38 Replies Latest reply on Jun 22, 2018 10:07 PM by amanm5143
    Scale all images at once in InDesign
    amanm5143 Level 1
      I am working on a document with 500 images and all of them run beyond the text frame size (W: 5 in, H: 7.7 in). Hence, to fit them to the frame, I tried to use Transform->Scale and set the percentage value to less than 100% and the image got fit into the text frame. However, the problem is with a single selection. Selecting an image every time and setting the scale for 500 objects is a time consuming task. I tried using Object style but it does not incorporate "Scale" option in its palette. I tried using Find/Change option but it does not take anything other than an Object style, hence bringing me back to square one.
      Then I started a discussion on InDesign for the problem: https://forums.adobe.com/thread/2502461
      vinny38 was a kind enough soul to provide two solutions:
      Solution A
      1. //FitAnchorToColumn v2
      2. //Transform anchored objects in order to rescale them to make them fit column width, keeping proportions.
      3. //by Vinny
      4.
      5.
      6. if (parseFloat(app.version) < 6
      7.     main();
      8. else
      9.     app.doScript(main, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "FitAnchorToColumn");
      10.
      11.
      12. function main() {
      13.
      14.
      15.     if (app.documents.length > 0) {
      16.         var
      17.         myDoc = app.activeDocument,
      18.         docUnits = myDoc.viewPreferences.horizontalMeasurementUnits;
      19.
      20.
      21.         app.findGrepPreferences = app.changeGrepPreferences = null
      22.         app.findGrepPreferences.findWhat = "~a"
      23.         var myFound = myDoc.findGrep();
      24.
      25.
      26.         for (i = 0; i < myFound.length; i++) {
      27.             if (typeof myFound[i].parentTextFrames[0] != "undefined") {
      28.                 var columnWidth = myFound[i].parentTextFrames[0].textFramePreferences.textColumnFixedWidth,
      29.                 myObjectWidth = myFound[i].pageItems[0].geometricBounds[3]-myFound[i].pageItems[0].geometricBounds[1],
      30.                 myScaleFactor = columnWidth/myObjectWidth,
      31.                 myScaleMatrix = app.transformationMatrices.add({horizontalScaleFactor:myScaleFactor,verticalScaleFactor:m yScaleFactor});
      32.
      33.                 myFound[i].pageItems[0].transform(
      34.                     CoordinateSpaces.INNER_COORDINATES,
      35.                     AnchorPoint.TOP_LEFT_ANCHOR,
      36.                     myScaleMatrix
      37.                 );
      38.             }
      39.         }
      40.
      41.
      42.         app.findGrepPreferences = app.changeGrepPreferences = null
      43.
      44.
      45.     } else
      46.         alert("Open a document");
      47.     }
      It worked wonders for the images with respect to the width. It rescaled (and not trimmed) the width of the over bound images to the width of the text frame however, it could not adjust the height of too large images.
      Thus, Vinny took out the time from his busy schedule and provided the following solution.
      Solution B
      1. //FitAnchorToColumn v3
      3. //by Vinny
      4.
      5.
      7.     main();
      8. else
      10.
      11.
      13.
      14.
      16.         var
      18.             docUnits = myDoc.viewPreferences.horizontalMeasurementUnits,
      19.             myFound;
      20.
      21.
      22.         app.findGrepPreferences = app.changeGrepPreferences = null
      23.         app.findGrepPreferences.findWhat = "~a"
      24.         myFound = myDoc.findGrep();
      25.
      26.
      27.         for (i = 0; i < myFound.length; i++) {
      28.             if (typeof myFound[i].parentTextFrames[0] != "undefined") {
      29.                 var
      30.                     columnWidth = myFound[i].parentTextFrames[0].textFramePreferences.textColumnFixedWidth,
      31.                     columnHeight = myFound[i].parentTextFrames[0].geometricBounds[2] - myFound[i].parentTextFrames[0].geometricBounds[0],
      32.                     myObjectWidth = myFound[i].pageItems[0].geometricBounds[3] - myFound[i].pageItems[0].geometricBounds[1],
      33.                     myObjectHeight = myFound[i].pageItems[0].geometricBounds[2] - myFound[i].pageItems[0].geometricBounds[0],
      34.                     myScaleFactor = columnWidth / myObjectWidth,
      35.                     myScaleMatrix = app.transformationMatrices.add({
      36.                         horizontalScaleFactor: myScaleFactor,
      37.                         verticalScaleFactor: myScaleFactor
      38.                     })
      39.
      40.
      41.                 if (myObjectHeight * myScaleFactor == columnHeight) {
      42.                     return null
      43.                 } else if (myObjectHeight * myScaleFactor < columnHeight) {
      44.
      45.
      46.                     myFound[i].pageItems[0].transform(
      47.                         CoordinateSpaces.INNER_COORDINATES,
      48.                         AnchorPoint.TOP_LEFT_ANCHOR,
      49.                         myScaleMatrix);
      50.                 } else
      51.                     myFound[i].pageItems[0].transform(
      52.                         CoordinateSpaces.INNER_COORDINATES,
      53.                         AnchorPoint.TOP_LEFT_ANCHOR,
      54.                         myScaleMatrix
      55.                     );
      56.                     myFound[i].pageItems[0].resize(
      57.                         CoordinateSpaces.INNER_COORDINATES,
      58.                         AnchorPoint.CENTER_ANCHOR,
      59.                         ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH, [ResizeConstraints.KEEP_CURRENT_VALUE,
      60.                             UnitValue(columnHeight + String(docUnits)).as('pt'
      61.                         ]
      62.                     );
      63.                 }
      64.             }
      65.         }
      66.
      67.
      68.         app.findGrepPreferences = app.changeGrepPreferences = null
      69.
      70.
