Error with external wsdl file for a cfcomponent (webservice)
Feb 25, 2009 Feb 25, 2009
Related to the post in this forum: http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=1&catid=7&threadid=1386433&high...
The problem is that ColdFusion 8.0.1 changes the case for namespaces of custom datatypes. This breaks the implementation of the webservice in other languages that are case sensitive. (like .NET). Because of this error, we cannot update the servers to fix other critical bugs in the 8.0.1 release.
Unable to find a solution ;-(, I'm trying to find a work-around for this problem. I thought I had it; I would save the generated WSDL document generated by Coldfusion 8.0.1 and correct the case manually. Then using the corrected WSDL file as an external WSDL file. The problem is that when I would use the generated WSDL file in the component I get an AXIS error.
It also generates this error when I don't use an external WSDL file, but use a custom namespace to the webservice url. Like: http://mydomain.com/soap/webservice.cfc?wsdl
This is the error I get:
AXIS error
Sorry, something seems to have gone wrong... here are the details:
Fault - Error attempting to create Java skeleton for CFC web service.; nested exception is:
coldfusion.xml.rpc.CFCInvocationException: [java.lang.ExceptionInInitializerError : null][java.lang.ClassCastException : [Ljava.lang.Object; cannot be cast to java.lang.String]
I've read on forums that this is a mapping problem. I currently do have a mapping, but removing this didn't fix the problem.
Does anybody have any ideas on how to solve this?
Maybe downgrade AXIS?, so the generated WSDL file would be the correct case as with version 8.0.0
Advanced techniques
1.8K
I've fixed the problem. I used an absolute path to the wsdl file and it needed a relative path.
But now I still don't know why it's incorrectly casing the namespaces in the WSDL document.
May 06, 2009 May 06, 2009
We are having the same problem with the case changes in WSDL generation, preventing us from upgrading, too.  Haven't heard a peep from Adobe on it.
- http://forums.adobe.com/message/1053957
Wish I could help more.
Fred
Aug 13, 2010 Aug 13, 2010
Any luck with this?
Sep 07, 2010 Sep 07, 2010
We had to rebuild our code that called the ColdFusion web service.  We had a few external incoming calls, too, and we ended up dropping one and paying for the vendor to update the others.  It was ugly and took several months because of the external vendor.
Documentation
