 3F6CC277-A5DD-3A28-896F-79F3CA756CAC <41 5 4 3>
216 0 0xffffff7f8493f000 0x6000 0x6000 com.apple.macos.driver.AppleUSBEthernetHost (8.1.1) 46751983-AA66-3D7C-AD07-39253E4B048C <22 15 5 4 3 1>
217 0 0xffffff7f848e8000 0x2000 0x2000 com.apple.driver.AppleMikeyHIDDriver (131) 64004532-CB84-3246-BEF9-6C5ECFCCF380 <41 7 4 3 1>
----FPS Report Legend:-----
Raw Instantaneous FPS:
30FPS delimiter: '|'
10FPS delimiter: '+'
1FPS delimiter: '-'
Defer+Work Instantaneous FPS: 'X'
Work Instantaneous FPS: '^'
Equal Work and Defer+Work Instantaneous FPS: '*'
====Frame Rate Report:====
Frame Length [SampleRange] WS Wait Length [SampleRange] Defer Length [SampleRange] WS Work Length [SampleRange] Frame Rate
19.51 ms[ No samples] 0.00 ms[ No samples] 16.53 ms[ No samples] 2.99 ms[ No samples] 51.25 FPS|---------+---------+---------|---------+---------+X ^
WS Idle: 519.92ms
531.63 ms[ 2-6 ] 519.92 ms[ 2-6 ] 10.78 ms[ No samples] 0.93 ms[ No samples] 1.88 FPS *
WS Idle: 376.11ms
382.68 ms[ 7-10 ] 376.11 ms[ 7-10 ] 5.75 ms[ No samples] 0.82 ms[ No samples] 2.61 FPS *
Model: iMac18,3, BootROM IM183.0161.B00, 4 processors, Intel Core i7, 4,2 GHz, 64 GB, SMC 2.41f1
Graphics: Radeon Pro 580, Radeon Pro 580, PCIe
Memory Module: BANK 0/DIMM0, 16 GB, DDR4, 2400 MHz, 0x80AD, 0x484D413832475336414652384E2D554820202020
Memory Module: BANK 0/DIMM1, 16 GB, DDR4, 2400 MHz, 0x80AD, 0x484D413832475336414652384E2D554820202020
Memory Module: BANK 1/DIMM0, 16 GB, DDR4, 2400 MHz, 0x80AD, 0x484D413832475336414652384E2D554820202020
Memory Module: BANK 1/DIMM1, 16 GB, DDR4, 2400 MHz, 0x80AD, 0x484D413832475336414652384E2D554820202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x16F), Broadcom BCM43xx 1.0 (7.77.37.31.1a9)
Bluetooth: Version 6.0.7f10, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: Multi-Reader
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: iPad
USB Device: USB2.0 Hub
Thunderbolt Bus: iMac, Apple Inc., 33.1
Hi helmuth,
Could you try updating Acrobat to the latest patch 2018.011.20058 from here: 18.011.20058 Planned update, August 14, 2018 — Release Notes for Acrobat DC Products reboot the machine after installing update and check if that helps.
Also, try creating a new user account on the machine by clicking Apple menu > System Preferences, then click Users & Groups, login into that account and launch Acrobat from there.
Let us know if you need any help.
Shivam
