.DV Not supported? Or did the codec get deleted?
Apr 10, 2018 Apr 10, 2018
I have been filming with a Mini DV camera for years (as well as now 4k cameras) and with the latest update, I have not been able to import my new footage. I import using an old version of iMovie HD 06 because for me, I can tell a difference in quality.
I'm not even able to batch convert them (not that I should have to) because Media Encoder gives me the same error. I had recently deleted a Final Cut Pro Trial as well as noticed my cc 2017 was still in my applications folder. I had just edited a 10 minute video using this camcorder last fall, what is going on?
10.4K
LEGEND , Apr 10, 2018 Apr 10, 2018
You can install an older version of Adobe Media Encoder along with the current version and use the older version to convert.
Adobe Employee ,
Hi Jordan,
This might be because of the removal of Legacy QT codecs.
As per this DV should import and export but if you are running into issues due to this please try the workarounds mentioned in the below link.
Dropped support for Quicktime 7 era formats and codecs
//Vinay
Why would this ever be a thing? What about documentaries with archival footage? And I can't even transcode them because Media Encoder can't import them either...
May 01, 2020 May 01, 2020
Hello
Wich older version of MEDIA ENCODER? I have installed v13 and it's still not working... I also have this same issue of loading .AVI files into PREMIERE, and I did shoot tons of footage in .AVI with DV codec (encoded with... PREMIERE on a PC, 20 years ago).
Please keep this codec still supported!
- VLC convert but in bad quality
- Mpegstream Clip is not working on OS X.15 anymore...
- QT7 PRO neither...
- Other solutions?
screenshot from VLC data info
May 02, 2020 May 02, 2020
To me, it's a bit like if the next version of Photoshop wouldn't support the JPEG format anymore....
You should use a third part software to convert all of your JPEG into PSD, then open it into Photoshop...
Ok, convert 20 years of JPEG now !....
Weirdest thing is the DV encapsulated in QT.
You can open it with QuickeTime10, but not in PREMIERE or MEDIA ENCODER.
Aug 16, 2023 Aug 16, 2023
"Install an older version of Media Encoder" isn't really a viable solution in 2023.
Is there a way to transcode?
Jun 24, 2018 Jun 24, 2018
Adobe claims that DV is still supported... but it is not. I spent an entire day today transcoding DV to ProRes in Compressor in order to edit a video in Premiere which contains some archive footage... from the 2000's!!!
This is just plain wrong. An entire decade was shot in DV.
Engaged ,
Jun 25, 2018 Jun 25, 2018
It's not an ideal solution, but there seems there never will be so... I reinstalled CC2017. It's much more stable and bug-free than 2018, and there's no real features that I miss going back a version. If you're just starting a project, I recommend it as a viable alternative to 2018.
If anyone has a small sample .dv file they could share, I'm still looking at the conversion options. The only .dv sample I could find is corrupt.
Also, to clarify, the problem files are .dv specifically, created by Macs. Those are not the only Mac digital video files, correct? And the others (some of the others?) still work?
I agree, the documentation still shows .dv files as supported, and they do not appear to be any longer.
No. The ones I am using are .avi files captured a decade ago on a Windows PC.
The latest version of Quicktime Player plays them without a problem. Only the Adobe suite doesn't.
The DV codec has NOT been deprecated by Apple, and the Library of Congress lists DV as one of the future-safe formats.
Adobe, what ...?
Can you post a screenshot of mediainfo of one of the files using the tree View?
I can import such AVIs into PR 2018.1.1.
Edited.
Jun 26, 2018 Jun 26, 2018
Mine are very similar.
Jim's point, I can't remember if there was a simpler conversion. For example, PR wants (like these) AVI Type 2. Seems to me Mac worked with type 1?
In QuickTime look for an output option that just rewraps it.
Those will work fine on a Windows machine.
On a Mac, you need QuickTime DV files.
DV files in the .avi or .mov container are the norm and should still work fine.  It's the .dv extension that is the issue.
Engaged ,
I'm dealing with this same issue. With none other than a – you guessed it – a documentary using legacy footage. I stupidly updated Premiere, because the project had been locked for 6 months. Now I needed to make a minor tweak, reviewed, and saw this patch of "media offline" frames.