      71.     } else
      72.         alert("Open a document");
      73.     }
      The solution worked for both width and height this time however, it trimmed down the top and bottom part of the over bound images (width got rescaled), instead of rescaling them to fit to the text frame size.
      Vinny has been of great help but he would not be able to provide more time to the puzzle and I am already grateful to him for providing all the help.
      I am searching for a solution which could search for all the over bound images and rescale (not trim down) them to fit to the size of the text frame. I urge all the scripting experts to provide guidance in the right direction.
      Aman Mittal
      3. //by Vinny
      4.
      5.
      7.     main();
      8. else
      10.
      11.
      13.
      14.
      16.         var
      19.             myFound;
      20.
      21.
      25.
      26.
      29.                 var
      38.                     })
      39.
      40.
      42.                     return null
      44.
      45.
      49.                         myScaleMatrix);
      50.                 } else
      54.                         myScaleMatrix
      55.                     );
      61.                         ]
      62.                     );
      63.                 }
      64.             }
      65.         }
      66.
      67.
      69.
      70.
      71.     } else
      73.     }
        • 1. Re: Scale all images at once in InDesign
          Peter Kahrel Adobe Community Professional & MVP
          You should let InDesign do all the work:
          links = app.documents[0].links.everyItem().getElements();
          for (i = 0; i < links.length; i++) {
            links[i].parent.parent.fit (FitOptions.CONTENT_TO_FRAME);
          P.
          • 2. Re: Scale all images at once in InDesign
            amanm5143 Level 1
            Hello Mr. Kahrel,
            Thank you for taking out time from your busy schedule and replying to the thread. I saved the script and tried to run it in InDesign, however, I regret (because your reputation in InDesign community precedes you) to tell you that it did not affect a single image. All the out of bound images remained of the same size and did not fit to the text frame size.
            I know your schedule remains too busy but I would really appreciate if you could help me out regarding the request. Hope to receive a positive reply.
            Aman Mittal
            • 3. Re: Scale all images at once in InDesign
              Marc Autret Level 5
              Hi Aman,
              If your goal is to proportionnally re-scale inline containers with respect to the width of the text frame they belong to, here is a possible approach:
              function rescaleInlines(  q,t,wso,items,chars,z,c,o,aos,k,w,x)
              // This function proportionnaly re-scales every *inline* or
              // *aboveLine* anchored item found in the document so that
              // it fits the parent frame width.
                  // Cache and constants.
                  q = (callee.Q||callee.Q={});
                  const EPSILON = 1e-3,
                        ANCH = +AnchorPosition.ANCHORED,
                        CPAR = +CoordinateSpaces.parentCoordinates,
                        CINN = +CoordinateSpaces.innerCoordinates,
                        BVSB = +BoundingBoxLimits.outerStrokeBounds,
                        PAR0 = [+AnchorPoint.topLeftAnchor, BVSB],
                        PAR1 = [+AnchorPoint.bottomRightAnchor, BVSB],
                        INN0 = PAR0.concat(CPAR),
                        INN1 = PAR1.concat(CPAR),
                        MATX = [1,0,0,1, 0,0];
                  // Get anchored items from all stories, and the respective parent char.
                  if( !(t=app.properties.activeDocument) ){ alert("No document!"); return; }
                  t = t.stories.everyItem().texts.everyItem().pageItems;
                  if( !t.length ){ alert("No anchored item."); return; }
                  items = (t=t.everyItem()).getElements(); // array of anchored items
                  chars = t.parent;                        // array of anchor characters
                  // Safer scaling options.
                  t = +WhenScalingOptions.ADJUST_SCALING_PERCENTAGE;
                  wso = +app.transformPreferences.whenScaling;
                  wso==t ? (wso=0) : (app.transformPreferences.whenScaling=t);
                  // Scan each anchor character and its respective parent frame (if any!)
                  // (Loop from the end to get as many parent frames as possible while rescaling.)
                  for( z=0 ; (c=chars.pop()) && (o=items.pop()) ; )
                      // c in overset text -> no parent available.
                      if( !(t=(c.parentTextFrames||0)[0]) ) continue;
                      // Filtering conditions on `o` (you may add your own.)
                      aos = o.properties.anchoredObjectSettings||0;
                      if( (!aos) || ANCH==+aos.anchoredPosition ) continue;
                      // If needed, do fitting jobs now.
                      o.fit(FitOptions.FRAME_TO_CONTENT);
                      // Use box coordinates to determine the scaling factor.
                      w = q[k=t.id]||(q[k]=t.resolve(PAR1,CINN)[0][0]-t.resolve(PAR0,CINN)[0][0]);
                      x = w/(o.resolve(INN1,CPAR)[0][0]-o.resolve(INN0,CPAR)[0][0]);
                      if( Math.abs(x-1) < EPSILON ) continue; // matches already.
                      // Rescale.
                      MATX[0] = MATX[3] = x;
                      o.transform(CPAR,INN0,MATX);
                      ++z;
                  wso && (app.transformPreferences.whenScaling=wso);
                  alert( "Processed items: " + z);
              app.doScript(rescaleInlines, void 0, void 0, UndoModes.entireScript, "RescaleInlines");
              Marc
              • 4. Re: Scale all images at once in InDesign
                Laubender Adobe Community Professional & MVP
                Hi Aman,
                is it width of text column or width of text frame what you need?
                Uwe
                • 5. Re: Scale all images at once in InDesign
                  amanm5143 Level 1
                  Hi Uwe,
                  Thank you replying to the thread. I need the over-bound images (only the over-bound images) to adjust withing the width and height of the text frame and not text column as I do not use more than one column in a page.
                  Basically, I am looking for a solution which can search the entire document for over-bound images (images sizing beyond text frame size: 5 inch {w} x 7.7 inch {h} either by width, height or both) and rescale (not trim) the images to fit under the frame size all the while leaving all the in-bound images unaffected.
