Has "Convert to Editable Text" been removed from After Effects?
Jan 05, 2017 Jan 05, 2017
Hey,
I'm using CC 2017. Just starting to learn Ae and no matter what I try I cannot get the text from an Illustrator design into Ae as something editable. I've followed all the common instructions, I have:
-Separated the nested elements into their own layers (in Illustrator)
-Exported this as a .psd in RGB with Text Editability preserved
When I import it into After Effects, it comes in as one psd file, not a compisition, and with no layers to reveal. If I select the file and click "layers", the "Convert to Editable Text" function does not appear. Not even greyed out. Help.
Thanks for any advice.
Error or problem
18.0K
LEGEND , Jan 05, 2017 Jan 05, 2017
Then it won't be editable in Ae too. "Convert   To editable text" is only for editable psd text layers.
about the merged file: in Ae if you want to import a multi-layered file as a composition then choose in the import dialog "Composition" and not "Footage".
open your PSD In photoshop - is the text editable? Also Make sure your psd is set to RGB and not CMYK - this could be the reason you are getting merged layers into one.
.psd export is set to RGB but no. The text is not editable in photoshop...
Jun 25, 2018 Jun 25, 2018
Layer > Create > Convert to editable text.
Like Roei said, if you want to convert to editable text you have to start in Photoshop. It won't work with illustrator files.
Sep 20, 2018 Sep 20, 2018
Thanks Andrew - That's the correct answer for me. 🙂
Yep. I like that they organized some of the commands, but a few things definitely got hidden a little bit.
"Reveal Layer Source in Project" is one movement deeper than it used to be, which makes me sad on the regs.
Aug 28, 2023 Aug 28, 2023
This works for me. Thanks a lot!
Nov 18, 2019 Nov 18, 2019
Try this. It just worked for me. www.youtube.com/watch?v=8GNt0Ux9kAk  Just be sure to save your Illustrator as RGB first.
To see all our Courses Visit: http://www.academyclass.com/ Follow Us At: Website - http://www.academyclass.com/ Facebook - https://www.facebook.com/AcademyClass Twitter - https://twitter.com/academyclass Google+ - https://plus.google.com/u/0/+AcademyClassPodcasts
Apr 09, 2024 Apr 09, 2024
There is an extra step Layer - Create - Editable Text
Good luck.
