since LR Classic CC 7.x I can't add a folder (like D:\RAW) which contains more than 1850 images. If more images than 1850 then LR crashes.
If I use Files -> Import LR is working.
In LR 6. all works fine. In LR 7.0 and above chrashes.
Will there be a fix?
Regards, Stefan
Are you adding a folder using the Synchronize window?
How are you adding the folder, if not Import. Please be very detailed in describing the steps you are following.
I'm going to the left pane click on the "+" by Folder and then on "Add Folder.."
Sorry, it's all in German here
Better to right click in the Folders panel on the parent folder that you
want to add. Select Synchronize and then you can choose the specific folder
from the Synchronize dialog box.
If the parent folder isn't visible, right click on the top folder in your
folders panel and select "Show Parent."
thanks a lot. That is working. But....In LR 6.0 my workflow works fine. In LR 7.x not. I think, there must be a bug
Regards, Stefan
Report this as a bug to Adobe at Lightroom Classic CC | Photoshop Family Customer Community
Done
Glad to help! I've never added a folder any other way that what I described above so I don't know about the bug.