                  Aman Mittal
                  • 6. Re: Scale all images at once in InDesign
                    So we can assume that all text frames are with the same size?
                    Uwe
                    • 7. Re: Scale all images at once in InDesign
                      amanm5143 Level 1
                      Hey Marc,
                      Thank you for taking out time from your busy schedule and replying to the query. I am grateful to you for going to the extent of developing a script to solve the problem. I tried the script however, the overset text remained the same and the file didn't flow till the time, I didn't change the Anchored Positioning to "Custom" from "Inline or Above Line" and the size of the the over-bound images with respect to height remained unchanged.
                      I am trying to look for a solution which could follow these steps:
                      1. Look through the entire document for over-bound images: Images that go beyond the text frame size: 5 inch x 7.7 inch (width x height) by width or height or both. Search for an image that exceeds the text frame size by width (5 inch) or exceeds the frame by height (7.7 inch) or exceed the frame through both ends.
                      2. Rescale and not trim down such over-bound images such that they fit to the frame size
                      3. Leave the already in-bound images unattended: The process may not rescale those mages which are already fit or are under the frame size by width or height or both.
                      I apologize for bothering you all so much but I do not have any form of learning the script language and am in need to such a thing to complete my project on time.
                      In case, such a thing is plausible then kindly, point in the right direction. Big thank you even considering the request.
                      Aman Mittal
                      • 8. Re: Scale all images at once in InDesign
                        amanm5143 Level 1
                        Hey Laubender,
                        Yes, all the pages have same text frame size: 5 inch x 7.7 inch with a single column setting.
                        Aman Mittal
                        • 9. Re: Scale all images at once in InDesign
                          Marc Autret Level 5
                          Hi Aman,
                          Do you mean (#7) that your document originally has mainly overset text and does not use smart reflow mechanism?
                          In that case it is impossible to tell which TextFrame an inline object should belong to (as there is no such TextFrame) and furthermore the inline object has no visible bounding box (it is a “ghost” object). Then it seems very complicate to compute width and or height ratio (and apply scaling) to objects that do not exist yet.
                          In case you'd have actual visible boxes to run on, my snippet (#3) should work. It does the job regarding the desired width. It applies rescaling to every non-matching anchor frame. If you want to exclude some stuff from the process—for example leaving unchanged frames that are under the width—it is easy to add filtering, etc.
                          The line
                          skips objects whose width ratio, x, is already 1 or very close to 1.
                          To only manage objects that require downscaling (x < 1) change it to:
                          if( x+EPSILON >= 1 ) continue;
                          Note. — If the size of all text frames is constant and already known, there are possible optimization but my code already uses a cache for width calculation so it should still provide fair performance while remaining more generic. (IMHO, the purpose of this Scripting Forum is about discussing and providing generic codes and techniques and not about solving for free highly specific problems that nobody will never encounter—anymore—like “Rescaling Not-Yet-Existing Inline Boxes to 5×7.7 in.”)
                          Marc
                          • 10. Re: Scale all images at once in InDesign
                            amanm5143 Level 1
                            Hey Marc,
                            Thank you for taking out the time and replying to the thread. Regarding the concern, It follows Smart Flow mechanism but due to large-size of the images and being already in-lined in the original document, the text overflows.
                            With reference to the purpose of scripting forum, you are right that the the purpose is to provide generic code and not specific ones. However, if you would look at the initial part of the request:
                            1. The problem raised is a genuine problem faced by almost all users at some point or the other (when the size of the images are too large that it overflows the text).
                            2. However, the problem is so general that you need a container to look/provide for a generic code therefore, i went with the concept of text frame size. If no container is applied, then the problem becomes vast and complex leading to probable application of machine learning. That is why, I applied a container so that one could tweak the container size to find relevant results.
                            Additionally, I perfectly understand the amount of expertise, a professional puts in bringing out such kinds of solutions and I respect one's time for the same. Therefore, for highly specific problems (which I thought to be more complex than the one state above), whenever I turn to a professional I keep in consideration the worthiness of their effort, as well. For instance, there was a highly specific problem pertaining to a concept for which I needed a solution. Even though I didn't know Mr. Peter Kahrel but knew his reputation preceded his good name so I turned to him for professional help rather than 'free highly specific problem' help.
                            With all due respect, I do not mean to exploit anyone as I know that the time and effort it takes to build such an expertise can't be quantified. If I had slightest bit of an idea that was a complex problem, I would have turned to experts in a professional manner, only.
                            Consider my sincerest apologies for the trouble caused and thank you for putting things in perspective. I shall be be considerate of the same, in future.
                            Aman Mittal
                            • 11. Re: Scale all images at once in InDesign
                              Marc Autret Level 5
                              Hi Aman,
                              While remaining extremely cautious and unsteady regarding my understanding of the whole picture, I might have now a slightly clearer view of the topic. So:
                              — SmartTextReflow is ON but your stream still overflows because sparse inline objects are too high relative to the frame that would host them.
                              — Apart from that, your main goal is to downscale those inline objects when needed, so that their width doesn't exceed text frame width.
                              Now, I admit that's an interesting (and very technical) question! Indeed, ghost page items are often a serious problem to us. They formally exist but as long as they belong to an overset part of the stream, they don't have geometric properties. Even worse, they do not have parent text frame yet. So we can't perform calculations based on either their own size, or the size of their host!
                              To address this issue, I think we need a two-step process.
                              1. First, detect ghost items and force them to show up by changing their formal scaling properties. Using a high downscaling factor should do the job—provided we keep track of that temporary fix.
                              2. Then, when all actors are on stage, we can perform the desired tasks the regular way.
                              That's what the code below—generously commented for further customizations—is trying to do:
                              function fixAndDownscaleInlines(  q,t,wso,items,chars,z,c,o,aos,k,wh,xy,x,y)
                              // This function proportionnaly downscale every *inline* or *aboveLine*
                              // anchored item found in the document, so that:
                              // 1. Target width does not exceed parent frame width (PFW.)