I'm not a software engineer, so it would be nice to know why they ended support for legacy codecs. I mean, it can't be adding much bloat to the app, can it? Seems Adobe got a case of Apple-itis, and decided to slim down because some engineer has issues about streamlined code at the expense of usability. And yes I can recode, but when you have a locked timeline that has been color-corrected, and is to spec, introducing newly re-encoded material is really nerve-wracking and potentially problematic.
This was a $#!† move on Adobe's part.
Apr 11, 2018 Apr 11, 2018
Here's the best I could find.
"Adobe continuously aims to keep up with the most modern workflows and support formats and codecs broadly used across the professional film and video industry. As a result, future versions of Premiere Pro will no longer support legacy QuickTime 7 era formats and codecs."  - Patrick J. Palmer
Engaged ,
Apr 13, 2018 Apr 13, 2018
I saw that. It's kind of a non-explanation. I don't that keeping up with modern codecs has to be mutually exclusive to supporting legacy ones. The two seemed to work be sympatico until Adobe decided they weren't.
I'm not a software developer, so...I can't really speak to that.
Aug 18, 2018 Aug 18, 2018
Actually, that was a move on Apple's part. Not Adobe's. Already, with the release of the newest version of OSX 10.14, 32-bit app support has been completely dropped, requiring all processes to utilize all 64 bits. QuickTime 7, on the other hand, is restricted to only 32 bits in operation. This will also be reflected in the newest versions of iMovie and FCP, which will be expected to completely drop QT7-era codec support as well. This, unfortunately, is part of a larger computer-industry-wide effort to rid itself of legacy support. Already, nVidia (on the Windows side) is no longer releasing new drivers for 32-bit operating systems, and any newer drivers now require full 64-bit support.
Participant ,
Jun 11, 2023 Jun 11, 2023
Which begs the question why does it still work on the older version of Media Encoder - obviously they could have just kept the so called 'unsupported' function if they hadn't had a nerd attack.
Aug 16, 2018 Aug 16, 2018
The daftest comment from Adobe on their page that announces the dropping of QuickTime 7 is in the "Workarounds" section:
  • "For import formats, transcode legacy footage to a newer codec."
How can you do this when Media Encoder ISN'T accepting the files anymore?
Thinking of going back to Avid or training on FCX.
Enthusiast ,
An AVI DV is not a legacy codec, in Windows it works fine., Premiere 12.1.2.
Format                                   : AVI
Format/Info                              : Audio Video Interleave
Commercial name                          : DVCPRO     <----------- Generated in QuickTime
File size                                : 96.8 MiB
Duration                                 : 27 s 840 ms
Overall bit rate mode                    : Constant
Overall bit rate                         : 29.2 Mb/s
Video
Format                                   : DV
Codec ID                                 : dvsd             <----------- DV
Codec ID/Hint                            : Sony          <----------- DV
Bit rate mode                            : Constant
Bit rate                                 : 24.4 Mb/s
Encoded bit rate                         : 28.8 Mb/s
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 4:3
Frame rate mode                          : Constant
Frame rate                               : 25.000 FPS
Standard                                 : PAL
Color space                              : YUV
Chroma subsampling                       : 4:1:1
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Bottom Field First
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 2.357
Time code of first frame                 : 00:00:00:00
Time code source                         : Subcode time code
Stream size                              : 95.6 MiB (99%)
AVI DV Premiere
Format                                   : AVI
File size                                : 8.47 MiB
Duration                                 : 2 s 336 ms
Overall bit rate                         : 30.4 Mb/s
Recorded date                            : 2018-08-18T01:34:53-03:00
Writing application                      : Adobe Premiere Pro CC 2018.1 (Windows)
Video
Format                                   : DV
Width                                    : 720 pixels
Height                                   : 480 pixels
Frame rate                               : 29.970 (30000/1001) FPS
Original frame rate                      : 29.970 (29970/1000) FPS
Standard                                 : NTSC
Color space                              : YUV
Bit depth                                : 8 bits
Time code of first frame                 : 00:00:00:00 / 00:00:00:00
Time code source                         : Adobe tc_A / Adobe tc_O
Stream size                              : 8.01 MiB (95%)
