Hello, when I go to younow.com a broadcasting website, and when I am on a broadcast, I have CPU usage peaks 100% every 20-30 seconds
making the page to freeze until the CPU goes down to normal.
It was absolutely working normally for years until today, when chrome (or flash) did an update.
On windows 7 64bits
Any help please
Tell the provider. There were recent changes to Flash that made some things 1000 times slower. This is a security fix not a bug apparently.
Test Screen Name can you explain me please, I'm not sure to understand
What do you mean by "tell the provider" ?
thank you
Duplicate issue by same OP. Locking discussion topic. Please use Editing the mms.cfg file
"Tell the provider", I mean contact the people who provide the web site, whonow.com in this case.
A bug is where software doesn't work as designed. This was intended so it is not a bug.
A security fix is a special change to software to protect you from viruses and malware. Sometimes security fixes make things work less well. This is a particularly strong case where some Flash sites are now useless. Running without the security fix is a REAL BAD IDEA so try and encourage younow.com to fix this.
Okay thank you I did wrote to them already
So it is only them who can do something about it then, alright
I don't know if they will know what to do
if they are serious developers so they will know where to go for the info and what to do