                              // 2. Targets whose width is *under* PFW are not touched.
                              // 3. Targets whose height exceeds the parent frame height (causing
                              //    overset issues that SmartTextReflow can't fix) are temporarily
                              //    downscaled so that the algorithm can eat them. When available back,
                              //    those objects are adjusted to the frame height unless width adjustment
                              //    is required to prevent them from violating rule 1.
                              // Note: Smart Text Reflow must be turned on and properly set.
                                        DOWN = 100, // Downscaling factor
                                  // Checkpoint.
                                  if( !t.textPreferences.properties.smartTextReflow )
                                      { alert("SmartTextReflow must be turned on!"); return; }
                                  // Safe scaling options are definitely needed.
                                  // [180618] Patch. Looping here from top to bottom (in
                                  // each story stream) we try to restore missing bounding boxes
                                  // due to 'formal heights' being higher than the parent frame.
                                  // A flag is then set in q[_id] to save those special cases.
                                  for( n=items.length, z=-1 ; ++z < n ; )
                                      // `o` is a PageItem which typically contains
                                      // a Graphic which typically controls a Link.
                                      o = items[z];
                                      if( o.properties.visibleBounds ) continue;
                                      // `o` has no parent text frame because it's too high!
                                      // Let's temporarily apply a hard downscaling to it.
                                      if( !(x=o.properties.horizontalScale) ) continue;
                                      if( !(y=o.properties.verticalScale) ) continue;
                                      o.horizontalScale = x/DOWN; // 1%
                                      o.verticalScale = y/DOWN;   // 1%
                                      q['_'+o.id] = 1; // flag
                                  // [REM] Original reason for looping upwards: "Get as many parent frames
                                  // as possible while rescaling." Sounds pointless now, but keeping the
                                  // logic won't hurt.
                                      // Here we check that the anchor is of inline/aboveLine kind.
                                      // Visible width and height of the text frame (if not in cache yet.)
                                      if( !(wh=q[k=t.id]) )
                                          wh = q[k] = t.resolve(PAR1,CINN)[0];
                                          xy = t.resolve(PAR0,CINN)[0];
                                          wh[0] -= xy[0];
                                          wh[1] -= xy[1];
                                      // Temporarily store the (w,h) of `o` (in parent space.)
                                      t = o.resolve(INN1,CPAR)[0].concat(o.resolve(INN0,CPAR)[0]);
                                      t[0] -= t[2];
                                      t[1] -= t[3];
                                      t.length = 2;
                                      // The x factor is required in either case.
                                      x = wh[0]/t[0];
                                      // If `o` has been previously downscaled to make it show up,
                                      // we need to find the *smallest fit factor*.
                                      y = q['_'+o.id] ? wh[1]/t[1] : false;
                                      // If `o` hasn't been downscaled, prevent it from being upscaled.
                                      // ("Width shorter than the frame width -> do nothing.")
                                      if( (!y) && 1 <= x+EPSILON ) continue;
                                      // Rescale.
                                      y && y < x && (x=y);
                                      ++z;
                              app.doScript(fixAndDownscaleInlines, void 0, void 0, UndoModes.entireScript, "FixAndDownscaleInlines");
                              Hope that helps.
                              Marc
                              • 12. Re: Scale all images at once in InDesign
                                https://forums.adobe.com/people/Marc+Autret  wrote
                                Hi Aman,
                                While remaining extremely cautious and unsteady regarding my understanding of the whole picture, I might have now a slightly clearer view of the topic.…
                                Hi Marc,
                                hope you noticed this other thread currently running in the InDesign forum that eventually makes clear what Aman is aiming at:
                                vinny38 was suggesting something similar by trying a high downscaling factor first in reply 18 over there:
                                So, I modified the script in a way it first look for overset objects, reduce them to 5% (assuming this would be small enough to make them fit in the flow), then, rescale them as described earlier.
                                Best,
                                Uwe
                                • 13. Re: Scale all images at once in InDesign
                                  amanm5143 Level 1
                                  Hi Marc,
                                  Thank you replying to thread, once again. It is delight to see such an amazing mind working on the technicality, and am glad to hear that you now have a bit clear understanding of the issue at hand.
                                  As rightly stated, my goal line is to downscale all those inline objects which run out of the text frame either by 'width' or 'height' or both; not particularly just the width but the height, as well as this helps in getting rid of the overflow problem and makes the workflow manageable.
                                  I went with the script and it worked on all the object in two different ways:
                                  • The dialog box displayed that it had processed two items. It perfectly gave the desired results for the first two objects as they were rescaled to fit to the text frame width
                                  • It left the already in-bound object (which fit well under the text frame size) unattended.
                                  • The script detected the ghost items and forced them to show up on stage, and the text flowed perfectly. However, the script highly downscaled the rest of the images and left them and din't do the adjustment, it did for the first two objects.
                                  This definitely solved the problem of overflow text arising out of large images, at a single go and definitely brought us one step closer to a simpler workflow in terms of text flow. However, it brings us back to the task of rescaling every image, again. Though the effort is great, however, it could have been tremendous if the work had given the same output generated for the first two objects to all the other objects, as well. This tweak could definitely bring a lot of people closer to a manageable workflow. Thank you for going through all the trouble and helping out! Greatly appreciated!
                                  Aman
                                  • 14. Re: Scale all images at once in InDesign
                                    Liphou Level 2
                                    Merci Marc pour les commentaire dans le script ça aide.
                                    A+
                                    Philou
                                    • 15. Re: Scale all images at once in InDesign
                                      Marc Autret Level 5
                                      Hi Aman,
                                      On downscaled images left as such, my guess is that the layout hasn't the time to update during the process—in the context of a huge document, latency issues arise.
