Hi so I recently sent an image of mine that was shot with an SLR and exported out of Lightroom to my graphic designer. He then complained that I sent him a low quality image. The image I sent is 2400x1832 px at 300 resolution Bicubic and 8x6 inches. He uses Indesign mainly. I pulled the same picture into photoshop and I have no clue what he is talking about. The image looked great to me. I am just wondering if there is a way to export original in Lightroom Classic like there is in the Lightroom Mobile app on my iPad and iPhone? Or maybe I am just exporting wrong or maybe there is nothing wrong with what I am doing and he got it into his programs wrong. He wasn't exactly clear as to what the lack of quality was. Any insights would be more then helpful thank you in advance!
Export Original is one of the presets that comes pre-installed. But do you really want to send him a raw file (with edits in xmp)? I would start by asking him to specify his complaint.
Your 300 resolution setting is basically meaningless. The image is 2400 x 1832 pixels regardless of what the resolution is. It all depends on what your graphic designer needed to do with that image. Changing the resolution will do nothing to increase or decrease the quality of the image. The only thing that would change the quality would be to provide more pixels.
I'm afraid he is right, in general terms that is a low resolution image. It is a 4 Megapixel image and modern cameras output images that are much higher in resolution - 20 to 50 Mp. So unless your camera is more than 15 years old, it is probably capable of much more. It sounds as though you are downsizing the image at export and if you can show us a screen shot of your Export Settings, perhaps we can help.
On the other hand, if all you want is a 6x8 print or to share it online, a reduced size image of those dimensions is entirely adequate for that. But you would not need a graphic designer for that.
I would note, however, that for a 6x8 print the image dimensions should be 1800x2400 pixels and since the printer will crop it to that you may lose some important details from the short side. Adjust your crop in LR to be an aspect ratio of 3:4.
So then ask him specifically to provide details about what is low quality.
