Hello,
since a couple of month, I've some trouble with the lens correction.
I build a preset, which triggers the lens correction while the import. But it dosen't work. The flags are set, but no brand is used, no lens is used.
If I'm klicking after the import on the right side on a preest (doesn't matter wich one) the correction find the correct vendor and lens.
If I import the pics without the preset and use the lens correction manualy, the lens correction work as it should.
Any ideas?
Cheers
Jörg
Which (exact number, not latest or alike) version of LR are you using?
What is your OS, the camera and lens?
Did you recreate the preset?
Lightroom Classic-Version: 7.4 [ 1176617 ]
not additional plugins or presets
OS: Windows 10 1803 (Bild 17134.112)
Camera: Canon EOS 70D
Lenses: Sigma and Canon, makes no difference according the problem.
Screenshot 1 lmport with using using the preset lens correction
after klicking on a default preset e.g. "sharpen -light"
Cheers Jörg
Hast du die Voreinstellung für die Objektivkorrektur mal neu erstellt?
yes, i created the preset allready several times new.
Cheers Jörg
Hello,
has anyone an idear?
Cheers Jörg
Another person is experiencing similar symptoms: They have a Develop preset with lens-correction settings. Applying that preset in Develop works correctly, but applying it during Import does not. See Re: Lens Correction Preset not working .
You might submit a bug report in the official Adobe feedback forum, where Adobe wants all bugs reported: Lightroom Classic CC | Photoshop Family Customer Community . Adobe product developers read everything posted there and sometimes engage, but they are rarely seen here (a user-to-user forum). It would be good if you upload the problem preset to Dropbox or similar and include the sharing link. Also, be sure to copy/paste the first ten lines or so of Help > System Info.
I tried this workarround, but it works only once. After importing new pics, I can start again.
Cheers
Jörg
You could try if it helps to reset the preferences: https://www.lightroomqueen.com/how-do-i-reset-lightrooms-preferences/
Sorry, this works also not..
But I think, I found something.
The Correction is default on "standard" If I change to "auto" it seems to work. But I can't find a way to get into the import-settings.It's always going to "standard"
Cheers Jörg