                                      So, after step 1, we should probably force the recomposition or something. Otherwise, Smart Text Reflow would still be under processing when step 2 starts, so most inline components remain in overset zone at this stage, which surely explains the result you observe.
                                      Is there a sample document somewhere so we can test refreshing strategies?
                                      Marc
                                      • 16. Re: Scale all images at once in InDesign
                                        … Is there a sample document somewhere so we can test refreshing strategies?
                                        Yes! This would help tremendously to tackle some issues.
                                        Best,
                                        Uwe
                                        • 17. Re: Scale all images at once in InDesign
                                          Marc Autret Level 5
                                          Hi Aman,
                                          Here is the variant with forced recomposition:
                                          function fixAndDownscaleInlines(  q,doc,t,wso,n,items,chars,z,c,o,aos,k,wh,xy,x,y)
                                          // [180619] Added `document.recompose()` to force smart reflow to update.
                                          // *aboveLine* anchored item found in the document, so that:
                                          // 3. Objects whose height exceeds the parent frame height (then causing
                                          //    is required instead (to prevent them from violating rule 1.)
                                              // Checkpoint.
                                              if( !(doc=app.properties.activeDocument) )
                                              if( !doc.textPreferences.properties.smartTextReflow )
                                              t = doc.stories.everyItem().texts.everyItem().pageItems;
                                                  o = items[z];
                                              // [180619] Force recomposition now.
                                              doc.recompose();
                                                      wh[0] -= xy[0];
                                                      wh[1] -= xy[1];
                                                  t[0] -= t[2];
                                                  t[1] -= t[3];
                                                  t.length = 2;
                                                  x = wh[0]/t[0];
                                                  // Rescale.
                                                  ++z;
                                          Marc
                                          • 18. Re: Scale all images at once in InDesign
                                            Hi Marc,
                                            I fear that doc.recompose() would not be enough.
                                            I'd also test the following menu action:
                                            app.menuActions.itemByName("$ID/Recompose all stories").invoke();
                                            Once I had success by invoking this menu command when a simple recompose() failed.
                                            Best,
                                            Uwe
                                            • 19. Re: Scale all images at once in InDesign
                                              Marc Autret Level 5
                                              Hi Uwe,
                                              You're probably right, but that's a starting point.
                                              (I confess I'm not efficient at dealing with refreshing problems. Your help is welcome!)
                                              Best,
                                              Marc
                                              • 20. Re: Scale all images at once in InDesign
                                                amanm5143 Level 1
                                                Hey Marc,
                                                I understand that a sample file would be rather help in understanding the problem. Hence, please find attached a sample INDD document with certain caveats:
                                                https://drive.google.com/file/d/19SrwcPWRUqLMrdgHLOSpdCpNRfw11bwA/view?usp=sharing
                                                1. I have removed the image content however, the image frames are intact and untouched which shall serve the same purpose.
                                                2. All the images have Anchored Object Positioning: Above or Inline, as the original word document have inline images
                                                3. You will find that the text overflows due to the varying size of images which run beyond the text frame size.
                                                4. If you apply Anchored Object Positioning: Custom through all Find/Change to all the Objects then, the file will start to flow and you will see images frames of varying sizes.
                                                Hope, this serves as a sample document.
                                                Aman
                                                • 21. Re: Scale all images at once in InDesign
                                                  amanm5143 Level 1
                                                  Hi Marc,
                                                  I tried the modified version of of the script and it gave the same results as we discussed before. for ease, I have already attached a sample document and hope that it will fulfill the purpose for testing. Hope to see this through.
                                                  Aman
                                                  • 22. Re: Scale all images at once in InDesign
                                                    Marc Autret Level 5
                                                    Hi Aman,
                                                    1. The sample document contains aboveLine anchors (not only pure inline.) I found that in such case rescaling to the height of the text frame is not sufficient to wake up the ghost object. An advanced product could surely work around this using smart calculations and so. But here I will consider the inline mode as a requirement, so the version below just converts any aboveLine anchor into inline. (Recall that custom anchored objects are ignored.)
                                                    2. Smart text reflow is not properly configured in the sample document. AFAIK, the master spread (applied to page 1) should have primary text frames, which should be chained due to facing pages, and the frame on page 1 should instantiate the master frame. The other pages can be removed by the script as a first step.
                                                    Then the code below worked for me.
                                                    Again, we may provide an automated check-and-repair mechanism regarding the issues above, but it's not technically interesting (and quite boring to implement), so better is to let the user prepare the input document as specified. (A simple document preset would solve this once for all.)
                                                    // [180621] Force inline anchoring when aboveLine is found.
                                                              ABOV = +AnchorPosition.ABOVE_LINE,
                                                              INLN = +AnchorPosition.INLINE_POSITION,
                                                        // Checkpoint.
                                                        if( !(t=doc.textPreferences).properties.smartTextReflow )
                                                        if( !(t=doc.pages[0].appliedMaster) )
                                                            if( !confirm("No applied master on first page. Fix this?") ) return;
                                                            t = doc.pages[0].appliedMaster = doc.masterSpreads[0];
                                                        if( !t.primaryTextFrame )
                                                            { alert("No primary frame on spread "+t.name+"."); return; }
                                                        // [ADD180621] Prepare text reflow.
                                                        doc.pages.itemByRange(1,-1).remove();
                                                        t.properties = {
                                                            addPages:                 +AddPageOptions.END_OF_STORY,
                                                            deleteEmptyPages:          true,
                                                            limitToMasterTextFrames:   true,
                                                            preserveFacingPageSpreads: true,
                                                            o = items[z];
                                                        doc.recompose();
                                                            // [FIX180621] Force inline.
