I did some research on Pro DC's PDF Portfolio functions. It looks like they did not include the custom layout functionality that is available in Pro XI in the Pro DC version, because Flash is not supported on many devices. I can only view the portfolios created in older versions of Adobe.
Adobe do you plan on bringing the customized layouts and functionalities for PDF portfolios that is available in Pro XI back in Pro DC?
Hi Joeh, Jonm,
The functionality of choosing layouts for your portfolio is not available in Acrobat Pro DC. You may visit the following link to submit your feedback to the product team: Portfolio layouts – Share your feedback on Acrobat DC
Thanks for the feedback.
Shivam
I have exactly the same question. Also i want to see the first page of each file within the created portfolio , not the adobe logo. You cannot manipulate the pages once the portfolio has been created. Adding a new file goes to the end of the portfolio where you cannot drag and drop where it is needed.
Is Pro DC the latest follow on from Pro XI as i fell it is a step backwards?
Hi Joeh, Jonm,
Shivam
So Shivam,
Is adobe planning anything to enable DC to run equally as Pro XI did in terms of portfolios?? It seems that there is a lot less functionality.
Not just the page views, it is the ability to manipulate the order of pages once the portfolio has been created and the addition and deletion of files.
There is a need to update the portfiolio sitaution in DC.
Hi Jonm,
Not sure if this functionality will be incorporated in Acrobat DC. However, you may share your thoughts with our product team using the link mentioned above.
Thank You,
Shivam