                                                            aos.anchoredPosition = INLN;
        wh[0] -= xy[0];
        wh[1] -= xy[1];
                                                            t[0] -= t[2];
                                                            t[1] -= t[3];
                                                            t.length = 2;
                                                            x = wh[0]/t[0];
                                                            // Rescale.
                                                            ++z;
                                                    Marc
                                                    1 person found this helpful
                                                    • 23. Re: Scale all images at once in InDesign
                                                      amanm5143 Level 1
                                                      Hey Marc,
                                                      Thank you for clarifying the mistakes. I tried the new version with the document. However, before placing the document, I went through the following steps:
                                                      Created a new document with "Primary Text Frame" option ticked to let A-Master spread have chained primary frames.
                                                      Then, I rechecked the first page to have A-Master applied and used the Place Gun to import the document.
                                                      After the file import, I ran the script, however, like before, the script processed first two items and download all other images to the size of dot, as discussed before.
                                                      I am not able to figure out, where I am going wrong. I tried to run the script following the above steps, it didn't change the size of the first image frame and deleted all other image frames.
                                                      Hence, if possible, I would request you to please attach the script applied sample document so that I may compare the properties applied to ascertain the glitches.
                                                      And, Mr. Marc, Thank you very much for taking out the time and being so patient and helpful. I am grateful to you for all the help and trouble, you went through.
                                                      Aman
                                                      • 24. Re: Scale all images at once in InDesign
                                                        Marc Autret Level 5
                                                        Hi Aman,
                                                        Sample document properly prepared is here:
                                                        http://indiscripts.com/blog/public/SampleDocument-OK.idml
                                                        And here is how the script works:
                                                        Marc
                                                        • 25. Re: Scale all images at once in InDesign
                                                          vinny38 Level 5
                                                          Hi there,
                                                          I'm "branching" this thread Scale all images at once in InDesign here... No need to have 2 similar threads...
                                                          So this message is the continuation of my previous attempts to handle this question.
                                                          Please note I'm learning scripting so be indulgent ^^ This interesting question is a good exercise for me.
                                                          So my suggested scenario was:
                                                          - change all inline objects to custom positioned ones. This trick, suggest by the OP, should prevent objects from over-flowing.
                                                          - then check width and height  for each object and columns
                                                          - use a couple of conditions to scale (or not) objects vertically or horizontally in regard of OP's requirements.
                                                          - reassign INLINE positioning to all objects
                                                          Sounded pretty much straightforward, But, in the last episode, a JavaScript error was thrown.
                                                          After a lot of thinking, I couldn't reproduce it... And I couldn't open the shared file since I use CS6...
                                                          I was stuck until I read Marc's remark:
                                                          "The sample document contains aboveLine anchors (not only pure inline.)"
                                                          Then I realized aboveLine anchors were not handled in my latest attempt.
                                                          So, please find below version 7 of the script that starts by changing all aboveLine anchors to Inline anchors.
                                                          I don't know why but sometimes script does not work properly, just like if it would need a "break" between the 2 instructions "app.findObjectPreferences". For now, I just put an alert() but this is a very unsatisfactory tweak and I would appreciate javascript experts advice on this issue.
                                                          Now Aman, please try this one:
                                                          If still not working, can you please share an idml file? Thanks
                                                          //FitAnchorToColumn v7
                                                          //by Vinny
                                                          if (parseFloat(app.version) < 6)
                                                              main();
                                                          else
                                                          function main() {
        var
        myFound;
        // Let's transform ABOVE_LINE to INLINE for all objects
        app.findObjectPreferences.anchoredPosition = AnchorPosition.ABOVE_LINE;
        app.findChangeObjectOptions.objectType = ObjectTypes.GRAPHIC_FRAMES_TYPE;
        myFound = myDoc.findObject();
        myFound[i].anchoredObjectSettings.anchoredPosition = AnchorPosition.INLINE_POSITION;
        //reset query
        myFound = [];
        app.findObjectPreferences = null;
        alert("let's go"); //need a pause here
        // Let's now transform INLINE to CUSTOM for all objects
        app.findObjectPreferences.anchoredPosition = AnchorPosition.INLINE_POSITION;
        myFound[i].anchoredObjectSettings.anchoredPosition = AnchorPosition.ANCHORED;
        //then check and transform
        var
        columnWidth = myFound[i].parent.parentTextFrames[0].textFramePreferences.textColumnFixedWidth,
        columnHeight = myFound[i].parent.parentTextFrames[0].geometricBounds[2] - myFound[i].parent.parentTextFrames[0].geometricBounds[0],
        myObjectWidth = myFound[i].geometricBounds[3] - myFound[i].geometricBounds[1],
        myObjectHeight = myFound[i].geometricBounds[2] - myFound[i].geometricBounds[0],
        myScaleFactorH = columnWidth / myObjectWidth,
        myScaleFactorV = columnHeight / myObjectHeight,
        myScaleMatrixH = app.transformationMatrices.add({
        horizontalScaleFactor: myScaleFactorH,
        verticalScaleFactor: myScaleFactorH
        myScaleMatrixV = app.transformationMatrices.add({
        horizontalScaleFactor: myScaleFactorV,
        verticalScaleFactor: myScaleFactorV
        if (myObjectWidth > columnWidth && myObjectHeight <= columnHeight) {
        myFound[i].transform(
        myScaleMatrixH);
        } else if (myObjectWidth < columnWidth && myObjectHeight > columnHeight) {
        myScaleMatrixV);
        } else if (myObjectWidth / myObjectHeight > columnWidth / columnHeight) {
        myScaleMatrixH);
        } else if (myObjectWidth / myObjectHeight < columnWidth / columnHeight) {
        myScaleMatrixV);
        } else {
        // nothing happens;
        // change back to inline  position
        // and (delete line below if not wanted), reset Y position to 0
        myFound[i].anchoredObjectSettings.anchorYoffset = 0;
                                                              } else {
                                                          • 26. Re: Scale all images at once in InDesign
                                                            Marc Autret Level 5
                                                            Hi Vinny,
                                                            Welcome to this subbranch of the original thread ;-)
                                                            I'm sure your code does a great job—in particular, it deals with text columns, which mine purely ignores.
                                                            In fact, I think the main problem (= the interesting problem) is solved in both cases. But in addition we have to address refreshing time issues. Indeed, while smart reflow is processing, layout components are created (additional text frames for receiving the flow) but we don't know exactly when this new stuff is ready to operate.
                                                            So, for example, the code
                                                            myFound[i].parent.parentTextFrames…
                                                            in your script might go to nowhere if myFound[i].parent still is in overset zone.
                                                            Reminder: myFound[i] is an object whose parent is a Character. This specific character, at a specific time, may have no parent text frame. A character instance always have a parentStory, but it doesn't necessarily have a host text frame. So I think you should check that before further processing. This may explain the undefined or invalid object errors you have observed.
                                                            Best,
                                                            Marc
                                                            2 people found this helpful
                                                            • 27. Re: Scale all images at once in InDesign
                                                              amanm5143 Level 1
                                                              Hi vinny38,
                                                              Welcome back! Thank you, once again for showing interest in the question. I tried your version 7 of the script in the original document and found:
                                                              1. The script rescaled even the in-bound images, again (which were needed to be left alone)
                                                              2. When I ran the script, it gave me the following error and left the very large image frame in their original size and did not change back the custom positioning to inline:
                                                              3. I tried it one more time, then the script worked. Upon the next trial, it gave the same error.
                                                              However, when I ran the same script in the sample document that I had shared, it worked wonders. Everything, you has written in the script worked but the script rescaled the in-bound images, as well. So, I am not able to figure out the anomaly in the original document though the sample document had been derived from the original, itself.
                                                              Additionally, I tried to tweak with your version 4 in terms of scaling factor and the script worked like charm. Though it rescaled the size of all the images, but did not give any error and worked perfectly:
                                                              //FitAnchorToColumn v4
                                                              //by Vinny
        main();
                                                              else
                                                              function main() {
        var
        myFound;
        app.findGrepPreferences = app.changeGrepPreferences = null;
        app.findGrepPreferences.findWhat = "~a";
        // first rescale overflow objects to 45%
        if (typeof myFound[i].parentTextFrames[0] == "undefined") {
        //  alert(myFound[i].pageItems[0].geometricBounds);
        horizontalScaleFactor: .45,
        verticalScaleFactor: .45
        // then fit everything to column width if possible, otherwise to column height
        var
        myScaleFactorH = (columnWidth / myObjectWidth) - 0.15,
        myScaleFactorV = (columnHeight / myObjectHeight) - 0.15,
        if (myObjectHeight * myScaleFactorH == columnHeight) {
        return null;
        } else if (myObjectHeight * myScaleFactorH < columnHeight) {
        myScaleMatrixH);
        } else {
        myScaleMatrixV);
        } else {
                                                              This one worked, perfectly when I changed the rescale overflow from 5% to 45% and changed the scale factor by 0.15. However, the rescale overflow seems to be a specific measure as for humongous image frames, this might not be an ideal solution for which, your version 7 of the script could work. However, the anomaly of the script to work one time and not the other time, seems to be interesting.
                                                              Aman
                                                              • 28. Re: Scale all images at once in InDesign
        Hi Aman,
        just a comment about your observation where Vinny's script sometimes produced errors when testing on the original placed Word document vs your constructed sample document that did not include images, but only graphic frames:
        1. If you are testing the original Word document the story that is placed has overset and ( that's important! ) InDesign never drew all frames necessary to expose the whole story to spreads in the layout window. I do not know how you did your made up sample for download, but it could be different with that.
        I saw cases where a very long table done in one frame with overset would answer when asked about its contents that a lot of cells are empty. In fact that was not the case after new frames were threaded to the story so that all the table was exposed to the pages. Later I tried to recreate the problem, removed all the frames of the story, but the first one, asked again after contents and to my surprise back then all frames seemed to be occupied with contents. So it made a difference if the story was at least exposed one time fully to the layout window.
        2. Complexness of your constructed sample is definitely lower than the original placed story from Word.
        So be aware that it will be a big difference to construct a sample vs to work with an original case!
        Best,
        Uwe
        • 29. Re: Scale all images at once in InDesign
        amanm5143 Level 1
        Hey Marc,
        Thank you for sending the IDML file. I tried the script n the sample document and it worked for all the frames and processed all the 7 items. However, when I followed the same properties for the master page and Text Reflow and tried to run the script in the original document, it gave the earlier results. It processed the first two images and turn the rest of the images to dots.
        I tried the script with another document and it worked like a charm. It left all the in-bound images to the original state and rescaled the out-of-bound images to the size of the frame.
        vinny38 An update regarding the script. It worked perfectly on other document as well. It rescaled out-of-bound images and gave them their anchor back. However, it rescaled all the in-bound images which was taken care of by Marc.
        Both, versions (yours and Marc) complement each other. I guess the scripts could be considered as a generic one as
        1. They solve the problem of overset text due to images
        2. Help in reducing the labour hours required to run ‘sort’ and ‘rescale’ tasks for images in small and large documents, alike.
        These scripts cater to such a problem which is experienced by every InDesign user one time or the other.
        Therefore, Thank you for all the hard work and for being such an amazing help and bringing out the best in things.
        Kudos to Marc, Uwe and Vinny for being such great sports.
        Aman Mittal
        • 30. Re: Scale all images at once in InDesign
        vinny38 Level 5
        Salut Marc!
        Thanks a million for the valuable lesson.
        It was very clear and I definitely see what you mean, although I am really not sure how to tackle the issue.
        Maybe some sort of timeout function that would check whether or not there is still overflowing text after changing all anchors as AnchorPosition.ANCHORED... wait a little, check again, wait a little, check again... then ends the script after an arbitrary amount of time...
        But I'm not sure about it, and I am now reaching my scripting limits.
        • 31. Re: Scale all images at once in InDesign
        amanm5143 Level 1
        There are two Correct answers to the thread, now.
        Post 22 and Post 25 are both correct answers to the query as provided by great people -
        If you would like to scale only out-of-bound images with proportions (those which run out of text frame size), then, you may go for Marc's script.
        Marc Autret
        If you would like to scale all the images to fit to the text frame column, even in-bound images (those which are already under the text frame size), then, you may go for Vinny's script.
        vinny38
        Big thank you to both of you! Stay blessed! Stay awesome!
        Aman
        • 32. Re: Scale all images at once in InDesign
        amanm5143 Level 1
        Hey Laubender,
        Thank you for the insights. Once, I found that the scripts worked on other documents, I realized that the original document could definitely have certainly complexities which could not have been captured by the script. The two specific points, you mentioned:
        "InDesign never drew all frames necessary to expose the whole story to spreads in the layout window".
        "So it made a difference if the story was at least exposed one time fully to the layout window."
        They are indeed the right observations and I shall bear them in mind, in future. Thank you for providing such an important insight.
        Aman
        • 33. Re: Scale all images at once in InDesign
        vinny38 Level 5
        Hi Aman
        Regarding the issue of rescaling inbound graphic frames, that was my mistake...
        You can replace lines
        myScaleMatrixH);
        myScaleMatrixV);
        by (just the "else if" lines)
        } else if (myObjectWidth > columnWidth && myObjectWidth / myObjectHeight > columnWidth / columnHeight) {
        myScaleMatrixH);
        } else if (myObjectHeight > columnHeight && myObjectWidth / myObjectHeight < columnWidth / columnHeight) {
        myScaleMatrixV);
        However, the main problem still remain...
        I have downloaded the IDML file, so I will have a look at it, and see if I can go deeper in the understanding of the issue.
        • 34. Re: Scale all images at once in InDesign
        vinny38 Level 5
        Hi Aman,
        I'm glad you finally solved your issue.
        I think you should give credit to Marc for his script as correct answer (not yours).
        Marc Autret
        I tried to analyze your script for learning purposes. It's quite hard to understand for a rookie like me^^ but obviously very interesting. I learnt a lot. Thanks for it!
        I understood that the recompose() method was definitely missing in my script.
        So I added it, as well as Uwe's snippet for safety purposes and it seems to make a real difference...
        I have no idea why the provided IDML would require much more time to recompose than my test documents, but as a matter of fact, it does...
        The latest version of my suggested script did throw the JS error, as mentioned by Aman.
        But with the recompose() method, (and a few adjustments) it seems to work nicely.
        So, dear Aman, please find below the version 8 - and final one - for your information purpose:
        - make sure auto reflow is ON
        - find all anchored objects and set anchor position as "custom"
        - recompose
        - check size of each found anchor and scale if necessary
        - set objects' anchor position as "inline" and reset Y position to 0
        //FitAnchorToColumn v8
        //by Vinny
        main();
        else
        function main() {
        var
        myFound,
        startTime = Date.now();
        // make sure autoreflow is on
        myDoc.textPreferences.properties = {
        // Let's transform all anchored objects into custom positioned objects
        myFound[i].pageItems[0].anchoredObjectSettings.anchoredPosition = AnchorPosition.ANCHORED;
        //recompose document
        myDoc.recompose();
        //then check size and transform
        var
        myScaleMatrixH);
        myScaleMatrixV);
        myScaleMatrixH);
        myScaleMatrixV);
        } else {
        // nothing happens;
        // change back every anchor to inline  position
        myFound[i].pageItems[0].anchoredObjectSettings.anchoredPosition = AnchorPosition.INLINE_POSITION;
        myFound[i].pageItems[0].anchoredObjectSettings.anchorYoffset = 0;
        alert("Script finished in "+ (Date.now() - startTime)+"ms. Now wait for autoreflow");
        } else {
        • 35. Re: Scale all images at once in InDesign
        amanm5143 Level 1
        Hey vinny38,
        I wanted to give credit to both - Marc as well as you for the answer. Unfortunately, forum does not allow two correct answers. Therefore, I created a post marking both answers (yours as well as Marc) correct. I could never take credit for the thing as I did not do anything. I was divided in giving credit one as it was a team effort led by Marc, Uwe and you so that is why, I marked another post as the right answer.
        I am highly indebted to all of you for pitching with such enthusiasm and for going through lengths to solved the request. Big thank you!
        Aman
        • 36. Re: Scale all images at once in InDesign
        vinny38 Level 5
        I know, I know, it's definitely a team work...
        It's just some sort of Forum "rule" not to mark his own post as "correct" but to try to pick the best answer.
        Not a big deal anyway, don't worry...
        Just by curiosity, how is version 8 working for you?
        • 37. Re: Scale all images at once in InDesign
        amanm5143 Level 1
        Hey vinny38,
        I apologize for the late reply. I could not try the latest version, yesterday hence, I could not comment upon the same. I tried your version 8 and it worked perfectly.
        It scaled out-of-bound images to text frame size and left the already in-bound images unattended.
        You did it with perfection! Thanks a lot for being such a great sport, for all the help and trouble you went through. Its been a pleasure knowing you! Stay blessed!
        Aman Mittal
        • 38. Re: Scale all images at once in InDesign
        amanm5143 Level 1
        Post 22 and Post 34 are both correct answers to the query as provided by great people -
        Marc Autret
        vinny38
        Aman
